root/radiance/ray/src/hd/rhdisp.c
Revision: 3.37
Committed: Fri Dec 18 11:56:10 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.36: +28 -21 lines
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15 #include <ctype.h>
16
17 #ifndef VIEWHISTLEN
18 #define VIEWHISTLEN 4 /* number of remembered views */
19 #endif
20
21 #ifndef FSIZDEF
22 #define FSIZDEF 0.125 /* default focus frame size */
23 #endif
24
25 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
26
27 char *hdofn[HDMAX+1]; /* holodeck section octree list */
28
29 char cmdlist[DC_NCMDS][8] = DC_INIT;
30
31 int imm_mode = 0; /* bundles are being delivered immediately */
32
33 int do_outside = 0; /* render from outside sections */
34
35 double eyesepdist = 1; /* eye separation distance */
36
37 char *progname; /* global argv[0] */
38
39 FILE *sstdin, *sstdout; /* server's standard input and output */
40
41 #ifdef DEBUG
42 #include <sys/types.h>
43 extern time_t time();
44 static time_t tmodesw;
45 static time_t timm, tadd;
46 static long nimmrays, naddrays;
47 #endif
48
49 #define RDY_SRV 01
50 #define RDY_DEV 02
51 #define RDY_SIN 04
52
53
54 main(argc, argv)
55 int argc;
56 char *argv[];
57 {
58 extern int eputs();
59 int rdy, inp, res = 0, pause = 0;
60
61 progname = argv[0];
62 if (argc < 3)
63 error(USER, "bad command line arguments");
64 /* open our device */
65 dev_open(argv[1]);
66 /* open server process i/o */
67 sstdout = fdopen(atoi(argv[2]), "w");
68 if (argc < 4 || (inp = atoi(argv[3])) < 0)
69 sstdin = NULL;
70 else
71 sstdin = fdopen(inp, "r");
72 /* set command error vector */
73 erract[COMMAND].pf = eputs;
74 #ifdef DEBUG
75 tmodesw = time(NULL);
76 #endif
77 /* enter main loop */
78 do {
79 rdy = disp_wait();
80 if (rdy & RDY_SRV) { /* process server result */
81 res = serv_result();
82 if (pause && res != DS_SHUTDOWN) {
83 serv_request(DR_ATTEN, 0, NULL);
84 while ((res = serv_result()) != DS_ACKNOW &&
85 res != DS_SHUTDOWN)
86 ;
87 }
88 }
89 if (rdy & RDY_DEV) { /* user input from driver */
90 inp = dev_input();
91 if (inp & DFL(DC_SETVIEW))
92 new_view(&odev.v);
93 else if (inp & DFL(DC_LASTVIEW))
94 new_view(NULL);
95 if (inp & DFL(DC_REDRAW))
96 imm_mode = beam_sync(1) > 0;
97 if (inp & DFL(DC_GETVIEW))
98 printview();
99 if (inp & DFL(DC_FOCUS))
100 set_focus(odev_args);
101 if (inp & DFL(DC_KILL)) {
102 serv_request(DR_KILL, 0, NULL);
103 pause = 0;
104 }
105 if (inp & DFL(DC_CLOBBER))
106 serv_request(DR_CLOBBER, 0, NULL);
107 if (inp & DFL(DC_RESTART)) {
108 serv_request(DR_RESTART, 0, NULL);
109 pause = 0;
110 }
111 if (inp & DFL(DC_RESUME)) {
112 serv_request(DR_NOOP, 0, NULL);
113 pause = 0;
114 }
115 if (inp & DFL(DC_PAUSE))
116 pause = 1;
117 if (inp & DFL(DC_QUIT))
118 serv_request(DR_SHUTDOWN, 0, NULL);
119 }
120 if (rdy & RDY_SIN && !imm_mode) /* user input from sstdin */
121 switch (usr_input()) {
122 case DC_PAUSE:
123 pause = 1;
124 break;
125 case DC_RESUME:
126 serv_request(DR_NOOP, 0, NULL);
127 /* fall through */
128 case DC_KILL:
129 case DC_RESTART:
130 pause = 0;
131 break;
132 }
133 } while (res != DS_SHUTDOWN);
134 #ifdef DEBUG
135 if (timm && nimmrays)
136 fprintf(stderr,
137 "%s: %.1f rays recalled/second (%ld rays total)\n",
138 progname, (double)nimmrays/timm, nimmrays);
139 if (tadd && naddrays)
140 fprintf(stderr,
141 "%s: %.1f rays calculated/second (%ld rays total)\n",
142 progname, (double)naddrays/tadd, naddrays);
143 #endif
144 /* all done */
145 quit(0);
146 }
147
148
149 int
150 disp_wait() /* wait for more input */
151 {
152 fd_set readset, errset;
153 int flgs;
154 int n;
155 register int i;
156 /* see if we can avoid select call */
157 flgs = 0; /* flag what's ready already */
158 if (imm_mode || stdin->_cnt > 0)
159 flgs |= RDY_SRV;
160 if (sstdin != NULL && sstdin->_cnt > 0)
161 flgs |= RDY_SIN;
162 if (odev.inpready)
163 flgs |= RDY_DEV;
164 if (flgs) /* got something? */
165 return(flgs);
166 if (dev_flush()) /* else flush output & check keyboard+mouse */
167 return(RDY_DEV);
168 /* if nothing, we need to call select */
169 FD_ZERO(&readset); FD_ZERO(&errset);
170 FD_SET(0, &readset);
171 FD_SET(0, &errset);
172 FD_SET(odev.ifd, &readset);
173 FD_SET(odev.ifd, &errset);
174 n = odev.ifd+1;
175 if (sstdin != NULL) {
176 FD_SET(fileno(sstdin), &readset);
177 FD_SET(fileno(sstdin), &errset);
178 if (fileno(sstdin) >= n)
179 n = fileno(sstdin) + 1;
180 }
181 n = select(n, &readset, NULL, &errset, NULL);
182 if (n < 0) {
183 if (errno == EINTR)
184 return(0);
185 error(SYSTEM, "select call failure in disp_wait");
186 }
187 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
188 flgs |= RDY_SRV;
189 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
190 flgs |= RDY_DEV;
191 if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) ||
192 FD_ISSET(fileno(sstdin), &errset)))
193 flgs |= RDY_SIN;
194 return(flgs);
195 }
196
197
198 add_holo(hdg, ofn) /* register a new holodeck section */
199 HDGRID *hdg;
200 char *ofn;
201 {
202 VIEW nv;
203 double d;
204 register int hd;
205
206 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
207 ;
208 if (hd >= HDMAX)
209 error(INTERNAL, "too many holodeck sections in add_holo");
210 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
211 if (hdlist[hd] == NULL)
212 error(SYSTEM, "out of memory in add_holo");
213 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
214 hdcompgrid(hdlist[hd]);
215 hdofn[hd] = savestr(ofn);
216 if (hd)
217 return;
218 /* set initial viewpoint */
219 copystruct(&nv, &odev.v);
220 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
221 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
222 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
223 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
224 VCOPY(nv.vup, hdlist[0]->xv[2]);
225 if (do_outside) {
226 normalize(nv.vdir);
227 d = VLEN(hdlist[0]->xv[1]);
228 d += VLEN(hdlist[0]->xv[2]);
229 VSUM(nv.vp, nv.vp, nv.vdir, -d);
230 }
231 new_view(&nv);
232 }
233
234
235 disp_bundle(p) /* display a ray bundle */
236 register PACKHEAD *p;
237 {
238 GCOORD gc[2];
239 FVECT ro, rd, wp;
240 double d;
241 register int i;
242 /* get beam coordinates */
243 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
244 error(INTERNAL, "bad holodeck number in disp_bundle");
245 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
246 error(INTERNAL, "bad beam index in disp_bundle");
247 /* display each ray */
248 for (i = p->nr; i--; ) {
249 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
250 d = hddepth(hdlist[p->hd], packra(p)[i].d);
251 if (d < .99*FHUGE) {
252 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
253 dev_value(packra(p)[i].v, rd, wp);
254 } else
255 dev_value(packra(p)[i].v, rd, NULL);
256 }
257 #ifdef DEBUG
258 if (imm_mode) nimmrays += p->nr;
259 else naddrays += p->nr;
260 #endif
261 }
262
263
264 new_view(v) /* change view parameters */
265 register VIEW *v;
266 {
267 static VIEW viewhist[VIEWHISTLEN];
268 static unsigned nhist;
269 VIEW *dv;
270 int i, res[2], *slist;
271 char *err;
272 /* restore previous view? */
273 if (v == NULL) {
274 if (nhist > 1) /* get one before last setting */
275 nhist--;
276 else /* else go to end of list */
277 while (nhist < VIEWHISTLEN && viewhist[nhist].type)
278 nhist++;
279 v = viewhist + ((nhist-1)%VIEWHISTLEN);
280 } else
281 again:
282 if ((err = setview(v)) != NULL) {
283 error(COMMAND, err);
284 return;
285 }
286 if (!dev_view(v)) /* notify display driver */
287 goto again;
288 if (v->type == VT_PAR) {
289 error(COMMAND, "cannot handle parallel views");
290 return;
291 }
292 beam_init(odev.firstuse); /* compute new beam set */
293 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) {
294 if ((slist = beam_view(dv, res[0], res[1])) == NULL) {
295 if (!nhist) {
296 error(COMMAND, "invalid starting view");
297 return;
298 }
299 copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN));
300 goto again; /* poss. overloading dev_section()? */
301 }
302 DCHECK(*slist < 0, WARNING, "no visible sections in new_view");
303 while (*slist >= 0)
304 dev_section(hdofn[*slist++]);
305 }
306 dev_section(NULL); /* end section list */
307 dev_flush(); /* update display */
308 /* update server */
309 imm_mode = beam_sync(odev.firstuse) > 0;
310 /* record new view */
311 if (v < viewhist || v >= viewhist+VIEWHISTLEN) {
312 copystruct(viewhist + (nhist%VIEWHISTLEN), v);
313 nhist++;
314 }
315 }
316
317
318 set_focus(args) /* set focus frame */
319 char *args;
320 {
321 double hcent, vcent, hsiz, vsiz;
322 VIEW *dv, vwfocus;
323 int i, res[2];
324
325 i = sscanf(args, "%lf %lf %lf %lf", &hcent, &vcent, &hsiz, &vsiz);
326 if (i < 2 || hcent < 0 || hcent > 1 || vcent < 0 || vcent > 1) {
327 beam_init(0); /* restore view */
328 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
329 beam_view(dv, res[0], res[1]);
330 beam_sync(0); /* update server */
331 return;
332 }
333 if (i < 4 || hsiz <= hcent || hsiz > 1 || vsiz <= vcent || vsiz > 1)
334 hsiz = vsiz = FSIZDEF; /* gave center only */
335 else {
336 hsiz -= hcent; hcent += 0.5*hsiz; /* gave min and max */
337 vsiz -= vcent; vcent += 0.5*vsiz;
338 }
339 beam_init(0); /* add basic views */
340 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
341 beam_view(dv, res[0]>>4, res[1]>>4);
342 copystruct(&vwfocus, &odev.v); /* add focus view */
343 switch (odev.v.type) {
344 case VT_PER:
345 vwfocus.horiz = 2.*180./PI*atan(
346 hsiz * tan(PI/180./2.*odev.v.horiz) );
347 vwfocus.vert = 2.*180./PI*atan(
348 vsiz * tan(PI/180./2.*odev.v.vert) );
349 break;
350 case VT_PAR:
351 case VT_ANG:
352 vwfocus.horiz = hsiz * odev.v.horiz;
353 vwfocus.vert = vsiz * odev.v.vert;
354 break;
355 case VT_HEM:
356 vwfocus.horiz = 2.*180./PI*asin(
357 hsiz * sin(PI/180./2.*odev.v.horiz) );
358 vwfocus.vert = 2.*180./PI*asin(
359 vsiz * sin(PI/180./2.*odev.v.vert) );
360 break;
361 case VT_CYL:
362 vwfocus.horiz = hsiz * odev.v.horiz;
363 vwfocus.vert = 2.*180./PI*atan(
364 vsiz * tan(PI/180./2.*odev.v.vert) );
365 break;
366 default:
367 error(INTERNAL, "bad view type in set_focus");
368 }
369 vwfocus.hoff = (odev.v.hoff + hcent - 0.5)/hsiz;
370 vwfocus.voff = (odev.v.voff + vcent - 0.5)/vsiz;
371 setview(&vwfocus);
372 beam_view(&vwfocus, (int)(3*odev.hres*hsiz)+100,
373 (int)(3*odev.vres*vsiz)+100);
374 beam_sync(0); /* update server */
375 }
376
377
378 int
379 usr_input() /* get user input and process it */
380 {
381 VIEW vparams;
382 char cmd[256];
383 register char *args;
384 register int i;
385
386 if (fgets(cmd, sizeof(cmd), sstdin) == NULL) {
387 fclose(sstdin);
388 sstdin = NULL;
389 return(-1);
390 }
391 if (*cmd == '\n')
392 return(DC_RESUME);
393 for (args = cmd; *args && !isspace(*args); args++)
394 ;
395 while (isspace(*args))
396 *args++ = '\0';
397 if (*args && args[i=strlen(args)-1] == '\n')
398 args[i] = '\0';
399 for (i = 0; i < DC_NCMDS; i++)
400 if (!strcmp(cmd, cmdlist[i]))
401 break;
402 if (i >= DC_NCMDS) {
403 dev_auxcom(cmd, args);
404 return(-1);
405 }
406 switch (i) {
407 case DC_SETVIEW: /* set the view */
408 copystruct(&vparams, &odev.v);
409 if (!sscanview(&vparams, args))
410 error(COMMAND, "missing view options");
411 else
412 new_view(&vparams);
413 break;
414 case DC_GETVIEW: /* print the current view */
415 printview();
416 break;
417 case DC_LASTVIEW: /* restore previous view */
418 new_view(NULL);
419 break;
420 case DC_FOCUS: /* set focus frame */
421 set_focus(args);
422 break;
423 case DC_PAUSE: /* pause the current calculation */
424 case DC_RESUME: /* resume the calculation */
425 /* handled in main() */
426 break;
427 case DC_REDRAW: /* redraw from server */
428 imm_mode = beam_sync(1) > 0;
429 dev_clear();
430 break;
431 case DC_KILL: /* kill rtrace process(es) */
432 serv_request(DR_KILL, 0, NULL);
433 break;
434 case DC_CLOBBER: /* clobber holodeck */
435 serv_request(DR_CLOBBER, 0, NULL);
436 break;
437 case DC_RESTART: /* restart rtrace */
438 serv_request(DR_RESTART, 0, NULL);
439 break;
440 case DC_QUIT: /* quit request */
441 serv_request(DR_SHUTDOWN, 0, NULL);
442 break;
443 default:
444 error(CONSISTENCY, "bad command id in usr_input");
445 }
446 return(i);
447 }
448
449
450 printview() /* print our current view to server stdout */
451 {
452 fputs(VIEWSTR, sstdout);
453 fprintview(&odev.v, sstdout);
454 fputc('\n', sstdout);
455 fflush(sstdout);
456 }
457
458
459 int
460 serv_result() /* get next server result and process it */
461 {
462 static char *buf = NULL;
463 static int bufsiz = 0;
464 MSGHEAD msg;
465 int n;
466 /* read message header */
467 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
468 goto readerr;
469 if (msg.nbytes > 0) { /* get the message body */
470 if (msg.nbytes > bufsiz) {
471 if (buf == NULL)
472 buf = (char *)malloc(bufsiz=msg.nbytes);
473 else
474 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
475 if (buf == NULL)
476 error(SYSTEM, "out of memory in serv_result");
477 }
478 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
479 goto readerr;
480 }
481 switch (msg.type) { /* process results */
482 case DS_BUNDLE:
483 if (msg.nbytes < sizeof(PACKHEAD) ||
484 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
485 error(INTERNAL, "bad display packet from server");
486 disp_bundle((PACKHEAD *)buf);
487 break;
488 case DS_ADDHOLO:
489 if (msg.nbytes <= sizeof(HDGRID))
490 error(INTERNAL, "bad holodeck record from server");
491 add_holo((HDGRID *)buf, buf+sizeof(HDGRID));
492 break;
493 case DS_OUTSECT:
494 do_outside = 1;
495 goto noargs;
496 case DS_EYESEP:
497 if (msg.nbytes <= 1 || (eyesepdist = atof(buf)) <= FTINY)
498 error(INTERNAL, "bad eye separation from server");
499 break;
500 case DS_STARTIMM:
501 case DS_ENDIMM:
502 #ifdef DEBUG
503 {
504 time_t tnow = time(NULL);
505 if (msg.type==DS_STARTIMM) tadd += tnow - tmodesw;
506 else timm += tnow - tmodesw;
507 tmodesw = tnow;
508 }
509 #endif
510 if (!(imm_mode = msg.type==DS_STARTIMM))
511 dev_flush();
512 goto noargs;
513 case DS_ACKNOW:
514 case DS_SHUTDOWN:
515 goto noargs;
516 default:
517 error(INTERNAL, "unrecognized result from server process");
518 }
519 return(msg.type); /* return message type */
520 noargs:
521 if (msg.nbytes) {
522 sprintf(errmsg, "unexpected body with server message %d",
523 msg.type);
524 error(INTERNAL, errmsg);
525 }
526 return(msg.type);
527 readerr:
528 if (feof(stdin))
529 error(SYSTEM, "server process died");
530 error(SYSTEM, "error reading from server process");
531 }
532
533
534 serv_request(type, nbytes, p) /* send a request to the server process */
535 int type, nbytes;
536 char *p;
537 {
538 MSGHEAD msg;
539 int m;
540 /* consistency checks */
541 DCHECK(nbytes < 0 || nbytes > 0 & p == NULL,
542 CONSISTENCY, "bad buffer handed to serv_request");
543 /* get server's attention for big request */
544 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
545 serv_request(DR_ATTEN, 0, NULL);
546 while ((m = serv_result()) != DS_ACKNOW)
547 if (m == DS_SHUTDOWN) /* the bugger quit on us */
548 quit(0);
549 }
550 msg.type = type; /* write and flush the message */
551 msg.nbytes = nbytes;
552 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
553 if (nbytes > 0)
554 fwrite(p, 1, nbytes, stdout);
555 if (fflush(stdout) < 0)
556 error(SYSTEM, "write error in serv_request");
557 }
558
559
560 eputs(s) /* put error message to stderr */
561 register char *s;
562 {
563 static int midline = 0;
564
565 if (!*s)
566 return;
567 if (!midline++) { /* prepend line with program name */
568 fputs(progname, stderr);
569 fputs(": ", stderr);
570 }
571 fputs(s, stderr);
572 if (s[strlen(s)-1] == '\n') {
573 fflush(stderr);
574 midline = 0;
575 }
576 }
577
578
579 quit(code) /* clean up and exit */
580 int code;
581 {
582 if (odev.v.type)
583 dev_close();
584 exit(code);
585 }
