root/radiance/ray/src/hd/rhdisp.c
Revision: 3.5
Committed: Mon Nov 24 17:11:40 1997 UTC (27 years, 7 months ago) by gregl
fixed update mode
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15
16 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
17
18 int imm_mode = 0; /* bundles are being delivered immediately */
19
20 VIEW dvw; /* our current display view */
21
22 char *progname; /* global argv[0] */
23
24 #define RDY_SRV 01
25 #define RDY_DEV 02
26
27
28 main(argc, argv)
29 int argc;
30 char *argv[];
31 {
32 int rdy, inp, res = 0, pause = 0;
33
34 progname = argv[0];
35 if (argc != 2)
36 error(USER, "bad command line arguments");
37 /* open our device */
38 dev_open(argv[1]);
39 /* enter main loop */
40 do {
41 rdy = disp_wait();
42 if (rdy & RDY_DEV) { /* get user input */
43 inp = dev_input();
44 if (inp & DEV_NEWVIEW)
45 new_view(&odev.v);
46 if (inp & DEV_SHUTDOWN)
47 serv_request(DR_SHUTDOWN, 0, NULL);
48 if (inp & DEV_REDRAW) {
49 imm_mode = 1; /* preempt updates */
50 beam_sync();
51 }
52 if (inp & DEV_WAIT)
53 pause = 1;
54 if (inp & DEV_RESUME) {
55 serv_request(DR_NOOP, 0, NULL);
56 pause = 0;
57 }
58 }
59 if (rdy & RDY_SRV) { /* get server result */
60 res = serv_result();
61 if (pause && res != DS_SHUTDOWN) {
62 serv_request(DR_ATTEN, 0, NULL);
63 while ((res = serv_result()) != DS_ACKNOW &&
64 res != DS_SHUTDOWN)
65 ;
66 }
67 }
68 } while (res != DS_SHUTDOWN);
69 /* all done */
70 quit(0);
71 }
72
73
74 int
75 disp_wait() /* wait for more input */
76 {
77 fd_set readset, errset;
78 int flgs;
79 int n;
80 register int i;
81 /* see if we can avoid select call */
82 if (imm_mode || stdin->_cnt > 0)
83 return(RDY_SRV);
84 if (dev_flush())
85 return(RDY_DEV);
86 /* make the call */
87 FD_ZERO(&readset); FD_ZERO(&errset);
88 FD_SET(0, &readset);
89 FD_SET(0, &errset);
90 FD_SET(odev.ifd, &readset);
91 FD_SET(odev.ifd, &errset);
92 n = odev.ifd + 1;
93 n = select(n, &readset, NULL, &errset, NULL);
94 if (n < 0) {
95 if (errno == EINTR)
96 return(0);
97 error(SYSTEM, "select call failure in disp_wait");
98 }
99 flgs = 0; /* flag what's ready */
100 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
101 flgs |= RDY_SRV;
102 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
103 flgs |= RDY_DEV;
104 return(flgs);
105 }
106
107
108 add_holo(hdg) /* register a new holodeck section */
109 HDGRID *hdg;
110 {
111 VIEW nv;
112 register int hd;
113
114 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
115 ;
116 if (hd >= HDMAX)
117 error(INTERNAL, "too many holodeck sections in add_holo");
118 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
119 if (hdlist[hd] == NULL)
120 error(SYSTEM, "out of memory in add_holo");
121 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
122 hdcompgrid(hdlist[hd]);
123 if (hd)
124 return;
125 /* set initial viewpoint */
126 copystruct(&nv, &odev.v);
127 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
128 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
129 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
130 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
131 VCOPY(nv.vup, hdlist[0]->xv[2]);
132 new_view(&nv);
133 }
134
135
136 disp_bundle(p) /* display a ray bundle */
137 register PACKHEAD *p;
138 {
139 GCOORD gc[2];
140 FVECT ro, rd, wp;
141 double d;
142 register int i;
143 /* get beam coordinates */
144 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
145 error(INTERNAL, "bad holodeck number in disp_bundle");
146 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
147 error(INTERNAL, "bad beam index in disp_bundle");
148 /* display each ray */
149 for (i = p->nr; i--; ) {
150 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
151 d = hddepth(hdlist[p->hd], packra(p)[i].d);
152 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
153 dev_value(packra(p)[i].v, wp);
154 }
155 }
156
157
158 new_view(v) /* change view parameters */
159 VIEW *v;
160 {
161 char *err;
162
163 if ((err = setview(v)) != NULL)
164 error(INTERNAL, err);
165 dev_view(v); /* update display driver */
166 beam_view(&dvw, v); /* update beam list */
167 copystruct(&dvw, v); /* record new view */
168 }
169
170
171 int
172 serv_result() /* get next server result and process it */
173 {
174 static char *buf = NULL;
175 static int bufsiz = 0;
176 MSGHEAD msg;
177 int n;
178 /* read message header */
179 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
180 goto readerr;
181 if (msg.nbytes > 0) { /* get the message body */
182 if (msg.nbytes > bufsiz) {
183 if (buf == NULL)
184 buf = (char *)malloc(bufsiz=msg.nbytes);
185 else
186 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
187 if (buf == NULL)
188 error(SYSTEM, "out of memory in serv_result");
189 }
190 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
191 goto readerr;
192 }
193 switch (msg.type) { /* process results */
194 case DS_BUNDLE:
195 if (msg.nbytes < sizeof(PACKHEAD) ||
196 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
197 error(INTERNAL, "bad display packet from server");
198 disp_bundle((PACKHEAD *)buf);
199 break;
200 case DS_ADDHOLO:
201 if (msg.nbytes != sizeof(HDGRID))
202 error(INTERNAL, "bad holodeck record from server");
203 add_holo((HDGRID *)buf);
204 break;
205 case DS_STARTIMM:
206 case DS_ENDIMM:
207 imm_mode = msg.type==DS_STARTIMM;
208 /* fall through */
209 case DS_ACKNOW:
210 case DS_SHUTDOWN:
211 if (msg.nbytes) {
212 sprintf(errmsg,
213 "unexpected body with server message %d",
214 msg.type);
215 error(INTERNAL, errmsg);
216 }
217 break;
218 default:
219 error(INTERNAL, "unrecognized result from server process");
220 }
221 return(msg.type); /* return message type */
222 readerr:
223 if (feof(stdin))
224 error(SYSTEM, "server process died");
225 error(SYSTEM, "error reading from server process");
226 }
227
228
229 serv_request(type, nbytes, p) /* send a request to the server process */
230 int type, nbytes;
231 char *p;
232 {
233 MSGHEAD msg;
234 int m;
235 /* get server's attention for big request */
236 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
237 serv_request(DR_ATTEN, 0, NULL);
238 while ((m = serv_result()) != DS_ACKNOW)
239 if (m == DS_SHUTDOWN) /* the bugger quit on us */
240 quit(0);
241 }
242 msg.type = type; /* write and flush the message */
243 msg.nbytes = nbytes;
244 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
245 if (nbytes > 0)
246 fwrite(p, 1, nbytes, stdout);
247 if (fflush(stdout) < 0)
248 error(SYSTEM, "write error in serv_request");
249 }
250
251
252 eputs(s) /* put error message to stderr */
253 register char *s;
254 {
255 static int midline = 0;
256
257 if (!*s)
258 return;
259 if (!midline++) { /* prepend line with program name */
260 fputs(progname, stderr);
261 fputs(": ", stderr);
262 }
263 fputs(s, stderr);
264 if (s[strlen(s)-1] == '\n') {
265 fflush(stderr);
266 midline = 0;
267 }
268 }
269
270
271 quit(code) /* clean up and exit */
272 int code;
273 {
274 if (odev.v.type)
275 dev_close();
276 exit(code);
277 }
