root/radiance/ray/src/hd/rhdisp.c
Revision: 3.1
Committed: Wed Nov 19 18:01:03 1997 UTC (27 years, 7 months ago) by gregl
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15
16 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
17
18 int imm_mode = 0; /* bundles are being delivered immediately */
19
20 VIEW dvw; /* our current display view */
21
22 char *progname; /* global argv[0] */
23
24 #define SERV_READY 01
25 #define DEV_READY 02
26
27
28 main(argc, argv)
29 int argc;
30 char *argv[];
31 {
32 int rdy, inp, res = 0;
33
34 progname = argv[0];
35 if (argc != 2)
36 error(USER, "bad command line arguments");
37 /* open our device */
38 dev_open(argv[1]);
39 /* enter main loop */
40 do {
41 rdy = disp_wait();
42 if (rdy & DEV_READY) {
43 inp = dev_input(); /* take residual action here */
44 if (inp & DEV_SHUTDOWN)
45 serv_request(DR_SHUTDOWN, 0, NULL);
46 else if (inp & DEV_NEWVIEW)
47 new_view(&odev.v);
48 }
49 if (rdy & SERV_READY)
50 res = serv_result(); /* processes result, also */
51 } while (res != DS_SHUTDOWN);
52 /* all done */
53 quit(0);
54 }
55
56
57 int
58 disp_wait() /* wait for more input */
59 {
60 fd_set readset, errset;
61 int flgs;
62 int n;
63 register int i;
64 /* see if we can avoid select call */
65 if (imm_mode || stdin->_cnt > 0)
66 return(SERV_READY);
67 if (dev_flush())
68 return(DEV_READY);
69 /* make the call */
70 FD_ZERO(&readset); FD_ZERO(&errset);
71 FD_SET(0, &readset);
72 FD_SET(0, &errset);
73 FD_SET(odev.ifd, &readset);
74 FD_SET(odev.ifd, &errset);
75 n = odev.ifd + 1;
76 n = select(n, &readset, NULL, &errset, NULL);
77 if (n < 0) {
78 if (errno == EINTR)
79 return(0);
80 error(SYSTEM, "select call failure in disp_wait");
81 }
82 flgs = 0; /* flag what's ready */
83 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
84 flgs |= SERV_READY;
85 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
86 flgs |= DEV_READY;
87 return(flgs);
88 }
89
90
91 add_holo(hdg) /* register a new holodeck section */
92 HDGRID *hdg;
93 {
94 VIEW nv;
95 register int hd;
96
97 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
98 ;
99 if (hd >= HDMAX)
100 error(INTERNAL, "too many holodeck sections in add_holo");
101 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
102 if (hdlist[hd] == NULL)
103 error(SYSTEM, "out of memory in add_holo");
104 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
105 hdcompgrid(hdlist[hd]);
106 if (hd)
107 return;
108 /* set initial viewpoint */
109 copystruct(&nv, &odev.v);
110 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
111 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
112 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
113 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
114 VCOPY(nv.vup, hdlist[0]->xv[2]);
115 new_view(&nv);
116 }
117
118
119 disp_bundle(p) /* display a ray bundle */
120 register PACKHEAD *p;
121 {
122 GCOORD gc[2];
123 FVECT ro, rd, wp;
124 double d;
125 register int i;
126 /* get beam coordinates */
127 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
128 error(INTERNAL, "bad holodeck number in disp_bundle");
129 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
130 error(INTERNAL, "bad beam index in disp_bundle");
131 /* display each ray */
132 for (i = p->nr; i--; ) {
133 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
134 d = hddepth(hdlist[p->hd], packra(p)[i].d);
135 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
136 dev_value(packra(p)[i].v, wp);
137 }
138 }
139
140
141 new_view(v) /* change view parameters */
142 VIEW *v;
143 {
144 char *err;
145
146 if ((err = setview(v)) != NULL)
147 error(INTERNAL, err);
148 dev_view(v); /* update display driver */
149 beam_view(&dvw, v); /* update beam list */
150 copystruct(&dvw, v); /* record new view */
151 }
152
153
154 int
155 serv_result() /* get next server result and process it */
156 {
157 static char *buf = NULL;
158 static int bufsiz = 0;
159 MSGHEAD msg;
160 int n;
161 /* read message header */
162 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
163 goto readerr;
164 if (msg.nbytes > 0) { /* get the message body */
165 if (msg.nbytes > bufsiz) {
166 if (buf == NULL)
167 buf = (char *)malloc(bufsiz=msg.nbytes);
168 else
169 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
170 if (buf == NULL)
171 error(SYSTEM, "out of memory in serv_result");
172 }
173 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
174 goto readerr;
175 }
176 switch (msg.type) { /* process results */
177 case DS_BUNDLE:
178 if (msg.nbytes < sizeof(PACKHEAD) ||
179 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
180 error(INTERNAL, "bad display packet from server");
181 disp_bundle((PACKHEAD *)buf);
182 break;
183 case DS_ADDHOLO:
184 if (msg.nbytes != sizeof(HDGRID))
185 error(INTERNAL, "bad holodeck record from server");
186 add_holo((HDGRID *)buf);
187 break;
188 case DS_STARTIMM:
189 case DS_ENDIMM:
190 imm_mode = msg.type==DS_STARTIMM;
191 /* fall through */
192 case DS_ACKNOW:
193 case DS_SHUTDOWN:
194 if (msg.nbytes) {
195 sprintf(errmsg,
196 "unexpected body with server message %d",
197 msg.type);
198 error(INTERNAL, errmsg);
199 }
200 break;
201 default:
202 error(INTERNAL, "unrecognized result from server process");
203 }
204 return(msg.type); /* return message type */
205 readerr:
206 if (feof(stdin))
207 error(SYSTEM, "server process died");
208 error(SYSTEM, "error reading from server process");
209 }
210
211
212 serv_request(type, nbytes, p) /* send a request to the server process */
213 int type, nbytes;
214 char *p;
215 {
216 MSGHEAD msg;
217 int m;
218 /* get server's attention for big request */
219 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
220 serv_request(DR_ATTEN, 0, NULL);
221 while ((m = serv_result()) != DS_ACKNOW)
222 if (m == DS_SHUTDOWN) /* the bugger quit on us */
223 quit(0);
224 }
225 msg.type = type; /* write and flush the message */
226 msg.nbytes = nbytes;
227 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
228 if (nbytes > 0)
229 fwrite(p, 1, nbytes, stdout);
230 if (fflush(stdout) < 0)
231 error(SYSTEM, "write error in serv_request");
232 }
233
234
235 quit(code) /* clean up and exit */
236 int code;
237 {
238 if (odev.v.type)
239 dev_close();
240 exit(code);
241 }
