root/radiance/ray/src/hd/rhdisp2.c
Revision: 3.33
Committed: Sat Feb 22 02:07:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.32: +2 -5 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.33 static const char RCSid[] = "$Id$";
3 gregl 3.1 #endif
4     /*
5 gregl 3.2 * Holodeck beam tracking for display process
6 gregl 3.1 */
7
8     #include "rholo.h"
9     #include "rhdisp.h"
10     #include "rhdriver.h"
11
12 gwlarson 3.26 #ifndef MEYERNG
13 gwlarson 3.30 #define MEYERNG 0.2 /* target mean eye range (rel. to grid) */
14 gwlarson 3.26 #endif
15 gwlarson 3.20
16 gregl 3.1 #define CBEAMBLK 1024 /* cbeam allocation block size */
17
18 gwlarson 3.32 static PACKHEAD *cbeam = NULL; /* current beam list */
19 gregl 3.1 static int ncbeams = 0; /* number of sorted beams in cbeam */
20     static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */
21     static int maxcbeam = 0; /* size of cbeam array */
22
23 gwlarson 3.32 VIEWPOINT cureye; /* current eye position */
24 gregl 3.1
25 gwlarson 3.32
26 gregl 3.1 int
27     newcbeam() /* allocate new entry at end of cbeam array */
28     {
29     int i;
30
31     if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */
32     maxcbeam += CBEAMBLK;
33     if (cbeam == NULL)
34 gwlarson 3.32 cbeam = (PACKHEAD *)malloc(
35     maxcbeam*sizeof(PACKHEAD) );
36 gregl 3.1 else
37 gwlarson 3.32 cbeam = (PACKHEAD *)realloc( (char *)cbeam,
38     maxcbeam*sizeof(PACKHEAD) );
39 gregl 3.1 if (cbeam == NULL)
40     error(SYSTEM, "out of memory in newcbeam");
41     }
42     return(i);
43     }
44
45
46     int
47     cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */
48 gwlarson 3.32 register PACKHEAD *cb1, *cb2;
49 gregl 3.1 {
50     register int c;
51
52     if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
53     return(c);
54     return(cb1->hd - cb2->hd); /* use hd to resolve matches */
55     }
56
57
58     int
59     cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */
60 gwlarson 3.32 register PACKHEAD *cb1, *cb2;
61 gregl 3.1 {
62     register int c;
63
64 gwlarson 3.22 if (!cb1->nr) /* put orphans at the end, unsorted */
65     return(cb2->nr);
66     if (!cb2->nr)
67 gregl 3.15 return(-1);
68 gregl 3.1 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
69     return(c);
70     return(cb1->hd - cb2->hd); /* use hd to resolve matches */
71     }
72
73
74     int
75     findcbeam(hd, bi) /* find the specified beam in our sorted list */
76     int hd, bi;
77     {
78 gwlarson 3.32 PACKHEAD cb;
79     register PACKHEAD *p;
80 gregl 3.1
81     if (ncbeams <= 0)
82     return(-1);
83 gwlarson 3.32 cb.hd = hd; cb.bi = bi; cb.nr = cb.nc = 0;
84     p = (PACKHEAD *)bsearch((char *)&cb, (char *)cbeam, ncbeams,
85     sizeof(PACKHEAD), cbeamcmp);
86 gregl 3.1 if (p == NULL)
87     return(-1);
88     return(p - cbeam);
89     }
90
91
92     int
93     getcbeam(hd, bi) /* get the specified beam, allocating as necessary */
94     register int hd;
95     int bi;
96     {
97     register int n;
98     /* first, look in sorted list */
99     if ((n = findcbeam(hd, bi)) >= 0)
100     return(n);
101     /* linear search through xcbeams to be sure */
102     for (n = ncbeams+xcbeams; n-- > ncbeams; )
103     if (cbeam[n].bi == bi && cbeam[n].hd == hd)
104     return(n);
105     /* check legality */
106     if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL)
107     error(INTERNAL, "illegal holodeck number in getcbeam");
108     if (bi < 1 | bi > nbeams(hdlist[hd]))
109     error(INTERNAL, "illegal beam index in getcbeam");
110     n = newcbeam(); /* allocate and assign */
111 gwlarson 3.32 cbeam[n].hd = hd; cbeam[n].bi = bi; cbeam[n].nr = cbeam[n].nc = 0;
112 gregl 3.1 return(n);
113     }
114
115
116     cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */
117     int adopt;
118     {
119     register int i;
120
121     if (!(ncbeams += xcbeams))
122     return;
123     xcbeams = 0;
124 gwlarson 3.32 qsort((char *)cbeam, ncbeams, sizeof(PACKHEAD),
125 gregl 3.1 adopt ? cbeamcmp : cbeamcmp2);
126     if (adopt)
127     return;
128     for (i = ncbeams; i--; ) /* identify orphans */
129 gwlarson 3.22 if (cbeam[i].nr)
130 gregl 3.1 break;
131     xcbeams = ncbeams - ++i; /* put orphans after ncbeams */
132     ncbeams = i;
133     }
134
135
136 gwlarson 3.24 beam_init(fresh) /* clear beam list for new view(s) */
137     int fresh;
138 gregl 3.1 {
139 gwlarson 3.21 register int i;
140 gwlarson 3.24
141     if (fresh) /* discard old beams? */
142     ncbeams = xcbeams = 0;
143     else /* else clear sample requests */
144     for (i = ncbeams+xcbeams; i--; )
145     cbeam[i].nr = 0;
146 gwlarson 3.26 cureye.rng = 0.;
147 gregl 3.1 }
148
149
150 gwlarson 3.32 int2 *
151 gwlarson 3.21 beam_view(vn, hr, vr) /* add beam view (if advisable) */
152     VIEW *vn;
153     int hr, vr;
154 gregl 3.4 {
155 gwlarson 3.32 int2 *slist;
156     BEAMLIST blist;
157     double eravg, d;
158 gwlarson 3.26 register HOLO *hp;
159 gwlarson 3.32 register int i, n;
160     /* compute beams for view */
161     slist = viewbeams(vn, hr, vr, &blist);
162     if (*slist < 0) {
163     error(COMMAND, "no sections visible from this view");
164 gwlarson 3.29 return(NULL);
165 gwlarson 3.32 }
166 gwlarson 3.30 /* sort current beam list */
167 gwlarson 3.21 cbeamsort(1);
168 gwlarson 3.32 /* add new beams to list */
169     for (i = blist.nb; i--; ) {
170     n = getcbeam(blist.bl[i].hd, blist.bl[i].bi);
171     if (blist.bl[i].nr > cbeam[n].nr)
172     cbeam[n].nr = blist.bl[i].nr;
173     }
174 greg 3.33 free((void *)blist.bl); /* free list */
175 gwlarson 3.32 if (MEYERNG <= FTINY)
176     return(slist);
177     /* compute average eye range */
178 gwlarson 3.30 eravg = 0.;
179 gwlarson 3.32 for (n = 0; slist[n] >= 0; n++) {
180     hp = hdlist[slist[n]];
181     eravg += MEYERNG/3. / VLEN(hp->wg[0]) +
182 gwlarson 3.30 MEYERNG/3. / VLEN(hp->wg[1]) +
183     MEYERNG/3. / VLEN(hp->wg[2]) ;
184     }
185     eravg /= (double)n;
186 gwlarson 3.26 /* add to current eye position */
187     if (cureye.rng <= FTINY) {
188     VCOPY(cureye.vpt, vn->vp);
189 gwlarson 3.30 cureye.rng = eravg;
190     } else if ((d = sqrt(dist2(vn->vp,cureye.vpt))) + eravg > cureye.rng) {
191 gwlarson 3.26 for (i = 3; i--; )
192     cureye.vpt[i] = 0.5*(cureye.vpt[i] + vn->vp[i]);
193 gwlarson 3.30 cureye.rng = 0.5*(cureye.rng + eravg + d);
194 gwlarson 3.26 }
195 gwlarson 3.32 return(slist);
196 gregl 3.4 }
197
198
199 gwlarson 3.21 int
200     beam_sync(all) /* update beam list on server */
201     int all;
202 gregl 3.1 {
203 gwlarson 3.26 /* set new eye position */
204     serv_request(DR_VIEWPOINT, sizeof(VIEWPOINT), (char *)&cureye);
205 gwlarson 3.24 /* sort list (put orphans at end) */
206     cbeamsort(all < 0);
207 gwlarson 3.26 /* send beam request */
208 gwlarson 3.32 if (all) {
209     if (ncbeams > 0)
210     serv_request(DR_NEWSET,
211     ncbeams*sizeof(PACKHEAD), cbeam);
212     } else {
213     if (ncbeams+xcbeams > 0)
214     serv_request(DR_ADJSET,
215     (ncbeams+xcbeams)*sizeof(PACKHEAD), cbeam);
216     }
217 gregl 3.1 xcbeams = 0; /* truncate our list */
218 gwlarson 3.21 return(ncbeams);
219 gwlarson 3.32 }
220
221
222     gridlines(f) /* run through holodeck section grid lines */
223     int (*f)();
224     {
225     register int hd, w, i;
226     int g0, g1;
227     FVECT wp[2], mov;
228     double d;
229     /* do each wall on each section */
230     for (hd = 0; hdlist[hd] != NULL; hd++)
231     for (w = 0; w < 6; w++) {
232     g0 = hdwg0[w];
233     g1 = hdwg1[w];
234     d = 1.0/hdlist[hd]->grid[g0];
235     mov[0] = d * hdlist[hd]->xv[g0][0];
236     mov[1] = d * hdlist[hd]->xv[g0][1];
237     mov[2] = d * hdlist[hd]->xv[g0][2];
238     if (w & 1) {
239     VSUM(wp[0], hdlist[hd]->orig,
240     hdlist[hd]->xv[w>>1], 1.);
241     VSUM(wp[0], wp[0], mov, 1.);
242     } else
243     VCOPY(wp[0], hdlist[hd]->orig);
244     VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.);
245     for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */
246     (*f)(wp);
247     if (!--i) break;
248     wp[0][0] += mov[0]; wp[0][1] += mov[1];
249     wp[0][2] += mov[2]; wp[1][0] += mov[0];
250     wp[1][1] += mov[1]; wp[1][2] += mov[2];
251     }
252     d = 1.0/hdlist[hd]->grid[g1];
253     mov[0] = d * hdlist[hd]->xv[g1][0];
254     mov[1] = d * hdlist[hd]->xv[g1][1];
255     mov[2] = d * hdlist[hd]->xv[g1][2];
256     if (w & 1)
257     VSUM(wp[0], hdlist[hd]->orig,
258     hdlist[hd]->xv[w>>1], 1.);
259     else
260     VSUM(wp[0], hdlist[hd]->orig, mov, 1.);
261     VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.);
262     for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */
263     (*f)(wp);
264     if (!--i) break;
265     wp[0][0] += mov[0]; wp[0][1] += mov[1];
266     wp[0][2] += mov[2]; wp[1][0] += mov[0];
267     wp[1][1] += mov[1]; wp[1][2] += mov[2];
268     }
269     }
270 gregl 3.1 }
