root/radiance/ray/src/hd/rhdisp2.c
Revision: 3.4
Committed: Fri Nov 21 16:10:17 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.3: +14 -28 lines
added server-driven redraw function to replace display quadtree
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck beam tracking for display process
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14
15 extern int *getviewcells();
16
17 typedef struct {
18 int hd; /* holodeck section number (-1 if inactive) */
19 int i[3]; /* voxel index (may be outside section) */
20 } VOXL; /* a voxel */
21
22 static VOXL voxel[8] = { /* current voxel list */
23 {-1}, {-1}, {-1}, {-1},
24 {-1}, {-1}, {-1}, {-1}
25 };
26
27 #define CBEAMBLK 1024 /* cbeam allocation block size */
28
29 static struct beamcomp {
30 short wants; /* flags telling which voxels want us */
31 short hd; /* holodeck section number */
32 int bi; /* beam index */
33 } *cbeam = NULL; /* current beam list */
34
35 static int ncbeams = 0; /* number of sorted beams in cbeam */
36 static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */
37 static int maxcbeam = 0; /* size of cbeam array */
38
39 struct cellact {
40 short vi; /* voxel index */
41 short add; /* zero means delete */
42 }; /* action for cell */
43
44 struct beamact {
45 struct cellact ca; /* cell action */
46 GCOORD gc; /* grid coordinate */
47 }; /* beam origin and action */
48
49
50 int
51 newcbeam() /* allocate new entry at end of cbeam array */
52 {
53 int i;
54
55 if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */
56 maxcbeam += CBEAMBLK;
57 if (cbeam == NULL)
58 cbeam = (struct beamcomp *)malloc(
59 maxcbeam*sizeof(struct beamcomp) );
60 else
61 cbeam = (struct beamcomp *)realloc( (char *)cbeam,
62 maxcbeam*sizeof(struct beamcomp) );
63 if (cbeam == NULL)
64 error(SYSTEM, "out of memory in newcbeam");
65 }
66 return(i);
67 }
68
69
70 int
71 cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */
72 register struct beamcomp *cb1, *cb2;
73 {
74 register int c;
75
76 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
77 return(c);
78 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
79 }
80
81
82 int
83 cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */
84 register struct beamcomp *cb1, *cb2;
85 {
86 register int c;
87
88 if (!cb1->wants) /* put orphans at the end, unsorted */
89 return(cb2->wants);
90 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
91 return(c);
92 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
93 }
94
95
96 int
97 findcbeam(hd, bi) /* find the specified beam in our sorted list */
98 int hd, bi;
99 {
100 struct beamcomp cb;
101 register struct beamcomp *p;
102
103 if (ncbeams <= 0)
104 return(-1);
105 cb.wants = 0; cb.hd = hd; cb.bi = bi;
106 p = (struct beamcomp *)bsearch((char *)&cb, (char *)cbeam, ncbeams,
107 sizeof(struct beamcomp), cbeamcmp);
108 if (p == NULL)
109 return(-1);
110 return(p - cbeam);
111 }
112
113
114 int
115 getcbeam(hd, bi) /* get the specified beam, allocating as necessary */
116 register int hd;
117 int bi;
118 {
119 register int n;
120 /* first, look in sorted list */
121 if ((n = findcbeam(hd, bi)) >= 0)
122 return(n);
123 /* linear search through xcbeams to be sure */
124 for (n = ncbeams+xcbeams; n-- > ncbeams; )
125 if (cbeam[n].bi == bi && cbeam[n].hd == hd)
126 return(n);
127 /* check legality */
128 if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL)
129 error(INTERNAL, "illegal holodeck number in getcbeam");
130 if (bi < 1 | bi > nbeams(hdlist[hd]))
131 error(INTERNAL, "illegal beam index in getcbeam");
132 n = newcbeam(); /* allocate and assign */
133 cbeam[n].wants = 0; cbeam[n].hd = hd; cbeam[n].bi = bi;
134 return(n);
135 }
136
137
138 cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */
139 int adopt;
140 {
141 register int i;
142
143 if (!(ncbeams += xcbeams))
144 return;
145 xcbeams = 0;
146 qsort((char *)cbeam, ncbeams, sizeof(struct beamcomp),
147 adopt ? cbeamcmp : cbeamcmp2);
148 if (adopt)
149 return;
150 for (i = ncbeams; i--; ) /* identify orphans */
151 if (cbeam[i].wants)
152 break;
153 xcbeams = ncbeams - ++i; /* put orphans after ncbeams */
154 ncbeams = i;
155 }
156
157
158 cbeamop(op, bl, n, v, hr, vr) /* update beams on server list */
159 int op;
160 register struct beamcomp *bl;
161 int n;
162 VIEW *v;
163 int hr, vr;
164 {
165 register PACKHEAD *pa;
166 register int i;
167
168 if (n <= 0)
169 return;
170 pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD));
171 if (pa == NULL)
172 error(SYSTEM, "out of memory in cbeamadd");
173 for (i = 0; i < n; i++) {
174 pa[i].hd = bl[i].hd;
175 pa[i].bi = bl[i].bi;
176 pa[i].nr = v==NULL ? 0 :
177 npixels(v, hr, vr, hdlist[bl[i].hd], bl[i].bi);
178 }
179 serv_request(op, n*sizeof(PACKHEAD), (char *)pa);
180 free((char *)pa);
181 }
182
183
184 int
185 set_voxels(vl, n) /* set new voxel array */
186 VOXL vl[8];
187 int n;
188 {
189 short wmap[256];
190 int vmap[8];
191 int comn = 0;
192 int no;
193 register int i, j;
194 /* find common voxels */
195 for (j = 0; j < 8 && voxel[j].hd >= 0; j++) {
196 vmap[j] = -1;
197 for (i = n; i--; )
198 if (!bcmp((char *)(vl+i), (char *)(voxel+j),
199 sizeof(VOXL))) {
200 vmap[j] = i;
201 comn |= 1<<i;
202 break;
203 }
204 }
205 no = comn ? j : 0; /* compute flag mapping */
206 for (i = 256; i--; ) {
207 wmap[i] = 0;
208 for (j = no; j--; )
209 if (vmap[j] >= 0 && i & 1<<j)
210 wmap[i] |= 1<<vmap[j];
211 }
212 /* fix cbeam flags */
213 for (i = ncbeams; i--; )
214 cbeam[i].wants = wmap[cbeam[i].wants];
215 /* update our voxel list */
216 bcopy((char *)vl, (char *)voxel, n*sizeof(VOXL));
217 for (j = n; j < 8; j++)
218 voxel[j].hd = -1;
219 return(comn); /* return bit array of common voxels */
220 }
221
222
223 int
224 get_voxels(vl, vp) /* find voxels corresponding to view point */
225 VOXL vl[8];
226 FVECT vp;
227 {
228 static int lastn = 0, lastd = -1;
229 int n = 0;
230 FVECT gp;
231 double d;
232 int dist, bestd = 0x7fff;
233 VOXL vox;
234 register int i, j, k;
235 /* find closest voxels */
236 for (i = 0; n < 8 && hdlist[i]; i++) {
237 hdgrid(gp, hdlist[i], vp);
238 for (j = 0; n < 8 && j < 8; j++) {
239 dist = 0;
240 for (k = 0; k < 3; k++) {
241 d = gp[k] - .5 + (j>>k & 1);
242 if (d < 0.)
243 dist += -(vox.i[k] = (int)d - 1);
244 else if ((vox.i[k] = d) >= hdlist[i]->grid[k])
245 dist += vox.i[k] -
246 hdlist[i]->grid[k] + 1;
247 }
248 if (dist > bestd) /* others were closer */
249 continue;
250 if (dist < bestd) { /* start closer list */
251 n = 0;
252 bestd = dist;
253 }
254 vox.hd = i; /* add this voxel */
255 copystruct(&vl[n], &vox);
256 n++;
257 }
258 }
259 /* warn of dangerous moves */
260 if (n < lastn && bestd >= lastd)
261 error(WARNING, "moving outside holodeck section");
262 else if (n > lastn && bestd <= lastd)
263 error(WARNING, "moving inside holodeck section");
264 lastd = bestd;
265 return(lastn = n);
266 }
267
268
269 int
270 dobeam(gcp, bp) /* express interest or disintrest in a beam */
271 GCOORD *gcp;
272 register struct beamact *bp;
273 {
274 GCOORD gc[2];
275 int bi, i;
276 /* compute beam index */
277 copystruct(gc, gcp);
278 copystruct(gc+1, &bp->gc);
279 if ((bi = hdbindex(hdlist[voxel[bp->ca.vi].hd], gc)) <= 0)
280 error(CONSISTENCY, "bad grid coordinate in dobeam");
281 if (bp->ca.add) { /* add it in */
282 i = getcbeam(voxel[bp->ca.vi].hd, bi);
283 cbeam[i].wants |= 1<<bp->ca.vi; /* say we want it */
284 return(i == ncbeams+xcbeams-1); /* return 1 if totally new */
285 }
286 /* else delete it */
287 i = findcbeam(voxel[bp->ca.vi].hd, bi);
288 if (i >= 0 && cbeam[i].wants & 1<<bp->ca.vi) {
289 cbeam[i].wants &= ~(1<<bp->ca.vi); /* we don't want it */
290 return(1); /* indicate change */
291 }
292 return(0);
293 }
294
295
296
297 int
298 docell(gcp, cap) /* find beams corresponding to cell and voxel */
299 GCOORD *gcp;
300 register struct cellact *cap;
301 {
302 FVECT org, dir[4];
303 FVECT gp, cv[4], vc;
304 struct beamact bo;
305 register int i;
306 /* compute cell vertices */
307 hdcell(cv, hdlist[voxel[cap->vi].hd], gcp);
308 /* compute cell and voxel centers */
309 for (i = 0; i < 3; i++) {
310 org[i] = 0.5*(cv[0][i] + cv[2][i]);
311 gp[i] = voxel[cap->vi].i[i] + 0.5;
312 }
313 hdworld(vc, hdlist[voxel[cap->vi].hd], gp);
314 /* compute voxel pyramid using vector trick */
315 for (i = 0; i < 3; i++) {
316 dir[0][i] = vc[i] - cv[0][i]; /* to 3 */
317 dir[2][i] = vc[i] - cv[3][i]; /* to 0 */
318 if (gcp->w & 1) { /* watch vertex order! */
319 dir[1][i] = vc[i] - cv[2][i]; /* to 1 */
320 dir[3][i] = vc[i] - cv[1][i]; /* to 2 */
321 } else {
322 dir[1][i] = vc[i] - cv[1][i]; /* to 2 */
323 dir[3][i] = vc[i] - cv[2][i]; /* to 1 */
324 }
325 }
326 /* visit beams for opposite cells */
327 copystruct(&bo.ca, cap);
328 copystruct(&bo.gc, gcp);
329 return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo));
330 }
331
332
333 int
334 doview(cap, vp) /* visit cells for a given view */
335 struct cellact *cap;
336 VIEW *vp;
337 {
338 FVECT org, dir[4];
339 /* compute view pyramid */
340 if (vp->type == VT_PAR) goto viewerr;
341 if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) goto viewerr;
342 if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) goto viewerr;
343 if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) goto viewerr;
344 if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) goto viewerr;
345 /* visit cells within pyramid */
346 return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], docell, cap));
347 viewerr:
348 error(INTERNAL, "unusable view in doview");
349 }
350
351
352 mvview(voxi, vold, vnew) /* move view for a voxel */
353 int voxi;
354 VIEW *vold, *vnew;
355 {
356 int netchange = 0;
357 int *ocl, *ncl;
358 struct cellact ca;
359 int ocnt, ncnt;
360 int c;
361 register GCOORD *ogcp, *ngcp;
362 /* get old and new cell lists */
363 ocl = getviewcells(hdlist[voxel[voxi].hd], vold);
364 ncl = getviewcells(hdlist[voxel[voxi].hd], vnew);
365 if (ocl != NULL) {
366 ocnt = *ocl; ogcp = (GCOORD *)(ocl+1);
367 } else {
368 ocnt = 0; ogcp = NULL;
369 }
370 if (ncl != NULL) {
371 ncnt = *ncl; ngcp = (GCOORD *)(ncl+1);
372 } else {
373 ncnt = 0; ngcp = NULL;
374 }
375 ca.vi = voxi; /* add and delete cells */
376 while (ocnt > 0 & ncnt > 0)
377 if ((c = cellcmp(ogcp, ngcp)) > 0) {
378 ca.add = 1; /* new cell */
379 netchange += docell(ngcp++, &ca);
380 ncnt--;
381 } else if (c < 0) {
382 ca.add = 0; /* obsolete cell */
383 netchange -= docell(ogcp++, &ca);
384 ocnt--;
385 } else {
386 ogcp++; ocnt--; /* unchanged cell */
387 ngcp++; ncnt--;
388 }
389 /* take care of list tails */
390 for (ca.add = 1; ncnt > 0; ncnt--)
391 netchange += docell(ngcp++, &ca);
392 for (ca.add = 0; ocnt > 0; ocnt--)
393 netchange -= docell(ogcp++, &ca);
394 /* clean up */
395 if (ocl != NULL) free((char *)ocl);
396 if (ncl != NULL) free((char *)ncl);
397 return(netchange);
398 }
399
400
401 beam_sync() /* synchronize beams on server */
402 {
403 cbeamop(DR_NEWSET, cbeam, ncbeams, &odev.v, odev.hres, odev.vres);
404 }
405
406
407 beam_view(vo, vn) /* change beam view */
408 VIEW *vo, *vn;
409 {
410 struct cellact ca;
411 VOXL vlnew[8];
412 int n, comn;
413
414 if (!vn->type) { /* clear our beam list */
415 set_voxels(vlnew, 0);
416 cbeamop(DR_DELSET, cbeam, ncbeams, NULL, 0, 0);
417 ncbeams = 0;
418 return;
419 }
420 /* find our new voxels */
421 n = get_voxels(vlnew, vn->vp);
422 /* set the new voxels */
423 comn = set_voxels(vlnew, n);
424 if (!vo->type)
425 comn = 0;
426 ca.add = 1; /* update our beam list */
427 for (ca.vi = n; ca.vi--; )
428 if (comn & 1<<ca.vi) /* change which cells we see */
429 mvview(ca.vi, vo, vn);
430 else /* else add all new cells */
431 doview(&ca, vn);
432 /* inform server of new beams */
433 cbeamop(DR_ADDSET, cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres);
434 /* sort list to put orphans at end */
435 cbeamsort(0);
436 /* tell server to delete orphans */
437 cbeamop(DR_DELSET, cbeam+ncbeams, xcbeams, NULL, 0, 0);
438 xcbeams = 0; /* truncate our list */
439 }
