root/radiance/ray/src/hd/rhdisp.c
Revision 3.56 - (view) (download) (annotate) - [select for diffs]
Mon Feb 6 22:40:21 2023 UTC (2 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 3.55: +2 -2 lines
Diff to previous 3.55 , to selected 3.49
Revision 3.55 - (view) (download) (annotate) - [select for diffs]
Fri Oct 5 19:19:16 2018 UTC (6 years, 7 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 3.54: +12 -12 lines
Diff to previous 3.54 , to selected 3.49
Revision 3.54 - (view) (download) (annotate) - [select for diffs]
Thu Aug 18 00:52:48 2016 UTC (8 years, 9 months ago) by greg
Changes since 3.53: +5 -5 lines
Diff to previous 3.53 , to selected 3.49
Revision 3.53 - (view) (download) (annotate) - [select for diffs]
Tue Aug 16 18:09:53 2011 UTC (13 years, 9 months ago) by greg
Changes since 3.52: +2 -2 lines
Diff to previous 3.52 , to selected 3.49
Minor fixes
Revision 3.52 - (view) (download) (annotate) - [select for diffs]
Tue Mar 11 02:21:47 2008 UTC (17 years, 2 months ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 3.51: +13 -1 lines
Diff to previous 3.51 , to selected 3.49
Revision 3.51 - (view) (download) (annotate) - [select for diffs]
Sun Mar 28 20:33:13 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 3.50: +2 -2 lines
Diff to previous 3.50 , to selected 3.49
Revision 3.50 - (view) (download) (annotate) - [select for diffs]
Thu Jan 1 11:21:55 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 3.49: +55 -29 lines
Diff to previous 3.49
Ansification and prototypes.
Revision 3.49 - (view) (download) (annotate) - [selected]
Sun Jul 27 22:12:02 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.48: +2 -2 lines
Diff to previous 3.48
Revision 3.48 - (view) (download) (annotate) - [select for diffs]
Mon Jul 21 22:30:18 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.47: +6 -6 lines
Diff to previous 3.47 , to selected 3.49
Revision 3.47 - (view) (download) (annotate) - [select for diffs]
Mon Jun 30 14:59:11 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.46: +5 -3 lines
Diff to previous 3.46 , to selected 3.49
Revision 3.46 - (view) (download) (annotate) - [select for diffs]
Fri Jun 20 00:25:49 2003 UTC (21 years, 11 months ago) by greg
Changes since 3.45: +2 -2 lines
Diff to previous 3.45 , to selected 3.49
Revision 3.45 - (view) (download) (annotate) - [select for diffs]
Tue May 13 17:58:33 2003 UTC (22 years ago) by greg
Changes since 3.44: +1 -1 lines
Diff to previous 3.44 , to selected 3.49
Revision 3.44 - (view) (download) (annotate) - [select for diffs]
Wed Apr 23 00:52:33 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.43: +2 -1 lines
Diff to previous 3.43 , to selected 3.49
Revision 3.43 - (view) (download) (annotate) - [select for diffs]
Sat Feb 22 02:07:24 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.42: +6 -6 lines
Diff to previous 3.42 , to selected 3.49
Revision 3.42 - (view) (download) (annotate) - [select for diffs]
Thu Jul 29 15:38:40 1999 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.41: +8 -2 lines
Diff to previous 3.41 , to selected 3.49
attempted fix for Linux _cnt field absence
Mon Mar 8 17:31:49 1999 UTC (26 years, 2 months ago) by gwlarson
Changes since 3.40: +1 -2 lines
Diff to previous 3.40 , to selected 3.49
Revision 3.40 - (view) (download) (annotate) - [select for diffs]
Thu Mar 4 10:14:52 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.39: +4 -1 lines
Diff to previous 3.39 , to selected 3.49
added wait for initialization in disp_wait()
changed return value of beam_view()
Sun Jan 3 17:49:11 1999 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.38: +2 -2 lines
Diff to previous 3.38 , to selected 3.49
fixed debug reporting of rays recalled/second
Sun Dec 20 20:39:31 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.37: +15 -10 lines
Diff to previous 3.37 , to selected 3.49
added new "portals" variable for multiple section geometry
Fri Dec 18 11:56:10 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.36: +28 -21 lines
Diff to previous 3.36 , to selected 3.49
Thu Dec 10 10:45:54 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.35: +69 -0 lines
Diff to previous 3.35 , to selected 3.49
created "frame" command to focus calculation
Wed Nov 11 16:58:51 1998 UTC (26 years, 6 months ago) by gwlarson
Changes since 3.34: +3 -3 lines
Diff to previous 3.34 , to selected 3.49
fixed problem with debug code after mode switch alterations
Thu Nov 5 14:27:02 1998 UTC (26 years, 6 months ago) by gwlarson
Changes since 3.33: +6 -4 lines
Diff to previous 3.33 , to selected 3.49
made animations from standard input work
Tue Oct 6 18:09:49 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.32: +5 -0 lines
Diff to previous 3.32 , to selected 3.49
added paranoid checks for negative message sizes
Wed Aug 26 13:06:09 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.31: +8 -8 lines
Diff to previous 3.31 , to selected 3.49
reordered display request handling
Wed Aug 19 18:23:56 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.30: +1 -1 lines
Diff to previous 3.30 , to selected 3.49
bug fix in getting empty user input
Wed Aug 19 17:43:08 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.29: +9 -5 lines
Diff to previous 3.29 , to selected 3.49
added odev.inpready member and periodic input checking to rhdisp
Tue Aug 11 07:51:19 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.28: +5 -2 lines
Diff to previous 3.28 , to selected 3.49
changed dev_value() interface so NULL is passed for infinite points
Fri Jul 31 16:53:47 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.27: +10 -9 lines
Diff to previous 3.27 , to selected 3.49
simplified error checking logic
Mon Jul 13 17:55:51 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.26: +1 -1 lines
Diff to previous 3.26 , to selected 3.49
changed beam management to allow temporary override
Wed Jun 17 15:44:07 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.25: +4 -5 lines
Diff to previous 3.25 , to selected 3.49
added dev_auxcom() for auxiliary command handling
Fri May 22 08:30:40 1998 UTC (27 years ago) by gwlarson
Changes since 3.24: +6 -0 lines
Diff to previous 3.24 , to selected 3.49
Thu May 14 13:06:32 1998 UTC (27 years ago) by gwlarson
Changes since 3.23: +16 -5 lines
Diff to previous 3.23 , to selected 3.49
added multiple device view capability
Thu Jan 8 21:19:05 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.22: +10 -5 lines
Diff to previous 3.22 , to selected 3.49
added check for EOF on server stdin and increased input buffer size
Tue Jan 6 05:26:20 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.21: +1 -0 lines
Diff to previous 3.21 , to selected 3.49
created dev_clear() routine to clear device ray cache
Mon Jan 5 17:40:28 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.20: +33 -0 lines
Diff to previous 3.20 , to selected 3.49
added statistics code for DEBUG mode (doesn't work with pauses)
Sun Jan 4 18:37:10 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.19: +12 -0 lines
Diff to previous 3.19 , to selected 3.49
added motion outside section when OBSTRUCTIONS=True
Sun Jan 4 12:28:09 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.18: +9 -9 lines
Diff to previous 3.18 , to selected 3.49
changed order of read after select to avoid stalls waiting for server
Thu Jan 1 13:00:16 1998 UTC (27 years, 5 months ago) by gregl
Changes since 3.17: +0 -2 lines
Diff to previous 3.17 , to selected 3.49
Fri Dec 19 14:49:05 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.16: +3 -2 lines
Diff to previous 3.16 , to selected 3.49
fixed minor logic error in new_view()
Thu Dec 18 18:14:15 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.15: +6 -6 lines
Diff to previous 3.15 , to selected 3.49
increased number of stored views to 4 and made view cycling logical
Mon Dec 15 20:43:48 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.14: +11 -4 lines
Diff to previous 3.14 , to selected 3.49
resume calculation after restart
Fri Dec 12 11:13:15 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.13: +15 -0 lines
Diff to previous 3.13 , to selected 3.49
Thu Dec 11 16:45:58 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.12: +13 -10 lines
Diff to previous 3.12 , to selected 3.49
normalized commands between driver and standard input
Thu Dec 11 09:37:43 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.11: +39 -16 lines
Diff to previous 3.11 , to selected 3.49
added command for returning to previous view(s)
added check to dev_view() for illegal views
fixed bug in X11 driver on window resizing
Tue Dec 9 17:12:15 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.10: +8 -7 lines
Diff to previous 3.10 , to selected 3.49
fixed minor error in parsing of command arguments
Mon Dec 8 18:51:15 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.9: +109 -8 lines
Diff to previous 3.9 , to selected 3.49
Thu Dec 4 10:54:24 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.8: +1 -1 lines
Diff to previous 3.8 , to selected 3.49
added direction vector to dev_value() call
Thu Dec 4 10:51:37 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.7: +6 -5 lines
Diff to previous 3.7 , to selected 3.49
added guard for inappropriate moves
Wed Nov 26 20:13:34 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.6: +2 -0 lines
Diff to previous 3.6 , to selected 3.49
added device flush when DS_ENDIMM is received
Tue Nov 25 10:27:47 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.5: +2 -4 lines
Diff to previous 3.5 , to selected 3.49
bug fixes and minor improvements
Mon Nov 24 17:11:40 1997 UTC (27 years, 6 months ago) by gregl
Diff to previous 3.4 , to selected 3.49
fixed update mode
Fri Nov 21 16:10:17 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.3: +12 -8 lines
Diff to previous 3.3 , to selected 3.49
added server-driven redraw function to replace display quadtree
Fri Nov 21 15:11:43 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.2: +16 -10 lines
Diff to previous 3.2 , to selected 3.49
stopped pause function from resuming upon iconification and
interfering with full view updates
Thu Nov 20 18:05:57 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.1: +30 -4 lines
Diff to previous 3.1 , to selected 3.49
added eputs() function to prepend program name
added noop function to recover from vain DR_ATTEN
added pause function
Wed Nov 19 18:01:03 1997 UTC (27 years, 6 months ago) by gregl
Diff to selected 3.49
