root/radiance/ray/src/hd/rhdisp.c
Revision: 3.38
Committed: Sun Dec 20 20:39:31 1998 UTC (26 years, 6 months ago) by gwlarson
Changes since 3.37: +15 -10 lines
added new "portals" variable for multiple section geometry
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15 #include <ctype.h>
16
17 #ifndef VIEWHISTLEN
18 #define VIEWHISTLEN 4 /* number of remembered views */
19 #endif
20
21 #ifndef FSIZDEF
22 #define FSIZDEF 0.125 /* default focus frame size */
23 #endif
24
25 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
26
27 char *hdgfn[HDMAX]; /* holodeck section geometry list */
28 char *hdpfn[HDMAX]; /* section portal list */
29
30 char cmdlist[DC_NCMDS][8] = DC_INIT;
31
32 int imm_mode = 0; /* bundles are being delivered immediately */
33
34 int do_outside = 0; /* render from outside sections */
35
36 double eyesepdist = 1; /* eye separation distance */
37
38 char *progname; /* global argv[0] */
39
40 FILE *sstdin, *sstdout; /* server's standard input and output */
41
42 #ifdef DEBUG
43 #include <sys/types.h>
44 extern time_t time();
45 static time_t tmodesw;
46 static time_t timm, tadd;
47 static long nimmrays, naddrays;
48 #endif
49
50 #define RDY_SRV 01
51 #define RDY_DEV 02
52 #define RDY_SIN 04
53
54
55 main(argc, argv)
56 int argc;
57 char *argv[];
58 {
59 extern int eputs();
60 int rdy, inp, res = 0, pause = 0;
61
62 progname = argv[0];
63 if (argc < 3)
64 error(USER, "bad command line arguments");
65 /* open our device */
66 dev_open(argv[1]);
67 /* open server process i/o */
68 sstdout = fdopen(atoi(argv[2]), "w");
69 if (argc < 4 || (inp = atoi(argv[3])) < 0)
70 sstdin = NULL;
71 else
72 sstdin = fdopen(inp, "r");
73 /* set command error vector */
74 erract[COMMAND].pf = eputs;
75 #ifdef DEBUG
76 tmodesw = time(NULL);
77 #endif
78 /* enter main loop */
79 do {
80 rdy = disp_wait();
81 if (rdy & RDY_SRV) { /* process server result */
82 res = serv_result();
83 if (pause && res != DS_SHUTDOWN) {
84 serv_request(DR_ATTEN, 0, NULL);
85 while ((res = serv_result()) != DS_ACKNOW &&
86 res != DS_SHUTDOWN)
87 ;
88 }
89 }
90 if (rdy & RDY_DEV) { /* user input from driver */
91 inp = dev_input();
92 if (inp & DFL(DC_SETVIEW))
93 new_view(&odev.v);
94 else if (inp & DFL(DC_LASTVIEW))
95 new_view(NULL);
96 if (inp & DFL(DC_REDRAW))
97 imm_mode = beam_sync(1) > 0;
98 if (inp & DFL(DC_GETVIEW))
99 printview();
100 if (inp & DFL(DC_FOCUS))
101 set_focus(odev_args);
102 if (inp & DFL(DC_KILL)) {
103 serv_request(DR_KILL, 0, NULL);
104 pause = 0;
105 }
106 if (inp & DFL(DC_CLOBBER))
107 serv_request(DR_CLOBBER, 0, NULL);
108 if (inp & DFL(DC_RESTART)) {
109 serv_request(DR_RESTART, 0, NULL);
110 pause = 0;
111 }
112 if (inp & DFL(DC_RESUME)) {
113 serv_request(DR_NOOP, 0, NULL);
114 pause = 0;
115 }
116 if (inp & DFL(DC_PAUSE))
117 pause = 1;
118 if (inp & DFL(DC_QUIT))
119 serv_request(DR_SHUTDOWN, 0, NULL);
120 }
121 if (rdy & RDY_SIN && !imm_mode) /* user input from sstdin */
122 switch (usr_input()) {
123 case DC_PAUSE:
124 pause = 1;
125 break;
126 case DC_RESUME:
127 serv_request(DR_NOOP, 0, NULL);
128 /* fall through */
129 case DC_KILL:
130 case DC_RESTART:
131 pause = 0;
132 break;
133 }
134 } while (res != DS_SHUTDOWN);
135 #ifdef DEBUG
136 if (timm && nimmrays)
137 fprintf(stderr,
138 "%s: %.1f rays recalled/second (%ld rays total)\n",
139 progname, (double)nimmrays/timm, nimmrays);
140 if (tadd && naddrays)
141 fprintf(stderr,
142 "%s: %.1f rays calculated/second (%ld rays total)\n",
143 progname, (double)naddrays/tadd, naddrays);
144 #endif
145 /* all done */
146 quit(0);
147 }
148
149
150 int
151 disp_wait() /* wait for more input */
152 {
153 fd_set readset, errset;
154 int flgs;
155 int n;
156 register int i;
157 /* see if we can avoid select call */
158 flgs = 0; /* flag what's ready already */
159 if (imm_mode || stdin->_cnt > 0)
160 flgs |= RDY_SRV;
161 if (sstdin != NULL && sstdin->_cnt > 0)
162 flgs |= RDY_SIN;
163 if (odev.inpready)
164 flgs |= RDY_DEV;
165 if (flgs) /* got something? */
166 return(flgs);
167 if (dev_flush()) /* else flush output & check keyboard+mouse */
168 return(RDY_DEV);
169 /* if nothing, we need to call select */
170 FD_ZERO(&readset); FD_ZERO(&errset);
171 FD_SET(0, &readset);
172 FD_SET(0, &errset);
173 FD_SET(odev.ifd, &readset);
174 FD_SET(odev.ifd, &errset);
175 n = odev.ifd+1;
176 if (sstdin != NULL) {
177 FD_SET(fileno(sstdin), &readset);
178 FD_SET(fileno(sstdin), &errset);
179 if (fileno(sstdin) >= n)
180 n = fileno(sstdin) + 1;
181 }
182 n = select(n, &readset, NULL, &errset, NULL);
183 if (n < 0) {
184 if (errno == EINTR)
185 return(0);
186 error(SYSTEM, "select call failure in disp_wait");
187 }
188 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
189 flgs |= RDY_SRV;
190 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
191 flgs |= RDY_DEV;
192 if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) ||
193 FD_ISSET(fileno(sstdin), &errset)))
194 flgs |= RDY_SIN;
195 return(flgs);
196 }
197
198
199 add_holo(hdg, gfn, pfn) /* register a new holodeck section */
200 HDGRID *hdg;
201 char *gfn, *pfn;
202 {
203 VIEW nv;
204 double d;
205 register int hd;
206
207 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
208 ;
209 if (hd >= HDMAX)
210 error(INTERNAL, "too many holodeck sections in add_holo");
211 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
212 if (hdlist[hd] == NULL)
213 error(SYSTEM, "out of memory in add_holo");
214 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
215 hdcompgrid(hdlist[hd]);
216 hdgfn[hd] = savestr(gfn);
217 hdpfn[hd] = pfn && *pfn ? savestr(pfn) : (char *)NULL;
218 if (hd)
219 return;
220 /* set initial viewpoint */
221 copystruct(&nv, &odev.v);
222 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
223 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
224 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
225 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
226 VCOPY(nv.vup, hdlist[0]->xv[2]);
227 if (do_outside) {
228 normalize(nv.vdir);
229 d = VLEN(hdlist[0]->xv[1]);
230 d += VLEN(hdlist[0]->xv[2]);
231 VSUM(nv.vp, nv.vp, nv.vdir, -d);
232 }
233 new_view(&nv);
234 }
235
236
237 disp_bundle(p) /* display a ray bundle */
238 register PACKHEAD *p;
239 {
240 GCOORD gc[2];
241 FVECT ro, rd, wp;
242 double d;
243 register int i;
244 /* get beam coordinates */
245 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
246 error(INTERNAL, "bad holodeck number in disp_bundle");
247 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
248 error(INTERNAL, "bad beam index in disp_bundle");
249 /* display each ray */
250 for (i = p->nr; i--; ) {
251 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
252 d = hddepth(hdlist[p->hd], packra(p)[i].d);
253 if (d < .99*FHUGE) {
254 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
255 dev_value(packra(p)[i].v, rd, wp);
256 } else
257 dev_value(packra(p)[i].v, rd, NULL);
258 }
259 #ifdef DEBUG
260 if (imm_mode) nimmrays += p->nr;
261 else naddrays += p->nr;
262 #endif
263 }
264
265
266 new_view(v) /* change view parameters */
267 register VIEW *v;
268 {
269 static VIEW viewhist[VIEWHISTLEN];
270 static unsigned nhist;
271 VIEW *dv;
272 int i, res[2], *slist;
273 char *err;
274 /* restore previous view? */
275 if (v == NULL) {
276 if (nhist > 1) /* get one before last setting */
277 nhist--;
278 else /* else go to end of list */
279 while (nhist < VIEWHISTLEN && viewhist[nhist].type)
280 nhist++;
281 v = viewhist + ((nhist-1)%VIEWHISTLEN);
282 } else
283 again:
284 if ((err = setview(v)) != NULL) {
285 error(COMMAND, err);
286 return;
287 }
288 if (!dev_view(v)) /* notify display driver */
289 goto again;
290 if (v->type == VT_PAR) {
291 error(COMMAND, "cannot handle parallel views");
292 return;
293 }
294 beam_init(odev.firstuse); /* compute new beam set */
295 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) {
296 if ((slist = beam_view(dv, res[0], res[1])) == NULL) {
297 if (!nhist) {
298 error(COMMAND, "invalid starting view");
299 return;
300 }
301 copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN));
302 goto again; /* poss. overloading dev_section()? */
303 }
304 DCHECK(*slist < 0, WARNING, "no visible sections in new_view");
305 for ( ; *slist >= 0; slist++)
306 dev_section(hdgfn[*slist], hdpfn[*slist]);
307 }
308 dev_section(NULL,NULL); /* end section list */
309 dev_flush(); /* update display */
310 /* update server */
311 imm_mode = beam_sync(odev.firstuse) > 0;
312 /* record new view */
313 if (v < viewhist || v >= viewhist+VIEWHISTLEN) {
314 copystruct(viewhist + (nhist%VIEWHISTLEN), v);
315 nhist++;
316 }
317 }
318
319
320 set_focus(args) /* set focus frame */
321 char *args;
322 {
323 double hcent, vcent, hsiz, vsiz;
324 VIEW *dv, vwfocus;
325 int i, res[2];
326
327 i = sscanf(args, "%lf %lf %lf %lf", &hcent, &vcent, &hsiz, &vsiz);
328 if (i < 2 || hcent < 0 || hcent > 1 || vcent < 0 || vcent > 1) {
329 beam_init(0); /* restore view */
330 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
331 beam_view(dv, res[0], res[1]);
332 beam_sync(0); /* update server */
333 return;
334 }
335 if (i < 4 || hsiz <= hcent || hsiz > 1 || vsiz <= vcent || vsiz > 1)
336 hsiz = vsiz = FSIZDEF; /* gave center only */
337 else {
338 hsiz -= hcent; hcent += 0.5*hsiz; /* gave min and max */
339 vsiz -= vcent; vcent += 0.5*vsiz;
340 }
341 beam_init(0); /* add basic views */
342 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
343 beam_view(dv, res[0]>>4, res[1]>>4);
344 copystruct(&vwfocus, &odev.v); /* add focus view */
345 switch (odev.v.type) {
346 case VT_PER:
347 vwfocus.horiz = 2.*180./PI*atan(
348 hsiz * tan(PI/180./2.*odev.v.horiz) );
349 vwfocus.vert = 2.*180./PI*atan(
350 vsiz * tan(PI/180./2.*odev.v.vert) );
351 break;
352 case VT_PAR:
353 case VT_ANG:
354 vwfocus.horiz = hsiz * odev.v.horiz;
355 vwfocus.vert = vsiz * odev.v.vert;
356 break;
357 case VT_HEM:
358 vwfocus.horiz = 2.*180./PI*asin(
359 hsiz * sin(PI/180./2.*odev.v.horiz) );
360 vwfocus.vert = 2.*180./PI*asin(
361 vsiz * sin(PI/180./2.*odev.v.vert) );
362 break;
363 case VT_CYL:
364 vwfocus.horiz = hsiz * odev.v.horiz;
365 vwfocus.vert = 2.*180./PI*atan(
366 vsiz * tan(PI/180./2.*odev.v.vert) );
367 break;
368 default:
369 error(INTERNAL, "bad view type in set_focus");
370 }
371 vwfocus.hoff = (odev.v.hoff + hcent - 0.5)/hsiz;
372 vwfocus.voff = (odev.v.voff + vcent - 0.5)/vsiz;
373 setview(&vwfocus);
374 beam_view(&vwfocus, (int)(3*odev.hres*hsiz)+100,
375 (int)(3*odev.vres*vsiz)+100);
376 beam_sync(0); /* update server */
377 }
378
379
380 int
381 usr_input() /* get user input and process it */
382 {
383 VIEW vparams;
384 char cmd[256];
385 register char *args;
386 register int i;
387
388 if (fgets(cmd, sizeof(cmd), sstdin) == NULL) {
389 fclose(sstdin);
390 sstdin = NULL;
391 return(-1);
392 }
393 if (*cmd == '\n')
394 return(DC_RESUME);
395 for (args = cmd; *args && !isspace(*args); args++)
396 ;
397 while (isspace(*args))
398 *args++ = '\0';
399 if (*args && args[i=strlen(args)-1] == '\n')
400 args[i] = '\0';
401 for (i = 0; i < DC_NCMDS; i++)
402 if (!strcmp(cmd, cmdlist[i]))
403 break;
404 if (i >= DC_NCMDS) {
405 dev_auxcom(cmd, args);
406 return(-1);
407 }
408 switch (i) {
409 case DC_SETVIEW: /* set the view */
410 copystruct(&vparams, &odev.v);
411 if (!sscanview(&vparams, args))
412 error(COMMAND, "missing view options");
413 else
414 new_view(&vparams);
415 break;
416 case DC_GETVIEW: /* print the current view */
417 printview();
418 break;
419 case DC_LASTVIEW: /* restore previous view */
420 new_view(NULL);
421 break;
422 case DC_FOCUS: /* set focus frame */
423 set_focus(args);
424 break;
425 case DC_PAUSE: /* pause the current calculation */
426 case DC_RESUME: /* resume the calculation */
427 /* handled in main() */
428 break;
429 case DC_REDRAW: /* redraw from server */
430 imm_mode = beam_sync(1) > 0;
431 dev_clear();
432 break;
433 case DC_KILL: /* kill rtrace process(es) */
434 serv_request(DR_KILL, 0, NULL);
435 break;
436 case DC_CLOBBER: /* clobber holodeck */
437 serv_request(DR_CLOBBER, 0, NULL);
438 break;
439 case DC_RESTART: /* restart rtrace */
440 serv_request(DR_RESTART, 0, NULL);
441 break;
442 case DC_QUIT: /* quit request */
443 serv_request(DR_SHUTDOWN, 0, NULL);
444 break;
445 default:
446 error(CONSISTENCY, "bad command id in usr_input");
447 }
448 return(i);
449 }
450
451
452 printview() /* print our current view to server stdout */
453 {
454 fputs(VIEWSTR, sstdout);
455 fprintview(&odev.v, sstdout);
456 fputc('\n', sstdout);
457 fflush(sstdout);
458 }
459
460
461 int
462 serv_result() /* get next server result and process it */
463 {
464 static char *buf = NULL;
465 static int bufsiz = 0;
466 MSGHEAD msg;
467 int n;
468 /* read message header */
469 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
470 goto readerr;
471 if (msg.nbytes > 0) { /* get the message body */
472 if (msg.nbytes > bufsiz) {
473 if (buf == NULL)
474 buf = (char *)malloc(bufsiz=msg.nbytes);
475 else
476 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
477 if (buf == NULL)
478 error(SYSTEM, "out of memory in serv_result");
479 }
480 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
481 goto readerr;
482 }
483 switch (msg.type) { /* process results */
484 case DS_BUNDLE:
485 if (msg.nbytes < sizeof(PACKHEAD) ||
486 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
487 error(INTERNAL, "bad display packet from server");
488 disp_bundle((PACKHEAD *)buf);
489 break;
490 case DS_ADDHOLO:
491 if (msg.nbytes < sizeof(HDGRID)+2)
492 error(INTERNAL, "bad holodeck record from server");
493 add_holo((HDGRID *)buf, buf+sizeof(HDGRID),
494 buf+sizeof(HDGRID)+strlen(buf+sizeof(HDGRID))+1);
495 break;
496 case DS_OUTSECT:
497 do_outside = 1;
498 goto noargs;
499 case DS_EYESEP:
500 if (msg.nbytes <= 1 || (eyesepdist = atof(buf)) <= FTINY)
501 error(INTERNAL, "bad eye separation from server");
502 break;
503 case DS_STARTIMM:
504 case DS_ENDIMM:
505 #ifdef DEBUG
506 {
507 time_t tnow = time(NULL);
508 if (msg.type==DS_STARTIMM) tadd += tnow - tmodesw;
509 else timm += tnow - tmodesw;
510 tmodesw = tnow;
511 }
512 #endif
513 if (!(imm_mode = msg.type==DS_STARTIMM))
514 dev_flush();
515 goto noargs;
516 case DS_ACKNOW:
517 case DS_SHUTDOWN:
518 goto noargs;
519 default:
520 error(INTERNAL, "unrecognized result from server process");
521 }
522 return(msg.type); /* return message type */
523 noargs:
524 if (msg.nbytes) {
525 sprintf(errmsg, "unexpected body with server message %d",
526 msg.type);
527 error(INTERNAL, errmsg);
528 }
529 return(msg.type);
530 readerr:
531 if (feof(stdin))
532 error(SYSTEM, "server process died");
533 error(SYSTEM, "error reading from server process");
534 }
535
536
537 serv_request(type, nbytes, p) /* send a request to the server process */
538 int type, nbytes;
539 char *p;
540 {
541 MSGHEAD msg;
542 int m;
543 /* consistency checks */
544 DCHECK(nbytes < 0 || nbytes > 0 & p == NULL,
545 CONSISTENCY, "bad buffer handed to serv_request");
546 /* get server's attention for big request */
547 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
548 serv_request(DR_ATTEN, 0, NULL);
549 while ((m = serv_result()) != DS_ACKNOW)
550 if (m == DS_SHUTDOWN) /* the bugger quit on us */
551 quit(0);
552 }
553 msg.type = type; /* write and flush the message */
554 msg.nbytes = nbytes;
555 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
556 if (nbytes > 0)
557 fwrite(p, 1, nbytes, stdout);
558 if (fflush(stdout) < 0)
559 error(SYSTEM, "write error in serv_request");
560 }
561
562
563 eputs(s) /* put error message to stderr */
564 register char *s;
565 {
566 static int midline = 0;
567
568 if (!*s)
569 return;
570 if (!midline++) { /* prepend line with program name */
571 fputs(progname, stderr);
572 fputs(": ", stderr);
573 }
574 fputs(s, stderr);
575 if (s[strlen(s)-1] == '\n') {
576 fflush(stderr);
577 midline = 0;
578 }
579 }
580
581
582 quit(code) /* clean up and exit */
583 int code;
584 {
585 if (code)
586 exit(code);
587 if (odev.v.type)
588 dev_close();
589 exit(0);
590 }
