1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Holodeck display process. |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "rhdisp.h" |
13 |
#include "rhdriver.h" |
14 |
#include "selcall.h" |
15 |
#include <ctype.h> |
16 |
17 |
#ifndef VIEWHISTLEN |
18 |
#define VIEWHISTLEN 2 /* number of remembered views */ |
19 |
#endif |
20 |
21 |
HOLO *hdlist[HDMAX+1]; /* global holodeck list */ |
22 |
23 |
char cmdlist[DC_NCMDS][8] = DC_INIT; |
24 |
25 |
int imm_mode = 0; /* bundles are being delivered immediately */ |
26 |
27 |
char *progname; /* global argv[0] */ |
28 |
29 |
FILE *sstdin, *sstdout; /* server's standard input and output */ |
30 |
31 |
#define RDY_SRV 01 |
32 |
#define RDY_DEV 02 |
33 |
#define RDY_SIN 04 |
34 |
35 |
36 |
main(argc, argv) |
37 |
int argc; |
38 |
char *argv[]; |
39 |
40 |
extern int eputs(); |
41 |
int rdy, inp, res = 0, pause = 0; |
42 |
43 |
progname = argv[0]; |
44 |
if (argc < 3) |
45 |
error(USER, "bad command line arguments"); |
46 |
/* open our device */ |
47 |
dev_open(argv[1]); |
48 |
/* open server process i/o */ |
49 |
sstdout = fdopen(atoi(argv[2]), "w"); |
50 |
if (argc < 4 || (inp = atoi(argv[3])) < 0) |
51 |
sstdin = NULL; |
52 |
else |
53 |
sstdin = fdopen(inp, "r"); |
54 |
/* set command error vector */ |
55 |
erract[COMMAND].pf = eputs; |
56 |
/* enter main loop */ |
57 |
do { |
58 |
rdy = disp_wait(); |
59 |
if (rdy & RDY_DEV) { /* user input from driver */ |
60 |
inp = dev_input(); |
61 |
if (inp & DEV_PUTVIEW) |
62 |
printview(); |
63 |
if (inp & DEV_NEWVIEW) |
64 |
new_view(&odev.v); |
65 |
if (inp & DEV_LASTVIEW) |
66 |
new_view(NULL); |
67 |
if (inp & DEV_SHUTDOWN) |
68 |
serv_request(DR_SHUTDOWN, 0, NULL); |
69 |
if (inp & DEV_REDRAW) |
70 |
imm_mode = beam_sync() > 0; |
71 |
if (inp & DEV_WAIT) |
72 |
pause = 1; |
73 |
if (inp & DEV_RESUME) { |
74 |
serv_request(DR_NOOP, 0, NULL); |
75 |
pause = 0; |
76 |
77 |
78 |
if (rdy & RDY_SIN) /* user input from sstdin */ |
79 |
switch (usr_input()) { |
80 |
case DC_PAUSE: |
81 |
pause = 1; |
82 |
break; |
83 |
case DC_RESUME: |
84 |
85 |
pause = 0; |
86 |
break; |
87 |
88 |
if (rdy & RDY_SRV) { /* process server result */ |
89 |
res = serv_result(); |
90 |
if (pause && res != DS_SHUTDOWN) { |
91 |
serv_request(DR_ATTEN, 0, NULL); |
92 |
while ((res = serv_result()) != DS_ACKNOW && |
93 |
res != DS_SHUTDOWN) |
94 |
95 |
96 |
97 |
} while (res != DS_SHUTDOWN); |
98 |
/* all done */ |
99 |
quit(0); |
100 |
101 |
102 |
103 |
int |
104 |
disp_wait() /* wait for more input */ |
105 |
106 |
fd_set readset, errset; |
107 |
int flgs; |
108 |
int n; |
109 |
register int i; |
110 |
/* see if we can avoid select call */ |
111 |
if (imm_mode || stdin->_cnt > 0) |
112 |
return(RDY_SRV); |
113 |
if (sstdin != NULL && sstdin->_cnt > 0) |
114 |
return(RDY_SIN); |
115 |
if (dev_flush()) |
116 |
return(RDY_DEV); |
117 |
/* make the call */ |
118 |
FD_ZERO(&readset); FD_ZERO(&errset); |
119 |
FD_SET(0, &readset); |
120 |
FD_SET(0, &errset); |
121 |
FD_SET(odev.ifd, &readset); |
122 |
FD_SET(odev.ifd, &errset); |
123 |
n = odev.ifd+1; |
124 |
if (sstdin != NULL) { |
125 |
FD_SET(fileno(sstdin), &readset); |
126 |
if (fileno(sstdin) >= n) |
127 |
n = fileno(sstdin) + 1; |
128 |
129 |
n = select(n, &readset, NULL, &errset, NULL); |
130 |
if (n < 0) { |
131 |
if (errno == EINTR) |
132 |
return(0); |
133 |
error(SYSTEM, "select call failure in disp_wait"); |
134 |
135 |
flgs = 0; /* flag what's ready */ |
136 |
if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset)) |
137 |
flgs |= RDY_SRV; |
138 |
if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset)) |
139 |
flgs |= RDY_DEV; |
140 |
if (sstdin != NULL && FD_ISSET(fileno(sstdin), &readset)) |
141 |
flgs |= RDY_SIN; |
142 |
return(flgs); |
143 |
144 |
145 |
146 |
add_holo(hdg) /* register a new holodeck section */ |
147 |
HDGRID *hdg; |
148 |
149 |
VIEW nv; |
150 |
register int hd; |
151 |
152 |
for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++) |
153 |
154 |
if (hd >= HDMAX) |
155 |
error(INTERNAL, "too many holodeck sections in add_holo"); |
156 |
hdlist[hd] = (HOLO *)malloc(sizeof(HOLO)); |
157 |
if (hdlist[hd] == NULL) |
158 |
error(SYSTEM, "out of memory in add_holo"); |
159 |
bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID)); |
160 |
hdcompgrid(hdlist[hd]); |
161 |
if (hd) |
162 |
return; |
163 |
/* set initial viewpoint */ |
164 |
copystruct(&nv, &odev.v); |
165 |
VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5); |
166 |
VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5); |
167 |
VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5); |
168 |
fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]); |
169 |
VCOPY(nv.vup, hdlist[0]->xv[2]); |
170 |
new_view(&nv); |
171 |
172 |
173 |
174 |
disp_bundle(p) /* display a ray bundle */ |
175 |
register PACKHEAD *p; |
176 |
177 |
GCOORD gc[2]; |
178 |
FVECT ro, rd, wp; |
179 |
double d; |
180 |
register int i; |
181 |
/* get beam coordinates */ |
182 |
if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL) |
183 |
error(INTERNAL, "bad holodeck number in disp_bundle"); |
184 |
if (!hdbcoord(gc, hdlist[p->hd], p->bi)) |
185 |
error(INTERNAL, "bad beam index in disp_bundle"); |
186 |
/* display each ray */ |
187 |
for (i = p->nr; i--; ) { |
188 |
hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r); |
189 |
d = hddepth(hdlist[p->hd], packra(p)[i].d); |
190 |
VSUM(wp, ro, rd, d); /* might be behind viewpoint */ |
191 |
dev_value(packra(p)[i].v, wp, rd); |
192 |
193 |
194 |
195 |
196 |
new_view(v) /* change view parameters */ |
197 |
register VIEW *v; |
198 |
199 |
static VIEW viewhist[VIEWHISTLEN]; |
200 |
static unsigned nhist; |
201 |
char *err; |
202 |
/* restore previous view? */ |
203 |
if (v == NULL) { |
204 |
if (nhist < 2) { |
205 |
error(COMMAND, "no previous view"); |
206 |
return; |
207 |
208 |
nhist--; /* get one before last setting */ |
209 |
v = viewhist + ((nhist-1)%VIEWHISTLEN); |
210 |
} else if ((err = setview(v)) != NULL) { |
211 |
error(COMMAND, err); |
212 |
return; |
213 |
214 |
again: |
215 |
if (v->type == VT_PAR) { |
216 |
error(COMMAND, "cannot handle parallel views"); |
217 |
return; |
218 |
219 |
if (!dev_view(v)) /* update display driver */ |
220 |
goto again; |
221 |
dev_flush(); /* update screen */ |
222 |
if (!beam_view(v)) /* update beam list */ |
223 |
goto again; |
224 |
/* record new view */ |
225 |
if (v < viewhist || v >= viewhist+VIEWHISTLEN) { |
226 |
copystruct(viewhist + (nhist%VIEWHISTLEN), v); |
227 |
nhist++; |
228 |
229 |
230 |
231 |
232 |
int |
233 |
usr_input() /* get user input and process it */ |
234 |
235 |
VIEW vparams; |
236 |
char cmd[128]; |
237 |
register char *args; |
238 |
register int i; |
239 |
240 |
if (fgets(cmd, sizeof(cmd), sstdin) == NULL) |
241 |
return(DC_QUIT); |
242 |
for (args = cmd; *args && !isspace(*args); args++) |
243 |
244 |
while (isspace(*args)) |
245 |
*args++ = '\0'; |
246 |
if (!*cmd) |
247 |
return(DC_RESUME); |
248 |
if (*args && args[i=strlen(args)-1] == '\n') |
249 |
args[i] = '\0'; |
250 |
for (i = 0; i < DC_NCMDS; i++) |
251 |
if (!strcmp(cmd, cmdlist[i])) |
252 |
break; |
253 |
if (i >= DC_NCMDS) { |
254 |
sprintf(errmsg, "unknown command: %s", cmd); |
255 |
error(COMMAND, errmsg); |
256 |
return(-1); |
257 |
258 |
switch (i) { |
259 |
case DC_SETVIEW: /* set the view */ |
260 |
copystruct(&vparams, &odev.v); |
261 |
if (!sscanview(&vparams, args)) |
262 |
error(COMMAND, "missing view options"); |
263 |
else |
264 |
new_view(&vparams); |
265 |
break; |
266 |
case DC_GETVIEW: /* print the current view */ |
267 |
printview(); |
268 |
break; |
269 |
case DC_LASTVIEW: /* restore previous view */ |
270 |
new_view(NULL); |
271 |
break; |
272 |
case DC_PAUSE: /* pause the current calculation */ |
273 |
case DC_RESUME: /* resume the calculation */ |
274 |
/* handled in main() */ |
275 |
break; |
276 |
case DC_QUIT: /* quit request */ |
277 |
278 |
break; |
279 |
default: |
280 |
error(CONSISTENCY, "bad command id in usr_input"); |
281 |
282 |
return(i); |
283 |
284 |
285 |
286 |
printview() /* print our current view to server stdout */ |
287 |
288 |
fputs(VIEWSTR, sstdout); |
289 |
fprintview(&odev.v, sstdout); |
290 |
fputc('\n', sstdout); |
291 |
fflush(sstdout); |
292 |
293 |
294 |
295 |
int |
296 |
serv_result() /* get next server result and process it */ |
297 |
298 |
static char *buf = NULL; |
299 |
static int bufsiz = 0; |
300 |
MSGHEAD msg; |
301 |
int n; |
302 |
/* read message header */ |
303 |
if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1) |
304 |
goto readerr; |
305 |
if (msg.nbytes > 0) { /* get the message body */ |
306 |
if (msg.nbytes > bufsiz) { |
307 |
if (buf == NULL) |
308 |
buf = (char *)malloc(bufsiz=msg.nbytes); |
309 |
else |
310 |
buf = (char *)realloc(buf, bufsiz=msg.nbytes); |
311 |
if (buf == NULL) |
312 |
error(SYSTEM, "out of memory in serv_result"); |
313 |
314 |
if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes) |
315 |
goto readerr; |
316 |
317 |
switch (msg.type) { /* process results */ |
318 |
case DS_BUNDLE: |
319 |
if (msg.nbytes < sizeof(PACKHEAD) || |
320 |
msg.nbytes != packsiz(((PACKHEAD *)buf)->nr)) |
321 |
error(INTERNAL, "bad display packet from server"); |
322 |
disp_bundle((PACKHEAD *)buf); |
323 |
break; |
324 |
case DS_ADDHOLO: |
325 |
if (msg.nbytes != sizeof(HDGRID)) |
326 |
error(INTERNAL, "bad holodeck record from server"); |
327 |
add_holo((HDGRID *)buf); |
328 |
break; |
329 |
case DS_STARTIMM: |
330 |
case DS_ENDIMM: |
331 |
imm_mode = msg.type==DS_STARTIMM; |
332 |
if (msg.type == DS_ENDIMM) |
333 |
dev_flush(); /* update display NOW */ |
334 |
/* fall through */ |
335 |
case DS_ACKNOW: |
336 |
case DS_SHUTDOWN: |
337 |
if (msg.nbytes) { |
338 |
sprintf(errmsg, |
339 |
"unexpected body with server message %d", |
340 |
msg.type); |
341 |
error(INTERNAL, errmsg); |
342 |
343 |
break; |
344 |
default: |
345 |
error(INTERNAL, "unrecognized result from server process"); |
346 |
347 |
return(msg.type); /* return message type */ |
348 |
readerr: |
349 |
if (feof(stdin)) |
350 |
error(SYSTEM, "server process died"); |
351 |
error(SYSTEM, "error reading from server process"); |
352 |
353 |
354 |
355 |
serv_request(type, nbytes, p) /* send a request to the server process */ |
356 |
int type, nbytes; |
357 |
char *p; |
358 |
359 |
MSGHEAD msg; |
360 |
int m; |
361 |
/* get server's attention for big request */ |
362 |
if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) { |
363 |
364 |
while ((m = serv_result()) != DS_ACKNOW) |
365 |
if (m == DS_SHUTDOWN) /* the bugger quit on us */ |
366 |
quit(0); |
367 |
368 |
msg.type = type; /* write and flush the message */ |
369 |
msg.nbytes = nbytes; |
370 |
fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout); |
371 |
if (nbytes > 0) |
372 |
fwrite(p, 1, nbytes, stdout); |
373 |
if (fflush(stdout) < 0) |
374 |
error(SYSTEM, "write error in serv_request"); |
375 |
376 |
377 |
378 |
eputs(s) /* put error message to stderr */ |
379 |
register char *s; |
380 |
381 |
static int midline = 0; |
382 |
383 |
if (!*s) |
384 |
return; |
385 |
if (!midline++) { /* prepend line with program name */ |
386 |
fputs(progname, stderr); |
387 |
fputs(": ", stderr); |
388 |
389 |
fputs(s, stderr); |
390 |
if (s[strlen(s)-1] == '\n') { |
391 |
fflush(stderr); |
392 |
midline = 0; |
393 |
394 |
395 |
396 |
397 |
quit(code) /* clean up and exit */ |
398 |
int code; |
399 |
400 |
if (odev.v.type) |
401 |
dev_close(); |
402 |
exit(code); |
403 |
