--- ray/src/hd/rhdisp2.c 1997/11/25 10:48:38 3.7 +++ ray/src/hd/rhdisp2.c 1997/12/15 20:40:46 3.15 @@ -12,6 +12,10 @@ static char SCCSid[] = "$SunId$ SGI"; #include "rhdisp.h" #include "rhdriver.h" +#ifndef MAXDIST +#define MAXDIST 42 /* maximum distance outside section */ +#endif + extern GCOORD *getviewcells(); static VIEW dvw; /* current view corresponding to beam list */ @@ -90,6 +94,8 @@ register struct beamcomp *cb1, *cb2; if (!cb1->wants) /* put orphans at the end, unsorted */ return(cb2->wants); + if (!cb2->wants) + return(-1); if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */ return(c); return(cb1->hd - cb2->hd); /* use hd to resolve matches */ @@ -158,6 +164,42 @@ int adopt; } +cbeamadj(v, hr, vr) /* adjust our beam list */ +VIEW *v; +int hr, vr; +{ + register PACKHEAD *pa; + register int i; + int n; + /* first handle additions */ + pa = (PACKHEAD *)malloc(xcbeams*sizeof(PACKHEAD)); + if (xcbeams && pa == NULL) + goto memerr; + for (i = xcbeams; i--; ) { + pa[i].hd = cbeam[ncbeams+i].hd; + pa[i].bi = cbeam[ncbeams+i].bi; + pa[i].nr = npixels(v, hr, vr, hdlist[pa[i].hd], pa[i].bi) + 1; + } + n = xcbeams; /* now sort list for deletions */ + cbeamsort(0); + pa = (PACKHEAD *)realloc((char *)pa, (n+xcbeams)*sizeof(PACKHEAD)); + if (n+xcbeams && pa == NULL) + goto memerr; + for (i = xcbeams; i--; ) { + pa[n+i].hd = cbeam[ncbeams+i].hd; + pa[n+i].bi = cbeam[ncbeams+i].bi; + pa[n+i].nr = 0; + } + n += xcbeams; + xcbeams = 0; /* delete orphans */ + serv_request(DR_ADJSET, n*sizeof(PACKHEAD), (char *)pa); + free((char *)pa); + return; +memerr: + error(SYSTEM, "out of memory in cbeamadj"); +} + + cbeamop(op, bl, n, v, hr, vr) /* update beams on server list */ int op; register struct beamcomp *bl; @@ -259,6 +301,11 @@ FVECT vp; n++; } } + /* check for really stupid move */ + if (bestd > MAXDIST) { + error(COMMAND, "move past outer limits"); + return(0); + } /* warn of dangerous moves */ if (n < lastn && bestd >= lastd) error(WARNING, "moving outside holodeck section"); @@ -307,34 +354,59 @@ docell(gcp, cap) /* find beams corresponding to cell a GCOORD *gcp; register struct cellact *cap; { + register HOLO *hp = hdlist[voxel[cap->vi].hd]; FVECT org, dir[4]; - FVECT gp, cv[4], vc; + FVECT vgp, cgp, vc; + FVECT v1, v2; struct beamact bo; + int axmax, j; + double d, avmax; register int i; - /* compute cell vertices */ - hdcell(cv, hdlist[voxel[cap->vi].hd], gcp); - /* compute cell and voxel centers */ - for (i = 0; i < 3; i++) { - org[i] = 0.5*(cv[0][i] + cv[2][i]); - gp[i] = voxel[cap->vi].i[i] + 0.5; - } - hdworld(vc, hdlist[voxel[cap->vi].hd], gp); - /* compute voxel pyramid using vector trick */ - for (i = 0; i < 3; i++) { - dir[0][i] = vc[i] - cv[0][i]; /* to 3 */ - dir[2][i] = vc[i] - cv[3][i]; /* to 0 */ - if (gcp->w & 1) { /* watch vertex order! */ - dir[1][i] = vc[i] - cv[2][i]; /* to 1 */ - dir[3][i] = vc[i] - cv[1][i]; /* to 2 */ - } else { - dir[1][i] = vc[i] - cv[1][i]; /* to 2 */ - dir[3][i] = vc[i] - cv[2][i]; /* to 1 */ + /* compute cell center */ + cgp[gcp->w>>1] = gcp->w&1 ? hp->grid[gcp->w>>1] : 0 ; + cgp[((gcp->w>>1)+1)%3] = gcp->i[0] + .5; + cgp[((gcp->w>>1)+2)%3] = gcp->i[1] + .5; + hdworld(org, hp, cgp); + /* compute direction to voxel center */ + for (i = 3; i--; ) + vgp[i] = voxel[cap->vi].i[i] + .5; + hdworld(vc, hp, vgp); + for (i = 3; i--; ) + vc[i] -= org[i]; + /* compute maximum area axis */ + axmax = -1; avmax = 0; + for (i = 3; i--; ) { + d = vgp[i] - cgp[i]; + if (d < 0.) d = -d; + if (d > avmax) { + avmax = d; + axmax = i; } } +#ifdef DEBUG + if (axmax < 0.) + error(CONSISTENCY, "botched axis computation in docell"); +#endif + /* compute offset vectors */ + d = 0.5/hp->grid[j=(axmax+1)%3]; + for (i = 3; i--; ) + v1[i] = hp->xv[j][i] * d; + d = 0.5/hp->grid[j=(axmax+2)%3]; + if (DOT(hp->wn[axmax], vc) < 0.) + d = -d; /* reverse vertex ordering */ + for (i = 3; i--; ) + v2[i] = hp->xv[j][i] * d; + /* compute voxel pyramid */ + for (i = 3; i--; ) { + dir[0][i] = vc[i] - v1[i] - v2[i]; + dir[1][i] = vc[i] + v1[i] - v2[i]; + dir[2][i] = vc[i] + v1[i] + v2[i]; + dir[3][i] = vc[i] - v1[i] + v2[i]; + } /* visit beams for opposite cells */ copystruct(&bo.ca, cap); copystruct(&bo.gc, gcp); - return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo)); + return(visit_cells(org, dir, hp, dobeam, &bo)); } @@ -370,7 +442,6 @@ VIEW *vold, *vnew; ngcp = ngcl = getviewcells(&ncnt, hdlist[voxel[voxi].hd], vnew); /* set up actions */ oca.vi = nca.vi = voxi; - oca.rev = nca.rev = 0; oca.add = 0; nca.add = 1; if ((oca.rev = ocnt < 0)) ocnt = -ocnt; @@ -400,28 +471,34 @@ VIEW *vold, *vnew; } +int beam_sync() /* synchronize beams on server */ { cbeamop(DR_NEWSET, cbeam, ncbeams, &odev.v, odev.hres, odev.vres); + return(ncbeams); } -beam_view(vn) /* change beam view */ +beam_view(vn) /* change beam view (if advisable) */ VIEW *vn; { struct cellact ca; VOXL vlnew[8]; int n, comn; - if (!vn->type) { /* clear our beam list */ + if (vn == NULL || !vn->type) { /* clear our beam list */ set_voxels(vlnew, 0); cbeamop(DR_DELSET, cbeam, ncbeams, NULL, 0, 0); ncbeams = 0; - copystruct(&dvw, vn); - return; + dvw.type = 0; + return(1); } /* find our new voxels */ n = get_voxels(vlnew, vn->vp); + if (dvw.type && !n) { + copystruct(vn, &dvw); /* cancel move */ + return(0); + } /* set the new voxels */ comn = set_voxels(vlnew, n); if (!dvw.type) @@ -432,6 +509,9 @@ VIEW *vn; mvview(ca.vi, &dvw, vn); else /* else add all new cells */ doview(&ca, vn); +#if 1 + cbeamadj(vn, odev.hres, odev.vres); +#else /* inform server of new beams */ cbeamop(DR_ADDSET, cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres); /* sort list to put orphans at end */ @@ -439,5 +519,7 @@ VIEW *vn; /* tell server to delete orphans */ cbeamop(DR_DELSET, cbeam+ncbeams, xcbeams, NULL, 0, 0); xcbeams = 0; /* truncate our list */ +#endif copystruct(&dvw, vn); /* record new view */ + return(1); }
