root/radiance/ray/src/hd/rhdisp.c
Revision: 3.48
Committed: Mon Jul 21 22:30:18 2003 UTC (22 years ago) by schorsch
Changes since 3.47: +6 -6 lines
2 static const char RCSid[] = "$Id: rhdisp.c,v 3.47 2003/06/30 14:59:11 schorsch Exp $";
5 * Holodeck display process.
6 */
7
8 #include <string.h>
9 #include <ctype.h>
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15
16 #ifndef VIEWHISTLEN
17 #define VIEWHISTLEN 4 /* number of remembered views */
18 #endif
19
20 #ifndef FSIZDEF
21 #define FSIZDEF 0.125 /* default focus frame size */
22 #endif
23
24 #if defined(freebsd)
25 #define fbufcnt(f) ((f)->_r)
26 #elif defined(__GNUC__)
27 #define fbufcnt(f) ((f)->_IO_read_end - (f)->_IO_read_ptr)
28 #else
29 #define fbufcnt(f) ((f)->_cnt)
30 #endif
31
32 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
33
34 char *hdgfn[HDMAX]; /* holodeck section geometry list */
35 char *hdpfn[HDMAX]; /* section portal list */
36
37 char cmdlist[DC_NCMDS][8] = DC_INIT;
38
39 int imm_mode = 0; /* bundles are being delivered immediately */
40
41 int do_outside = 0; /* render from outside sections */
42
43 double eyesepdist = 1; /* eye separation distance */
44
45 char *progname; /* global argv[0] */
46
47 FILE *sstdin, *sstdout; /* server's standard input and output */
48
49 #ifdef DEBUG
50 extern time_t time();
51 static time_t tmodesw;
52 static time_t timm, tadd;
53 static long nimmrays, naddrays;
54 #endif
55
56 #define RDY_SRV 01
57 #define RDY_DEV 02
58 #define RDY_SIN 04
59
60
61 main(argc, argv)
62 int argc;
63 char *argv[];
64 {
65 int rdy, inp, res = 0, pause = 0;
66
67 progname = argv[0];
68 if (argc < 3)
69 error(USER, "bad command line arguments");
70 /* open our device */
71 dev_open(argv[1]);
72 /* open server process i/o */
73 sstdout = fdopen(atoi(argv[2]), "w");
74 if (argc < 4 || (inp = atoi(argv[3])) < 0)
75 sstdin = NULL;
76 else
77 sstdin = fdopen(inp, "r");
78 /* set command error vector */
79 erract[COMMAND].pf = eputs;
80 #ifdef DEBUG
81 tmodesw = time(NULL);
82 #endif
83 /* enter main loop */
84 do {
85 rdy = disp_wait();
86 if (rdy & RDY_SRV) { /* process server result */
87 res = serv_result();
88 if (pause && res != DS_SHUTDOWN) {
89 serv_request(DR_ATTEN, 0, NULL);
90 while ((res = serv_result()) != DS_ACKNOW &&
91 res != DS_SHUTDOWN)
92 ;
93 }
94 }
95 if (rdy & RDY_DEV) { /* user input from driver */
96 inp = dev_input();
97 if (inp & DFL(DC_SETVIEW))
98 new_view(&odev.v);
99 else if (inp & DFL(DC_LASTVIEW))
100 new_view(NULL);
101 if (inp & DFL(DC_REDRAW))
102 imm_mode = beam_sync(1) > 0;
103 if (inp & DFL(DC_GETVIEW))
104 printview();
105 if (inp & DFL(DC_FOCUS))
106 set_focus(odev_args);
107 if (inp & DFL(DC_KILL)) {
108 serv_request(DR_KILL, 0, NULL);
109 pause = 0;
110 }
111 if (inp & DFL(DC_CLOBBER))
112 serv_request(DR_CLOBBER, 0, NULL);
113 if (inp & DFL(DC_RESTART)) {
114 serv_request(DR_RESTART, 0, NULL);
115 pause = 0;
116 }
117 if (inp & DFL(DC_RESUME)) {
118 serv_request(DR_NOOP, 0, NULL);
119 pause = 0;
120 }
121 if (inp & DFL(DC_PAUSE))
122 pause = 1;
123 if (inp & DFL(DC_QUIT))
124 serv_request(DR_SHUTDOWN, 0, NULL);
125 }
126 if (rdy & RDY_SIN && !imm_mode) /* user input from sstdin */
127 switch (usr_input()) {
128 case DC_PAUSE:
129 pause = 1;
130 break;
131 case DC_RESUME:
132 serv_request(DR_NOOP, 0, NULL);
133 /* fall through */
134 case DC_KILL:
135 case DC_RESTART:
136 pause = 0;
137 break;
138 }
139 } while (res != DS_SHUTDOWN);
140 #ifdef DEBUG
141 if (timm && nimmrays)
142 fprintf(stderr,
143 "%s: %.1f rays recalled/second (%ld rays total)\n",
144 progname, (double)nimmrays/timm, nimmrays);
145 if (tadd && naddrays)
146 fprintf(stderr,
147 "%s: %.1f rays calculated/second (%ld rays total)\n",
148 progname, (double)naddrays/tadd, naddrays);
149 #endif
150 /* all done */
151 quit(0);
152 }
153
154
155 int
156 disp_wait() /* wait for more input */
157 {
158 fd_set readset, errset;
159 int flgs;
160 int n;
161 register int i;
162 /* see if we can avoid select call */
163 if (hdlist[0] == NULL)
164 return(RDY_SRV); /* initialize first */
165 flgs = 0; /* flag what's ready already */
166 if (imm_mode || fbufcnt(stdin) > 0)
167 flgs |= RDY_SRV;
168 if (sstdin != NULL && fbufcnt(sstdin) > 0)
169 flgs |= RDY_SIN;
170 if (odev.inpready)
171 flgs |= RDY_DEV;
172 if (flgs) /* got something? */
173 return(flgs);
174 if (dev_flush()) /* else flush output & check keyboard+mouse */
175 return(RDY_DEV);
176 /* if nothing, we need to call select */
177 FD_ZERO(&readset); FD_ZERO(&errset);
178 FD_SET(0, &readset);
179 FD_SET(0, &errset);
180 FD_SET(odev.ifd, &readset);
181 FD_SET(odev.ifd, &errset);
182 n = odev.ifd+1;
183 if (sstdin != NULL) {
184 FD_SET(fileno(sstdin), &readset);
185 FD_SET(fileno(sstdin), &errset);
186 if (fileno(sstdin) >= n)
187 n = fileno(sstdin) + 1;
188 }
189 n = select(n, &readset, NULL, &errset, NULL);
190 if (n < 0) {
191 if (errno == EINTR)
192 return(0);
193 error(SYSTEM, "select call failure in disp_wait");
194 }
195 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
196 flgs |= RDY_SRV;
197 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
198 flgs |= RDY_DEV;
199 if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) ||
200 FD_ISSET(fileno(sstdin), &errset)))
201 flgs |= RDY_SIN;
202 return(flgs);
203 }
204
205
206 add_holo(hdg, gfn, pfn) /* register a new holodeck section */
207 HDGRID *hdg;
208 char *gfn, *pfn;
209 {
210 VIEW nv;
211 double d;
212 register int hd;
213
214 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
215 ;
216 if (hd >= HDMAX)
217 error(INTERNAL, "too many holodeck sections in add_holo");
218 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
219 if (hdlist[hd] == NULL)
220 error(SYSTEM, "out of memory in add_holo");
221 memcpy((void *)hdlist[hd], (void *)hdg, sizeof(HDGRID));
222 hdcompgrid(hdlist[hd]);
223 hdgfn[hd] = savestr(gfn);
224 hdpfn[hd] = pfn && *pfn ? savestr(pfn) : (char *)NULL;
225 if (hd)
226 return;
227 /* set initial viewpoint */
228 nv = odev.v;
229 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
230 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
231 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
232 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
233 VCOPY(nv.vup, hdlist[0]->xv[2]);
234 if (do_outside) {
235 normalize(nv.vdir);
236 d = VLEN(hdlist[0]->xv[1]);
237 d += VLEN(hdlist[0]->xv[2]);
238 VSUM(nv.vp, nv.vp, nv.vdir, -d);
239 }
240 new_view(&nv);
241 }
242
243
244 disp_bundle(p) /* display a ray bundle */
245 register PACKHEAD *p;
246 {
247 GCOORD gc[2];
248 FVECT ro, rd, wp;
249 double d;
250 register int i;
251 /* get beam coordinates */
252 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
253 error(INTERNAL, "bad holodeck number in disp_bundle");
254 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
255 error(INTERNAL, "bad beam index in disp_bundle");
256 /* display each ray */
257 for (i = p->nr; i--; ) {
258 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
259 d = hddepth(hdlist[p->hd], packra(p)[i].d);
260 if (d < .99*FHUGE) {
261 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
262 dev_value(packra(p)[i].v, rd, wp);
263 } else
264 dev_value(packra(p)[i].v, rd, NULL);
265 }
266 #ifdef DEBUG
267 if (imm_mode) nimmrays += p->nr;
268 else naddrays += p->nr;
269 #endif
270 }
271
272
273 new_view(v) /* change view parameters */
274 register VIEW *v;
275 {
276 static VIEW viewhist[VIEWHISTLEN];
277 static unsigned nhist;
278 VIEW *dv;
279 int i, res[2];
280 int16 *slist;
281 char *err;
282 /* restore previous view? */
283 if (v == NULL) {
284 if (nhist > 1) /* get one before last setting */
285 nhist--;
286 else /* else go to end of list */
287 while (nhist < VIEWHISTLEN && viewhist[nhist].type)
288 nhist++;
289 v = viewhist + ((nhist-1)%VIEWHISTLEN);
290 } else
291 again:
292 if ((err = setview(v)) != NULL) {
293 error(COMMAND, err);
294 return;
295 }
296 if (!dev_view(v)) /* notify display driver */
297 goto again;
298 if (v->type == VT_PAR) {
299 error(COMMAND, "cannot handle parallel views");
300 return;
301 }
302 beam_init(odev.firstuse); /* compute new beam set */
303 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) {
304 if ((slist = beam_view(dv, res[0], res[1])) == NULL) {
305 if (!nhist) {
306 error(COMMAND, "invalid starting view");
307 return;
308 }
309 *v = *(viewhist + ((nhist-1)%VIEWHISTLEN));
310 goto again; /* poss. overloading dev_section()? */
311 }
312 DCHECK(*slist < 0, WARNING, "no visible sections in new_view");
313 for ( ; *slist >= 0; slist++)
314 dev_section(hdgfn[*slist], hdpfn[*slist]);
315 }
316 dev_section(NULL,NULL); /* end section list */
317 dev_flush(); /* update display */
318 /* update server */
319 imm_mode = beam_sync(odev.firstuse) > 0;
320 /* record new view */
321 if (v < viewhist || v >= viewhist+VIEWHISTLEN) {
322 *(viewhist + (nhist%VIEWHISTLEN)) = *v;
323 nhist++;
324 }
325 }
326
327
328 set_focus(args) /* set focus frame */
329 char *args;
330 {
331 double hcent, vcent, hsiz, vsiz;
332 VIEW *dv, vwfocus;
333 int i, res[2];
334
335 i = sscanf(args, "%lf %lf %lf %lf", &hcent, &vcent, &hsiz, &vsiz);
336 if (i < 2 || hcent < 0 || hcent > 1 || vcent < 0 || vcent > 1) {
337 beam_init(0); /* restore view */
338 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
339 beam_view(dv, res[0], res[1]);
340 beam_sync(0); /* update server */
341 return;
342 }
343 if (i < 4 || hsiz <= hcent || hsiz > 1 || vsiz <= vcent || vsiz > 1)
344 hsiz = vsiz = FSIZDEF; /* gave center only */
345 else {
346 hsiz -= hcent; hcent += 0.5*hsiz; /* gave min and max */
347 vsiz -= vcent; vcent += 0.5*vsiz;
348 }
349 beam_init(0); /* add basic views */
350 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
351 beam_view(dv, res[0]>>4, res[1]>>4);
352 vwfocus = odev.v; /* add focus view */
353 switch (odev.v.type) {
354 case VT_PER:
355 vwfocus.horiz = 2.*180./PI*atan(
356 hsiz * tan(PI/180./2.*odev.v.horiz) );
357 vwfocus.vert = 2.*180./PI*atan(
358 vsiz * tan(PI/180./2.*odev.v.vert) );
359 break;
360 case VT_PAR:
361 case VT_ANG:
362 vwfocus.horiz = hsiz * odev.v.horiz;
363 vwfocus.vert = vsiz * odev.v.vert;
364 break;
365 case VT_HEM:
366 vwfocus.horiz = 2.*180./PI*asin(
367 hsiz * sin(PI/180./2.*odev.v.horiz) );
368 vwfocus.vert = 2.*180./PI*asin(
369 vsiz * sin(PI/180./2.*odev.v.vert) );
370 break;
371 case VT_CYL:
372 vwfocus.horiz = hsiz * odev.v.horiz;
373 vwfocus.vert = 2.*180./PI*atan(
374 vsiz * tan(PI/180./2.*odev.v.vert) );
375 break;
376 default:
377 error(INTERNAL, "bad view type in set_focus");
378 }
379 vwfocus.hoff = (odev.v.hoff + hcent - 0.5)/hsiz;
380 vwfocus.voff = (odev.v.voff + vcent - 0.5)/vsiz;
381 setview(&vwfocus);
382 beam_view(&vwfocus, (int)(3*odev.hres*hsiz)+100,
383 (int)(3*odev.vres*vsiz)+100);
384 beam_sync(0); /* update server */
385 }
386
387
388 int
389 usr_input() /* get user input and process it */
390 {
391 VIEW vparams;
392 char cmd[256];
393 register char *args;
394 register int i;
395
396 if (fgets(cmd, sizeof(cmd), sstdin) == NULL) {
397 fclose(sstdin);
398 sstdin = NULL;
399 return(-1);
400 }
401 if (*cmd == '\n')
402 return(DC_RESUME);
403 for (args = cmd; *args && !isspace(*args); args++)
404 ;
405 while (isspace(*args))
406 *args++ = '\0';
407 if (*args && args[i=strlen(args)-1] == '\n')
408 args[i] = '\0';
409 for (i = 0; i < DC_NCMDS; i++)
410 if (!strcmp(cmd, cmdlist[i]))
411 break;
412 if (i >= DC_NCMDS) {
413 dev_auxcom(cmd, args);
414 return(-1);
415 }
416 switch (i) {
417 case DC_SETVIEW: /* set the view */
418 vparams = odev.v;
419 if (!sscanview(&vparams, args))
420 error(COMMAND, "missing view options");
421 else
422 new_view(&vparams);
423 break;
424 case DC_GETVIEW: /* print the current view */
425 printview();
426 break;
427 case DC_LASTVIEW: /* restore previous view */
428 new_view(NULL);
429 break;
430 case DC_FOCUS: /* set focus frame */
431 set_focus(args);
432 break;
433 case DC_PAUSE: /* pause the current calculation */
434 case DC_RESUME: /* resume the calculation */
435 /* handled in main() */
436 break;
437 case DC_REDRAW: /* redraw from server */
438 imm_mode = beam_sync(1) > 0;
439 dev_clear();
440 break;
441 case DC_KILL: /* kill rtrace process(es) */
442 serv_request(DR_KILL, 0, NULL);
443 break;
444 case DC_CLOBBER: /* clobber holodeck */
445 serv_request(DR_CLOBBER, 0, NULL);
446 break;
447 case DC_RESTART: /* restart rtrace */
448 serv_request(DR_RESTART, 0, NULL);
449 break;
450 case DC_QUIT: /* quit request */
451 serv_request(DR_SHUTDOWN, 0, NULL);
452 break;
453 default:
454 error(CONSISTENCY, "bad command id in usr_input");
455 }
456 return(i);
457 }
458
459
460 printview() /* print our current view to server stdout */
461 {
462 fputs(VIEWSTR, sstdout);
463 fprintview(&odev.v, sstdout);
464 fputc('\n', sstdout);
465 fflush(sstdout);
466 }
467
468
469 int
470 serv_result() /* get next server result and process it */
471 {
472 static char *buf = NULL;
473 static int bufsiz = 0;
474 MSGHEAD msg;
475 int n;
476 /* read message header */
477 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
478 goto readerr;
479 if (msg.nbytes > 0) { /* get the message body */
480 if (msg.nbytes > bufsiz) {
481 if (buf == NULL)
482 buf = (char *)malloc(bufsiz=msg.nbytes);
483 else
484 buf = (char *)realloc((void *)buf,
485 bufsiz=msg.nbytes);
486 if (buf == NULL)
487 error(SYSTEM, "out of memory in serv_result");
488 }
489 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
490 goto readerr;
491 }
492 switch (msg.type) { /* process results */
493 case DS_BUNDLE:
494 if (msg.nbytes < sizeof(PACKHEAD) ||
495 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
496 error(INTERNAL, "bad display packet from server");
497 disp_bundle((PACKHEAD *)buf);
498 break;
499 case DS_ADDHOLO:
500 if (msg.nbytes < sizeof(HDGRID)+2)
501 error(INTERNAL, "bad holodeck record from server");
502 add_holo((HDGRID *)buf, buf+sizeof(HDGRID),
503 buf+sizeof(HDGRID)+strlen(buf+sizeof(HDGRID))+1);
504 break;
505 case DS_OUTSECT:
506 do_outside = 1;
507 goto noargs;
508 case DS_EYESEP:
509 if (msg.nbytes <= 1 || (eyesepdist = atof(buf)) <= FTINY)
510 error(INTERNAL, "bad eye separation from server");
511 break;
512 case DS_STARTIMM:
513 case DS_ENDIMM:
514 if (!(imm_mode = msg.type==DS_STARTIMM))
515 dev_flush();
516 #ifdef DEBUG
517 {
518 time_t tnow = time(NULL);
519 if (msg.type==DS_STARTIMM) tadd += tnow - tmodesw;
520 else timm += tnow - tmodesw;
521 tmodesw = tnow;
522 }
523 #endif
524 goto noargs;
525 case DS_ACKNOW:
526 case DS_SHUTDOWN:
527 goto noargs;
528 default:
529 error(INTERNAL, "unrecognized result from server process");
530 }
531 return(msg.type); /* return message type */
532 noargs:
533 if (msg.nbytes) {
534 sprintf(errmsg, "unexpected body with server message %d",
535 msg.type);
536 error(INTERNAL, errmsg);
537 }
538 return(msg.type);
539 readerr:
540 if (feof(stdin))
541 error(SYSTEM, "server process died");
542 error(SYSTEM, "error reading from server process");
543 }
544
545
546 serv_request(type, nbytes, p) /* send a request to the server process */
547 int type, nbytes;
548 char *p;
549 {
550 MSGHEAD msg;
551 int m;
552 /* consistency checks */
553 DCHECK(nbytes < 0 || nbytes > 0 & p == NULL,
554 CONSISTENCY, "bad buffer handed to serv_request");
555 /* get server's attention for big request */
556 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
557 serv_request(DR_ATTEN, 0, NULL);
558 while ((m = serv_result()) != DS_ACKNOW)
559 if (m == DS_SHUTDOWN) /* the bugger quit on us */
560 quit(0);
561 }
562 msg.type = type; /* write and flush the message */
563 msg.nbytes = nbytes;
564 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
565 if (nbytes > 0)
566 fwrite(p, 1, nbytes, stdout);
567 if (fflush(stdout) < 0)
568 error(SYSTEM, "write error in serv_request");
569 }
570
571
572 void
573 eputs(s) /* put error message to stderr */
574 register char *s;
575 {
576 static int midline = 0;
577
578 if (!*s)
579 return;
580 if (!midline++) { /* prepend line with program name */
581 fputs(progname, stderr);
582 fputs(": ", stderr);
583 }
584 fputs(s, stderr);
585 if (s[strlen(s)-1] == '\n') {
586 fflush(stderr);
587 midline = 0;
588 }
589 }
590
591
592 void
593 quit(code) /* clean up and exit */
594 int code;
595 {
596 if (code)
597 exit(code);
598 if (odev.v.type)
599 dev_close();
600 exit(0);
601 }
