root/radiance/ray/src/hd/rhdisp2.c
Fri Oct 5 19:19:16 2018 UTC (6 years, 6 months ago) by greg
Changes since 3.37: +15 -15 lines
Diff to previous 3.37
Thu Jan 1 11:21:55 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.36: +61 -38 lines
Diff to previous 3.36
Ansification and prototypes.
Sun Jul 27 22:12:02 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.35: +3 -3 lines
Diff to previous 3.35
Changes since 3.34: +3 -3 lines
Diff to previous 3.34
Wed Apr 23 00:52:33 2003 UTC (22 years ago) by greg
Changes since 3.33: +1 -1 lines
Diff to previous 3.33
Sat Feb 22 02:07:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.32: +2 -5 lines
Diff to previous 3.32
Thu Mar 4 10:29:22 1999 UTC (26 years, 2 months ago) by gwlarson
Changes since 3.31: +100 -172 lines
Diff to previous 3.31
Wed Mar 3 10:25:27 1999 UTC (26 years, 2 months ago) by gwlarson
Changes since 3.30: +2 -2 lines
Diff to previous 3.30
fixed parameter ordering in addview() call to viewray()
Tue Dec 22 15:57:20 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.29: +32 -23 lines
Diff to previous 3.29
added jittering around viewpoint for better beam selection
Fri Dec 18 11:56:10 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.28: +21 -10 lines
Diff to previous 3.28
Thu Dec 10 10:45:55 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.27: +2 -2 lines
Diff to previous 3.27
created "frame" command to focus calculation
Thu Dec 3 15:18:08 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.26: +5 -4 lines
Diff to previous 3.26
minor efficiency hack
Tue Nov 24 17:05:36 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.25: +39 -6 lines
Diff to previous 3.25
Tue Nov 24 12:01:17 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.24: +71 -179 lines
Diff to previous 3.24
simplified beam calculation using view ray samples
took out a lot of old, hard-won code!
Tue Sep 15 15:59:31 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.23: +12 -8 lines
Diff to previous 3.23
changed beam management to allow temporary override
Mon Jul 6 18:17:00 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.22: +1 -1 lines
Diff to previous 3.22
fixed comment
Fri May 22 15:12:36 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.21: +19 -31 lines
Diff to previous 3.21
got rid of unnecessary "wants" field
Thu May 14 13:23:00 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.20: +66 -171 lines
Diff to previous 3.20
added multiple device view capability
Thu May 14 10:13:50 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.19: +30 -17 lines
Diff to previous 3.19
partial edit towards multiple views
Wed Jan 7 16:04:14 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.18: +32 -12 lines
Diff to previous 3.18
added code to mvview() to count number of matches for better
performance when the overlap is small or empty
Tue Jan 6 15:08:50 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.17: +4 -4 lines
Diff to previous 3.17
Thu Jan 1 13:00:16 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.16: +2 -75 lines
Diff to previous 3.16
Tue Dec 16 11:57:32 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.15: +45 -18 lines
Diff to previous 3.15
add to beam list in two stages -- prioritize bundles through viewpoint
Mon Dec 15 20:40:46 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.14: +2 -0 lines
Diff to previous 3.14
fixed bug in orphan sorting
Fri Dec 12 12:30:20 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.13: +1 -1 lines
Diff to previous 3.13
increased MAXDIST to 42
Thu Dec 11 17:26:55 1997 UTC (27 years, 4 months ago) by gregl
Diff to previous 3.12
allow NULL to be passed to beam_view()
Thu Dec 11 09:36:59 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.11: +5 -3 lines
Diff to previous 3.11
beam_sync() now returns number of beams
Tue Dec 9 13:53:21 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.10: +1 -2 lines
Diff to previous 3.10
minor optimization
Mon Dec 8 19:03:01 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.9: +47 -22 lines
Diff to previous 3.9
improved docell() algorithm for better coverage
Fri Dec 5 15:50:43 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.8: +16 -2 lines
Diff to previous 3.8
added guard for inappropriate moves
Tue Dec 2 15:02:37 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.7: +40 -0 lines
Diff to previous 3.7
made beam list updating more efficient using DR_ADJSET request
Tue Nov 25 10:48:38 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.6: +13 -8 lines
Diff to previous 3.6
bug fixes and minor improvements
Mon Nov 24 15:17:28 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.5: +12 -15 lines
Diff to previous 3.5
fixed bug in mvview()
Fri Nov 21 18:17:37 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.4: +41 -39 lines
Diff to previous 3.4
added check for holodeck behind viewpoint for more robust beam selection
Fri Nov 21 16:10:17 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.3: +14 -28 lines
added server-driven redraw function to replace display quadtree
Thu Nov 20 18:06:35 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.2: +8 -1 lines
added warning for leaving or entering holodeck sections
Thu Nov 20 14:46:07 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.1: +5 -7 lines
added consistency check
Wed Nov 19 18:01:03 1997 UTC (27 years, 5 months ago) by gregl
