--- ray/src/hd/rhdisp.h 1997/11/03 18:33:12 3.2 +++ ray/src/hd/rhdisp.h 2003/02/22 02:07:24 3.13 @@ -1,27 +1,31 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid: $Id: rhdisp.h,v 3.13 2003/02/22 02:07:24 greg Exp $ */ /* * Header for holodeck display drivers. - * Include after "rholo.h". */ /* display requests */ -#define DR_BUNDLE 1 /* bundle request */ +#define DR_NOOP 0 /* to release from vain DR_ATTEN */ +#define DR_BUNDLE 1 /* lone bundle request */ #define DR_ATTEN 2 /* request for attention */ #define DR_SHUTDOWN 3 /* shutdown request */ #define DR_NEWSET 4 /* new bundle set */ #define DR_ADDSET 5 /* add to current set */ -#define DR_DELSET 6 /* delete from current set */ +#define DR_ADJSET 6 /* adjust set quantities */ +#define DR_DELSET 7 /* delete from current set */ +#define DR_KILL 8 /* kill rtrace process(es) */ +#define DR_RESTART 9 /* restart rtrace */ +#define DR_CLOBBER 10 /* clobber holodeck */ +#define DR_VIEWPOINT 11 /* set desired eye position */ /* server responses */ -#define DS_BUNDLE 1 /* computed bundle */ -#define DS_ACKNOW 2 /* acknowledge request for attention */ -#define DS_SHUTDOWN 3 /* end process and close connection */ -#define DS_ADDHOLO 4 /* register new holodeck */ -#define DS_STARTIMM 5 /* begin immediate bundle set */ -#define DS_ENDIMM 6 /* end immediate bundle set */ +#define DS_BUNDLE 32 /* computed bundle */ +#define DS_ACKNOW 33 /* acknowledge request for attention */ +#define DS_SHUTDOWN 34 /* end process and close connection */ +#define DS_ADDHOLO 35 /* register new holodeck */ +#define DS_STARTIMM 36 /* begin immediate bundle set */ +#define DS_ENDIMM 37 /* end immediate bundle set */ +#define DS_OUTSECT 38 /* render from outside sections */ +#define DS_EYESEP 39 /* eye separation distance */ /* * Normally, the server channel has priority, with the display process @@ -33,37 +37,25 @@ * Priority returns to normal after the following request. */ +#ifndef BIGREQSIZ +#define BIGREQSIZ 512 /* big request size (bytes) */ +#endif + typedef struct { int2 type; /* message type */ int4 nbytes; /* number of additional bytes */ } MSGHEAD; /* message head */ - /* display request message bodies */ - - /* DR_BUNDLE */ -#define BUNDLE_REQ PACKHEAD - /* DR_ATTEN */ -/* no body */ - /* DR_SHUTDOWN */ -/* no body */ - /* DR_NEWSET */ -/* body is nbytes/sizeof(BUNDLE_REQ) BUNDLE_REQ bodies */ - /* DR_ADDSET */ -/* body is nbytes/sizeof(PACKHEAD) BUNDLE_REQ bodies */ - /* DR_DELSET */ -/* body is nbytes/sizeof(PACKHEAD) BUNDLE_REQ bodies */ - - /* server response message bodies */ - - /* DS_BUNDLE */ -#define BUNDLE_RES PACKHEAD /* followed by nr RAYVAL structs */ - /* DS_ACKNOW */ -/* no body */ - /* DS_SHUTDOWN */ -/* no body */ - /* DS_ADDHOLO */ -#define HOLO_RES HDGRID - /* DS_STARTIMM */ -/* no body */ - /* DS_ENDIMM */ -/* no body */ +/* + * The display process is started with three arguments. The first argument + * is the short name of the holodeck file, appropriate for window naming, etc. + * The second and third arguments are the file descriptor numbers assigned to + * the server's standard output and input, respectively. The stdin and stdout + * of the display process are used for normal communication with the server, + * and are connected to pipes going each way. It is entirely appropriate + * for the display process to borrow the server's stdin and stdout for reading + * and writing user commands from the list in rhdriver.h. If standard input + * is not available for reading, then a descriptor of -1 will be passed. + * The standard output will always be available for writing, though it + * may go to /dev/null. + */
