root/radiance/ray/src/hd/rhdisp2.c
Revision: 3.3
Committed: Thu Nov 20 18:06:35 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.2: +8 -1 lines
added warning for leaving or entering holodeck sections
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck beam tracking for display process
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14
15 extern int *getviewcells();
16
17 typedef struct {
18 int hd; /* holodeck section number (-1 if inactive) */
19 int i[3]; /* voxel index (may be outside section) */
20 } VOXL; /* a voxel */
21
22 static VOXL voxel[8] = { /* current voxel list */
23 {-1}, {-1}, {-1}, {-1},
24 {-1}, {-1}, {-1}, {-1}
25 };
26
27 #define CBEAMBLK 1024 /* cbeam allocation block size */
28
29 static struct beamcomp {
30 short wants; /* flags telling which voxels want us */
31 short hd; /* holodeck section number */
32 int bi; /* beam index */
33 } *cbeam = NULL; /* current beam list */
34
35 static int ncbeams = 0; /* number of sorted beams in cbeam */
36 static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */
37 static int maxcbeam = 0; /* size of cbeam array */
38
39 struct cellact {
40 short vi; /* voxel index */
41 short add; /* zero means delete */
42 }; /* action for cell */
43
44 struct beamact {
45 struct cellact ca; /* cell action */
46 GCOORD gc; /* grid coordinate */
47 }; /* beam origin and action */
48
49
50 int
51 newcbeam() /* allocate new entry at end of cbeam array */
52 {
53 int i;
54
55 if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */
56 maxcbeam += CBEAMBLK;
57 if (cbeam == NULL)
58 cbeam = (struct beamcomp *)malloc(
59 maxcbeam*sizeof(struct beamcomp) );
60 else
61 cbeam = (struct beamcomp *)realloc( (char *)cbeam,
62 maxcbeam*sizeof(struct beamcomp) );
63 if (cbeam == NULL)
64 error(SYSTEM, "out of memory in newcbeam");
65 }
66 return(i);
67 }
68
69
70 int
71 cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */
72 register struct beamcomp *cb1, *cb2;
73 {
74 register int c;
75
76 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
77 return(c);
78 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
79 }
80
81
82 int
83 cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */
84 register struct beamcomp *cb1, *cb2;
85 {
86 register int c;
87
88 if (!cb1->wants) /* put orphans at the end, unsorted */
89 return(cb2->wants);
90 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
91 return(c);
92 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
93 }
94
95
96 int
97 findcbeam(hd, bi) /* find the specified beam in our sorted list */
98 int hd, bi;
99 {
100 struct beamcomp cb;
101 register struct beamcomp *p;
102
103 if (ncbeams <= 0)
104 return(-1);
105 cb.wants = 0; cb.hd = hd; cb.bi = bi;
106 p = (struct beamcomp *)bsearch((char *)&cb, (char *)cbeam, ncbeams,
107 sizeof(struct beamcomp), cbeamcmp);
108 if (p == NULL)
109 return(-1);
110 return(p - cbeam);
111 }
112
113
114 int
115 getcbeam(hd, bi) /* get the specified beam, allocating as necessary */
116 register int hd;
117 int bi;
118 {
119 register int n;
120 /* first, look in sorted list */
121 if ((n = findcbeam(hd, bi)) >= 0)
122 return(n);
123 /* linear search through xcbeams to be sure */
124 for (n = ncbeams+xcbeams; n-- > ncbeams; )
125 if (cbeam[n].bi == bi && cbeam[n].hd == hd)
126 return(n);
127 /* check legality */
128 if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL)
129 error(INTERNAL, "illegal holodeck number in getcbeam");
130 if (bi < 1 | bi > nbeams(hdlist[hd]))
131 error(INTERNAL, "illegal beam index in getcbeam");
132 n = newcbeam(); /* allocate and assign */
133 cbeam[n].wants = 0; cbeam[n].hd = hd; cbeam[n].bi = bi;
134 return(n);
135 }
136
137
138 cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */
139 int adopt;
140 {
141 register int i;
142
143 if (!(ncbeams += xcbeams))
144 return;
145 xcbeams = 0;
146 qsort((char *)cbeam, ncbeams, sizeof(struct beamcomp),
147 adopt ? cbeamcmp : cbeamcmp2);
148 if (adopt)
149 return;
150 for (i = ncbeams; i--; ) /* identify orphans */
151 if (cbeam[i].wants)
152 break;
153 xcbeams = ncbeams - ++i; /* put orphans after ncbeams */
154 ncbeams = i;
155 }
156
157
158 cbeamadd(bl, n, v, hr, vr) /* add beams to server list */
159 register struct beamcomp *bl;
160 int n;
161 VIEW *v;
162 int hr, vr;
163 {
164 register PACKHEAD *pa;
165 register int i;
166
167 if (n <= 0)
168 return;
169 pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD));
170 if (pa == NULL)
171 error(SYSTEM, "out of memory in cbeamadd");
172 for (i = 0; i < n; i++)
173 pa[i].nr = npixels(v, hr, vr,
174 hdlist[pa[i].hd=bl[i].hd],
175 pa[i].bi=bl[i].bi) / 8;
176
177 serv_request(DR_ADDSET, n*sizeof(PACKHEAD), (char *)pa);
178 free((char *)pa);
179 }
180
181
182 cbeamdel(bl, n) /* delete unwanted beam requests */
183 register struct beamcomp *bl;
184 int n;
185 {
186 register PACKHEAD *pa;
187 register int i;
188
189 if (n <= 0)
190 return;
191 pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD));
192 if (pa == NULL)
193 error(SYSTEM, "out of memory in cbeamdel");
194 for (i = 0; i < n; i++) {
195 pa[i].hd = bl[i].hd;
196 pa[i].bi = bl[i].bi;
197 pa[i].nr = 0; /* removes any request */
198 }
199 serv_request(DR_DELSET, n*sizeof(PACKHEAD), (char *)pa);
200 free((char *)pa);
201 }
202
203
204 int
205 set_voxels(vl, n) /* set new voxel array */
206 VOXL vl[8];
207 int n;
208 {
209 short wmap[256];
210 int vmap[8];
211 int comn = 0;
212 int no;
213 register int i, j;
214 /* find common voxels */
215 for (j = 0; j < 8 && voxel[j].hd >= 0; j++) {
216 vmap[j] = -1;
217 for (i = n; i--; )
218 if (!bcmp((char *)(vl+i), (char *)(voxel+j),
219 sizeof(VOXL))) {
220 vmap[j] = i;
221 comn |= 1<<i;
222 break;
223 }
224 }
225 no = comn ? j : 0; /* compute flag mapping */
226 for (i = 256; i--; ) {
227 wmap[i] = 0;
228 for (j = no; j--; )
229 if (vmap[j] >= 0 && i & 1<<j)
230 wmap[i] |= 1<<vmap[j];
231 }
232 /* fix cbeam flags */
233 for (i = ncbeams; i--; )
234 cbeam[i].wants = wmap[cbeam[i].wants];
235 /* update our voxel list */
236 bcopy((char *)vl, (char *)voxel, n*sizeof(VOXL));
237 for (j = n; j < 8; j++)
238 voxel[j].hd = -1;
239 return(comn); /* return bit array of common voxels */
240 }
241
242
243 int
244 get_voxels(vl, vp) /* find voxels corresponding to view point */
245 VOXL vl[8];
246 FVECT vp;
247 {
248 static int lastn = 0, lastd = -1;
249 int n = 0;
250 FVECT gp;
251 double d;
252 int dist, bestd = 0x7fff;
253 VOXL vox;
254 register int i, j, k;
255 /* find closest voxels */
256 for (i = 0; n < 8 && hdlist[i]; i++) {
257 hdgrid(gp, hdlist[i], vp);
258 for (j = 0; n < 8 && j < 8; j++) {
259 dist = 0;
260 for (k = 0; k < 3; k++) {
261 d = gp[k] - .5 + (j>>k & 1);
262 if (d < 0.)
263 dist += -(vox.i[k] = (int)d - 1);
264 else if ((vox.i[k] = d) >= hdlist[i]->grid[k])
265 dist += vox.i[k] -
266 hdlist[i]->grid[k] + 1;
267 }
268 if (dist > bestd) /* others were closer */
269 continue;
270 if (dist < bestd) { /* start closer list */
271 n = 0;
272 bestd = dist;
273 }
274 vox.hd = i; /* add this voxel */
275 copystruct(&vl[n], &vox);
276 n++;
277 }
278 }
279 /* warn of dangerous moves */
280 if (n < lastn && bestd >= lastd)
281 error(WARNING, "moving outside holodeck section");
282 else if (n > lastn && bestd <= lastd)
283 error(WARNING, "moving inside holodeck section");
284 lastd = bestd;
285 return(lastn = n);
286 }
287
288
289 int
290 dobeam(gcp, bp) /* express interest or disintrest in a beam */
291 GCOORD *gcp;
292 register struct beamact *bp;
293 {
294 GCOORD gc[2];
295 int bi, i;
296 /* compute beam index */
297 copystruct(gc, gcp);
298 copystruct(gc+1, &bp->gc);
299 if ((bi = hdbindex(hdlist[voxel[bp->ca.vi].hd], gc)) <= 0)
300 error(CONSISTENCY, "bad grid coordinate in dobeam");
301 if (bp->ca.add) { /* add it in */
302 i = getcbeam(voxel[bp->ca.vi].hd, bi);
303 cbeam[i].wants |= 1<<bp->ca.vi; /* say we want it */
304 return(i == ncbeams+xcbeams-1); /* return 1 if totally new */
305 }
306 /* else delete it */
307 i = findcbeam(voxel[bp->ca.vi].hd, bi);
308 if (i >= 0 && cbeam[i].wants & 1<<bp->ca.vi) {
309 cbeam[i].wants &= ~(1<<bp->ca.vi); /* we don't want it */
310 return(1); /* indicate change */
311 }
312 return(0);
313 }
314
315
316
317 int
318 docell(gcp, cap) /* find beams corresponding to cell and voxel */
319 GCOORD *gcp;
320 register struct cellact *cap;
321 {
322 FVECT org, dir[4];
323 FVECT gp, cv[4], vc;
324 struct beamact bo;
325 register int i;
326 /* compute cell vertices */
327 hdcell(cv, hdlist[voxel[cap->vi].hd], gcp);
328 /* compute cell and voxel centers */
329 for (i = 0; i < 3; i++) {
330 org[i] = 0.5*(cv[0][i] + cv[2][i]);
331 gp[i] = voxel[cap->vi].i[i] + 0.5;
332 }
333 hdworld(vc, hdlist[voxel[cap->vi].hd], gp);
334 /* compute voxel pyramid using vector trick */
335 for (i = 0; i < 3; i++) {
336 dir[0][i] = vc[i] - cv[0][i]; /* to 3 */
337 dir[2][i] = vc[i] - cv[3][i]; /* to 0 */
338 if (gcp->w & 1) { /* watch vertex order! */
339 dir[1][i] = vc[i] - cv[2][i]; /* to 1 */
340 dir[3][i] = vc[i] - cv[1][i]; /* to 2 */
341 } else {
342 dir[1][i] = vc[i] - cv[1][i]; /* to 2 */
343 dir[3][i] = vc[i] - cv[2][i]; /* to 1 */
344 }
345 }
346 /* visit beams for opposite cells */
347 copystruct(&bo.ca, cap);
348 copystruct(&bo.gc, gcp);
349 return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo));
350 }
351
352
353 int
354 doview(cap, vp) /* visit cells for a given view */
355 struct cellact *cap;
356 VIEW *vp;
357 {
358 FVECT org, dir[4];
359 /* compute view pyramid */
360 if (vp->type == VT_PAR) goto viewerr;
361 if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) goto viewerr;
362 if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) goto viewerr;
363 if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) goto viewerr;
364 if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) goto viewerr;
365 /* visit cells within pyramid */
366 return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], docell, cap));
367 viewerr:
368 error(INTERNAL, "unusable view in doview");
369 }
370
371
372 mvview(voxi, vold, vnew) /* move view for a voxel */
373 int voxi;
374 VIEW *vold, *vnew;
375 {
376 int netchange = 0;
377 int *ocl, *ncl;
378 struct cellact ca;
379 int ocnt, ncnt;
380 int c;
381 register GCOORD *ogcp, *ngcp;
382 /* get old and new cell lists */
383 ocl = getviewcells(hdlist[voxel[voxi].hd], vold);
384 ncl = getviewcells(hdlist[voxel[voxi].hd], vnew);
385 if (ocl != NULL) {
386 ocnt = *ocl; ogcp = (GCOORD *)(ocl+1);
387 } else {
388 ocnt = 0; ogcp = NULL;
389 }
390 if (ncl != NULL) {
391 ncnt = *ncl; ngcp = (GCOORD *)(ncl+1);
392 } else {
393 ncnt = 0; ngcp = NULL;
394 }
395 ca.vi = voxi; /* add and delete cells */
396 while (ocnt > 0 & ncnt > 0)
397 if ((c = cellcmp(ogcp, ngcp)) > 0) {
398 ca.add = 1; /* new cell */
399 netchange += docell(ngcp++, &ca);
400 ncnt--;
401 } else if (c < 0) {
402 ca.add = 0; /* obsolete cell */
403 netchange -= docell(ogcp++, &ca);
404 ocnt--;
405 } else {
406 ogcp++; ocnt--; /* unchanged cell */
407 ngcp++; ncnt--;
408 }
409 /* take care of list tails */
410 for (ca.add = 1; ncnt > 0; ncnt--)
411 netchange += docell(ngcp++, &ca);
412 for (ca.add = 0; ocnt > 0; ocnt--)
413 netchange -= docell(ogcp++, &ca);
414 /* clean up */
415 if (ocl != NULL) free((char *)ocl);
416 if (ncl != NULL) free((char *)ncl);
417 return(netchange);
418 }
419
420
421 beam_view(vo, vn) /* change beam view */
422 VIEW *vo, *vn;
423 {
424 struct cellact ca;
425 VOXL vlnew[8];
426 int n, comn;
427
428 if (!vn->type) { /* clear our beam list */
429 set_voxels(vlnew, 0);
430 cbeamdel(cbeam, ncbeams);
431 ncbeams = 0;
432 return;
433 }
434 /* find our new voxels */
435 n = get_voxels(vlnew, vn->vp);
436 /* set the new voxels */
437 comn = set_voxels(vlnew, n);
438 if (!vo->type)
439 comn = 0;
440 ca.add = 1; /* update our beam list */
441 for (ca.vi = n; ca.vi--; )
442 if (comn & 1<<ca.vi) /* change which cells we see */
443 mvview(ca.vi, vo, vn);
444 else /* else add all new cells */
445 doview(&ca, vn);
446 /* inform server of new beams */
447 cbeamadd(cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres);
448 /* sort list to put orphans at end */
449 cbeamsort(0);
450 /* tell server to delete orphans */
451 cbeamdel(cbeam+ncbeams, xcbeams);
452 xcbeams = 0; /* truncate our list */
453 }
