root/radiance/ray/src/hd/rhdisp.c
Revision: 3.20
Committed: Sun Jan 4 18:37:10 1998 UTC (27 years, 5 months ago) by gregl
Changes since 3.19: +12 -0 lines
added motion outside section when OBSTRUCTIONS=True
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15 #include <ctype.h>
16
17 #ifndef VIEWHISTLEN
18 #define VIEWHISTLEN 4 /* number of remembered views */
19 #endif
20
21 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
22
23 char cmdlist[DC_NCMDS][8] = DC_INIT;
24
25 int imm_mode = 0; /* bundles are being delivered immediately */
26
27 int do_outside = 0; /* render from outside sections */
28
29 char *progname; /* global argv[0] */
30
31 FILE *sstdin, *sstdout; /* server's standard input and output */
32
33 #define RDY_SRV 01
34 #define RDY_DEV 02
35 #define RDY_SIN 04
36
37
38 main(argc, argv)
39 int argc;
40 char *argv[];
41 {
42 extern int eputs();
43 int rdy, inp, res = 0, pause = 0;
44
45 progname = argv[0];
46 if (argc < 3)
47 error(USER, "bad command line arguments");
48 /* open our device */
49 dev_open(argv[1]);
50 /* open server process i/o */
51 sstdout = fdopen(atoi(argv[2]), "w");
52 if (argc < 4 || (inp = atoi(argv[3])) < 0)
53 sstdin = NULL;
54 else
55 sstdin = fdopen(inp, "r");
56 /* set command error vector */
57 erract[COMMAND].pf = eputs;
58 /* enter main loop */
59 do {
60 rdy = disp_wait();
61 if (rdy & RDY_SRV) { /* process server result */
62 res = serv_result();
63 if (pause && res != DS_SHUTDOWN) {
64 serv_request(DR_ATTEN, 0, NULL);
65 while ((res = serv_result()) != DS_ACKNOW &&
66 res != DS_SHUTDOWN)
67 ;
68 }
69 }
70 if (rdy & RDY_DEV) { /* user input from driver */
71 inp = dev_input();
72 if (inp & DFL(DC_SETVIEW))
73 new_view(&odev.v);
74 if (inp & DFL(DC_GETVIEW))
75 printview();
76 if (inp & DFL(DC_LASTVIEW))
77 new_view(NULL);
78 if (inp & DFL(DC_RESUME)) {
79 serv_request(DR_NOOP, 0, NULL);
80 pause = 0;
81 }
82 if (inp & DFL(DC_PAUSE))
83 pause = 1;
84 if (inp & DFL(DC_REDRAW))
85 imm_mode = beam_sync() > 0;
86 if (inp & DFL(DC_KILL)) {
87 serv_request(DR_KILL, 0, NULL);
88 pause = 0;
89 }
90 if (inp & DFL(DC_CLOBBER))
91 serv_request(DR_CLOBBER, 0, NULL);
92 if (inp & DFL(DC_RESTART)) {
93 serv_request(DR_RESTART, 0, NULL);
94 pause = 0;
95 }
96 if (inp & DFL(DC_QUIT))
97 serv_request(DR_SHUTDOWN, 0, NULL);
98 }
99 if (rdy & RDY_SIN) /* user input from sstdin */
100 switch (usr_input()) {
101 case DC_PAUSE:
102 pause = 1;
103 break;
104 case DC_RESUME:
105 serv_request(DR_NOOP, 0, NULL);
106 /* fall through */
107 case DC_KILL:
108 case DC_RESTART:
109 pause = 0;
110 break;
111 }
112 } while (res != DS_SHUTDOWN);
113 /* all done */
114 quit(0);
115 }
116
117
118 int
119 disp_wait() /* wait for more input */
120 {
121 fd_set readset, errset;
122 int flgs;
123 int n;
124 register int i;
125 /* see if we can avoid select call */
126 if (imm_mode || stdin->_cnt > 0)
127 return(RDY_SRV);
128 if (sstdin != NULL && sstdin->_cnt > 0)
129 return(RDY_SIN);
130 if (dev_flush())
131 return(RDY_DEV);
132 /* make the call */
133 FD_ZERO(&readset); FD_ZERO(&errset);
134 FD_SET(0, &readset);
135 FD_SET(0, &errset);
136 FD_SET(odev.ifd, &readset);
137 FD_SET(odev.ifd, &errset);
138 n = odev.ifd+1;
139 if (sstdin != NULL) {
140 FD_SET(fileno(sstdin), &readset);
141 if (fileno(sstdin) >= n)
142 n = fileno(sstdin) + 1;
143 }
144 n = select(n, &readset, NULL, &errset, NULL);
145 if (n < 0) {
146 if (errno == EINTR)
147 return(0);
148 error(SYSTEM, "select call failure in disp_wait");
149 }
150 flgs = 0; /* flag what's ready */
151 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
152 flgs |= RDY_SRV;
153 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
154 flgs |= RDY_DEV;
155 if (sstdin != NULL && FD_ISSET(fileno(sstdin), &readset))
156 flgs |= RDY_SIN;
157 return(flgs);
158 }
159
160
161 add_holo(hdg) /* register a new holodeck section */
162 HDGRID *hdg;
163 {
164 VIEW nv;
165 double d;
166 register int hd;
167
168 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
169 ;
170 if (hd >= HDMAX)
171 error(INTERNAL, "too many holodeck sections in add_holo");
172 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
173 if (hdlist[hd] == NULL)
174 error(SYSTEM, "out of memory in add_holo");
175 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
176 hdcompgrid(hdlist[hd]);
177 if (hd)
178 return;
179 /* set initial viewpoint */
180 copystruct(&nv, &odev.v);
181 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
182 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
183 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
184 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
185 VCOPY(nv.vup, hdlist[0]->xv[2]);
186 if (do_outside) {
187 normalize(nv.vdir);
188 d = VLEN(hdlist[0]->xv[1]);
189 d += VLEN(hdlist[0]->xv[2]);
190 VSUM(nv.vp, nv.vp, nv.vdir, -d);
191 }
192 new_view(&nv);
193 }
194
195
196 disp_bundle(p) /* display a ray bundle */
197 register PACKHEAD *p;
198 {
199 GCOORD gc[2];
200 FVECT ro, rd, wp;
201 double d;
202 register int i;
203 /* get beam coordinates */
204 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
205 error(INTERNAL, "bad holodeck number in disp_bundle");
206 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
207 error(INTERNAL, "bad beam index in disp_bundle");
208 /* display each ray */
209 for (i = p->nr; i--; ) {
210 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
211 d = hddepth(hdlist[p->hd], packra(p)[i].d);
212 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
213 dev_value(packra(p)[i].v, wp, rd);
214 }
215 }
216
217
218 new_view(v) /* change view parameters */
219 register VIEW *v;
220 {
221 static VIEW viewhist[VIEWHISTLEN];
222 static unsigned nhist;
223 char *err;
224 /* restore previous view? */
225 if (v == NULL) {
226 if (nhist > 1) /* get one before last setting */
227 nhist--;
228 else /* else go to end of list */
229 while (nhist < VIEWHISTLEN && viewhist[nhist].type)
230 nhist++;
231 v = viewhist + ((nhist-1)%VIEWHISTLEN);
232 } else
233 again:
234 if ((err = setview(v)) != NULL) {
235 error(COMMAND, err);
236 return;
237 }
238 if (v->type == VT_PAR) {
239 error(COMMAND, "cannot handle parallel views");
240 return;
241 }
242 if (!dev_view(v)) /* update display driver */
243 goto again;
244 dev_flush(); /* update screen */
245 if (!beam_view(v)) /* update beam list */
246 goto again;
247 /* record new view */
248 if (v < viewhist || v >= viewhist+VIEWHISTLEN) {
249 copystruct(viewhist + (nhist%VIEWHISTLEN), v);
250 nhist++;
251 }
252 }
253
254
255 int
256 usr_input() /* get user input and process it */
257 {
258 VIEW vparams;
259 char cmd[128];
260 register char *args;
261 register int i;
262
263 if (fgets(cmd, sizeof(cmd), sstdin) == NULL)
264 return(DC_QUIT);
265 for (args = cmd; *args && !isspace(*args); args++)
266 ;
267 while (isspace(*args))
268 *args++ = '\0';
269 if (!*cmd)
270 return(DC_RESUME);
271 if (*args && args[i=strlen(args)-1] == '\n')
272 args[i] = '\0';
273 for (i = 0; i < DC_NCMDS; i++)
274 if (!strcmp(cmd, cmdlist[i]))
275 break;
276 if (i >= DC_NCMDS) {
277 sprintf(errmsg, "unknown command: %s", cmd);
278 error(COMMAND, errmsg);
279 return(-1);
280 }
281 switch (i) {
282 case DC_SETVIEW: /* set the view */
283 copystruct(&vparams, &odev.v);
284 if (!sscanview(&vparams, args))
285 error(COMMAND, "missing view options");
286 else
287 new_view(&vparams);
288 break;
289 case DC_GETVIEW: /* print the current view */
290 printview();
291 break;
292 case DC_LASTVIEW: /* restore previous view */
293 new_view(NULL);
294 break;
295 case DC_PAUSE: /* pause the current calculation */
296 case DC_RESUME: /* resume the calculation */
297 /* handled in main() */
298 break;
299 case DC_REDRAW: /* redraw from server */
300 imm_mode = beam_sync() > 0;
301 break;
302 case DC_KILL: /* kill rtrace process(es) */
303 serv_request(DR_KILL, 0, NULL);
304 break;
305 case DC_CLOBBER: /* clobber holodeck */
306 serv_request(DR_CLOBBER, 0, NULL);
307 break;
308 case DC_RESTART: /* restart rtrace */
309 serv_request(DR_RESTART, 0, NULL);
310 break;
311 case DC_QUIT: /* quit request */
312 serv_request(DR_SHUTDOWN, 0, NULL);
313 break;
314 default:
315 error(CONSISTENCY, "bad command id in usr_input");
316 }
317 return(i);
318 }
319
320
321 printview() /* print our current view to server stdout */
322 {
323 fputs(VIEWSTR, sstdout);
324 fprintview(&odev.v, sstdout);
325 fputc('\n', sstdout);
326 fflush(sstdout);
327 }
328
329
330 int
331 serv_result() /* get next server result and process it */
332 {
333 static char *buf = NULL;
334 static int bufsiz = 0;
335 MSGHEAD msg;
336 int n;
337 /* read message header */
338 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
339 goto readerr;
340 if (msg.nbytes > 0) { /* get the message body */
341 if (msg.nbytes > bufsiz) {
342 if (buf == NULL)
343 buf = (char *)malloc(bufsiz=msg.nbytes);
344 else
345 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
346 if (buf == NULL)
347 error(SYSTEM, "out of memory in serv_result");
348 }
349 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
350 goto readerr;
351 }
352 switch (msg.type) { /* process results */
353 case DS_BUNDLE:
354 if (msg.nbytes < sizeof(PACKHEAD) ||
355 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
356 error(INTERNAL, "bad display packet from server");
357 disp_bundle((PACKHEAD *)buf);
358 break;
359 case DS_ADDHOLO:
360 if (msg.nbytes != sizeof(HDGRID))
361 error(INTERNAL, "bad holodeck record from server");
362 add_holo((HDGRID *)buf);
363 break;
364 case DS_OUTSECT:
365 do_outside = 1;
366 break;
367 case DS_STARTIMM:
368 case DS_ENDIMM:
369 imm_mode = msg.type==DS_STARTIMM;
370 /* fall through */
371 case DS_ACKNOW:
372 case DS_SHUTDOWN:
373 if (msg.nbytes) {
374 sprintf(errmsg,
375 "unexpected body with server message %d",
376 msg.type);
377 error(INTERNAL, errmsg);
378 }
379 break;
380 default:
381 error(INTERNAL, "unrecognized result from server process");
382 }
383 return(msg.type); /* return message type */
384 readerr:
385 if (feof(stdin))
386 error(SYSTEM, "server process died");
387 error(SYSTEM, "error reading from server process");
388 }
389
390
391 serv_request(type, nbytes, p) /* send a request to the server process */
392 int type, nbytes;
393 char *p;
394 {
395 MSGHEAD msg;
396 int m;
397 /* get server's attention for big request */
398 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
399 serv_request(DR_ATTEN, 0, NULL);
400 while ((m = serv_result()) != DS_ACKNOW)
401 if (m == DS_SHUTDOWN) /* the bugger quit on us */
402 quit(0);
403 }
404 msg.type = type; /* write and flush the message */
405 msg.nbytes = nbytes;
406 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
407 if (nbytes > 0)
408 fwrite(p, 1, nbytes, stdout);
409 if (fflush(stdout) < 0)
410 error(SYSTEM, "write error in serv_request");
411 }
412
413
414 eputs(s) /* put error message to stderr */
415 register char *s;
416 {
417 static int midline = 0;
418
419 if (!*s)
420 return;
421 if (!midline++) { /* prepend line with program name */
422 fputs(progname, stderr);
423 fputs(": ", stderr);
424 }
425 fputs(s, stderr);
426 if (s[strlen(s)-1] == '\n') {
427 fflush(stderr);
428 midline = 0;
429 }
430 }
431
432
433 quit(code) /* clean up and exit */
434 int code;
435 {
436 if (odev.v.type)
437 dev_close();
438 exit(code);
439 }
