root/radiance/ray/src/hd/rhdisp.c
Revision: 3.28
Committed: Fri Jul 31 16:53:47 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.27: +10 -9 lines
simplified error checking logic
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15 #include <ctype.h>
16
17 #ifndef VIEWHISTLEN
18 #define VIEWHISTLEN 4 /* number of remembered views */
19 #endif
20
21 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
22
23 char cmdlist[DC_NCMDS][8] = DC_INIT;
24
25 int imm_mode = 0; /* bundles are being delivered immediately */
26
27 int do_outside = 0; /* render from outside sections */
28
29 double eyesepdist = 1; /* eye separation distance */
30
31 char *progname; /* global argv[0] */
32
33 FILE *sstdin, *sstdout; /* server's standard input and output */
34
35 #ifdef DEBUG
36 #include <sys/types.h>
37 extern time_t time();
38 static time_t tmodesw;
39 static time_t timm, tadd;
40 static long nimmrays, naddrays;
41 #endif
42
43 #define RDY_SRV 01
44 #define RDY_DEV 02
45 #define RDY_SIN 04
46
47
48 main(argc, argv)
49 int argc;
50 char *argv[];
51 {
52 extern int eputs();
53 int rdy, inp, res = 0, pause = 0;
54
55 progname = argv[0];
56 if (argc < 3)
57 error(USER, "bad command line arguments");
58 /* open our device */
59 dev_open(argv[1]);
60 /* open server process i/o */
61 sstdout = fdopen(atoi(argv[2]), "w");
62 if (argc < 4 || (inp = atoi(argv[3])) < 0)
63 sstdin = NULL;
64 else
65 sstdin = fdopen(inp, "r");
66 /* set command error vector */
67 erract[COMMAND].pf = eputs;
68 #ifdef DEBUG
69 tmodesw = time(NULL);
70 #endif
71 /* enter main loop */
72 do {
73 rdy = disp_wait();
74 if (rdy & RDY_SRV) { /* process server result */
75 res = serv_result();
76 if (pause && res != DS_SHUTDOWN) {
77 serv_request(DR_ATTEN, 0, NULL);
78 while ((res = serv_result()) != DS_ACKNOW &&
79 res != DS_SHUTDOWN)
80 ;
81 }
82 }
83 if (rdy & RDY_DEV) { /* user input from driver */
84 inp = dev_input();
85 if (inp & DFL(DC_SETVIEW))
86 new_view(&odev.v);
87 if (inp & DFL(DC_GETVIEW))
88 printview();
89 if (inp & DFL(DC_LASTVIEW))
90 new_view(NULL);
91 if (inp & DFL(DC_RESUME)) {
92 serv_request(DR_NOOP, 0, NULL);
93 pause = 0;
94 }
95 if (inp & DFL(DC_PAUSE))
96 pause = 1;
97 if (inp & DFL(DC_REDRAW))
98 imm_mode = beam_sync(1) > 0;
99 if (inp & DFL(DC_KILL)) {
100 serv_request(DR_KILL, 0, NULL);
101 pause = 0;
102 }
103 if (inp & DFL(DC_CLOBBER))
104 serv_request(DR_CLOBBER, 0, NULL);
105 if (inp & DFL(DC_RESTART)) {
106 serv_request(DR_RESTART, 0, NULL);
107 pause = 0;
108 }
109 if (inp & DFL(DC_QUIT))
110 serv_request(DR_SHUTDOWN, 0, NULL);
111 }
112 if (rdy & RDY_SIN) /* user input from sstdin */
113 switch (usr_input()) {
114 case DC_PAUSE:
115 pause = 1;
116 break;
117 case DC_RESUME:
118 serv_request(DR_NOOP, 0, NULL);
119 /* fall through */
120 case DC_KILL:
121 case DC_RESTART:
122 pause = 0;
123 break;
124 }
125 } while (res != DS_SHUTDOWN);
126 #ifdef DEBUG
127 if (timm && nimmrays)
128 fprintf(stderr,
129 "%s: %.1f rays recalled/second (%ld rays total)\n",
130 progname, (double)nimmrays/timm, nimmrays);
131 if (tadd && naddrays)
132 fprintf(stderr,
133 "%s: %.1f rays calculated/second (%ld rays total)\n",
134 progname, (double)naddrays/tadd, naddrays);
135 #endif
136 /* all done */
137 quit(0);
138 }
139
140
141 int
142 disp_wait() /* wait for more input */
143 {
144 fd_set readset, errset;
145 int flgs;
146 int n;
147 register int i;
148 /* see if we can avoid select call */
149 if (imm_mode || stdin->_cnt > 0)
150 return(RDY_SRV);
151 if (sstdin != NULL && sstdin->_cnt > 0)
152 return(RDY_SIN);
153 if (dev_flush())
154 return(RDY_DEV);
155 /* make the call */
156 FD_ZERO(&readset); FD_ZERO(&errset);
157 FD_SET(0, &readset);
158 FD_SET(0, &errset);
159 FD_SET(odev.ifd, &readset);
160 FD_SET(odev.ifd, &errset);
161 n = odev.ifd+1;
162 if (sstdin != NULL) {
163 FD_SET(fileno(sstdin), &readset);
164 FD_SET(fileno(sstdin), &errset);
165 if (fileno(sstdin) >= n)
166 n = fileno(sstdin) + 1;
167 }
168 n = select(n, &readset, NULL, &errset, NULL);
169 if (n < 0) {
170 if (errno == EINTR)
171 return(0);
172 error(SYSTEM, "select call failure in disp_wait");
173 }
174 flgs = 0; /* flag what's ready */
175 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
176 flgs |= RDY_SRV;
177 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
178 flgs |= RDY_DEV;
179 if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) ||
180 FD_ISSET(fileno(sstdin), &errset)))
181 flgs |= RDY_SIN;
182 return(flgs);
183 }
184
185
186 add_holo(hdg) /* register a new holodeck section */
187 HDGRID *hdg;
188 {
189 VIEW nv;
190 double d;
191 register int hd;
192
193 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
194 ;
195 if (hd >= HDMAX)
196 error(INTERNAL, "too many holodeck sections in add_holo");
197 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
198 if (hdlist[hd] == NULL)
199 error(SYSTEM, "out of memory in add_holo");
200 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
201 hdcompgrid(hdlist[hd]);
202 if (hd)
203 return;
204 /* set initial viewpoint */
205 copystruct(&nv, &odev.v);
206 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
207 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
208 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
209 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
210 VCOPY(nv.vup, hdlist[0]->xv[2]);
211 if (do_outside) {
212 normalize(nv.vdir);
213 d = VLEN(hdlist[0]->xv[1]);
214 d += VLEN(hdlist[0]->xv[2]);
215 VSUM(nv.vp, nv.vp, nv.vdir, -d);
216 }
217 new_view(&nv);
218 }
219
220
221 disp_bundle(p) /* display a ray bundle */
222 register PACKHEAD *p;
223 {
224 GCOORD gc[2];
225 FVECT ro, rd, wp;
226 double d;
227 register int i;
228 /* get beam coordinates */
229 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
230 error(INTERNAL, "bad holodeck number in disp_bundle");
231 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
232 error(INTERNAL, "bad beam index in disp_bundle");
233 /* display each ray */
234 for (i = p->nr; i--; ) {
235 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
236 d = hddepth(hdlist[p->hd], packra(p)[i].d);
237 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
238 dev_value(packra(p)[i].v, wp, rd);
239 }
240 #ifdef DEBUG
241 if (imm_mode) nimmrays += p->nr;
242 else naddrays += p->nr;
243 #endif
244 }
245
246
247 new_view(v) /* change view parameters */
248 register VIEW *v;
249 {
250 static VIEW viewhist[VIEWHISTLEN];
251 static unsigned nhist;
252 VIEW *dv;
253 int i, res[2];
254 char *err;
255 /* restore previous view? */
256 if (v == NULL) {
257 if (nhist > 1) /* get one before last setting */
258 nhist--;
259 else /* else go to end of list */
260 while (nhist < VIEWHISTLEN && viewhist[nhist].type)
261 nhist++;
262 v = viewhist + ((nhist-1)%VIEWHISTLEN);
263 } else
264 again:
265 if ((err = setview(v)) != NULL) {
266 error(COMMAND, err);
267 return;
268 }
269 if (v->type == VT_PAR) {
270 error(COMMAND, "cannot handle parallel views");
271 return;
272 }
273 if (!dev_view(v)) /* notify display driver */
274 goto again;
275 dev_flush(); /* update screen */
276 beam_init(0); /* compute new beam set */
277 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
278 if (!beam_view(dv, res[0], res[1])) {
279 if (!nhist) {
280 error(COMMAND, "invalid starting view");
281 return;
282 }
283 copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN));
284 goto again;
285 }
286 beam_sync(0); /* update server */
287 /* record new view */
288 if (v < viewhist || v >= viewhist+VIEWHISTLEN) {
289 copystruct(viewhist + (nhist%VIEWHISTLEN), v);
290 nhist++;
291 }
292 }
293
294
295 int
296 usr_input() /* get user input and process it */
297 {
298 VIEW vparams;
299 char cmd[256];
300 register char *args;
301 register int i;
302
303 if (fgets(cmd, sizeof(cmd), sstdin) == NULL) {
304 fclose(sstdin);
305 sstdin = NULL;
306 return(-1);
307 }
308 if (!*cmd)
309 return(DC_RESUME);
310 for (args = cmd; *args && !isspace(*args); args++)
311 ;
312 while (isspace(*args))
313 *args++ = '\0';
314 if (*args && args[i=strlen(args)-1] == '\n')
315 args[i] = '\0';
316 for (i = 0; i < DC_NCMDS; i++)
317 if (!strcmp(cmd, cmdlist[i]))
318 break;
319 if (i >= DC_NCMDS) {
320 dev_auxcom(cmd, args);
321 return(-1);
322 }
323 switch (i) {
324 case DC_SETVIEW: /* set the view */
325 copystruct(&vparams, &odev.v);
326 if (!sscanview(&vparams, args))
327 error(COMMAND, "missing view options");
328 else
329 new_view(&vparams);
330 break;
331 case DC_GETVIEW: /* print the current view */
332 printview();
333 break;
334 case DC_LASTVIEW: /* restore previous view */
335 new_view(NULL);
336 break;
337 case DC_PAUSE: /* pause the current calculation */
338 case DC_RESUME: /* resume the calculation */
339 /* handled in main() */
340 break;
341 case DC_REDRAW: /* redraw from server */
342 imm_mode = beam_sync(1) > 0;
343 dev_clear();
344 break;
345 case DC_KILL: /* kill rtrace process(es) */
346 serv_request(DR_KILL, 0, NULL);
347 break;
348 case DC_CLOBBER: /* clobber holodeck */
349 serv_request(DR_CLOBBER, 0, NULL);
350 break;
351 case DC_RESTART: /* restart rtrace */
352 serv_request(DR_RESTART, 0, NULL);
353 break;
354 case DC_QUIT: /* quit request */
355 serv_request(DR_SHUTDOWN, 0, NULL);
356 break;
357 default:
358 error(CONSISTENCY, "bad command id in usr_input");
359 }
360 return(i);
361 }
362
363
364 printview() /* print our current view to server stdout */
365 {
366 fputs(VIEWSTR, sstdout);
367 fprintview(&odev.v, sstdout);
368 fputc('\n', sstdout);
369 fflush(sstdout);
370 }
371
372
373 int
374 serv_result() /* get next server result and process it */
375 {
376 static char *buf = NULL;
377 static int bufsiz = 0;
378 MSGHEAD msg;
379 int n;
380 /* read message header */
381 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
382 goto readerr;
383 if (msg.nbytes > 0) { /* get the message body */
384 if (msg.nbytes > bufsiz) {
385 if (buf == NULL)
386 buf = (char *)malloc(bufsiz=msg.nbytes);
387 else
388 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
389 if (buf == NULL)
390 error(SYSTEM, "out of memory in serv_result");
391 }
392 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
393 goto readerr;
394 }
395 switch (msg.type) { /* process results */
396 case DS_BUNDLE:
397 if (msg.nbytes < sizeof(PACKHEAD) ||
398 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
399 error(INTERNAL, "bad display packet from server");
400 disp_bundle((PACKHEAD *)buf);
401 break;
402 case DS_ADDHOLO:
403 if (msg.nbytes != sizeof(HDGRID))
404 error(INTERNAL, "bad holodeck record from server");
405 add_holo((HDGRID *)buf);
406 break;
407 case DS_OUTSECT:
408 do_outside = 1;
409 goto noargs;
410 case DS_EYESEP:
411 if (msg.nbytes <= 1 || (eyesepdist = atof(buf)) <= FTINY)
412 error(INTERNAL, "bad eye separation from server");
413 break;
414 case DS_STARTIMM:
415 case DS_ENDIMM:
416 #ifdef DEBUG
417 if (imm_mode != (msg.type==DS_STARTIMM)) {
418 time_t tnow = time(NULL);
419 if (imm_mode) timm += tnow - tmodesw;
420 else tadd += tnow - tmodesw;
421 tmodesw = tnow;
422 }
423 #endif
424 imm_mode = msg.type==DS_STARTIMM;
425 goto noargs;
426 case DS_ACKNOW:
427 case DS_SHUTDOWN:
428 goto noargs;
429 default:
430 error(INTERNAL, "unrecognized result from server process");
431 }
432 return(msg.type); /* return message type */
433 noargs:
434 if (msg.nbytes) {
435 sprintf(errmsg, "unexpected body with server message %d",
436 msg.type);
437 error(INTERNAL, errmsg);
438 }
439 return(msg.type);
440 readerr:
441 if (feof(stdin))
442 error(SYSTEM, "server process died");
443 error(SYSTEM, "error reading from server process");
444 }
445
446
447 serv_request(type, nbytes, p) /* send a request to the server process */
448 int type, nbytes;
449 char *p;
450 {
451 MSGHEAD msg;
452 int m;
453 /* get server's attention for big request */
454 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
455 serv_request(DR_ATTEN, 0, NULL);
456 while ((m = serv_result()) != DS_ACKNOW)
457 if (m == DS_SHUTDOWN) /* the bugger quit on us */
458 quit(0);
459 }
460 msg.type = type; /* write and flush the message */
461 msg.nbytes = nbytes;
462 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
463 if (nbytes > 0)
464 fwrite(p, 1, nbytes, stdout);
465 if (fflush(stdout) < 0)
466 error(SYSTEM, "write error in serv_request");
467 }
468
469
470 eputs(s) /* put error message to stderr */
471 register char *s;
472 {
473 static int midline = 0;
474
475 if (!*s)
476 return;
477 if (!midline++) { /* prepend line with program name */
478 fputs(progname, stderr);
479 fputs(": ", stderr);
480 }
481 fputs(s, stderr);
482 if (s[strlen(s)-1] == '\n') {
483 fflush(stderr);
484 midline = 0;
485 }
486 }
487
488
489 quit(code) /* clean up and exit */
490 int code;
491 {
492 if (odev.v.type)
493 dev_close();
494 exit(code);
495 }
