--- ray/src/hd/rhdisp2.c 1997/11/24 15:17:28 3.6 +++ ray/src/hd/rhdisp2.c 1997/12/11 09:36:59 3.12 @@ -12,8 +12,14 @@ static char SCCSid[] = "$SunId$ SGI"; #include "rhdisp.h" #include "rhdriver.h" +#ifndef MAXDIST +#define MAXDIST 13 /* maximum distance outside section */ +#endif + extern GCOORD *getviewcells(); +static VIEW dvw; /* current view corresponding to beam list */ + typedef struct { int hd; /* holodeck section number (-1 if inactive) */ int i[3]; /* voxel index (may be outside section) */ @@ -156,6 +162,42 @@ int adopt; } +cbeamadj(v, hr, vr) /* adjust our beam list */ +VIEW *v; +int hr, vr; +{ + register PACKHEAD *pa; + register int i; + int n; + /* first handle additions */ + pa = (PACKHEAD *)malloc(xcbeams*sizeof(PACKHEAD)); + if (xcbeams && pa == NULL) + goto memerr; + for (i = xcbeams; i--; ) { + pa[i].hd = cbeam[ncbeams+i].hd; + pa[i].bi = cbeam[ncbeams+i].bi; + pa[i].nr = npixels(v, hr, vr, hdlist[pa[i].hd], pa[i].bi) + 1; + } + n = xcbeams; /* now sort list for deletions */ + cbeamsort(0); + pa = (PACKHEAD *)realloc((char *)pa, (n+xcbeams)*sizeof(PACKHEAD)); + if (n+xcbeams && pa == NULL) + goto memerr; + for (i = xcbeams; i--; ) { + pa[n+i].hd = cbeam[ncbeams+i].hd; + pa[n+i].bi = cbeam[ncbeams+i].bi; + pa[n+i].nr = 0; + } + n += xcbeams; + xcbeams = 0; /* delete orphans */ + serv_request(DR_ADJSET, n*sizeof(PACKHEAD), (char *)pa); + free((char *)pa); + return; +memerr: + error(SYSTEM, "out of memory in cbeamadj"); +} + + cbeamop(op, bl, n, v, hr, vr) /* update beams on server list */ int op; register struct beamcomp *bl; @@ -257,6 +299,11 @@ FVECT vp; n++; } } + /* check for really stupid move */ + if (bestd > MAXDIST) { + error(COMMAND, "move past outer limits"); + return(0); + } /* warn of dangerous moves */ if (n < lastn && bestd >= lastd) error(WARNING, "moving outside holodeck section"); @@ -305,34 +352,59 @@ docell(gcp, cap) /* find beams corresponding to cell a GCOORD *gcp; register struct cellact *cap; { + register HOLO *hp = hdlist[voxel[cap->vi].hd]; FVECT org, dir[4]; - FVECT gp, cv[4], vc; + FVECT vgp, cgp, vc; + FVECT v1, v2; struct beamact bo; + int axmax, j; + double d, avmax; register int i; - /* compute cell vertices */ - hdcell(cv, hdlist[voxel[cap->vi].hd], gcp); - /* compute cell and voxel centers */ - for (i = 0; i < 3; i++) { - org[i] = 0.5*(cv[0][i] + cv[2][i]); - gp[i] = voxel[cap->vi].i[i] + 0.5; - } - hdworld(vc, hdlist[voxel[cap->vi].hd], gp); - /* compute voxel pyramid using vector trick */ - for (i = 0; i < 3; i++) { - dir[0][i] = vc[i] - cv[0][i]; /* to 3 */ - dir[2][i] = vc[i] - cv[3][i]; /* to 0 */ - if (gcp->w & 1) { /* watch vertex order! */ - dir[1][i] = vc[i] - cv[2][i]; /* to 1 */ - dir[3][i] = vc[i] - cv[1][i]; /* to 2 */ - } else { - dir[1][i] = vc[i] - cv[1][i]; /* to 2 */ - dir[3][i] = vc[i] - cv[2][i]; /* to 1 */ + /* compute cell center */ + cgp[gcp->w>>1] = gcp->w&1 ? hp->grid[gcp->w>>1] : 0 ; + cgp[((gcp->w>>1)+1)%3] = gcp->i[0] + .5; + cgp[((gcp->w>>1)+2)%3] = gcp->i[1] + .5; + hdworld(org, hp, cgp); + /* compute direction to voxel center */ + for (i = 3; i--; ) + vgp[i] = voxel[cap->vi].i[i] + .5; + hdworld(vc, hp, vgp); + for (i = 3; i--; ) + vc[i] -= org[i]; + /* compute maximum area axis */ + axmax = -1; avmax = 0; + for (i = 3; i--; ) { + d = vgp[i] - cgp[i]; + if (d < 0.) d = -d; + if (d > avmax) { + avmax = d; + axmax = i; } } +#ifdef DEBUG + if (axmax < 0.) + error(CONSISTENCY, "botched axis computation in docell"); +#endif + /* compute offset vectors */ + d = 0.5/hp->grid[j=(axmax+1)%3]; + for (i = 3; i--; ) + v1[i] = hp->xv[j][i] * d; + d = 0.5/hp->grid[j=(axmax+2)%3]; + if (DOT(hp->wn[axmax], vc) < 0.) + d = -d; /* reverse vertex ordering */ + for (i = 3; i--; ) + v2[i] = hp->xv[j][i] * d; + /* compute voxel pyramid */ + for (i = 3; i--; ) { + dir[0][i] = vc[i] - v1[i] - v2[i]; + dir[1][i] = vc[i] + v1[i] - v2[i]; + dir[2][i] = vc[i] + v1[i] + v2[i]; + dir[3][i] = vc[i] - v1[i] + v2[i]; + } /* visit beams for opposite cells */ copystruct(&bo.ca, cap); copystruct(&bo.gc, gcp); - return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo)); + return(visit_cells(org, dir, hp, dobeam, &bo)); } @@ -361,13 +433,13 @@ VIEW *vold, *vnew; struct cellact oca, nca; int ocnt, ncnt; int c; + GCOORD *ogcl, *ngcl; register GCOORD *ogcp, *ngcp; /* get old and new cell lists */ - ogcp = getviewcells(&ocnt, hdlist[voxel[voxi].hd], vold); - ngcp = getviewcells(&ncnt, hdlist[voxel[voxi].hd], vnew); + ogcp = ogcl = getviewcells(&ocnt, hdlist[voxel[voxi].hd], vold); + ngcp = ngcl = getviewcells(&ncnt, hdlist[voxel[voxi].hd], vnew); /* set up actions */ oca.vi = nca.vi = voxi; - oca.rev = nca.rev = 0; oca.add = 0; nca.add = 1; if ((oca.rev = ocnt < 0)) ocnt = -ocnt; @@ -391,20 +463,22 @@ VIEW *vold, *vnew; for ( ; ocnt > 0; ocnt--) netchange -= docell(ogcp++, &oca); /* clean up */ - if (ogcp != NULL) free((char *)ogcp); - if (ngcp != NULL) free((char *)ngcp); + if (ogcl != NULL) free((char *)ogcl); + if (ngcl != NULL) free((char *)ngcl); return(netchange); } +int beam_sync() /* synchronize beams on server */ { cbeamop(DR_NEWSET, cbeam, ncbeams, &odev.v, odev.hres, odev.vres); + return(ncbeams); } -beam_view(vo, vn) /* change beam view */ -VIEW *vo, *vn; +beam_view(vn) /* change beam view (if advisable) */ +VIEW *vn; { struct cellact ca; VOXL vlnew[8]; @@ -414,20 +488,28 @@ VIEW *vo, *vn; set_voxels(vlnew, 0); cbeamop(DR_DELSET, cbeam, ncbeams, NULL, 0, 0); ncbeams = 0; - return; + copystruct(&dvw, vn); + return(1); } /* find our new voxels */ n = get_voxels(vlnew, vn->vp); + if (dvw.type && !n) { + copystruct(vn, &dvw); /* cancel move */ + return(0); + } /* set the new voxels */ comn = set_voxels(vlnew, n); - if (!vo->type) + if (!dvw.type) comn = 0; ca.add = 1; /* update our beam list */ for (ca.vi = n; ca.vi--; ) if (comn & 1<
