root/radiance/ray/src/hd/rhdisp2.c
Revision: 3.2
Committed: Thu Nov 20 14:46:07 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.1: +5 -7 lines
added consistency check
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck beam tracking for display process
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14
15 extern int *getviewcells();
16
17 typedef struct {
18 int hd; /* holodeck section number (-1 if inactive) */
19 int i[3]; /* voxel index (may be outside section) */
20 } VOXL; /* a voxel */
21
22 static VOXL voxel[8] = { /* current voxel list */
23 {-1}, {-1}, {-1}, {-1},
24 {-1}, {-1}, {-1}, {-1}
25 };
26
27 #define CBEAMBLK 1024 /* cbeam allocation block size */
28
29 static struct beamcomp {
30 short wants; /* flags telling which voxels want us */
31 short hd; /* holodeck section number */
32 int bi; /* beam index */
33 } *cbeam = NULL; /* current beam list */
34
35 static int ncbeams = 0; /* number of sorted beams in cbeam */
36 static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */
37 static int maxcbeam = 0; /* size of cbeam array */
38
39 struct cellact {
40 short vi; /* voxel index */
41 short add; /* zero means delete */
42 }; /* action for cell */
43
44 struct beamact {
45 struct cellact ca; /* cell action */
46 GCOORD gc; /* grid coordinate */
47 }; /* beam origin and action */
48
49
50 int
51 newcbeam() /* allocate new entry at end of cbeam array */
52 {
53 int i;
54
55 if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */
56 maxcbeam += CBEAMBLK;
57 if (cbeam == NULL)
58 cbeam = (struct beamcomp *)malloc(
59 maxcbeam*sizeof(struct beamcomp) );
60 else
61 cbeam = (struct beamcomp *)realloc( (char *)cbeam,
62 maxcbeam*sizeof(struct beamcomp) );
63 if (cbeam == NULL)
64 error(SYSTEM, "out of memory in newcbeam");
65 }
66 return(i);
67 }
68
69
70 int
71 cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */
72 register struct beamcomp *cb1, *cb2;
73 {
74 register int c;
75
76 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
77 return(c);
78 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
79 }
80
81
82 int
83 cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */
84 register struct beamcomp *cb1, *cb2;
85 {
86 register int c;
87
88 if (!cb1->wants) /* put orphans at the end, unsorted */
89 return(cb2->wants);
90 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
91 return(c);
92 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
93 }
94
95
96 int
97 findcbeam(hd, bi) /* find the specified beam in our sorted list */
98 int hd, bi;
99 {
100 struct beamcomp cb;
101 register struct beamcomp *p;
102
103 if (ncbeams <= 0)
104 return(-1);
105 cb.wants = 0; cb.hd = hd; cb.bi = bi;
106 p = (struct beamcomp *)bsearch((char *)&cb, (char *)cbeam, ncbeams,
107 sizeof(struct beamcomp), cbeamcmp);
108 if (p == NULL)
109 return(-1);
110 return(p - cbeam);
111 }
112
113
114 int
115 getcbeam(hd, bi) /* get the specified beam, allocating as necessary */
116 register int hd;
117 int bi;
118 {
119 register int n;
120 /* first, look in sorted list */
121 if ((n = findcbeam(hd, bi)) >= 0)
122 return(n);
123 /* linear search through xcbeams to be sure */
124 for (n = ncbeams+xcbeams; n-- > ncbeams; )
125 if (cbeam[n].bi == bi && cbeam[n].hd == hd)
126 return(n);
127 /* check legality */
128 if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL)
129 error(INTERNAL, "illegal holodeck number in getcbeam");
130 if (bi < 1 | bi > nbeams(hdlist[hd]))
131 error(INTERNAL, "illegal beam index in getcbeam");
132 n = newcbeam(); /* allocate and assign */
133 cbeam[n].wants = 0; cbeam[n].hd = hd; cbeam[n].bi = bi;
134 return(n);
135 }
136
137
138 cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */
139 int adopt;
140 {
141 register int i;
142
143 if (!(ncbeams += xcbeams))
144 return;
145 xcbeams = 0;
146 qsort((char *)cbeam, ncbeams, sizeof(struct beamcomp),
147 adopt ? cbeamcmp : cbeamcmp2);
148 if (adopt)
149 return;
150 for (i = ncbeams; i--; ) /* identify orphans */
151 if (cbeam[i].wants)
152 break;
153 xcbeams = ncbeams - ++i; /* put orphans after ncbeams */
154 ncbeams = i;
155 }
156
157
158 cbeamadd(bl, n, v, hr, vr) /* add beams to server list */
159 register struct beamcomp *bl;
160 int n;
161 VIEW *v;
162 int hr, vr;
163 {
164 register PACKHEAD *pa;
165 register int i;
166
167 if (n <= 0)
168 return;
169 pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD));
170 if (pa == NULL)
171 error(SYSTEM, "out of memory in cbeamadd");
172 for (i = 0; i < n; i++)
173 pa[i].nr = npixels(v, hr, vr,
174 hdlist[pa[i].hd=bl[i].hd],
175 pa[i].bi=bl[i].bi) / 8;
176
177 serv_request(DR_ADDSET, n*sizeof(PACKHEAD), (char *)pa);
178 free((char *)pa);
179 }
180
181
182 cbeamdel(bl, n) /* delete unwanted beam requests */
183 register struct beamcomp *bl;
184 int n;
185 {
186 register PACKHEAD *pa;
187 register int i;
188
189 if (n <= 0)
190 return;
191 pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD));
192 if (pa == NULL)
193 error(SYSTEM, "out of memory in cbeamdel");
194 for (i = 0; i < n; i++) {
195 pa[i].hd = bl[i].hd;
196 pa[i].bi = bl[i].bi;
197 pa[i].nr = 0; /* removes any request */
198 }
199 serv_request(DR_DELSET, n*sizeof(PACKHEAD), (char *)pa);
200 free((char *)pa);
201 }
202
203
204 int
205 set_voxels(vl, n) /* set new voxel array */
206 VOXL vl[8];
207 int n;
208 {
209 short wmap[256];
210 int vmap[8];
211 int comn = 0;
212 int no;
213 register int i, j;
214 /* find common voxels */
215 for (j = 0; j < 8 && voxel[j].hd >= 0; j++) {
216 vmap[j] = -1;
217 for (i = n; i--; )
218 if (!bcmp((char *)(vl+i), (char *)(voxel+j),
219 sizeof(VOXL))) {
220 vmap[j] = i;
221 comn |= 1<<i;
222 break;
223 }
224 }
225 no = comn ? j : 0; /* compute flag mapping */
226 for (i = 256; i--; ) {
227 wmap[i] = 0;
228 for (j = no; j--; )
229 if (vmap[j] >= 0 && i & 1<<j)
230 wmap[i] |= 1<<vmap[j];
231 }
232 /* fix cbeam flags */
233 for (i = ncbeams; i--; )
234 cbeam[i].wants = wmap[cbeam[i].wants];
235 /* update our voxel list */
236 bcopy((char *)vl, (char *)voxel, n*sizeof(VOXL));
237 for (j = n; j < 8; j++)
238 voxel[j].hd = -1;
239 return(comn); /* return bit array of common voxels */
240 }
241
242
243 int
244 get_voxels(vl, vp) /* find voxels corresponding to view point */
245 VOXL vl[8];
246 FVECT vp;
247 {
248 int n = 0;
249 FVECT gp;
250 double d;
251 int dist, bestd = 0x7fff;
252 VOXL vox;
253 register int i, j, k;
254 /* find closest voxels */
255 for (i = 0; n < 8 && hdlist[i]; i++) {
256 hdgrid(gp, hdlist[i], vp);
257 for (j = 0; n < 8 && j < 8; j++) {
258 dist = 0;
259 for (k = 0; k < 3; k++) {
260 d = gp[k] - .5 + (j>>k & 1);
261 if (d < 0.)
262 dist += -(vox.i[k] = (int)d - 1);
263 else if ((vox.i[k] = d) >= hdlist[i]->grid[k])
264 dist += vox.i[k] -
265 hdlist[i]->grid[k] + 1;
266 }
267 if (dist > bestd) /* others were closer */
268 continue;
269 if (dist < bestd) { /* start closer list */
270 n = 0;
271 bestd = dist;
272 }
273 vox.hd = i; /* add this voxel */
274 copystruct(&vl[n], &vox);
275 n++;
276 }
277 }
278 return(n);
279 }
280
281
282 int
283 dobeam(gcp, bp) /* express interest or disintrest in a beam */
284 GCOORD *gcp;
285 register struct beamact *bp;
286 {
287 GCOORD gc[2];
288 int bi, i;
289 /* compute beam index */
290 copystruct(gc, gcp);
291 copystruct(gc+1, &bp->gc);
292 if ((bi = hdbindex(hdlist[voxel[bp->ca.vi].hd], gc)) <= 0)
293 error(CONSISTENCY, "bad grid coordinate in dobeam");
294 if (bp->ca.add) { /* add it in */
295 i = getcbeam(voxel[bp->ca.vi].hd, bi);
296 cbeam[i].wants |= 1<<bp->ca.vi; /* say we want it */
297 return(i == ncbeams+xcbeams-1); /* return 1 if totally new */
298 }
299 /* else delete it */
300 i = findcbeam(voxel[bp->ca.vi].hd, bi);
301 if (i >= 0 && cbeam[i].wants & 1<<bp->ca.vi) {
302 cbeam[i].wants &= ~(1<<bp->ca.vi); /* we don't want it */
303 return(1); /* indicate change */
304 }
305 return(0);
306 }
307
308
309
310 int
311 docell(gcp, cap) /* find beams corresponding to cell and voxel */
312 GCOORD *gcp;
313 register struct cellact *cap;
314 {
315 FVECT org, dir[4];
316 FVECT gp, cv[4], vc;
317 struct beamact bo;
318 register int i;
319 /* compute cell vertices */
320 hdcell(cv, hdlist[voxel[cap->vi].hd], gcp);
321 /* compute cell and voxel centers */
322 for (i = 0; i < 3; i++) {
323 org[i] = 0.5*(cv[0][i] + cv[2][i]);
324 gp[i] = voxel[cap->vi].i[i] + 0.5;
325 }
326 hdworld(vc, hdlist[voxel[cap->vi].hd], gp);
327 /* compute voxel pyramid using vector trick */
328 for (i = 0; i < 3; i++) {
329 dir[0][i] = vc[i] - cv[0][i]; /* to 3 */
330 dir[2][i] = vc[i] - cv[3][i]; /* to 0 */
331 if (gcp->w & 1) { /* watch vertex order! */
332 dir[1][i] = vc[i] - cv[2][i]; /* to 1 */
333 dir[3][i] = vc[i] - cv[1][i]; /* to 2 */
334 } else {
335 dir[1][i] = vc[i] - cv[1][i]; /* to 2 */
336 dir[3][i] = vc[i] - cv[2][i]; /* to 1 */
337 }
338 }
339 /* visit beams for opposite cells */
340 copystruct(&bo.ca, cap);
341 copystruct(&bo.gc, gcp);
342 return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo));
343 }
344
345
346 int
347 doview(cap, vp) /* visit cells for a given view */
348 struct cellact *cap;
349 VIEW *vp;
350 {
351 FVECT org, dir[4];
352 /* compute view pyramid */
353 if (vp->type == VT_PAR) goto viewerr;
354 if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) goto viewerr;
355 if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) goto viewerr;
356 if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) goto viewerr;
357 if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) goto viewerr;
358 /* visit cells within pyramid */
359 return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], docell, cap));
360 viewerr:
361 error(INTERNAL, "unusable view in doview");
362 }
363
364
365 mvview(voxi, vold, vnew) /* move view for a voxel */
366 int voxi;
367 VIEW *vold, *vnew;
368 {
369 int netchange = 0;
370 int *ocl, *ncl;
371 struct cellact ca;
372 int ocnt, ncnt;
373 int c;
374 register GCOORD *ogcp, *ngcp;
375 /* get old and new cell lists */
376 ocl = getviewcells(hdlist[voxel[voxi].hd], vold);
377 ncl = getviewcells(hdlist[voxel[voxi].hd], vnew);
378 if (ocl != NULL) {
379 ocnt = *ocl; ogcp = (GCOORD *)(ocl+1);
380 } else {
381 ocnt = 0; ogcp = NULL;
382 }
383 if (ncl != NULL) {
384 ncnt = *ncl; ngcp = (GCOORD *)(ncl+1);
385 } else {
386 ncnt = 0; ngcp = NULL;
387 }
388 ca.vi = voxi; /* add and delete cells */
389 while (ocnt > 0 & ncnt > 0)
390 if ((c = cellcmp(ogcp, ngcp)) > 0) {
391 ca.add = 1; /* new cell */
392 netchange += docell(ngcp++, &ca);
393 ncnt--;
394 } else if (c < 0) {
395 ca.add = 0; /* obsolete cell */
396 netchange -= docell(ogcp++, &ca);
397 ocnt--;
398 } else {
399 ogcp++; ocnt--; /* unchanged cell */
400 ngcp++; ncnt--;
401 }
402 /* take care of list tails */
403 for (ca.add = 1; ncnt > 0; ncnt--)
404 netchange += docell(ngcp++, &ca);
405 for (ca.add = 0; ocnt > 0; ocnt--)
406 netchange -= docell(ogcp++, &ca);
407 /* clean up */
408 if (ocl != NULL) free((char *)ocl);
409 if (ncl != NULL) free((char *)ncl);
410 return(netchange);
411 }
412
413
414 beam_view(vo, vn) /* change beam view */
415 VIEW *vo, *vn;
416 {
417 struct cellact ca;
418 VOXL vlnew[8];
419 int n, comn;
420
421 if (!vn->type) { /* clear our beam list */
422 set_voxels(vlnew, 0);
423 cbeamdel(cbeam, ncbeams);
424 ncbeams = 0;
425 return;
426 }
427 /* find our new voxels */
428 n = get_voxels(vlnew, vn->vp);
429 /* set the new voxels */
430 comn = set_voxels(vlnew, n);
431 if (!vo->type)
432 comn = 0;
433 ca.add = 1; /* update our beam list */
434 for (ca.vi = n; ca.vi--; )
435 if (comn & 1<<ca.vi) /* change which cells we see */
436 mvview(ca.vi, vo, vn);
437 else /* else add all new cells */
438 doview(&ca, vn);
439 /* inform server of new beams */
440 cbeamadd(cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres);
441 /* sort list to put orphans at end */
442 cbeamsort(0);
443 /* tell server to delete orphans */
444 cbeamdel(cbeam+ncbeams, xcbeams);
445 xcbeams = 0; /* truncate our list */
446 }
