root/radiance/ray/src/hd/rhdisp.c
Revision: 3.24
Committed: Thu May 14 13:06:32 1998 UTC (27 years ago) by gwlarson
Changes since 3.23: +16 -5 lines
added multiple device view capability
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15 #include <ctype.h>
16
17 #ifndef VIEWHISTLEN
18 #define VIEWHISTLEN 4 /* number of remembered views */
19 #endif
20
21 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
22
23 char cmdlist[DC_NCMDS][8] = DC_INIT;
24
25 int imm_mode = 0; /* bundles are being delivered immediately */
26
27 int do_outside = 0; /* render from outside sections */
28
29 char *progname; /* global argv[0] */
30
31 FILE *sstdin, *sstdout; /* server's standard input and output */
32
33 #ifdef DEBUG
34 #include <sys/types.h>
35 extern time_t time();
36 static time_t tmodesw;
37 static time_t timm, tadd;
38 static long nimmrays, naddrays;
39 #endif
40
41 #define RDY_SRV 01
42 #define RDY_DEV 02
43 #define RDY_SIN 04
44
45
46 main(argc, argv)
47 int argc;
48 char *argv[];
49 {
50 extern int eputs();
51 int rdy, inp, res = 0, pause = 0;
52
53 progname = argv[0];
54 if (argc < 3)
55 error(USER, "bad command line arguments");
56 /* open our device */
57 dev_open(argv[1]);
58 /* open server process i/o */
59 sstdout = fdopen(atoi(argv[2]), "w");
60 if (argc < 4 || (inp = atoi(argv[3])) < 0)
61 sstdin = NULL;
62 else
63 sstdin = fdopen(inp, "r");
64 /* set command error vector */
65 erract[COMMAND].pf = eputs;
66 #ifdef DEBUG
67 tmodesw = time(NULL);
68 #endif
69 /* enter main loop */
70 do {
71 rdy = disp_wait();
72 if (rdy & RDY_SRV) { /* process server result */
73 res = serv_result();
74 if (pause && res != DS_SHUTDOWN) {
75 serv_request(DR_ATTEN, 0, NULL);
76 while ((res = serv_result()) != DS_ACKNOW &&
77 res != DS_SHUTDOWN)
78 ;
79 }
80 }
81 if (rdy & RDY_DEV) { /* user input from driver */
82 inp = dev_input();
83 if (inp & DFL(DC_SETVIEW))
84 new_view(&odev.v);
85 if (inp & DFL(DC_GETVIEW))
86 printview();
87 if (inp & DFL(DC_LASTVIEW))
88 new_view(NULL);
89 if (inp & DFL(DC_RESUME)) {
90 serv_request(DR_NOOP, 0, NULL);
91 pause = 0;
92 }
93 if (inp & DFL(DC_PAUSE))
94 pause = 1;
95 if (inp & DFL(DC_REDRAW))
96 imm_mode = beam_sync(1) > 0;
97 if (inp & DFL(DC_KILL)) {
98 serv_request(DR_KILL, 0, NULL);
99 pause = 0;
100 }
101 if (inp & DFL(DC_CLOBBER))
102 serv_request(DR_CLOBBER, 0, NULL);
103 if (inp & DFL(DC_RESTART)) {
104 serv_request(DR_RESTART, 0, NULL);
105 pause = 0;
106 }
107 if (inp & DFL(DC_QUIT))
108 serv_request(DR_SHUTDOWN, 0, NULL);
109 }
110 if (rdy & RDY_SIN) /* user input from sstdin */
111 switch (usr_input()) {
112 case DC_PAUSE:
113 pause = 1;
114 break;
115 case DC_RESUME:
116 serv_request(DR_NOOP, 0, NULL);
117 /* fall through */
118 case DC_KILL:
119 case DC_RESTART:
120 pause = 0;
121 break;
122 }
123 } while (res != DS_SHUTDOWN);
124 #ifdef DEBUG
125 if (timm && nimmrays)
126 fprintf(stderr,
127 "%s: %.1f rays recalled/second (%ld rays total)\n",
128 progname, (double)nimmrays/timm, nimmrays);
129 if (tadd && naddrays)
130 fprintf(stderr,
131 "%s: %.1f rays calculated/second (%ld rays total)\n",
132 progname, (double)naddrays/tadd, naddrays);
133 #endif
134 /* all done */
135 quit(0);
136 }
137
138
139 int
140 disp_wait() /* wait for more input */
141 {
142 fd_set readset, errset;
143 int flgs;
144 int n;
145 register int i;
146 /* see if we can avoid select call */
147 if (imm_mode || stdin->_cnt > 0)
148 return(RDY_SRV);
149 if (sstdin != NULL && sstdin->_cnt > 0)
150 return(RDY_SIN);
151 if (dev_flush())
152 return(RDY_DEV);
153 /* make the call */
154 FD_ZERO(&readset); FD_ZERO(&errset);
155 FD_SET(0, &readset);
156 FD_SET(0, &errset);
157 FD_SET(odev.ifd, &readset);
158 FD_SET(odev.ifd, &errset);
159 n = odev.ifd+1;
160 if (sstdin != NULL) {
161 FD_SET(fileno(sstdin), &readset);
162 FD_SET(fileno(sstdin), &errset);
163 if (fileno(sstdin) >= n)
164 n = fileno(sstdin) + 1;
165 }
166 n = select(n, &readset, NULL, &errset, NULL);
167 if (n < 0) {
168 if (errno == EINTR)
169 return(0);
170 error(SYSTEM, "select call failure in disp_wait");
171 }
172 flgs = 0; /* flag what's ready */
173 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
174 flgs |= RDY_SRV;
175 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
176 flgs |= RDY_DEV;
177 if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) ||
178 FD_ISSET(fileno(sstdin), &errset)))
179 flgs |= RDY_SIN;
180 return(flgs);
181 }
182
183
184 add_holo(hdg) /* register a new holodeck section */
185 HDGRID *hdg;
186 {
187 VIEW nv;
188 double d;
189 register int hd;
190
191 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
192 ;
193 if (hd >= HDMAX)
194 error(INTERNAL, "too many holodeck sections in add_holo");
195 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
196 if (hdlist[hd] == NULL)
197 error(SYSTEM, "out of memory in add_holo");
198 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
199 hdcompgrid(hdlist[hd]);
200 if (hd)
201 return;
202 /* set initial viewpoint */
203 copystruct(&nv, &odev.v);
204 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
205 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
206 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
207 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
208 VCOPY(nv.vup, hdlist[0]->xv[2]);
209 if (do_outside) {
210 normalize(nv.vdir);
211 d = VLEN(hdlist[0]->xv[1]);
212 d += VLEN(hdlist[0]->xv[2]);
213 VSUM(nv.vp, nv.vp, nv.vdir, -d);
214 }
215 new_view(&nv);
216 }
217
218
219 disp_bundle(p) /* display a ray bundle */
220 register PACKHEAD *p;
221 {
222 GCOORD gc[2];
223 FVECT ro, rd, wp;
224 double d;
225 register int i;
226 /* get beam coordinates */
227 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
228 error(INTERNAL, "bad holodeck number in disp_bundle");
229 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
230 error(INTERNAL, "bad beam index in disp_bundle");
231 /* display each ray */
232 for (i = p->nr; i--; ) {
233 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
234 d = hddepth(hdlist[p->hd], packra(p)[i].d);
235 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
236 dev_value(packra(p)[i].v, wp, rd);
237 }
238 #ifdef DEBUG
239 if (imm_mode) nimmrays += p->nr;
240 else naddrays += p->nr;
241 #endif
242 }
243
244
245 new_view(v) /* change view parameters */
246 register VIEW *v;
247 {
248 static VIEW viewhist[VIEWHISTLEN];
249 static unsigned nhist;
250 VIEW *dv;
251 int i, res[2];
252 char *err;
253 /* restore previous view? */
254 if (v == NULL) {
255 if (nhist > 1) /* get one before last setting */
256 nhist--;
257 else /* else go to end of list */
258 while (nhist < VIEWHISTLEN && viewhist[nhist].type)
259 nhist++;
260 v = viewhist + ((nhist-1)%VIEWHISTLEN);
261 } else
262 again:
263 if ((err = setview(v)) != NULL) {
264 error(COMMAND, err);
265 return;
266 }
267 if (v->type == VT_PAR) {
268 error(COMMAND, "cannot handle parallel views");
269 return;
270 }
271 if (!dev_view(v)) /* notify display driver */
272 goto again;
273 dev_flush(); /* update screen */
274 beam_init(); /* compute new beam set */
275 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
276 if (!beam_view(dv, res[0], res[1])) {
277 if (!nhist) {
278 error(COMMAND, "invalid starting view");
279 return;
280 }
281 copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN));
282 goto again;
283 }
284 beam_sync(0); /* update server */
285 /* record new view */
286 if (v < viewhist || v >= viewhist+VIEWHISTLEN) {
287 copystruct(viewhist + (nhist%VIEWHISTLEN), v);
288 nhist++;
289 }
290 }
291
292
293 int
294 usr_input() /* get user input and process it */
295 {
296 VIEW vparams;
297 char cmd[256];
298 register char *args;
299 register int i;
300
301 if (fgets(cmd, sizeof(cmd), sstdin) == NULL) {
302 fclose(sstdin);
303 sstdin = NULL;
304 return(0);
305 }
306 for (args = cmd; *args && !isspace(*args); args++)
307 ;
308 while (isspace(*args))
309 *args++ = '\0';
310 if (!*cmd)
311 return(DC_RESUME);
312 if (*args && args[i=strlen(args)-1] == '\n')
313 args[i] = '\0';
314 for (i = 0; i < DC_NCMDS; i++)
315 if (!strcmp(cmd, cmdlist[i]))
316 break;
317 if (i >= DC_NCMDS) {
318 sprintf(errmsg, "unknown command: %s", cmd);
319 error(COMMAND, errmsg);
320 return(-1);
321 }
322 switch (i) {
323 case DC_SETVIEW: /* set the view */
324 copystruct(&vparams, &odev.v);
325 if (!sscanview(&vparams, args))
326 error(COMMAND, "missing view options");
327 else
328 new_view(&vparams);
329 break;
330 case DC_GETVIEW: /* print the current view */
331 printview();
332 break;
333 case DC_LASTVIEW: /* restore previous view */
334 new_view(NULL);
335 break;
336 case DC_PAUSE: /* pause the current calculation */
337 case DC_RESUME: /* resume the calculation */
338 /* handled in main() */
339 break;
340 case DC_REDRAW: /* redraw from server */
341 imm_mode = beam_sync(1) > 0;
342 dev_clear();
343 break;
344 case DC_KILL: /* kill rtrace process(es) */
345 serv_request(DR_KILL, 0, NULL);
346 break;
347 case DC_CLOBBER: /* clobber holodeck */
348 serv_request(DR_CLOBBER, 0, NULL);
349 break;
350 case DC_RESTART: /* restart rtrace */
351 serv_request(DR_RESTART, 0, NULL);
352 break;
353 case DC_QUIT: /* quit request */
354 serv_request(DR_SHUTDOWN, 0, NULL);
355 break;
356 default:
357 error(CONSISTENCY, "bad command id in usr_input");
358 }
359 return(i);
360 }
361
362
363 printview() /* print our current view to server stdout */
364 {
365 fputs(VIEWSTR, sstdout);
366 fprintview(&odev.v, sstdout);
367 fputc('\n', sstdout);
368 fflush(sstdout);
369 }
370
371
372 int
373 serv_result() /* get next server result and process it */
374 {
375 static char *buf = NULL;
376 static int bufsiz = 0;
377 MSGHEAD msg;
378 int n;
379 /* read message header */
380 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
381 goto readerr;
382 if (msg.nbytes > 0) { /* get the message body */
383 if (msg.nbytes > bufsiz) {
384 if (buf == NULL)
385 buf = (char *)malloc(bufsiz=msg.nbytes);
386 else
387 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
388 if (buf == NULL)
389 error(SYSTEM, "out of memory in serv_result");
390 }
391 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
392 goto readerr;
393 }
394 switch (msg.type) { /* process results */
395 case DS_BUNDLE:
396 if (msg.nbytes < sizeof(PACKHEAD) ||
397 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
398 error(INTERNAL, "bad display packet from server");
399 disp_bundle((PACKHEAD *)buf);
400 break;
401 case DS_ADDHOLO:
402 if (msg.nbytes != sizeof(HDGRID))
403 error(INTERNAL, "bad holodeck record from server");
404 add_holo((HDGRID *)buf);
405 break;
406 case DS_OUTSECT:
407 do_outside = 1;
408 break;
409 case DS_STARTIMM:
410 case DS_ENDIMM:
411 #ifdef DEBUG
412 if (imm_mode != (msg.type==DS_STARTIMM)) {
413 time_t tnow = time(NULL);
414 if (imm_mode) timm += tnow - tmodesw;
415 else tadd += tnow - tmodesw;
416 tmodesw = tnow;
417 }
418 #endif
419 imm_mode = msg.type==DS_STARTIMM;
420 /* fall through */
421 case DS_ACKNOW:
422 case DS_SHUTDOWN:
423 if (msg.nbytes) {
424 sprintf(errmsg,
425 "unexpected body with server message %d",
426 msg.type);
427 error(INTERNAL, errmsg);
428 }
429 break;
430 default:
431 error(INTERNAL, "unrecognized result from server process");
432 }
433 return(msg.type); /* return message type */
434 readerr:
435 if (feof(stdin))
436 error(SYSTEM, "server process died");
437 error(SYSTEM, "error reading from server process");
438 }
439
440
441 serv_request(type, nbytes, p) /* send a request to the server process */
442 int type, nbytes;
443 char *p;
444 {
445 MSGHEAD msg;
446 int m;
447 /* get server's attention for big request */
448 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
449 serv_request(DR_ATTEN, 0, NULL);
450 while ((m = serv_result()) != DS_ACKNOW)
451 if (m == DS_SHUTDOWN) /* the bugger quit on us */
452 quit(0);
453 }
454 msg.type = type; /* write and flush the message */
455 msg.nbytes = nbytes;
456 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
457 if (nbytes > 0)
458 fwrite(p, 1, nbytes, stdout);
459 if (fflush(stdout) < 0)
460 error(SYSTEM, "write error in serv_request");
461 }
462
463
464 eputs(s) /* put error message to stderr */
465 register char *s;
466 {
467 static int midline = 0;
468
469 if (!*s)
470 return;
471 if (!midline++) { /* prepend line with program name */
472 fputs(progname, stderr);
473 fputs(": ", stderr);
474 }
475 fputs(s, stderr);
476 if (s[strlen(s)-1] == '\n') {
477 fflush(stderr);
478 midline = 0;
479 }
480 }
481
482
483 quit(code) /* clean up and exit */
484 int code;
485 {
486 if (odev.v.type)
487 dev_close();
488 exit(code);
489 }
