--- ray/src/hd/rhdisp.c 1998/12/10 10:45:54 3.36 +++ ray/src/hd/rhdisp.c 1998/12/18 11:56:10 3.37 @@ -24,6 +24,8 @@ static char SCCSid[] = "$SunId$ SGI"; HOLO *hdlist[HDMAX+1]; /* global holodeck list */ +char *hdofn[HDMAX+1]; /* holodeck section octree list */ + char cmdlist[DC_NCMDS][8] = DC_INIT; int imm_mode = 0; /* bundles are being delivered immediately */ @@ -88,10 +90,12 @@ char *argv[]; inp = dev_input(); if (inp & DFL(DC_SETVIEW)) new_view(&odev.v); + else if (inp & DFL(DC_LASTVIEW)) + new_view(NULL); + if (inp & DFL(DC_REDRAW)) + imm_mode = beam_sync(1) > 0; if (inp & DFL(DC_GETVIEW)) printview(); - if (inp & DFL(DC_LASTVIEW)) - new_view(NULL); if (inp & DFL(DC_FOCUS)) set_focus(odev_args); if (inp & DFL(DC_KILL)) { @@ -110,8 +114,6 @@ char *argv[]; } if (inp & DFL(DC_PAUSE)) pause = 1; - if (inp & DFL(DC_REDRAW)) - imm_mode = beam_sync(1) > 0; if (inp & DFL(DC_QUIT)) serv_request(DR_SHUTDOWN, 0, NULL); } @@ -193,8 +195,9 @@ disp_wait() /* wait for more input */ } -add_holo(hdg) /* register a new holodeck section */ +add_holo(hdg, ofn) /* register a new holodeck section */ HDGRID *hdg; +char *ofn; { VIEW nv; double d; @@ -209,6 +212,7 @@ HDGRID *hdg; error(SYSTEM, "out of memory in add_holo"); bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID)); hdcompgrid(hdlist[hd]); + hdofn[hd] = savestr(ofn); if (hd) return; /* set initial viewpoint */ @@ -263,7 +267,7 @@ register VIEW *v; static VIEW viewhist[VIEWHISTLEN]; static unsigned nhist; VIEW *dv; - int i, res[2]; + int i, res[2], *slist; char *err; /* restore previous view? */ if (v == NULL) { @@ -279,25 +283,30 @@ again: error(COMMAND, err); return; } + if (!dev_view(v)) /* notify display driver */ + goto again; if (v->type == VT_PAR) { error(COMMAND, "cannot handle parallel views"); return; } - if (!dev_view(v)) /* notify display driver */ - goto again; - dev_flush(); /* update screen */ - beam_init(0); /* compute new beam set */ - for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) - if (!beam_view(dv, res[0], res[1])) { + beam_init(odev.firstuse); /* compute new beam set */ + for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) { + if ((slist = beam_view(dv, res[0], res[1])) == NULL) { if (!nhist) { error(COMMAND, "invalid starting view"); return; } copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN)); - goto again; - } + goto again; /* poss. overloading dev_section()? */ + } + DCHECK(*slist < 0, WARNING, "no visible sections in new_view"); + while (*slist >= 0) + dev_section(hdofn[*slist++]); + } + dev_section(NULL); /* end section list */ + dev_flush(); /* update display */ /* update server */ - imm_mode = beam_sync(0) > 0; + imm_mode = beam_sync(odev.firstuse) > 0; /* record new view */ if (v < viewhist || v >= viewhist+VIEWHISTLEN) { copystruct(viewhist + (nhist%VIEWHISTLEN), v); @@ -477,9 +486,9 @@ serv_result() /* get next server result and process disp_bundle((PACKHEAD *)buf); break; case DS_ADDHOLO: - if (msg.nbytes != sizeof(HDGRID)) + if (msg.nbytes <= sizeof(HDGRID)) error(INTERNAL, "bad holodeck record from server"); - add_holo((HDGRID *)buf); + add_holo((HDGRID *)buf, buf+sizeof(HDGRID)); break; case DS_OUTSECT: do_outside = 1; @@ -529,10 +538,8 @@ char *p; MSGHEAD msg; int m; /* consistency checks */ -#ifdef DEBUG - if (nbytes < 0 || nbytes > 0 & p == NULL) - error(CONSISTENCY, "bad buffer handed to serv_request"); -#endif + DCHECK(nbytes < 0 || nbytes > 0 & p == NULL, + CONSISTENCY, "bad buffer handed to serv_request"); /* get server's attention for big request */ if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) { serv_request(DR_ATTEN, 0, NULL);
