root/radiance/ray/src/hd/rhdisp.c
Revision: 3.8
Committed: Thu Dec 4 10:51:37 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.7: +6 -5 lines
added guard for inappropriate moves
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15
16 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
17
18 int imm_mode = 0; /* bundles are being delivered immediately */
19
20 char *progname; /* global argv[0] */
21
22 #define RDY_SRV 01
23 #define RDY_DEV 02
24
25
26 main(argc, argv)
27 int argc;
28 char *argv[];
29 {
30 int rdy, inp, res = 0, pause = 0;
31
32 progname = argv[0];
33 if (argc != 2)
34 error(USER, "bad command line arguments");
35 /* open our device */
36 dev_open(argv[1]);
37 /* enter main loop */
38 do {
39 rdy = disp_wait();
40 if (rdy & RDY_DEV) { /* get user input */
41 inp = dev_input();
42 if (inp & DEV_NEWVIEW)
43 new_view(&odev.v);
44 if (inp & DEV_SHUTDOWN)
45 serv_request(DR_SHUTDOWN, 0, NULL);
46 if (inp & DEV_REDRAW) {
47 imm_mode = 1; /* preempt updates */
48 beam_sync();
49 }
50 if (inp & DEV_WAIT)
51 pause = 1;
52 if (inp & DEV_RESUME) {
53 serv_request(DR_NOOP, 0, NULL);
54 pause = 0;
55 }
56 }
57 if (rdy & RDY_SRV) { /* get server result */
58 res = serv_result();
59 if (pause && res != DS_SHUTDOWN) {
60 serv_request(DR_ATTEN, 0, NULL);
61 while ((res = serv_result()) != DS_ACKNOW &&
62 res != DS_SHUTDOWN)
63 ;
64 }
65 }
66 } while (res != DS_SHUTDOWN);
67 /* all done */
68 quit(0);
69 }
70
71
72 int
73 disp_wait() /* wait for more input */
74 {
75 fd_set readset, errset;
76 int flgs;
77 int n;
78 register int i;
79 /* see if we can avoid select call */
80 if (imm_mode || stdin->_cnt > 0)
81 return(RDY_SRV);
82 if (dev_flush())
83 return(RDY_DEV);
84 /* make the call */
85 FD_ZERO(&readset); FD_ZERO(&errset);
86 FD_SET(0, &readset);
87 FD_SET(0, &errset);
88 FD_SET(odev.ifd, &readset);
89 FD_SET(odev.ifd, &errset);
90 n = odev.ifd + 1;
91 n = select(n, &readset, NULL, &errset, NULL);
92 if (n < 0) {
93 if (errno == EINTR)
94 return(0);
95 error(SYSTEM, "select call failure in disp_wait");
96 }
97 flgs = 0; /* flag what's ready */
98 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
99 flgs |= RDY_SRV;
100 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
101 flgs |= RDY_DEV;
102 return(flgs);
103 }
104
105
106 add_holo(hdg) /* register a new holodeck section */
107 HDGRID *hdg;
108 {
109 VIEW nv;
110 register int hd;
111
112 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
113 ;
114 if (hd >= HDMAX)
115 error(INTERNAL, "too many holodeck sections in add_holo");
116 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
117 if (hdlist[hd] == NULL)
118 error(SYSTEM, "out of memory in add_holo");
119 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
120 hdcompgrid(hdlist[hd]);
121 if (hd)
122 return;
123 /* set initial viewpoint */
124 copystruct(&nv, &odev.v);
125 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
126 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
127 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
128 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
129 VCOPY(nv.vup, hdlist[0]->xv[2]);
130 new_view(&nv);
131 }
132
133
134 disp_bundle(p) /* display a ray bundle */
135 register PACKHEAD *p;
136 {
137 GCOORD gc[2];
138 FVECT ro, rd, wp;
139 double d;
140 register int i;
141 /* get beam coordinates */
142 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
143 error(INTERNAL, "bad holodeck number in disp_bundle");
144 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
145 error(INTERNAL, "bad beam index in disp_bundle");
146 /* display each ray */
147 for (i = p->nr; i--; ) {
148 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
149 d = hddepth(hdlist[p->hd], packra(p)[i].d);
150 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
151 dev_value(packra(p)[i].v, wp);
152 }
153 }
154
155
156 new_view(v) /* change view parameters */
157 VIEW *v;
158 {
159 char *err;
160
161 do {
162 if ((err = setview(v)) != NULL)
163 error(INTERNAL, err);
164 dev_view(v); /* update display driver */
165 dev_flush(); /* update screen */
166 } while (!beam_view(v)); /* update beam list */
167 }
168
169
170 int
171 serv_result() /* get next server result and process it */
172 {
173 static char *buf = NULL;
174 static int bufsiz = 0;
175 MSGHEAD msg;
176 int n;
177 /* read message header */
178 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
179 goto readerr;
180 if (msg.nbytes > 0) { /* get the message body */
181 if (msg.nbytes > bufsiz) {
182 if (buf == NULL)
183 buf = (char *)malloc(bufsiz=msg.nbytes);
184 else
185 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
186 if (buf == NULL)
187 error(SYSTEM, "out of memory in serv_result");
188 }
189 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
190 goto readerr;
191 }
192 switch (msg.type) { /* process results */
193 case DS_BUNDLE:
194 if (msg.nbytes < sizeof(PACKHEAD) ||
195 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
196 error(INTERNAL, "bad display packet from server");
197 disp_bundle((PACKHEAD *)buf);
198 break;
199 case DS_ADDHOLO:
200 if (msg.nbytes != sizeof(HDGRID))
201 error(INTERNAL, "bad holodeck record from server");
202 add_holo((HDGRID *)buf);
203 break;
204 case DS_STARTIMM:
205 case DS_ENDIMM:
206 imm_mode = msg.type==DS_STARTIMM;
207 if (msg.type == DS_ENDIMM)
208 dev_flush(); /* update display NOW */
209 /* fall through */
210 case DS_ACKNOW:
211 case DS_SHUTDOWN:
212 if (msg.nbytes) {
213 sprintf(errmsg,
214 "unexpected body with server message %d",
215 msg.type);
216 error(INTERNAL, errmsg);
217 }
218 break;
219 default:
220 error(INTERNAL, "unrecognized result from server process");
221 }
222 return(msg.type); /* return message type */
223 readerr:
224 if (feof(stdin))
225 error(SYSTEM, "server process died");
226 error(SYSTEM, "error reading from server process");
227 }
228
229
230 serv_request(type, nbytes, p) /* send a request to the server process */
231 int type, nbytes;
232 char *p;
233 {
234 MSGHEAD msg;
235 int m;
236 /* get server's attention for big request */
237 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
238 serv_request(DR_ATTEN, 0, NULL);
239 while ((m = serv_result()) != DS_ACKNOW)
240 if (m == DS_SHUTDOWN) /* the bugger quit on us */
241 quit(0);
242 }
243 msg.type = type; /* write and flush the message */
244 msg.nbytes = nbytes;
245 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
246 if (nbytes > 0)
247 fwrite(p, 1, nbytes, stdout);
248 if (fflush(stdout) < 0)
249 error(SYSTEM, "write error in serv_request");
250 }
251
252
253 eputs(s) /* put error message to stderr */
254 register char *s;
255 {
256 static int midline = 0;
257
258 if (!*s)
259 return;
260 if (!midline++) { /* prepend line with program name */
261 fputs(progname, stderr);
262 fputs(": ", stderr);
263 }
264 fputs(s, stderr);
265 if (s[strlen(s)-1] == '\n') {
266 fflush(stderr);
267 midline = 0;
268 }
269 }
270
271
272 quit(code) /* clean up and exit */
273 int code;
274 {
275 if (odev.v.type)
276 dev_close();
277 exit(code);
278 }
