--- ray/src/hd/rhdisp2.c 1998/05/22 15:12:36 3.22 +++ ray/src/hd/rhdisp2.c 1999/03/03 10:25:27 3.31 @@ -11,45 +11,39 @@ static char SCCSid[] = "$SunId$ SGI"; #include "rholo.h" #include "rhdisp.h" #include "rhdriver.h" +#include "random.h" #ifndef MAXDIST #define MAXDIST 42 /* maximum distance outside section */ #endif +#ifndef NVSAMPS +#define NVSAMPS 16384 /* number of ray samples per view */ +#endif +#ifndef MEYERNG +#define MEYERNG 0.2 /* target mean eye range (rel. to grid) */ +#endif +#ifndef MAXTODO +#define MAXTODO 3 /* maximum sections to look at */ +#endif +#ifndef MAXDRAT +#define MAXDRAT 3.0 /* maximum distance ratio btwn. cand. sect. */ +#endif -#define MAXVOXEL 32 /* maximum number of active voxels */ - -typedef struct { - int hd; /* holodeck section number (-1 if inactive) */ - int i[3]; /* voxel index (may be outside section) */ -} VOXL; /* a voxel */ - -static VOXL voxel[MAXVOXEL] = {{-1}}; /* current voxel list */ - #define CBEAMBLK 1024 /* cbeam allocation block size */ static struct beamcomp { int hd; /* holodeck section number */ - int4 bi; /* beam index */ + int bi; /* beam index */ int4 nr; /* number of samples desired */ } *cbeam = NULL; /* current beam list */ +VIEWPOINT cureye; /* current eye position */ + static int ncbeams = 0; /* number of sorted beams in cbeam */ static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */ static int maxcbeam = 0; /* size of cbeam array */ -struct cellact { - short vi; /* voxel index */ - short rev; /* reverse ray direction? */ - VIEW *vp; /* view for image */ - short hr, vr; /* image resolution */ -}; /* action for cell */ -struct beamact { - struct cellact ca; /* cell action */ - GCOORD gc; /* grid coordinate */ -}; /* beam origin and action */ - - int newcbeam() /* allocate new entry at end of cbeam array */ { @@ -184,199 +178,152 @@ int n; } -unsigned int4 -add_voxels(vp) /* add voxels corresponding to view point */ -FVECT vp; +static int +comptodo(tdl, vw) /* compute holodeck sections in view */ +int tdl[MAXTODO+1]; +VIEW *vw; { - int first, n, rfl = 0; - FVECT gp; - double d; - int dist, bestd = 0x7fff; - VOXL vox; - register int i, j, k; - /* count voxels in list already */ - for (first = 0; first < MAXVOXEL && voxel[first].hd >= 0; first++) - ; - /* find closest voxels */ - for (n = first, i = 0; n < MAXVOXEL && hdlist[i]; i++) { - hdgrid(gp, hdlist[i], vp); - for (j = 0; n < MAXVOXEL && j < 8; j++) { - dist = 0; - for (k = 0; k < 3; k++) { - d = gp[k] - .5 + (j>>k & 1); - if (d < 0.) - dist += -(vox.i[k] = (int)d - 1); - else if ((vox.i[k] = d) >= hdlist[i]->grid[k]) - dist += vox.i[k] - - hdlist[i]->grid[k] + 1; - } - if (dist > bestd) /* others were closer */ - continue; - if (dist < bestd) { /* start closer list */ - n = first; - bestd = dist; - rfl = 0; - } - /* check if already in list */ - for (k = first; k--; ) - if (voxel[k].hd == i && - voxel[k].i[0] == vox.i[0] && - voxel[k].i[1] == vox.i[1] && - voxel[k].i[2] == vox.i[2]) - break; - if (k >= 0) { - rfl |= 1<vp); + for (j = 0; j < 3; j++) + if (gp[j] < 0.) + dv[j] = -gp[j]; + else if (gp[j] > hdlist[i]->grid[j]) + dv[j] = gp[j] - hdlist[i]->grid[j]; + else + dv[j] = 0.; + thisdist2 = DOT(dv,dv); + for (j = n; j > 0 && thisdist2 < dist2[j-1]; j--) { + tdl[j] = tdl[j-1]; + dist2[j] = dist2[j-1]; } + tdl[j] = i; + dist2[j] = thisdist2; + if (n < MAXTODO) + n++; } - /* check for really stupid move */ - if (bestd > MAXDIST) { + /* watch for bad move */ + if (n && dist2[0] > MAXDIST*MAXDIST) { error(COMMAND, "move past outer limits"); return(0); } - if (n < MAXVOXEL) - voxel[n].hd = -1; - return(rfl); + /* avoid big differences */ + for (j = 1; j < n; j++) + if (dist2[j] > MAXDRAT*MAXDRAT*dist2[j-1]) + n = j; + tdl[n] = -1; + return(n); } int -dobeam(gcp, bp) /* express interest or disintrest in a beam */ -GCOORD *gcp; -register struct beamact *bp; +addview(hd, vw, rad, hres, vres) /* add view for section */ +int hd; +VIEW *vw; +double rad; +int hres, vres; { + int sampquant, samptot = 0; + int h, v, shr, svr; GCOORD gc[2]; - int bi, i, n; - /* compute beam index */ - if (bp->ca.rev) { - copystruct(gc, &bp->gc); - copystruct(gc+1, gcp); + FVECT rorg, rdir; + /* compute sampling grid */ + if (hres|vres && hres*vres <= NVSAMPS) { + shr = hres; svr = vres; + sampquant = 1; } else { - copystruct(gc, gcp); - copystruct(gc+1, &bp->gc); + shr = sqrt(NVSAMPS/viewaspect(vw)) + .5; + svr = (NVSAMPS + shr/2)/shr; + sampquant = (hres*vres + shr*svr/2)/(shr*svr); } - if ((bi = hdbindex(hdlist[voxel[bp->ca.vi].hd], gc)) <= 0) - error(CONSISTENCY, "bad grid coordinate in dobeam"); - /* add it in */ - i = getcbeam(voxel[bp->ca.vi].hd, bi); - n = npixels(bp->ca.vp, bp->ca.hr, bp->ca.vr, - hdlist[cbeam[i].hd], cbeam[i].bi); - if (n > cbeam[i].nr) - cbeam[i].nr = n; - return(i == ncbeams+xcbeams-1); /* return 1 if totally new */ + /* intersect sample rays with section */ + for (v = svr; v--; ) + for (h = shr; h--; ) { + if (viewray(rorg, rdir, vw, (h+frandom())/shr, + (v+frandom())/svr) < -FTINY) + continue; + if (rad > FTINY) { + rorg[0] += (1.-2.*frandom())*rad; + rorg[1] += (1.-2.*frandom())*rad; + rorg[2] += (1.-2.*frandom())*rad; + } + if (hdinter(gc, NULL, NULL, hdlist[hd], rorg, rdir) + >= 0.99*FHUGE) + continue; + cbeam[getcbeam(hd,hdbindex(hdlist[hd],gc))].nr += + sampquant; + samptot += sampquant; + } + return(samptot); } - -int -docell(gcp, cap) /* find beams corresponding to cell and voxel */ -GCOORD *gcp; -register struct cellact *cap; +beam_init(fresh) /* clear beam list for new view(s) */ +int fresh; { - register HOLO *hp = hdlist[voxel[cap->vi].hd]; - FVECT org, dir[4]; - FVECT vgp, cgp, vc; - FVECT v1, v2; - struct beamact bo; - int axmax, j; - double d, avmax; register int i; - /* compute cell center */ - cgp[gcp->w>>1] = gcp->w&1 ? hp->grid[gcp->w>>1] : 0 ; - cgp[hdwg0[gcp->w]] = gcp->i[0] + .5; - cgp[hdwg1[gcp->w]] = gcp->i[1] + .5; - hdworld(org, hp, cgp); - /* compute direction to voxel center */ - for (i = 3; i--; ) - vgp[i] = voxel[cap->vi].i[i] + .5; - hdworld(vc, hp, vgp); - for (i = 3; i--; ) - vc[i] -= org[i]; - /* compute maximum area axis */ - axmax = -1; avmax = 0; - for (i = 3; i--; ) { - d = vgp[i] - cgp[i]; - if (d < 0.) d = -d; - if (d > avmax) { - avmax = d; - axmax = i; - } - } -#ifdef DEBUG - if (axmax < 0.) - error(CONSISTENCY, "botched axis computation in docell"); -#endif - /* compute offset vectors */ - d = 0.5/hp->grid[j=(axmax+1)%3]; - for (i = 3; i--; ) - v1[i] = hp->xv[j][i] * d; - d = 0.5/hp->grid[j=(axmax+2)%3]; - if (DOT(hp->wg[axmax], vc) < 0.) - d = -d; /* reverse vertex order */ - for (i = 3; i--; ) - v2[i] = hp->xv[j][i] * d; - /* compute voxel pyramid */ - for (i = 3; i--; ) { - dir[0][i] = vc[i] - v1[i] - v2[i]; - dir[1][i] = vc[i] + v1[i] - v2[i]; - dir[2][i] = vc[i] + v1[i] + v2[i]; - dir[3][i] = vc[i] - v1[i] + v2[i]; - } - /* visit beams for opposite cells */ - copystruct(&bo.ca, cap); - copystruct(&bo.gc, gcp); - return(visit_cells(org, dir, hp, dobeam, &bo)); -} - -int -doview(cap) /* visit cells for a given view */ -struct cellact *cap; -{ - int orient; - FVECT org, dir[4]; - /* compute view pyramid */ - orient = viewpyramid(org, dir, hdlist[voxel[cap->vi].hd], cap->vp); - if (!orient) - error(INTERNAL, "unusable view in doview"); - cap->rev = orient < 0; - /* visit cells within pyramid */ - return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], docell, cap)); + if (fresh) /* discard old beams? */ + ncbeams = xcbeams = 0; + else /* else clear sample requests */ + for (i = ncbeams+xcbeams; i--; ) + cbeam[i].nr = 0; + cureye.rng = 0.; } -beam_init() /* clear beam list for new view(s) */ -{ - register int i; - /* clear desire flags */ - for (i = ncbeams+xcbeams; i--; ) - cbeam[i].nr = 0; - voxel[0].hd = -1; /* clear voxel list */ -} - - +int * beam_view(vn, hr, vr) /* add beam view (if advisable) */ VIEW *vn; int hr, vr; { - struct cellact ca; - unsigned int4 vfl; - /* sort our list */ + static int todo[MAXTODO+1]; + int n; + double er, eravg, d; + register HOLO *hp; + register int i; + /* find nearby sections */ + if (!(n = comptodo(todo, vn))) + return(NULL); + /* sort current beam list */ cbeamsort(1); - /* add new voxels */ - vfl = add_voxels(vn->vp); - if (!vfl) - return(0); - ca.vp = vn; ca.hr = hr; ca.vr = vr; - /* update our beam list */ - for (ca.vi = 0; vfl; vfl >>= 1, ca.vi++) - if (vfl & 1) - doview(&ca); - return(1); + /* add view to nearby sections */ + eravg = 0.; + for (i = 0; i < n; i++) { + hp = hdlist[todo[i]]; + if (MEYERNG > FTINY) + er = MEYERNG/3. / VLEN(hp->wg[0]) + + MEYERNG/3. / VLEN(hp->wg[1]) + + MEYERNG/3. / VLEN(hp->wg[2]) ; + else + er = 0.; + if (!addview(todo[i], vn, 0.25*er, hr, vr)) { + register int j; /* whoops! */ + n--; /* delete from list */ + for (j = i--; j <= n; j++) + todo[j] = todo[j+1]; + } else + eravg += er; + } + if (eravg <= FTINY) + return(todo); + /* compute average eye range */ + eravg /= (double)n; + /* add to current eye position */ + if (cureye.rng <= FTINY) { + VCOPY(cureye.vpt, vn->vp); + cureye.rng = eravg; + } else if ((d = sqrt(dist2(vn->vp,cureye.vpt))) + eravg > cureye.rng) { + for (i = 3; i--; ) + cureye.vpt[i] = 0.5*(cureye.vpt[i] + vn->vp[i]); + cureye.rng = 0.5*(cureye.rng + eravg + d); + } + return(todo); } @@ -384,8 +331,11 @@ int beam_sync(all) /* update beam list on server */ int all; { - /* sort list to put orphans at end */ - cbeamsort(0); + /* set new eye position */ + serv_request(DR_VIEWPOINT, sizeof(VIEWPOINT), (char *)&cureye); + /* sort list (put orphans at end) */ + cbeamsort(all < 0); + /* send beam request */ if (all) cbeamop(DR_NEWSET, cbeam, ncbeams); else
