1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Holodeck beam tracking |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "rhdisp.h" |
13 |
#include "rhdriver.h" |
14 |
15 |
extern int *getviewcells(); |
16 |
17 |
typedef struct { |
18 |
int hd; /* holodeck section number */ |
19 |
int i[3]; /* voxel index (may be outside section) */ |
20 |
} VOXL; /* a voxel */ |
21 |
22 |
static VOXL voxel[8] = { /* current voxel list */ |
23 |
{-1}, {-1}, {-1}, {-1}, |
24 |
{-1}, {-1}, {-1}, {-1} |
25 |
26 |
27 |
#define CBEAMBLK 1024 /* cbeam allocation block size */ |
28 |
29 |
static struct beamcomp { |
30 |
short wants; /* flags telling which voxels want us */ |
31 |
short hd; /* holodeck section number */ |
32 |
int bi; /* beam index */ |
33 |
} *cbeam = NULL; /* current beam list */ |
34 |
35 |
static int ncbeams = 0; /* number of sorted beams in cbeam */ |
36 |
static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */ |
37 |
static int maxcbeam = 0; /* size of cbeam array */ |
38 |
39 |
40 |
struct cellact { |
41 |
short vi; /* voxel index */ |
42 |
short add; /* zero means delete */ |
43 |
}; /* action for cell */ |
44 |
45 |
46 |
struct beamact { |
47 |
struct cellact ca; /* cell action */ |
48 |
GCOORD gc; /* grid coordinate */ |
49 |
}; /* beam origin and action */ |
50 |
51 |
52 |
int |
53 |
newcbeam() /* allocate new entry at end of cbeam array */ |
54 |
55 |
int i; |
56 |
57 |
if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */ |
58 |
maxcbeam += CBEAMBLK; |
59 |
if (cbeam == NULL) |
60 |
cbeam = (struct beamcomp *)malloc( |
61 |
maxcbeam*sizeof(struct beamcomp) ); |
62 |
else |
63 |
cbeam = (struct beamcomp *)realloc( (char *)cbeam, |
64 |
65 |
66 |
error(SYSTEM, "out of memory in newcbeam"); |
67 |
68 |
return(i); |
69 |
70 |
71 |
72 |
int |
73 |
cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */ |
74 |
register struct beamcomp *cb1, *cb2; |
75 |
76 |
register int c; |
77 |
78 |
if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */ |
79 |
return(c); |
80 |
return(cb1->hd - cb2->hd); /* use hd to resolve matches */ |
81 |
82 |
83 |
84 |
int |
85 |
cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */ |
86 |
87 |
88 |
register int c; |
89 |
90 |
if (!cb1->wants) /* put orphans at the end, unsorted */ |
91 |
return(cb2->wants); |
92 |
93 |
return(c); |
94 |
95 |
96 |
97 |
98 |
int |
99 |
findcbeam(hd, bi) /* find the specified beam in our sorted list */ |
100 |
int hd, bi; |
101 |
102 |
struct beamcomp cb; |
103 |
register struct beamcomp *p; |
104 |
105 |
if (ncbeams <= 0) |
106 |
return(-1); |
107 |
cb.wants = 0; cb.hd = hd; cb.bi = bi; |
108 |
p = (struct beamcomp *)bsearch((char *)&cb, (char *)cbeam, ncbeams, |
109 |
sizeof(struct beamcomp), cbeamcmp); |
110 |
if (p == NULL) |
111 |
return(-1); |
112 |
return(p - cbeam); |
113 |
114 |
115 |
116 |
int |
117 |
getcbeam(hd, bi) /* get the specified beam, allocating as necessary */ |
118 |
register int hd; |
119 |
int bi; |
120 |
121 |
register int n; |
122 |
/* first, look in sorted list */ |
123 |
if ((n = findcbeam(hd, bi)) >= 0) |
124 |
return(n); |
125 |
/* linear search through xcbeams to be sure */ |
126 |
for (n = ncbeams+xcbeams; n-- > ncbeams; ) |
127 |
if (cbeam[n].bi == bi && cbeam[n].hd == hd) |
128 |
return(n); |
129 |
/* check legality */ |
130 |
if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL) |
131 |
error(INTERNAL, "illegal holodeck number in getcbeam"); |
132 |
if (bi < 1 | bi > nbeams(hdlist[hd])) |
133 |
error(INTERNAL, "illegal beam index in getcbeam"); |
134 |
n = newcbeam(); /* allocate and assign */ |
135 |
cbeam[n].wants = 0; cbeam[n].hd = hd; cbeam[n].bi = bi; |
136 |
return(n); |
137 |
138 |
139 |
140 |
cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */ |
141 |
int adopt; |
142 |
143 |
register int i; |
144 |
145 |
if (!(ncbeams += xcbeams)) |
146 |
return; |
147 |
xcbeams = 0; |
148 |
qsort((char *)cbeam, ncbeams, sizeof(struct beamcomp), |
149 |
adopt ? cbeamcmp : cbeamcmp2); |
150 |
if (adopt) |
151 |
return; |
152 |
for (i = ncbeams; i--; ) /* identify orphans */ |
153 |
if (cbeam[i].wants) |
154 |
break; |
155 |
xcbeams = ncbeams - ++i; /* put orphans after ncbeams */ |
156 |
ncbeams = i; |
157 |
158 |
159 |
160 |
cbeamadd(bl, n, v, hr, vr) /* add beams to server list */ |
161 |
register struct beamcomp *bl; |
162 |
int n; |
163 |
VIEW *v; |
164 |
int hr, vr; |
165 |
166 |
register PACKHEAD *pa; |
167 |
register int i; |
168 |
169 |
if (n <= 0) |
170 |
return; |
171 |
pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD)); |
172 |
if (pa == NULL) |
173 |
error(SYSTEM, "out of memory in cbeamadd"); |
174 |
for (i = 0; i < n; i++) |
175 |
pa[i].nr = npixels(v, hr, vr, |
176 |
hdlist[pa[i].hd=bl[i].hd], |
177 |
pa[i].bi=bl[i].bi) / 8; |
178 |
179 |
serv_request(DR_ADDSET, n*sizeof(PACKHEAD), (char *)pa); |
180 |
free((char *)pa); |
181 |
182 |
183 |
184 |
cbeamdel(bl, n) /* delete unwanted beam requests */ |
185 |
186 |
int n; |
187 |
188 |
189 |
register int i; |
190 |
191 |
if (n <= 0) |
192 |
return; |
193 |
194 |
if (pa == NULL) |
195 |
error(SYSTEM, "out of memory in cbeamdel"); |
196 |
for (i = 0; i < n; i++) { |
197 |
pa[i].hd = bl[i].hd; |
198 |
pa[i].bi = bl[i].bi; |
199 |
pa[i].nr = 0; /* removes any request */ |
200 |
201 |
serv_request(DR_DELSET, n*sizeof(PACKHEAD), (char *)pa); |
202 |
free((char *)pa); |
203 |
204 |
205 |
206 |
int |
207 |
set_voxels(vl, n) /* set new voxel array */ |
208 |
VOXL vl[8]; |
209 |
int n; |
210 |
211 |
short wmap[256]; |
212 |
int vmap[8]; |
213 |
int comn = 0; |
214 |
int no; |
215 |
register int i, j; |
216 |
/* find common voxels */ |
217 |
for (j = 0; j < 8 && voxel[j].hd >= 0; j++) { |
218 |
vmap[j] = -1; |
219 |
for (i = n; i--; ) |
220 |
if (!bcmp((char *)(vl+i), (char *)(voxel+j), |
221 |
sizeof(VOXL))) { |
222 |
vmap[j] = i; |
223 |
comn |= 1<<i; |
224 |
break; |
225 |
226 |
227 |
no = comn ? j : 0; /* compute flag mapping */ |
228 |
for (i = 256; i--; ) { |
229 |
wmap[i] = 0; |
230 |
for (j = no; j--; ) |
231 |
if (vmap[j] >= 0 && i & 1<<j) |
232 |
wmap[i] |= 1<<vmap[j]; |
233 |
234 |
/* fix cbeam flags */ |
235 |
for (i = ncbeams; i--; ) |
236 |
cbeam[i].wants = wmap[cbeam[i].wants]; |
237 |
/* update our voxel list */ |
238 |
bcopy((char *)vl, (char *)voxel, n*sizeof(VOXL)); |
239 |
for (j = n; j < 8; j++) |
240 |
voxel[j].hd = -1; |
241 |
return(comn); /* return bit array of common voxels */ |
242 |
243 |
244 |
245 |
int |
246 |
get_voxels(vl, vp) /* find voxels corresponding to view point */ |
247 |
VOXL vl[8]; |
248 |
FVECT vp; |
249 |
250 |
int n = 0; |
251 |
FVECT gp; |
252 |
double d; |
253 |
int dist, bestd = 0x7fff; |
254 |
VOXL vox; |
255 |
register int i, j, k; |
256 |
/* find closest voxels */ |
257 |
for (i = 0; n < 8 && hdlist[i]; i++) { |
258 |
hdgrid(gp, hdlist[i], vp); |
259 |
for (j = 0; n < 8 && j < 8; j++) { |
260 |
dist = 0; |
261 |
for (k = 0; k < 3; k++) { |
262 |
d = gp[k] - .5 + (j>>k & 1); |
263 |
if (d < 0.) |
264 |
dist += -(vox.i[k] = (int)d - 1); |
265 |
else if ((vox.i[k] = d) >= hdlist[i]->grid[k]) |
266 |
dist += vox.i[k] - |
267 |
hdlist[i]->grid[k] + 1; |
268 |
269 |
if (dist > bestd) /* others were closer */ |
270 |
continue; |
271 |
if (dist < bestd) { /* start closer list */ |
272 |
n = 0; |
273 |
bestd = dist; |
274 |
275 |
vox.hd = i; /* add this voxel */ |
276 |
copystruct(&vl[n], &vox); |
277 |
n++; |
278 |
279 |
280 |
return(n); |
281 |
282 |
283 |
284 |
int |
285 |
dobeam(gcp, bp) /* express interest or disintrest in a beam */ |
286 |
GCOORD *gcp; |
287 |
register struct beamact *bp; |
288 |
289 |
GCOORD gc[2]; |
290 |
int bi, i; |
291 |
/* compute beam index */ |
292 |
copystruct(gc, gcp); |
293 |
copystruct(gc+1, &bp->gc); |
294 |
if ((bi = hdbindex(hdlist[voxel[bp->ca.vi].hd], gc)) <= 0) |
295 |
return(0); /* should report an error? */ |
296 |
if (bp->ca.add) { /* add it in */ |
297 |
i = getcbeam(voxel[bp->ca.vi].hd, bi); |
298 |
cbeam[i].wants |= 1<<bp->ca.vi; /* say we want it */ |
299 |
return(i == ncbeams+xcbeams-1); /* return 1 if totally new */ |
300 |
301 |
/* else delete it */ |
302 |
i = findcbeam(voxel[bp->ca.vi].hd, bi); |
303 |
if (i >= 0 && cbeam[i].wants & 1<<bp->ca.vi) { |
304 |
cbeam[i].wants &= ~(1<<bp->ca.vi); /* we don't want it */ |
305 |
return(1); /* indicate change */ |
306 |
307 |
return(0); |
308 |
309 |
310 |
311 |
312 |
int |
313 |
docell(gcp, cap) /* find beams corresponding to cell and voxel */ |
314 |
GCOORD *gcp; |
315 |
register struct cellact *cap; |
316 |
317 |
FVECT org, dir[4]; |
318 |
FVECT gp, cv[4], vc; |
319 |
struct beamact bo; |
320 |
register int i; |
321 |
/* compute cell vertices */ |
322 |
hdcell(cv, hdlist[voxel[cap->vi].hd], gcp); |
323 |
/* compute cell and voxel centers */ |
324 |
for (i = 0; i < 3; i++) { |
325 |
org[i] = 0.5*(cv[0][i] + cv[2][i]); |
326 |
gp[i] = voxel[cap->vi].i[i] + 0.5; |
327 |
328 |
hdworld(vc, hdlist[voxel[cap->vi].hd], gp); |
329 |
/* compute voxel pyramid using vector trick */ |
330 |
331 |
dir[0][i] = vc[i] - cv[0][i]; /* to 3 */ |
332 |
dir[2][i] = vc[i] - cv[3][i]; /* to 0 */ |
333 |
if (gcp->w & 1) { /* watch vertex order! */ |
334 |
dir[1][i] = vc[i] - cv[2][i]; /* to 1 */ |
335 |
dir[3][i] = vc[i] - cv[1][i]; /* to 2 */ |
336 |
} else { |
337 |
dir[1][i] = vc[i] - cv[1][i]; /* to 2 */ |
338 |
dir[3][i] = vc[i] - cv[2][i]; /* to 1 */ |
339 |
340 |
341 |
/* visit beams for opposite cells */ |
342 |
copystruct(&bo.ca, cap); |
343 |
copystruct(&bo.gc, gcp); |
344 |
return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo)); |
345 |
346 |
347 |
348 |
int |
349 |
doview(cap, vp) /* visit cells for a given view */ |
350 |
351 |
VIEW *vp; |
352 |
353 |
354 |
/* compute view pyramid */ |
355 |
if (vp->type == VT_PAR) goto viewerr; |
356 |
if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) goto viewerr; |
357 |
if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) goto viewerr; |
358 |
if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) goto viewerr; |
359 |
if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) goto viewerr; |
360 |
/* visit cells within pyramid */ |
361 |
return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], docell, cap)); |
362 |
viewerr: |
363 |
error(INTERNAL, "unusable view in doview"); |
364 |
365 |
366 |
367 |
mvview(voxi, vold, vnew) /* move view for a voxel */ |
368 |
int voxi; |
369 |
VIEW *vold, *vnew; |
370 |
371 |
int netchange = 0; |
372 |
int *ocl, *ncl; |
373 |
struct cellact ca; |
374 |
int ocnt, ncnt; |
375 |
int c; |
376 |
register GCOORD *ogcp, *ngcp; |
377 |
/* get old and new cell lists */ |
378 |
ocl = getviewcells(hdlist[voxel[voxi].hd], vold); |
379 |
ncl = getviewcells(hdlist[voxel[voxi].hd], vnew); |
380 |
if (ocl != NULL) { |
381 |
ocnt = *ocl; ogcp = (GCOORD *)(ocl+1); |
382 |
} else { |
383 |
ocnt = 0; ogcp = NULL; |
384 |
385 |
if (ncl != NULL) { |
386 |
ncnt = *ncl; ngcp = (GCOORD *)(ncl+1); |
387 |
} else { |
388 |
ncnt = 0; ngcp = NULL; |
389 |
390 |
ca.vi = voxi; /* add and delete cells */ |
391 |
while (ocnt > 0 & ncnt > 0) |
392 |
if ((c = cellcmp(ogcp, ngcp)) > 0) { |
393 |
ca.add = 1; /* new cell */ |
394 |
netchange += docell(ngcp++, &ca); |
395 |
ncnt--; |
396 |
} else if (c < 0) { |
397 |
ca.add = 0; /* obsolete cell */ |
398 |
netchange -= docell(ogcp++, &ca); |
399 |
ocnt--; |
400 |
} else { |
401 |
ogcp++; ocnt--; /* unchanged cell */ |
402 |
ngcp++; ncnt--; |
403 |
404 |
/* take care of list tails */ |
405 |
for (ca.add = 1; ncnt > 0; ncnt--) |
406 |
407 |
for (ca.add = 0; ocnt > 0; ocnt--) |
408 |
409 |
/* clean up */ |
410 |
if (ocl != NULL) free((char *)ocl); |
411 |
if (ncl != NULL) free((char *)ncl); |
412 |
return(netchange); |
413 |
414 |
415 |
416 |
beam_view(vo, vn) /* change beam view */ |
417 |
VIEW *vo, *vn; |
418 |
419 |
420 |
VOXL vlnew[8]; |
421 |
int n, comn; |
422 |
423 |
if (!vn->type) { /* clear our beam list */ |
424 |
set_voxels(vlnew, 0); |
425 |
cbeamdel(cbeam, ncbeams); |
426 |
ncbeams = 0; |
427 |
return; |
428 |
429 |
/* find our new voxels */ |
430 |
n = get_voxels(vlnew, vn->vp); |
431 |
/* set the new voxels */ |
432 |
comn = set_voxels(vlnew, n); |
433 |
if (!vo->type) |
434 |
comn = 0; |
435 |
ca.add = 1; /* update our beam list */ |
436 |
for (ca.vi = n; ca.vi--; ) |
437 |
if (comn & 1<<ca.vi) /* change which cells we see */ |
438 |
mvview(ca.vi, vo, vn); |
439 |
else /* else add all new cells */ |
440 |
doview(&ca, vn); |
441 |
/* inform server of new beams */ |
442 |
cbeamadd(cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres); |
443 |
/* sort list to put orphans at end */ |
444 |
cbeamsort(0); |
445 |
/* tell server to delete orphans */ |
446 |
cbeamdel(cbeam+ncbeams, xcbeams); |
447 |
xcbeams = 0; /* truncate our list */ |
448 |
