root/radiance/ray/src/hd/rhdisp.h
Thu Jan 1 11:21:55 2004 UTC (20 years, 3 months ago) by schorsch
Changes since 3.15: +18 -1 lines
Diff to previous 3.15 , to selected 3.1
Ansification and prototypes.
Changes since 3.14: +13 -1 lines
Diff to previous 3.14 , to selected 3.1
Diff to previous 3.13 , to selected 3.1
Changes since 3.12: +1 -4 lines
Diff to previous 3.12 , to selected 3.1
Tue Nov 24 17:05:35 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.11: +2 -1 lines
Diff to previous 3.11 , to selected 3.1
Fri May 22 08:30:40 1998 UTC (25 years, 11 months ago) by gwlarson
Diff to previous 3.10 , to selected 3.1
Sun Jan 4 18:37:11 1998 UTC (26 years, 3 months ago) by gregl
Changes since 3.9: +1 -0 lines
Diff to previous 3.9 , to selected 3.1
added motion outside section when OBSTRUCTIONS=True
Fri Dec 12 11:13:16 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.8: +10 -7 lines
Diff to previous 3.8 , to selected 3.1
Thu Dec 11 16:45:59 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.7: +1 -13 lines
Diff to previous 3.7 , to selected 3.1
normalized commands between driver and standard input
Thu Dec 11 09:35:32 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.6: +6 -5 lines
Diff to previous 3.6 , to selected 3.1
added DC_LASTVIEW command
Mon Dec 8 18:51:16 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.5: +25 -0 lines
Diff to previous 3.5 , to selected 3.1
Wed Nov 26 21:34:27 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.4: +9 -8 lines
Diff to previous 3.4 , to selected 3.1
Thu Nov 20 18:04:59 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 3.3 , to selected 3.1
added noop function to recover from vain DR_ATTEN
Mon Nov 10 18:04:20 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.2: +10 -37 lines
Diff to previous 3.2 , to selected 3.1
took out irrelevant body types
Mon Nov 3 18:33:12 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.1: +21 -18 lines
Revision 3.1 - (view) (download) (annotate) - [selected]
Fri Oct 31 10:23:29 1997 UTC (26 years, 5 months ago) by gregl
