--- ray/src/hd/rhdisp2.c 1997/12/02 15:02:37 3.8 +++ ray/src/hd/rhdisp2.c 1998/01/07 16:04:14 3.19 @@ -1,4 +1,4 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint static char SCCSid[] = "$SunId$ SGI"; @@ -12,6 +12,10 @@ static char SCCSid[] = "$SunId$ SGI"; #include "rhdisp.h" #include "rhdriver.h" +#ifndef MAXDIST +#define MAXDIST 42 /* maximum distance outside section */ +#endif + extern GCOORD *getviewcells(); static VIEW dvw; /* current view corresponding to beam list */ @@ -90,6 +94,8 @@ register struct beamcomp *cb1, *cb2; if (!cb1->wants) /* put orphans at the end, unsorted */ return(cb2->wants); + if (!cb2->wants) + return(-1); if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */ return(c); return(cb1->hd - cb2->hd); /* use hd to resolve matches */ @@ -158,42 +164,6 @@ int adopt; } -cbeamadj(v, hr, vr) /* adjust our beam list */ -VIEW *v; -int hr, vr; -{ - register PACKHEAD *pa; - register int i; - int n; - /* first handle additions */ - pa = (PACKHEAD *)malloc(xcbeams*sizeof(PACKHEAD)); - if (xcbeams && pa == NULL) - goto memerr; - for (i = xcbeams; i--; ) { - pa[i].hd = cbeam[ncbeams+i].hd; - pa[i].bi = cbeam[ncbeams+i].bi; - pa[i].nr = npixels(v, hr, vr, hdlist[pa[i].hd], pa[i].bi); - } - n = xcbeams; /* now sort list for deletions */ - cbeamsort(0); - pa = (PACKHEAD *)realloc((char *)pa, (n+xcbeams)*sizeof(PACKHEAD)); - if (n+xcbeams && pa == NULL) - goto memerr; - for (i = xcbeams; i--; ) { - pa[n+i].hd = cbeam[ncbeams+i].hd; - pa[n+i].bi = cbeam[ncbeams+i].bi; - pa[n+i].nr = 0; - } - n += xcbeams; - xcbeams = 0; /* delete orphans */ - serv_request(DR_ADJSET, n*sizeof(PACKHEAD), (char *)pa); - free((char *)pa); - return; -memerr: - error(SYSTEM, "out of memory in cbeamadj"); -} - - cbeamop(op, bl, n, v, hr, vr) /* update beams on server list */ int op; register struct beamcomp *bl; @@ -214,6 +184,7 @@ int hr, vr; pa[i].bi = bl[i].bi; pa[i].nr = v==NULL ? 0 : npixels(v, hr, vr, hdlist[bl[i].hd], bl[i].bi); + pa[i].nc = 0; } serv_request(op, n*sizeof(PACKHEAD), (char *)pa); free((char *)pa); @@ -264,7 +235,6 @@ get_voxels(vl, vp) /* find voxels corresponding to vie VOXL vl[8]; FVECT vp; { - static int lastn = 0, lastd = -1; int n = 0; FVECT gp; double d; @@ -295,13 +265,12 @@ FVECT vp; n++; } } - /* warn of dangerous moves */ - if (n < lastn && bestd >= lastd) - error(WARNING, "moving outside holodeck section"); - else if (n > lastn && bestd <= lastd) - error(WARNING, "moving inside holodeck section"); - lastd = bestd; - return(lastn = n); + /* check for really stupid move */ + if (bestd > MAXDIST) { + error(COMMAND, "move past outer limits"); + return(0); + } + return(n); } @@ -343,34 +312,59 @@ docell(gcp, cap) /* find beams corresponding to cell a GCOORD *gcp; register struct cellact *cap; { + register HOLO *hp = hdlist[voxel[cap->vi].hd]; FVECT org, dir[4]; - FVECT gp, cv[4], vc; + FVECT vgp, cgp, vc; + FVECT v1, v2; struct beamact bo; + int axmax, j; + double d, avmax; register int i; - /* compute cell vertices */ - hdcell(cv, hdlist[voxel[cap->vi].hd], gcp); - /* compute cell and voxel centers */ - for (i = 0; i < 3; i++) { - org[i] = 0.5*(cv[0][i] + cv[2][i]); - gp[i] = voxel[cap->vi].i[i] + 0.5; - } - hdworld(vc, hdlist[voxel[cap->vi].hd], gp); - /* compute voxel pyramid using vector trick */ - for (i = 0; i < 3; i++) { - dir[0][i] = vc[i] - cv[0][i]; /* to 3 */ - dir[2][i] = vc[i] - cv[3][i]; /* to 0 */ - if (gcp->w & 1) { /* watch vertex order! */ - dir[1][i] = vc[i] - cv[2][i]; /* to 1 */ - dir[3][i] = vc[i] - cv[1][i]; /* to 2 */ - } else { - dir[1][i] = vc[i] - cv[1][i]; /* to 2 */ - dir[3][i] = vc[i] - cv[2][i]; /* to 1 */ + /* compute cell center */ + cgp[gcp->w>>1] = gcp->w&1 ? hp->grid[gcp->w>>1] : 0 ; + cgp[hdwg0[gcp->w]] = gcp->i[0] + .5; + cgp[hdwg1[gcp->w]] = gcp->i[1] + .5; + hdworld(org, hp, cgp); + /* compute direction to voxel center */ + for (i = 3; i--; ) + vgp[i] = voxel[cap->vi].i[i] + .5; + hdworld(vc, hp, vgp); + for (i = 3; i--; ) + vc[i] -= org[i]; + /* compute maximum area axis */ + axmax = -1; avmax = 0; + for (i = 3; i--; ) { + d = vgp[i] - cgp[i]; + if (d < 0.) d = -d; + if (d > avmax) { + avmax = d; + axmax = i; } } +#ifdef DEBUG + if (axmax < 0.) + error(CONSISTENCY, "botched axis computation in docell"); +#endif + /* compute offset vectors */ + d = 0.5/hp->grid[j=(axmax+1)%3]; + for (i = 3; i--; ) + v1[i] = hp->xv[j][i] * d; + d = 0.5/hp->grid[j=(axmax+2)%3]; + if (DOT(hp->wg[axmax], vc) < 0.) + d = -d; /* reverse vertex order */ + for (i = 3; i--; ) + v2[i] = hp->xv[j][i] * d; + /* compute voxel pyramid */ + for (i = 3; i--; ) { + dir[0][i] = vc[i] - v1[i] - v2[i]; + dir[1][i] = vc[i] + v1[i] - v2[i]; + dir[2][i] = vc[i] + v1[i] + v2[i]; + dir[3][i] = vc[i] - v1[i] + v2[i]; + } /* visit beams for opposite cells */ copystruct(&bo.ca, cap); copystruct(&bo.gc, gcp); - return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo)); + return(visit_cells(org, dir, hp, dobeam, &bo)); } @@ -398,32 +392,51 @@ VIEW *vold, *vnew; int netchange = 0; struct cellact oca, nca; int ocnt, ncnt; - int c; + int nmatch = 0; GCOORD *ogcl, *ngcl; + register int c; register GCOORD *ogcp, *ngcp; /* get old and new cell lists */ ogcp = ogcl = getviewcells(&ocnt, hdlist[voxel[voxi].hd], vold); ngcp = ngcl = getviewcells(&ncnt, hdlist[voxel[voxi].hd], vnew); /* set up actions */ oca.vi = nca.vi = voxi; - oca.rev = nca.rev = 0; oca.add = 0; nca.add = 1; if ((oca.rev = ocnt < 0)) ocnt = -ocnt; if ((nca.rev = ncnt < 0)) ncnt = -ncnt; - if (nca.rev == oca.rev) /* add and delete cells in order */ - while (ocnt > 0 & ncnt > 0) - if ((c = cellcmp(ogcp, ngcp)) > 0) { /* new cell */ - netchange += docell(ngcp++, &nca); - ncnt--; - } else if (c < 0) { /* old cell */ - netchange -= docell(ogcp++, &oca); - ocnt--; - } else { /* same cell */ - ogcp++; ocnt--; - ngcp++; ncnt--; + if (oca.rev == nca.rev) { /* count matches */ + int oc = ocnt, nc = ncnt; + while (oc > 0 & nc > 0) { + c = cellcmp(ogcp, ngcp); + if (c >= 0) { ngcp++; nc--; } + if (c <= 0) { ogcp++; oc--; } + nmatch += c==0; + } + ogcp = ogcl; ngcp = ngcl; + } + if (nmatch < ocnt>>1) { /* faster to just delete old cells? */ + for (c = ncbeams; c--; ) + if (cbeam[c].wants & 1< 0 & ncnt > 0) + if ((c = cellcmp(ogcp, ngcp)) > 0) { /* new cell */ + netchange += docell(ngcp++, &nca); + ncnt--; + } else if (c < 0) { /* old cell */ + netchange -= docell(ogcp++, &oca); + ocnt--; + } else { /* same cell */ + ogcp++; ocnt--; + ngcp++; ncnt--; + } /* take care of list tails */ for ( ; ncnt > 0; ncnt--) netchange += docell(ngcp++, &nca); @@ -436,28 +449,34 @@ VIEW *vold, *vnew; } +int beam_sync() /* synchronize beams on server */ { cbeamop(DR_NEWSET, cbeam, ncbeams, &odev.v, odev.hres, odev.vres); + return(ncbeams); } -beam_view(vn) /* change beam view */ +beam_view(vn) /* change beam view (if advisable) */ VIEW *vn; { struct cellact ca; VOXL vlnew[8]; int n, comn; - if (!vn->type) { /* clear our beam list */ + if (vn == NULL || !vn->type) { /* clear our beam list */ set_voxels(vlnew, 0); cbeamop(DR_DELSET, cbeam, ncbeams, NULL, 0, 0); ncbeams = 0; - copystruct(&dvw, vn); - return; + dvw.type = 0; + return(1); } /* find our new voxels */ n = get_voxels(vlnew, vn->vp); + if (dvw.type && !n) { + copystruct(vn, &dvw); /* cancel move */ + return(0); + } /* set the new voxels */ comn = set_voxels(vlnew, n); if (!dvw.type) @@ -468,9 +487,6 @@ VIEW *vn; mvview(ca.vi, &dvw, vn); else /* else add all new cells */ doview(&ca, vn); -#if 1 - cbeamadj(vn, odev.hres, odev.vres); -#else /* inform server of new beams */ cbeamop(DR_ADDSET, cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres); /* sort list to put orphans at end */ @@ -478,6 +494,6 @@ VIEW *vn; /* tell server to delete orphans */ cbeamop(DR_DELSET, cbeam+ncbeams, xcbeams, NULL, 0, 0); xcbeams = 0; /* truncate our list */ -#endif copystruct(&dvw, vn); /* record new view */ + return(1); }
