| 1 |
/* RCSid: $Id: rhdisp.h,v 3.16 2004/01/01 11:21:55 schorsch Exp $ */
| 2 |
| 3 |
* Header for holodeck display drivers.
| 4 |
| 5 |
#ifndef _RAD_RHDISP_H_
| 6 |
#define _RAD_RHDISP_H_
| 7 |
| 8 |
#include "color.h"
| 9 |
| 10 |
#ifdef __cplusplus
| 11 |
extern "C" {
| 12 |
#endif
| 13 |
| 14 |
/* display requests */
| 15 |
#define DR_NOOP 0 /* to release from vain DR_ATTEN */
| 16 |
#define DR_BUNDLE 1 /* lone bundle request */
| 17 |
#define DR_ATTEN 2 /* request for attention */
| 18 |
#define DR_SHUTDOWN 3 /* shutdown request */
| 19 |
#define DR_NEWSET 4 /* new bundle set */
| 20 |
#define DR_ADDSET 5 /* add to current set */
| 21 |
#define DR_ADJSET 6 /* adjust set quantities */
| 22 |
#define DR_DELSET 7 /* delete from current set */
| 23 |
#define DR_KILL 8 /* kill rtrace process(es) */
| 24 |
#define DR_RESTART 9 /* restart rtrace */
| 25 |
#define DR_CLOBBER 10 /* clobber holodeck */
| 26 |
#define DR_VIEWPOINT 11 /* set desired eye position */
| 27 |
| 28 |
/* server responses */
| 29 |
#define DS_BUNDLE 32 /* computed bundle */
| 30 |
#define DS_ACKNOW 33 /* acknowledge request for attention */
| 31 |
#define DS_SHUTDOWN 34 /* end process and close connection */
| 32 |
#define DS_ADDHOLO 35 /* register new holodeck */
| 33 |
#define DS_STARTIMM 36 /* begin immediate bundle set */
| 34 |
#define DS_ENDIMM 37 /* end immediate bundle set */
| 35 |
#define DS_OUTSECT 38 /* render from outside sections */
| 36 |
#define DS_EYESEP 39 /* eye separation distance */
| 37 |
| 38 |
| 39 |
* Normally, the server channel has priority, with the display process
| 40 |
* checking it frequently for new data. However, when the display process
| 41 |
* makes a request for attention (DR_ATTEN), the server will finish its
| 42 |
* current operations and flush its buffers, sending an acknowledge
| 43 |
* message (DS_ACKNOW) when it's done. This then allows the
| 44 |
* display process to send a long request to the holodeck server.
| 45 |
* Priority returns to normal after the following request.
| 46 |
| 47 |
| 48 |
#ifndef BIGREQSIZ
| 49 |
#define BIGREQSIZ 512 /* big request size (bytes) */
| 50 |
#endif
| 51 |
| 52 |
typedef struct {
| 53 |
int16 type; /* message type */
| 54 |
int32 nbytes; /* number of additional bytes */
| 55 |
} MSGHEAD; /* message head */
| 56 |
| 57 |
| 58 |
* The display process is started with three arguments. The first argument
| 59 |
* is the short name of the holodeck file, appropriate for window naming, etc.
| 60 |
* The second and third arguments are the file descriptor numbers assigned to
| 61 |
* the server's standard output and input, respectively. The stdin and stdout
| 62 |
* of the display process are used for normal communication with the server,
| 63 |
* and are connected to pipes going each way. It is entirely appropriate
| 64 |
* for the display process to borrow the server's stdin and stdout for reading
| 65 |
* and writing user commands from the list in rhdriver.h. If standard input
| 66 |
* is not available for reading, then a descriptor of -1 will be passed.
| 67 |
* The standard output will always be available for writing, though it
| 68 |
* may go to /dev/null.
| 69 |
| 70 |
| 71 |
| 72 |
/* rhdisp.c */
| 73 |
extern void serv_request(int type, int nbytes, char *p);
| 74 |
extern int serv_result(void);
| 75 |
/* rhdisp2.c */
| 76 |
extern int beam_sync(int all);
| 77 |
extern void beam_init(int fresh);
| 78 |
//extern int16 * beam_view(VIEW *vn, int hr, int vr);
| 79 |
/* rhdisp2.c, rhdisp3.c */
| 80 |
extern void gridlines(void (*f)(FVECT wp[2]));
| 81 |
/* rhd_ctab.c */
| 82 |
extern int new_ctab(int ncolors);
| 83 |
extern int get_pixel(uby8 rgb[3], void (*set_pixel)(int h, int r, int g, int b));
| 84 |
| 85 |
| 86 |
#ifdef __cplusplus
| 87 |
| 88 |
#endif
| 89 |
#endif /* _RAD_RHDISP_H_ */
| 90 |
