--- ray/src/hd/rhdisp.c 2003/06/30 14:59:11 3.47 +++ ray/src/hd/rhdisp.c 2004/03/28 20:33:13 3.51 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rhdisp.c,v 3.47 2003/06/30 14:59:11 schorsch Exp $"; +static const char RCSid[] = "$Id: rhdisp.c,v 3.51 2004/03/28 20:33:13 schorsch Exp $"; #endif /* * Holodeck display process. @@ -8,6 +8,7 @@ static const char RCSid[] = "$Id: rhdisp.c,v 3.47 2003 #include #include +#include "rterror.h" #include "rholo.h" #include "rhdisp.h" #include "rhdriver.h" @@ -57,10 +58,20 @@ static long nimmrays, naddrays; #define RDY_DEV 02 #define RDY_SIN 04 +static int disp_wait(void); +static void add_holo(HDGRID *hdg, char *gfn, char *pfn); +static void disp_bundle(PACKHEAD *p); +static void new_view(register VIEW *v); +static void set_focus(char *args); +static int usr_input(void); +static void printview(void); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { int rdy, inp, res = 0, pause = 0; @@ -149,16 +160,16 @@ char *argv[]; #endif /* all done */ quit(0); + return 0; /* pro forma return */ } -int -disp_wait() /* wait for more input */ +static int +disp_wait(void) /* wait for more input */ { fd_set readset, errset; int flgs; int n; - register int i; /* see if we can avoid select call */ if (hdlist[0] == NULL) return(RDY_SRV); /* initialize first */ @@ -203,9 +214,12 @@ disp_wait() /* wait for more input */ } -add_holo(hdg, gfn, pfn) /* register a new holodeck section */ -HDGRID *hdg; -char *gfn, *pfn; +static void +add_holo( /* register a new holodeck section */ + HDGRID *hdg, + char *gfn, + char *pfn +) { VIEW nv; double d; @@ -225,7 +239,7 @@ char *gfn, *pfn; if (hd) return; /* set initial viewpoint */ - copystruct(&nv, &odev.v); + nv = odev.v; VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5); VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5); VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5); @@ -241,15 +255,17 @@ char *gfn, *pfn; } -disp_bundle(p) /* display a ray bundle */ -register PACKHEAD *p; +static void +disp_bundle( /* display a ray bundle */ + register PACKHEAD *p +) { GCOORD gc[2]; FVECT ro, rd, wp; double d; register int i; /* get beam coordinates */ - if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL) + if ((p->hd < 0) | (p->hd >= HDMAX) || hdlist[p->hd] == NULL) error(INTERNAL, "bad holodeck number in disp_bundle"); if (!hdbcoord(gc, hdlist[p->hd], p->bi)) error(INTERNAL, "bad beam index in disp_bundle"); @@ -270,8 +286,10 @@ register PACKHEAD *p; } -new_view(v) /* change view parameters */ -register VIEW *v; +static void +new_view( /* change view parameters */ + register VIEW *v +) { static VIEW viewhist[VIEWHISTLEN]; static unsigned nhist; @@ -306,8 +324,8 @@ again: error(COMMAND, "invalid starting view"); return; } - copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN)); - goto again; /* poss. overloading dev_section()? */ + *v = *(viewhist + ((nhist-1)%VIEWHISTLEN)); + goto again; /* XXX overloading dev_section()? */ } DCHECK(*slist < 0, WARNING, "no visible sections in new_view"); for ( ; *slist >= 0; slist++) @@ -319,14 +337,16 @@ again: imm_mode = beam_sync(odev.firstuse) > 0; /* record new view */ if (v < viewhist || v >= viewhist+VIEWHISTLEN) { - copystruct(viewhist + (nhist%VIEWHISTLEN), v); + *(viewhist + (nhist%VIEWHISTLEN)) = *v; nhist++; } } -set_focus(args) /* set focus frame */ -char *args; +static void +set_focus( /* set focus frame */ + char *args +) { double hcent, vcent, hsiz, vsiz; VIEW *dv, vwfocus; @@ -349,7 +369,7 @@ char *args; beam_init(0); /* add basic views */ for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) beam_view(dv, res[0]>>4, res[1]>>4); - copystruct(&vwfocus, &odev.v); /* add focus view */ + vwfocus = odev.v; /* add focus view */ switch (odev.v.type) { case VT_PER: vwfocus.horiz = 2.*180./PI*atan( @@ -385,8 +405,8 @@ char *args; } -int -usr_input() /* get user input and process it */ +static int +usr_input(void) /* get user input and process it */ { VIEW vparams; char cmd[256]; @@ -415,7 +435,7 @@ usr_input() /* get user input and process it */ } switch (i) { case DC_SETVIEW: /* set the view */ - copystruct(&vparams, &odev.v); + vparams = odev.v; if (!sscanview(&vparams, args)) error(COMMAND, "missing view options"); else @@ -457,7 +477,8 @@ usr_input() /* get user input and process it */ } -printview() /* print our current view to server stdout */ +static void +printview(void) /* print our current view to server stdout */ { fputs(VIEWSTR, sstdout); fprintview(&odev.v, sstdout); @@ -466,13 +487,12 @@ printview() /* print our current view to server stdo } -int -serv_result() /* get next server result and process it */ +extern int +serv_result(void) /* get next server result and process it */ { static char *buf = NULL; static int bufsiz = 0; MSGHEAD msg; - int n; /* read message header */ if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1) goto readerr; @@ -540,12 +560,16 @@ readerr: if (feof(stdin)) error(SYSTEM, "server process died"); error(SYSTEM, "error reading from server process"); + return -1; } -serv_request(type, nbytes, p) /* send a request to the server process */ -int type, nbytes; -char *p; +extern void +serv_request( /* send a request to the server process */ + int type, + int nbytes, + char *p +) { MSGHEAD msg; int m; @@ -570,8 +594,9 @@ char *p; void -eputs(s) /* put error message to stderr */ -register char *s; +eputs( /* put error message to stderr */ + register char *s +) { static int midline = 0; @@ -590,8 +615,9 @@ register char *s; void -quit(code) /* clean up and exit */ -int code; +quit( /* clean up and exit */ + int code +) { if (code) exit(code);
