| 1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Holodeck display process.
| 9 |
| 10 |
| 11 |
#include "rholo.h"
| 12 |
#include "rhdisp.h"
| 13 |
#include "rhdriver.h"
| 14 |
#include "selcall.h"
| 15 |
#include <ctype.h>
| 16 |
| 17 |
#ifndef VIEWHISTLEN
| 18 |
#define VIEWHISTLEN 4 /* number of remembered views */
| 19 |
#endif
| 20 |
| 21 |
HOLO *hdlist[HDMAX+1]; /* global holodeck list */
| 22 |
| 23 |
char cmdlist[DC_NCMDS][8] = DC_INIT;
| 24 |
| 25 |
int imm_mode = 0; /* bundles are being delivered immediately */
| 26 |
| 27 |
int do_outside = 0; /* render from outside sections */
| 28 |
| 29 |
double eyesepdist = 1; /* eye separation distance */
| 30 |
| 31 |
char *progname; /* global argv[0] */
| 32 |
| 33 |
FILE *sstdin, *sstdout; /* server's standard input and output */
| 34 |
| 35 |
#ifdef DEBUG
| 36 |
#include <sys/types.h>
| 37 |
extern time_t time();
| 38 |
static time_t tmodesw;
| 39 |
static time_t timm, tadd;
| 40 |
static long nimmrays, naddrays;
| 41 |
#endif
| 42 |
| 43 |
#define RDY_SRV 01
| 44 |
#define RDY_DEV 02
| 45 |
#define RDY_SIN 04
| 46 |
| 47 |
| 48 |
main(argc, argv)
| 49 |
int argc;
| 50 |
char *argv[];
| 51 |
| 52 |
extern int eputs();
| 53 |
int rdy, inp, res = 0, pause = 0;
| 54 |
| 55 |
progname = argv[0];
| 56 |
if (argc < 3)
| 57 |
error(USER, "bad command line arguments");
| 58 |
/* open our device */
| 59 |
dev_open(argv[1]);
| 60 |
/* open server process i/o */
| 61 |
sstdout = fdopen(atoi(argv[2]), "w");
| 62 |
if (argc < 4 || (inp = atoi(argv[3])) < 0)
| 63 |
sstdin = NULL;
| 64 |
else
| 65 |
sstdin = fdopen(inp, "r");
| 66 |
/* set command error vector */
| 67 |
erract[COMMAND].pf = eputs;
| 68 |
#ifdef DEBUG
| 69 |
tmodesw = time(NULL);
| 70 |
#endif
| 71 |
/* enter main loop */
| 72 |
do {
| 73 |
rdy = disp_wait();
| 74 |
if (rdy & RDY_SRV) { /* process server result */
| 75 |
res = serv_result();
| 76 |
if (pause && res != DS_SHUTDOWN) {
| 77 |
serv_request(DR_ATTEN, 0, NULL);
| 78 |
while ((res = serv_result()) != DS_ACKNOW &&
| 79 |
res != DS_SHUTDOWN)
| 80 |
| 81 |
| 82 |
| 83 |
if (rdy & RDY_DEV) { /* user input from driver */
| 84 |
inp = dev_input();
| 85 |
if (inp & DFL(DC_SETVIEW))
| 86 |
new_view(&odev.v);
| 87 |
if (inp & DFL(DC_GETVIEW))
| 88 |
printview();
| 89 |
if (inp & DFL(DC_LASTVIEW))
| 90 |
new_view(NULL);
| 91 |
if (inp & DFL(DC_RESUME)) {
| 92 |
serv_request(DR_NOOP, 0, NULL);
| 93 |
pause = 0;
| 94 |
| 95 |
if (inp & DFL(DC_PAUSE))
| 96 |
pause = 1;
| 97 |
if (inp & DFL(DC_REDRAW))
| 98 |
imm_mode = beam_sync(1) > 0;
| 99 |
if (inp & DFL(DC_KILL)) {
| 100 |
serv_request(DR_KILL, 0, NULL);
| 101 |
pause = 0;
| 102 |
| 103 |
if (inp & DFL(DC_CLOBBER))
| 104 |
serv_request(DR_CLOBBER, 0, NULL);
| 105 |
if (inp & DFL(DC_RESTART)) {
| 106 |
serv_request(DR_RESTART, 0, NULL);
| 107 |
pause = 0;
| 108 |
| 109 |
if (inp & DFL(DC_QUIT))
| 110 |
serv_request(DR_SHUTDOWN, 0, NULL);
| 111 |
| 112 |
if (rdy & RDY_SIN) /* user input from sstdin */
| 113 |
switch (usr_input()) {
| 114 |
case DC_PAUSE:
| 115 |
pause = 1;
| 116 |
break;
| 117 |
case DC_RESUME:
| 118 |
| 119 |
/* fall through */
| 120 |
case DC_KILL:
| 121 |
case DC_RESTART:
| 122 |
pause = 0;
| 123 |
break;
| 124 |
| 125 |
} while (res != DS_SHUTDOWN);
| 126 |
#ifdef DEBUG
| 127 |
if (timm && nimmrays)
| 128 |
fprintf(stderr,
| 129 |
"%s: %.1f rays recalled/second (%ld rays total)\n",
| 130 |
progname, (double)nimmrays/timm, nimmrays);
| 131 |
if (tadd && naddrays)
| 132 |
fprintf(stderr,
| 133 |
"%s: %.1f rays calculated/second (%ld rays total)\n",
| 134 |
progname, (double)naddrays/tadd, naddrays);
| 135 |
#endif
| 136 |
/* all done */
| 137 |
quit(0);
| 138 |
| 139 |
| 140 |
| 141 |
int
| 142 |
disp_wait() /* wait for more input */
| 143 |
| 144 |
fd_set readset, errset;
| 145 |
int flgs;
| 146 |
int n;
| 147 |
register int i;
| 148 |
/* see if we can avoid select call */
| 149 |
if (imm_mode || stdin->_cnt > 0)
| 150 |
return(RDY_SRV);
| 151 |
if (sstdin != NULL && sstdin->_cnt > 0)
| 152 |
return(RDY_SIN);
| 153 |
if (dev_flush())
| 154 |
return(RDY_DEV);
| 155 |
/* make the call */
| 156 |
FD_ZERO(&readset); FD_ZERO(&errset);
| 157 |
FD_SET(0, &readset);
| 158 |
FD_SET(0, &errset);
| 159 |
FD_SET(odev.ifd, &readset);
| 160 |
FD_SET(odev.ifd, &errset);
| 161 |
n = odev.ifd+1;
| 162 |
if (sstdin != NULL) {
| 163 |
FD_SET(fileno(sstdin), &readset);
| 164 |
FD_SET(fileno(sstdin), &errset);
| 165 |
if (fileno(sstdin) >= n)
| 166 |
n = fileno(sstdin) + 1;
| 167 |
| 168 |
n = select(n, &readset, NULL, &errset, NULL);
| 169 |
if (n < 0) {
| 170 |
if (errno == EINTR)
| 171 |
return(0);
| 172 |
error(SYSTEM, "select call failure in disp_wait");
| 173 |
| 174 |
flgs = 0; /* flag what's ready */
| 175 |
if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
| 176 |
flgs |= RDY_SRV;
| 177 |
if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
| 178 |
flgs |= RDY_DEV;
| 179 |
if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) ||
| 180 |
FD_ISSET(fileno(sstdin), &errset)))
| 181 |
flgs |= RDY_SIN;
| 182 |
return(flgs);
| 183 |
| 184 |
| 185 |
| 186 |
add_holo(hdg) /* register a new holodeck section */
| 187 |
HDGRID *hdg;
| 188 |
| 189 |
VIEW nv;
| 190 |
double d;
| 191 |
register int hd;
| 192 |
| 193 |
for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
| 194 |
| 195 |
if (hd >= HDMAX)
| 196 |
error(INTERNAL, "too many holodeck sections in add_holo");
| 197 |
hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
| 198 |
if (hdlist[hd] == NULL)
| 199 |
error(SYSTEM, "out of memory in add_holo");
| 200 |
bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
| 201 |
hdcompgrid(hdlist[hd]);
| 202 |
if (hd)
| 203 |
return;
| 204 |
/* set initial viewpoint */
| 205 |
copystruct(&nv, &odev.v);
| 206 |
VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
| 207 |
VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
| 208 |
VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
| 209 |
fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
| 210 |
VCOPY(nv.vup, hdlist[0]->xv[2]);
| 211 |
if (do_outside) {
| 212 |
normalize(nv.vdir);
| 213 |
d = VLEN(hdlist[0]->xv[1]);
| 214 |
d += VLEN(hdlist[0]->xv[2]);
| 215 |
VSUM(nv.vp, nv.vp, nv.vdir, -d);
| 216 |
| 217 |
new_view(&nv);
| 218 |
| 219 |
| 220 |
| 221 |
disp_bundle(p) /* display a ray bundle */
| 222 |
register PACKHEAD *p;
| 223 |
| 224 |
GCOORD gc[2];
| 225 |
FVECT ro, rd, wp;
| 226 |
double d;
| 227 |
register int i;
| 228 |
/* get beam coordinates */
| 229 |
if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
| 230 |
error(INTERNAL, "bad holodeck number in disp_bundle");
| 231 |
if (!hdbcoord(gc, hdlist[p->hd], p->bi))
| 232 |
error(INTERNAL, "bad beam index in disp_bundle");
| 233 |
/* display each ray */
| 234 |
for (i = p->nr; i--; ) {
| 235 |
hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
| 236 |
d = hddepth(hdlist[p->hd], packra(p)[i].d);
| 237 |
VSUM(wp, ro, rd, d); /* might be behind viewpoint */
| 238 |
dev_value(packra(p)[i].v, wp, rd);
| 239 |
| 240 |
#ifdef DEBUG
| 241 |
if (imm_mode) nimmrays += p->nr;
| 242 |
else naddrays += p->nr;
| 243 |
#endif
| 244 |
| 245 |
| 246 |
| 247 |
new_view(v) /* change view parameters */
| 248 |
register VIEW *v;
| 249 |
| 250 |
static VIEW viewhist[VIEWHISTLEN];
| 251 |
static unsigned nhist;
| 252 |
VIEW *dv;
| 253 |
int i, res[2];
| 254 |
char *err;
| 255 |
/* restore previous view? */
| 256 |
if (v == NULL) {
| 257 |
if (nhist > 1) /* get one before last setting */
| 258 |
nhist--;
| 259 |
else /* else go to end of list */
| 260 |
while (nhist < VIEWHISTLEN && viewhist[nhist].type)
| 261 |
nhist++;
| 262 |
v = viewhist + ((nhist-1)%VIEWHISTLEN);
| 263 |
} else
| 264 |
again:
| 265 |
if ((err = setview(v)) != NULL) {
| 266 |
error(COMMAND, err);
| 267 |
return;
| 268 |
| 269 |
if (v->type == VT_PAR) {
| 270 |
error(COMMAND, "cannot handle parallel views");
| 271 |
return;
| 272 |
| 273 |
if (!dev_view(v)) /* notify display driver */
| 274 |
goto again;
| 275 |
dev_flush(); /* update screen */
| 276 |
beam_init(); /* compute new beam set */
| 277 |
for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
| 278 |
if (!beam_view(dv, res[0], res[1])) {
| 279 |
if (!nhist) {
| 280 |
error(COMMAND, "invalid starting view");
| 281 |
return;
| 282 |
| 283 |
copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN));
| 284 |
goto again;
| 285 |
| 286 |
beam_sync(0); /* update server */
| 287 |
/* record new view */
| 288 |
if (v < viewhist || v >= viewhist+VIEWHISTLEN) {
| 289 |
copystruct(viewhist + (nhist%VIEWHISTLEN), v);
| 290 |
nhist++;
| 291 |
| 292 |
| 293 |
| 294 |
| 295 |
int
| 296 |
usr_input() /* get user input and process it */
| 297 |
| 298 |
VIEW vparams;
| 299 |
char cmd[256];
| 300 |
register char *args;
| 301 |
register int i;
| 302 |
| 303 |
if (fgets(cmd, sizeof(cmd), sstdin) == NULL) {
| 304 |
fclose(sstdin);
| 305 |
sstdin = NULL;
| 306 |
return(-1);
| 307 |
| 308 |
if (!*cmd)
| 309 |
return(DC_RESUME);
| 310 |
for (args = cmd; *args && !isspace(*args); args++)
| 311 |
| 312 |
while (isspace(*args))
| 313 |
*args++ = '\0';
| 314 |
if (*args && args[i=strlen(args)-1] == '\n')
| 315 |
args[i] = '\0';
| 316 |
for (i = 0; i < DC_NCMDS; i++)
| 317 |
if (!strcmp(cmd, cmdlist[i]))
| 318 |
break;
| 319 |
if (i >= DC_NCMDS) {
| 320 |
dev_auxcom(cmd, args);
| 321 |
return(-1);
| 322 |
| 323 |
switch (i) {
| 324 |
case DC_SETVIEW: /* set the view */
| 325 |
copystruct(&vparams, &odev.v);
| 326 |
if (!sscanview(&vparams, args))
| 327 |
error(COMMAND, "missing view options");
| 328 |
else
| 329 |
new_view(&vparams);
| 330 |
break;
| 331 |
case DC_GETVIEW: /* print the current view */
| 332 |
printview();
| 333 |
break;
| 334 |
case DC_LASTVIEW: /* restore previous view */
| 335 |
new_view(NULL);
| 336 |
break;
| 337 |
case DC_PAUSE: /* pause the current calculation */
| 338 |
case DC_RESUME: /* resume the calculation */
| 339 |
/* handled in main() */
| 340 |
break;
| 341 |
case DC_REDRAW: /* redraw from server */
| 342 |
| 343 |
dev_clear();
| 344 |
break;
| 345 |
case DC_KILL: /* kill rtrace process(es) */
| 346 |
| 347 |
break;
| 348 |
case DC_CLOBBER: /* clobber holodeck */
| 349 |
| 350 |
break;
| 351 |
case DC_RESTART: /* restart rtrace */
| 352 |
| 353 |
break;
| 354 |
case DC_QUIT: /* quit request */
| 355 |
| 356 |
break;
| 357 |
default:
| 358 |
error(CONSISTENCY, "bad command id in usr_input");
| 359 |
| 360 |
return(i);
| 361 |
| 362 |
| 363 |
| 364 |
printview() /* print our current view to server stdout */
| 365 |
| 366 |
fputs(VIEWSTR, sstdout);
| 367 |
fprintview(&odev.v, sstdout);
| 368 |
fputc('\n', sstdout);
| 369 |
fflush(sstdout);
| 370 |
| 371 |
| 372 |
| 373 |
int
| 374 |
serv_result() /* get next server result and process it */
| 375 |
| 376 |
static char *buf = NULL;
| 377 |
static int bufsiz = 0;
| 378 |
MSGHEAD msg;
| 379 |
int n;
| 380 |
/* read message header */
| 381 |
if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
| 382 |
goto readerr;
| 383 |
if (msg.nbytes > 0) { /* get the message body */
| 384 |
if (msg.nbytes > bufsiz) {
| 385 |
if (buf == NULL)
| 386 |
buf = (char *)malloc(bufsiz=msg.nbytes);
| 387 |
else
| 388 |
buf = (char *)realloc(buf, bufsiz=msg.nbytes);
| 389 |
if (buf == NULL)
| 390 |
error(SYSTEM, "out of memory in serv_result");
| 391 |
| 392 |
if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
| 393 |
goto readerr;
| 394 |
| 395 |
switch (msg.type) { /* process results */
| 396 |
case DS_BUNDLE:
| 397 |
if (msg.nbytes < sizeof(PACKHEAD) ||
| 398 |
msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
| 399 |
error(INTERNAL, "bad display packet from server");
| 400 |
disp_bundle((PACKHEAD *)buf);
| 401 |
break;
| 402 |
case DS_ADDHOLO:
| 403 |
if (msg.nbytes != sizeof(HDGRID))
| 404 |
error(INTERNAL, "bad holodeck record from server");
| 405 |
add_holo((HDGRID *)buf);
| 406 |
break;
| 407 |
case DS_OUTSECT:
| 408 |
do_outside = 1;
| 409 |
break;
| 410 |
case DS_EYESEP:
| 411 |
if (msg.nbytes <= 1 || (eyesepdist = atof(buf)) <= FTINY)
| 412 |
error(INTERNAL, "bad eye separation from server");
| 413 |
break;
| 414 |
case DS_STARTIMM:
| 415 |
case DS_ENDIMM:
| 416 |
#ifdef DEBUG
| 417 |
if (imm_mode != (msg.type==DS_STARTIMM)) {
| 418 |
time_t tnow = time(NULL);
| 419 |
if (imm_mode) timm += tnow - tmodesw;
| 420 |
else tadd += tnow - tmodesw;
| 421 |
tmodesw = tnow;
| 422 |
| 423 |
#endif
| 424 |
imm_mode = msg.type==DS_STARTIMM;
| 425 |
/* fall through */
| 426 |
case DS_ACKNOW:
| 427 |
case DS_SHUTDOWN:
| 428 |
if (msg.nbytes) {
| 429 |
sprintf(errmsg,
| 430 |
"unexpected body with server message %d",
| 431 |
msg.type);
| 432 |
error(INTERNAL, errmsg);
| 433 |
| 434 |
break;
| 435 |
default:
| 436 |
error(INTERNAL, "unrecognized result from server process");
| 437 |
| 438 |
return(msg.type); /* return message type */
| 439 |
readerr:
| 440 |
if (feof(stdin))
| 441 |
error(SYSTEM, "server process died");
| 442 |
error(SYSTEM, "error reading from server process");
| 443 |
| 444 |
| 445 |
| 446 |
serv_request(type, nbytes, p) /* send a request to the server process */
| 447 |
int type, nbytes;
| 448 |
char *p;
| 449 |
| 450 |
MSGHEAD msg;
| 451 |
int m;
| 452 |
/* get server's attention for big request */
| 453 |
if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
| 454 |
| 455 |
while ((m = serv_result()) != DS_ACKNOW)
| 456 |
if (m == DS_SHUTDOWN) /* the bugger quit on us */
| 457 |
quit(0);
| 458 |
| 459 |
msg.type = type; /* write and flush the message */
| 460 |
msg.nbytes = nbytes;
| 461 |
fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
| 462 |
if (nbytes > 0)
| 463 |
fwrite(p, 1, nbytes, stdout);
| 464 |
if (fflush(stdout) < 0)
| 465 |
error(SYSTEM, "write error in serv_request");
| 466 |
| 467 |
| 468 |
| 469 |
eputs(s) /* put error message to stderr */
| 470 |
register char *s;
| 471 |
| 472 |
static int midline = 0;
| 473 |
| 474 |
if (!*s)
| 475 |
return;
| 476 |
if (!midline++) { /* prepend line with program name */
| 477 |
fputs(progname, stderr);
| 478 |
fputs(": ", stderr);
| 479 |
| 480 |
fputs(s, stderr);
| 481 |
if (s[strlen(s)-1] == '\n') {
| 482 |
fflush(stderr);
| 483 |
midline = 0;
| 484 |
| 485 |
| 486 |
| 487 |
| 488 |
quit(code) /* clean up and exit */
| 489 |
int code;
| 490 |
| 491 |
if (odev.v.type)
| 492 |
dev_close();
| 493 |
exit(code);
| 494 |
