1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Holodeck beam tracking for display process |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "rhdisp.h" |
13 |
#include "rhdriver.h" |
14 |
15 |
#ifndef MAXDIST |
16 |
#define MAXDIST 42 /* maximum distance outside section */ |
17 |
#endif |
18 |
19 |
extern GCOORD *getviewcells(); |
20 |
21 |
static VIEW dvw; /* current view corresponding to beam list */ |
22 |
23 |
typedef struct { |
24 |
int hd; /* holodeck section number (-1 if inactive) */ |
25 |
int i[3]; /* voxel index (may be outside section) */ |
26 |
} VOXL; /* a voxel */ |
27 |
28 |
static VOXL voxel[8] = { /* current voxel list */ |
29 |
{-1}, {-1}, {-1}, {-1}, |
30 |
{-1}, {-1}, {-1}, {-1} |
31 |
32 |
33 |
#define CBEAMBLK 1024 /* cbeam allocation block size */ |
34 |
35 |
static struct beamcomp { |
36 |
short wants; /* flags telling which voxels want us */ |
37 |
short hd; /* holodeck section number */ |
38 |
int bi; /* beam index */ |
39 |
} *cbeam = NULL; /* current beam list */ |
40 |
41 |
static int ncbeams = 0; /* number of sorted beams in cbeam */ |
42 |
static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */ |
43 |
static int maxcbeam = 0; /* size of cbeam array */ |
44 |
45 |
struct cellact { |
46 |
short vi; /* voxel index */ |
47 |
short add; /* zero means delete */ |
48 |
short rev; /* reverse ray direction? */ |
49 |
}; /* action for cell */ |
50 |
51 |
struct beamact { |
52 |
struct cellact ca; /* cell action */ |
53 |
GCOORD gc; /* grid coordinate */ |
54 |
}; /* beam origin and action */ |
55 |
56 |
57 |
int |
58 |
newcbeam() /* allocate new entry at end of cbeam array */ |
59 |
60 |
int i; |
61 |
62 |
if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */ |
63 |
maxcbeam += CBEAMBLK; |
64 |
if (cbeam == NULL) |
65 |
cbeam = (struct beamcomp *)malloc( |
66 |
maxcbeam*sizeof(struct beamcomp) ); |
67 |
else |
68 |
cbeam = (struct beamcomp *)realloc( (char *)cbeam, |
69 |
70 |
71 |
error(SYSTEM, "out of memory in newcbeam"); |
72 |
73 |
return(i); |
74 |
75 |
76 |
77 |
int |
78 |
cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */ |
79 |
register struct beamcomp *cb1, *cb2; |
80 |
81 |
register int c; |
82 |
83 |
if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */ |
84 |
return(c); |
85 |
return(cb1->hd - cb2->hd); /* use hd to resolve matches */ |
86 |
87 |
88 |
89 |
int |
90 |
cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */ |
91 |
92 |
93 |
register int c; |
94 |
95 |
if (!cb1->wants) /* put orphans at the end, unsorted */ |
96 |
return(cb2->wants); |
97 |
if (!cb2->wants) |
98 |
return(-1); |
99 |
100 |
return(c); |
101 |
102 |
103 |
104 |
105 |
int |
106 |
findcbeam(hd, bi) /* find the specified beam in our sorted list */ |
107 |
int hd, bi; |
108 |
109 |
struct beamcomp cb; |
110 |
register struct beamcomp *p; |
111 |
112 |
if (ncbeams <= 0) |
113 |
return(-1); |
114 |
cb.wants = 0; cb.hd = hd; cb.bi = bi; |
115 |
p = (struct beamcomp *)bsearch((char *)&cb, (char *)cbeam, ncbeams, |
116 |
sizeof(struct beamcomp), cbeamcmp); |
117 |
if (p == NULL) |
118 |
return(-1); |
119 |
return(p - cbeam); |
120 |
121 |
122 |
123 |
int |
124 |
getcbeam(hd, bi) /* get the specified beam, allocating as necessary */ |
125 |
register int hd; |
126 |
int bi; |
127 |
128 |
register int n; |
129 |
/* first, look in sorted list */ |
130 |
if ((n = findcbeam(hd, bi)) >= 0) |
131 |
return(n); |
132 |
/* linear search through xcbeams to be sure */ |
133 |
for (n = ncbeams+xcbeams; n-- > ncbeams; ) |
134 |
if (cbeam[n].bi == bi && cbeam[n].hd == hd) |
135 |
return(n); |
136 |
/* check legality */ |
137 |
if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL) |
138 |
error(INTERNAL, "illegal holodeck number in getcbeam"); |
139 |
if (bi < 1 | bi > nbeams(hdlist[hd])) |
140 |
error(INTERNAL, "illegal beam index in getcbeam"); |
141 |
n = newcbeam(); /* allocate and assign */ |
142 |
cbeam[n].wants = 0; cbeam[n].hd = hd; cbeam[n].bi = bi; |
143 |
return(n); |
144 |
145 |
146 |
147 |
cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */ |
148 |
int adopt; |
149 |
150 |
register int i; |
151 |
152 |
if (!(ncbeams += xcbeams)) |
153 |
return; |
154 |
xcbeams = 0; |
155 |
qsort((char *)cbeam, ncbeams, sizeof(struct beamcomp), |
156 |
adopt ? cbeamcmp : cbeamcmp2); |
157 |
if (adopt) |
158 |
return; |
159 |
for (i = ncbeams; i--; ) /* identify orphans */ |
160 |
if (cbeam[i].wants) |
161 |
break; |
162 |
xcbeams = ncbeams - ++i; /* put orphans after ncbeams */ |
163 |
ncbeams = i; |
164 |
165 |
166 |
167 |
cbeamop(op, bl, n, v, hr, vr) /* update beams on server list */ |
168 |
int op; |
169 |
register struct beamcomp *bl; |
170 |
int n; |
171 |
VIEW *v; |
172 |
int hr, vr; |
173 |
174 |
register PACKHEAD *pa; |
175 |
register int i; |
176 |
177 |
if (n <= 0) |
178 |
return; |
179 |
pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD)); |
180 |
if (pa == NULL) |
181 |
error(SYSTEM, "out of memory in cbeamadd"); |
182 |
for (i = 0; i < n; i++) { |
183 |
pa[i].hd = bl[i].hd; |
184 |
pa[i].bi = bl[i].bi; |
185 |
pa[i].nr = v==NULL ? 0 : |
186 |
npixels(v, hr, vr, hdlist[bl[i].hd], bl[i].bi); |
187 |
pa[i].nc = 0; |
188 |
189 |
serv_request(op, n*sizeof(PACKHEAD), (char *)pa); |
190 |
free((char *)pa); |
191 |
192 |
193 |
194 |
int |
195 |
set_voxels(vl, n) /* set new voxel array */ |
196 |
VOXL vl[8]; |
197 |
int n; |
198 |
199 |
short wmap[256]; |
200 |
int vmap[8]; |
201 |
int comn = 0; |
202 |
int no; |
203 |
register int i, j; |
204 |
/* find common voxels */ |
205 |
for (j = 0; j < 8 && voxel[j].hd >= 0; j++) { |
206 |
vmap[j] = -1; |
207 |
for (i = n; i--; ) |
208 |
if (!bcmp((char *)(vl+i), (char *)(voxel+j), |
209 |
sizeof(VOXL))) { |
210 |
vmap[j] = i; |
211 |
comn |= 1<<i; |
212 |
break; |
213 |
214 |
215 |
no = comn ? j : 0; /* compute flag mapping */ |
216 |
for (i = 256; i--; ) { |
217 |
wmap[i] = 0; |
218 |
for (j = no; j--; ) |
219 |
if (vmap[j] >= 0 && i & 1<<j) |
220 |
wmap[i] |= 1<<vmap[j]; |
221 |
222 |
/* fix cbeam flags */ |
223 |
for (i = ncbeams; i--; ) |
224 |
cbeam[i].wants = wmap[cbeam[i].wants]; |
225 |
/* update our voxel list */ |
226 |
bcopy((char *)vl, (char *)voxel, n*sizeof(VOXL)); |
227 |
for (j = n; j < 8; j++) |
228 |
voxel[j].hd = -1; |
229 |
return(comn); /* return bit array of common voxels */ |
230 |
231 |
232 |
233 |
int |
234 |
get_voxels(vl, vp) /* find voxels corresponding to view point */ |
235 |
VOXL vl[8]; |
236 |
FVECT vp; |
237 |
238 |
int n = 0; |
239 |
FVECT gp; |
240 |
double d; |
241 |
int dist, bestd = 0x7fff; |
242 |
VOXL vox; |
243 |
register int i, j, k; |
244 |
/* find closest voxels */ |
245 |
for (i = 0; n < 8 && hdlist[i]; i++) { |
246 |
hdgrid(gp, hdlist[i], vp); |
247 |
for (j = 0; n < 8 && j < 8; j++) { |
248 |
dist = 0; |
249 |
for (k = 0; k < 3; k++) { |
250 |
d = gp[k] - .5 + (j>>k & 1); |
251 |
if (d < 0.) |
252 |
dist += -(vox.i[k] = (int)d - 1); |
253 |
else if ((vox.i[k] = d) >= hdlist[i]->grid[k]) |
254 |
dist += vox.i[k] - |
255 |
hdlist[i]->grid[k] + 1; |
256 |
257 |
if (dist > bestd) /* others were closer */ |
258 |
continue; |
259 |
if (dist < bestd) { /* start closer list */ |
260 |
n = 0; |
261 |
bestd = dist; |
262 |
263 |
vox.hd = i; /* add this voxel */ |
264 |
copystruct(&vl[n], &vox); |
265 |
n++; |
266 |
267 |
268 |
/* check for really stupid move */ |
269 |
if (bestd > MAXDIST) { |
270 |
error(COMMAND, "move past outer limits"); |
271 |
return(0); |
272 |
273 |
return(n); |
274 |
275 |
276 |
277 |
int |
278 |
dobeam(gcp, bp) /* express interest or disintrest in a beam */ |
279 |
GCOORD *gcp; |
280 |
register struct beamact *bp; |
281 |
282 |
GCOORD gc[2]; |
283 |
int bi, i; |
284 |
/* compute beam index */ |
285 |
if (bp->ca.rev) { |
286 |
copystruct(gc, &bp->gc); |
287 |
copystruct(gc+1, gcp); |
288 |
} else { |
289 |
copystruct(gc, gcp); |
290 |
copystruct(gc+1, &bp->gc); |
291 |
292 |
if ((bi = hdbindex(hdlist[voxel[bp->ca.vi].hd], gc)) <= 0) |
293 |
error(CONSISTENCY, "bad grid coordinate in dobeam"); |
294 |
if (bp->ca.add) { /* add it in */ |
295 |
i = getcbeam(voxel[bp->ca.vi].hd, bi); |
296 |
cbeam[i].wants |= 1<<bp->ca.vi; /* say we want it */ |
297 |
return(i == ncbeams+xcbeams-1); /* return 1 if totally new */ |
298 |
299 |
/* else delete it */ |
300 |
i = findcbeam(voxel[bp->ca.vi].hd, bi); |
301 |
if (i >= 0 && cbeam[i].wants & 1<<bp->ca.vi) { |
302 |
cbeam[i].wants &= ~(1<<bp->ca.vi); /* we don't want it */ |
303 |
return(1); /* indicate change */ |
304 |
305 |
return(0); |
306 |
307 |
308 |
309 |
310 |
int |
311 |
docell(gcp, cap) /* find beams corresponding to cell and voxel */ |
312 |
GCOORD *gcp; |
313 |
register struct cellact *cap; |
314 |
315 |
register HOLO *hp = hdlist[voxel[cap->vi].hd]; |
316 |
FVECT org, dir[4]; |
317 |
FVECT vgp, cgp, vc; |
318 |
FVECT v1, v2; |
319 |
struct beamact bo; |
320 |
int axmax, j; |
321 |
double d, avmax; |
322 |
register int i; |
323 |
/* compute cell center */ |
324 |
cgp[gcp->w>>1] = gcp->w&1 ? hp->grid[gcp->w>>1] : 0 ; |
325 |
cgp[hdwg0[gcp->w]] = gcp->i[0] + .5; |
326 |
cgp[hdwg1[gcp->w]] = gcp->i[1] + .5; |
327 |
hdworld(org, hp, cgp); |
328 |
/* compute direction to voxel center */ |
329 |
for (i = 3; i--; ) |
330 |
vgp[i] = voxel[cap->vi].i[i] + .5; |
331 |
hdworld(vc, hp, vgp); |
332 |
333 |
vc[i] -= org[i]; |
334 |
/* compute maximum area axis */ |
335 |
axmax = -1; avmax = 0; |
336 |
for (i = 3; i--; ) { |
337 |
d = vgp[i] - cgp[i]; |
338 |
if (d < 0.) d = -d; |
339 |
if (d > avmax) { |
340 |
avmax = d; |
341 |
axmax = i; |
342 |
343 |
344 |
#ifdef DEBUG |
345 |
if (axmax < 0.) |
346 |
error(CONSISTENCY, "botched axis computation in docell"); |
347 |
#endif |
348 |
/* compute offset vectors */ |
349 |
d = 0.5/hp->grid[j=(axmax+1)%3]; |
350 |
351 |
v1[i] = hp->xv[j][i] * d; |
352 |
d = 0.5/hp->grid[j=(axmax+2)%3]; |
353 |
if (DOT(hp->wg[axmax], vc) < 0.) |
354 |
d = -d; /* reverse vertex order */ |
355 |
356 |
v2[i] = hp->xv[j][i] * d; |
357 |
/* compute voxel pyramid */ |
358 |
359 |
dir[0][i] = vc[i] - v1[i] - v2[i]; |
360 |
dir[1][i] = vc[i] + v1[i] - v2[i]; |
361 |
dir[2][i] = vc[i] + v1[i] + v2[i]; |
362 |
dir[3][i] = vc[i] - v1[i] + v2[i]; |
363 |
364 |
/* visit beams for opposite cells */ |
365 |
copystruct(&bo.ca, cap); |
366 |
copystruct(&bo.gc, gcp); |
367 |
return(visit_cells(org, dir, hp, dobeam, &bo)); |
368 |
369 |
370 |
371 |
int |
372 |
doview(cap, vp) /* visit cells for a given view */ |
373 |
374 |
VIEW *vp; |
375 |
376 |
int orient; |
377 |
378 |
/* compute view pyramid */ |
379 |
orient = viewpyramid(org, dir, hdlist[voxel[cap->vi].hd], vp); |
380 |
if (!orient) |
381 |
error(INTERNAL, "unusable view in doview"); |
382 |
cap->rev = orient < 0; |
383 |
/* visit cells within pyramid */ |
384 |
return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], docell, cap)); |
385 |
386 |
387 |
388 |
mvview(voxi, vold, vnew) /* move view for a voxel */ |
389 |
int voxi; |
390 |
VIEW *vold, *vnew; |
391 |
392 |
int netchange = 0; |
393 |
struct cellact oca, nca; |
394 |
int ocnt, ncnt; |
395 |
int c; |
396 |
GCOORD *ogcl, *ngcl; |
397 |
register GCOORD *ogcp, *ngcp; |
398 |
/* get old and new cell lists */ |
399 |
ogcp = ogcl = getviewcells(&ocnt, hdlist[voxel[voxi].hd], vold); |
400 |
ngcp = ngcl = getviewcells(&ncnt, hdlist[voxel[voxi].hd], vnew); |
401 |
/* set up actions */ |
402 |
oca.vi = nca.vi = voxi; |
403 |
oca.add = 0; nca.add = 1; |
404 |
if ((oca.rev = ocnt < 0)) |
405 |
ocnt = -ocnt; |
406 |
if ((nca.rev = ncnt < 0)) |
407 |
ncnt = -ncnt; |
408 |
if (nca.rev == oca.rev) /* add and delete cells in order */ |
409 |
while (ocnt > 0 & ncnt > 0) |
410 |
if ((c = cellcmp(ogcp, ngcp)) > 0) { /* new cell */ |
411 |
netchange += docell(ngcp++, &nca); |
412 |
ncnt--; |
413 |
} else if (c < 0) { /* old cell */ |
414 |
netchange -= docell(ogcp++, &oca); |
415 |
ocnt--; |
416 |
} else { /* same cell */ |
417 |
ogcp++; ocnt--; |
418 |
ngcp++; ncnt--; |
419 |
420 |
/* take care of list tails */ |
421 |
for ( ; ncnt > 0; ncnt--) |
422 |
423 |
for ( ; ocnt > 0; ocnt--) |
424 |
425 |
/* clean up */ |
426 |
if (ogcl != NULL) free((char *)ogcl); |
427 |
if (ngcl != NULL) free((char *)ngcl); |
428 |
return(netchange); |
429 |
430 |
431 |
432 |
int |
433 |
beam_sync() /* synchronize beams on server */ |
434 |
435 |
cbeamop(DR_NEWSET, cbeam, ncbeams, &odev.v, odev.hres, odev.vres); |
436 |
return(ncbeams); |
437 |
438 |
439 |
440 |
beam_view(vn) /* change beam view (if advisable) */ |
441 |
VIEW *vn; |
442 |
443 |
struct cellact ca; |
444 |
VOXL vlnew[8]; |
445 |
int n, comn; |
446 |
447 |
if (vn == NULL || !vn->type) { /* clear our beam list */ |
448 |
set_voxels(vlnew, 0); |
449 |
cbeamop(DR_DELSET, cbeam, ncbeams, NULL, 0, 0); |
450 |
ncbeams = 0; |
451 |
dvw.type = 0; |
452 |
return(1); |
453 |
454 |
/* find our new voxels */ |
455 |
n = get_voxels(vlnew, vn->vp); |
456 |
if (dvw.type && !n) { |
457 |
copystruct(vn, &dvw); /* cancel move */ |
458 |
return(0); |
459 |
460 |
/* set the new voxels */ |
461 |
comn = set_voxels(vlnew, n); |
462 |
if (!dvw.type) |
463 |
comn = 0; |
464 |
ca.add = 1; /* update our beam list */ |
465 |
for (ca.vi = n; ca.vi--; ) |
466 |
if (comn & 1<<ca.vi) /* change which cells we see */ |
467 |
mvview(ca.vi, &dvw, vn); |
468 |
else /* else add all new cells */ |
469 |
doview(&ca, vn); |
470 |
/* inform server of new beams */ |
471 |
cbeamop(DR_ADDSET, cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres); |
472 |
/* sort list to put orphans at end */ |
473 |
cbeamsort(0); |
474 |
/* tell server to delete orphans */ |
475 |
cbeamop(DR_DELSET, cbeam+ncbeams, xcbeams, NULL, 0, 0); |
476 |
xcbeams = 0; /* truncate our list */ |
477 |
copystruct(&dvw, vn); /* record new view */ |
478 |
return(1); |
479 |
