root/radiance/ray/src/hd/rhdisp2.c
Revision: 3.37
Committed: Thu Jan 1 11:21:55 2004 UTC (21 years, 7 months ago) by schorsch
CVS Tags: rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2
Changes since 3.36: +61 -38 lines
Ansification and prototypes.
2 static const char RCSid[] = "$Id: rhdisp2.c,v 3.36 2003/07/27 22:12:02 schorsch Exp $";
5 * Holodeck beam tracking for display process
6 */
7
8 #include "rholo.h"
9 #include "rhdisp.h"
10 #include "rhdriver.h"
11
12 #ifndef MEYERNG
13 #define MEYERNG 0.2 /* target mean eye range (rel. to grid) */
14 #endif
15
16 #define CBEAMBLK 1024 /* cbeam allocation block size */
17
18 static PACKHEAD *cbeam = NULL; /* current beam list */
19 static int ncbeams = 0; /* number of sorted beams in cbeam */
20 static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */
21 static int maxcbeam = 0; /* size of cbeam array */
22
23 VIEWPOINT cureye; /* current eye position */
24
25 static int newcbeam(void);
26 static int cbeamcmp(const void *cb1, const void *cb2);
27 static int cbeamcmp2(const void *cb1, const void *cb2);
28 static int findcbeam(int hd, int bi);
29 static int getcbeam(int hd, int bi);
30 static void cbeamsort(int adopt);
31
32
33 static int
34 newcbeam(void) /* allocate new entry at end of cbeam array */
35 {
36 int i;
37
38 if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */
39 maxcbeam += CBEAMBLK;
40 if (cbeam == NULL)
41 cbeam = (PACKHEAD *)malloc(
42 maxcbeam*sizeof(PACKHEAD) );
43 else
44 cbeam = (PACKHEAD *)realloc((void *)cbeam,
45 maxcbeam*sizeof(PACKHEAD) );
46 if (cbeam == NULL)
47 error(SYSTEM, "out of memory in newcbeam");
48 }
49 return(i);
50 }
51
52
53 static int
54 cbeamcmp( /* compare two cbeam entries for sort: keep orphans */
55 const void *cb1,
56 const void *cb2
57 )
58 {
59 register int c;
60
61 if ((c = ((PACKHEAD*)cb1)->bi - ((PACKHEAD*)cb2)->bi)) /* sort on beam index first */
62 return(c);
63 return(((PACKHEAD*)cb1)->hd - ((PACKHEAD*)cb2)->hd); /* use hd to resolve matches */
64 }
65
66
67 static int
68 cbeamcmp2( /* compare two cbeam entries for sort: no orphans */
69 const void *cb1,
70 const void *cb2
71 )
72 {
73 register int c;
74
75 if (!((PACKHEAD*)cb1)->nr) /* put orphans at the end, unsorted */
76 return(((PACKHEAD*)cb2)->nr);
77 if (!((PACKHEAD*)cb2)->nr)
78 return(-1);
79 if ((c = ((PACKHEAD*)cb1)->bi - ((PACKHEAD*)cb2)->bi)) /* sort on beam index first */
80 return(c);
81 return(((PACKHEAD*)cb1)->hd - ((PACKHEAD*)cb2)->hd); /* use hd to resolve matches */
82 }
83
84
85 static int
86 findcbeam( /* find the specified beam in our sorted list */
87 int hd,
88 int bi
89 )
90 {
91 PACKHEAD cb;
92 register PACKHEAD *p;
93
94 if (ncbeams <= 0)
95 return(-1);
96 cb.hd = hd; cb.bi = bi; cb.nr = cb.nc = 0;
97 p = (PACKHEAD *)bsearch((char *)&cb, (char *)cbeam, ncbeams,
98 sizeof(PACKHEAD), cbeamcmp);
99 if (p == NULL)
100 return(-1);
101 return(p - cbeam);
102 }
103
104
105 static int
106 getcbeam( /* get the specified beam, allocating as necessary */
107 register int hd,
108 int bi
109 )
110 {
111 register int n;
112 /* first, look in sorted list */
113 if ((n = findcbeam(hd, bi)) >= 0)
114 return(n);
115 /* linear search through xcbeams to be sure */
116 for (n = ncbeams+xcbeams; n-- > ncbeams; )
117 if (cbeam[n].bi == bi && cbeam[n].hd == hd)
118 return(n);
119 /* check legality */
120 if ((hd < 0) | (hd >= HDMAX) || hdlist[hd] == NULL)
121 error(INTERNAL, "illegal holodeck number in getcbeam");
122 if ((bi < 1) | (bi > nbeams(hdlist[hd])))
123 error(INTERNAL, "illegal beam index in getcbeam");
124 n = newcbeam(); /* allocate and assign */
125 cbeam[n].hd = hd; cbeam[n].bi = bi; cbeam[n].nr = cbeam[n].nc = 0;
126 return(n);
127 }
128
129
130 static void
131 cbeamsort( /* sort our beam list, possibly turning out orphans */
132 int adopt
133 )
134 {
135 register int i;
136
137 if (!(ncbeams += xcbeams))
138 return;
139 xcbeams = 0;
140 qsort((char *)cbeam, ncbeams, sizeof(PACKHEAD),
141 adopt ? cbeamcmp : cbeamcmp2);
142 if (adopt)
143 return;
144 for (i = ncbeams; i--; ) /* identify orphans */
145 if (cbeam[i].nr)
146 break;
147 xcbeams = ncbeams - ++i; /* put orphans after ncbeams */
148 ncbeams = i;
149 }
150
151
152 extern void
153 beam_init( /* clear beam list for new view(s) */
154 int fresh
155 )
156 {
157 register int i;
158
159 if (fresh) /* discard old beams? */
160 ncbeams = xcbeams = 0;
161 else /* else clear sample requests */
162 for (i = ncbeams+xcbeams; i--; )
163 cbeam[i].nr = 0;
164 cureye.rng = 0.;
165 }
166
167
168 extern int16 *
169 beam_view( /* add beam view (if advisable) */
170 VIEW *vn,
171 int hr,
172 int vr
173 )
174 {
175 int16 *slist;
176 BEAMLIST blist;
177 double eravg, d;
178 register HOLO *hp;
179 register int i, n;
180 /* compute beams for view */
181 slist = viewbeams(vn, hr, vr, &blist);
182 if (*slist < 0) {
183 error(COMMAND, "no sections visible from this view");
184 return(NULL);
185 }
186 /* sort current beam list */
187 cbeamsort(1);
188 /* add new beams to list */
189 for (i = blist.nb; i--; ) {
190 n = getcbeam(blist.bl[i].hd, blist.bl[i].bi);
191 if (blist.bl[i].nr > cbeam[n].nr)
192 cbeam[n].nr = blist.bl[i].nr;
193 }
194 free((void *)blist.bl); /* free list */
195 if (MEYERNG <= FTINY)
196 return(slist);
197 /* compute average eye range */
198 eravg = 0.;
199 for (n = 0; slist[n] >= 0; n++) {
200 hp = hdlist[slist[n]];
201 eravg += MEYERNG/3. / VLEN(hp->wg[0]) +
202 MEYERNG/3. / VLEN(hp->wg[1]) +
203 MEYERNG/3. / VLEN(hp->wg[2]) ;
204 }
205 eravg /= (double)n;
206 /* add to current eye position */
207 if (cureye.rng <= FTINY) {
208 VCOPY(cureye.vpt, vn->vp);
209 cureye.rng = eravg;
210 } else if ((d = sqrt(dist2(vn->vp,cureye.vpt))) + eravg > cureye.rng) {
211 for (i = 3; i--; )
212 cureye.vpt[i] = 0.5*(cureye.vpt[i] + vn->vp[i]);
213 cureye.rng = 0.5*(cureye.rng + eravg + d);
214 }
215 return(slist);
216 }
217
218
219 extern int
220 beam_sync( /* update beam list on server */
221 int all
222 )
223 {
224 /* set new eye position */
225 serv_request(DR_VIEWPOINT, sizeof(VIEWPOINT), (char *)&cureye);
226 /* sort list (put orphans at end) */
227 cbeamsort(all < 0);
228 /* send beam request */
229 if (all) {
230 if (ncbeams > 0)
231 serv_request(DR_NEWSET,
232 ncbeams*sizeof(PACKHEAD), (char *)cbeam);
233 } else {
234 if (ncbeams+xcbeams > 0)
235 serv_request(DR_ADJSET,
236 (ncbeams+xcbeams)*sizeof(PACKHEAD), (char *)cbeam);
237 }
238 xcbeams = 0; /* truncate our list */
239 return(ncbeams);
240 }
241
242
243 extern void
244 gridlines( /* run through holodeck section grid lines */
245 void (*f)(FVECT wp[2])
246 )
247 {
248 register int hd, w, i;
249 int g0, g1;
250 FVECT wp[2], mov;
251 double d;
252 /* do each wall on each section */
253 for (hd = 0; hdlist[hd] != NULL; hd++)
254 for (w = 0; w < 6; w++) {
255 g0 = hdwg0[w];
256 g1 = hdwg1[w];
257 d = 1.0/hdlist[hd]->grid[g0];
258 mov[0] = d * hdlist[hd]->xv[g0][0];
259 mov[1] = d * hdlist[hd]->xv[g0][1];
260 mov[2] = d * hdlist[hd]->xv[g0][2];
261 if (w & 1) {
262 VSUM(wp[0], hdlist[hd]->orig,
263 hdlist[hd]->xv[w>>1], 1.);
264 VSUM(wp[0], wp[0], mov, 1.);
265 } else
266 VCOPY(wp[0], hdlist[hd]->orig);
267 VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.);
268 for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */
269 (*f)(wp);
270 if (!--i) break;
271 wp[0][0] += mov[0]; wp[0][1] += mov[1];
272 wp[0][2] += mov[2]; wp[1][0] += mov[0];
273 wp[1][1] += mov[1]; wp[1][2] += mov[2];
274 }
275 d = 1.0/hdlist[hd]->grid[g1];
276 mov[0] = d * hdlist[hd]->xv[g1][0];
277 mov[1] = d * hdlist[hd]->xv[g1][1];
278 mov[2] = d * hdlist[hd]->xv[g1][2];
279 if (w & 1)
280 VSUM(wp[0], hdlist[hd]->orig,
281 hdlist[hd]->xv[w>>1], 1.);
282 else
283 VSUM(wp[0], hdlist[hd]->orig, mov, 1.);
284 VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.);
285 for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */
286 (*f)(wp);
287 if (!--i) break;
288 wp[0][0] += mov[0]; wp[0][1] += mov[1];
289 wp[0][2] += mov[2]; wp[1][0] += mov[0];
290 wp[1][1] += mov[1]; wp[1][2] += mov[2];
291 }
292 }
293 }
