root/radiance/ray/src/hd/rhdisp.c
Revision: 3.3
Committed: Fri Nov 21 15:11:43 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.2: +16 -10 lines
stopped pause function from resuming upon iconification and
interfering with full view updates
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15
16 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
17
18 int imm_mode = 0; /* bundles are being delivered immediately */
19
20 VIEW dvw; /* our current display view */
21
22 char *progname; /* global argv[0] */
23
24 #define SERV_READY 01
25 #define DEV_READY 02
26
27
28 main(argc, argv)
29 int argc;
30 char *argv[];
31 {
32 int rdy, inp, res = 0, pause = 0;
33
34 progname = argv[0];
35 if (argc != 2)
36 error(USER, "bad command line arguments");
37 /* open our device */
38 dev_open(argv[1]);
39 /* enter main loop */
40 do {
41 rdy = disp_wait();
42 if (rdy & DEV_READY) { /* get user input */
43 inp = dev_input();
44 if (inp & DEV_NEWVIEW)
45 new_view(&odev.v);
46 if (inp & DEV_SHUTDOWN)
47 serv_request(DR_SHUTDOWN, 0, NULL);
48 if (inp & DEV_WAIT)
49 pause = 1;
50 if (inp & DEV_RESUME) {
51 serv_request(DR_NOOP, 0, NULL);
52 pause = 0;
53 }
54 }
55 if (rdy & SERV_READY) { /* get server result */
56 res = serv_result();
57 if (pause && res != DS_SHUTDOWN) {
58 serv_request(DR_ATTEN, 0, NULL);
59 while ((res = serv_result()) != DS_ACKNOW &&
60 res != DS_SHUTDOWN)
61 ;
62 }
63 }
64 } while (res != DS_SHUTDOWN);
65 /* all done */
66 quit(0);
67 }
68
69
70 int
71 disp_wait() /* wait for more input */
72 {
73 fd_set readset, errset;
74 int flgs;
75 int n;
76 register int i;
77 /* see if we can avoid select call */
78 if (imm_mode || stdin->_cnt > 0)
79 return(SERV_READY);
80 if (dev_flush())
81 return(DEV_READY);
82 /* make the call */
83 FD_ZERO(&readset); FD_ZERO(&errset);
84 FD_SET(0, &readset);
85 FD_SET(0, &errset);
86 FD_SET(odev.ifd, &readset);
87 FD_SET(odev.ifd, &errset);
88 n = odev.ifd + 1;
89 n = select(n, &readset, NULL, &errset, NULL);
90 if (n < 0) {
91 if (errno == EINTR)
92 return(0);
93 error(SYSTEM, "select call failure in disp_wait");
94 }
95 flgs = 0; /* flag what's ready */
96 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
97 flgs |= SERV_READY;
98 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
99 flgs |= DEV_READY;
100 return(flgs);
101 }
102
103
104 add_holo(hdg) /* register a new holodeck section */
105 HDGRID *hdg;
106 {
107 VIEW nv;
108 register int hd;
109
110 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
111 ;
112 if (hd >= HDMAX)
113 error(INTERNAL, "too many holodeck sections in add_holo");
114 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
115 if (hdlist[hd] == NULL)
116 error(SYSTEM, "out of memory in add_holo");
117 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
118 hdcompgrid(hdlist[hd]);
119 if (hd)
120 return;
121 /* set initial viewpoint */
122 copystruct(&nv, &odev.v);
123 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
124 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
125 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
126 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
127 VCOPY(nv.vup, hdlist[0]->xv[2]);
128 new_view(&nv);
129 }
130
131
132 disp_bundle(p) /* display a ray bundle */
133 register PACKHEAD *p;
134 {
135 GCOORD gc[2];
136 FVECT ro, rd, wp;
137 double d;
138 register int i;
139 /* get beam coordinates */
140 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
141 error(INTERNAL, "bad holodeck number in disp_bundle");
142 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
143 error(INTERNAL, "bad beam index in disp_bundle");
144 /* display each ray */
145 for (i = p->nr; i--; ) {
146 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
147 d = hddepth(hdlist[p->hd], packra(p)[i].d);
148 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
149 dev_value(packra(p)[i].v, wp);
150 }
151 }
152
153
154 new_view(v) /* change view parameters */
155 VIEW *v;
156 {
157 char *err;
158
159 if ((err = setview(v)) != NULL)
160 error(INTERNAL, err);
161 dev_view(v); /* update display driver */
162 beam_view(&dvw, v); /* update beam list */
163 copystruct(&dvw, v); /* record new view */
164 }
165
166
167 int
168 serv_result() /* get next server result and process it */
169 {
170 static char *buf = NULL;
171 static int bufsiz = 0;
172 MSGHEAD msg;
173 int n;
174 /* read message header */
175 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
176 goto readerr;
177 if (msg.nbytes > 0) { /* get the message body */
178 if (msg.nbytes > bufsiz) {
179 if (buf == NULL)
180 buf = (char *)malloc(bufsiz=msg.nbytes);
181 else
182 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
183 if (buf == NULL)
184 error(SYSTEM, "out of memory in serv_result");
185 }
186 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
187 goto readerr;
188 }
189 switch (msg.type) { /* process results */
190 case DS_BUNDLE:
191 if (msg.nbytes < sizeof(PACKHEAD) ||
192 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
193 error(INTERNAL, "bad display packet from server");
194 disp_bundle((PACKHEAD *)buf);
195 break;
196 case DS_ADDHOLO:
197 if (msg.nbytes != sizeof(HDGRID))
198 error(INTERNAL, "bad holodeck record from server");
199 add_holo((HDGRID *)buf);
200 break;
201 case DS_STARTIMM:
202 case DS_ENDIMM:
203 imm_mode = msg.type==DS_STARTIMM;
204 /* fall through */
205 case DS_ACKNOW:
206 case DS_SHUTDOWN:
207 if (msg.nbytes) {
208 sprintf(errmsg,
209 "unexpected body with server message %d",
210 msg.type);
211 error(INTERNAL, errmsg);
212 }
213 break;
214 default:
215 error(INTERNAL, "unrecognized result from server process");
216 }
217 return(msg.type); /* return message type */
218 readerr:
219 if (feof(stdin))
220 error(SYSTEM, "server process died");
221 error(SYSTEM, "error reading from server process");
222 }
223
224
225 serv_request(type, nbytes, p) /* send a request to the server process */
226 int type, nbytes;
227 char *p;
228 {
229 MSGHEAD msg;
230 int m;
231 /* get server's attention for big request */
232 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
233 serv_request(DR_ATTEN, 0, NULL);
234 while ((m = serv_result()) != DS_ACKNOW)
235 if (m == DS_SHUTDOWN) /* the bugger quit on us */
236 quit(0);
237 }
238 msg.type = type; /* write and flush the message */
239 msg.nbytes = nbytes;
240 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
241 if (nbytes > 0)
242 fwrite(p, 1, nbytes, stdout);
243 if (fflush(stdout) < 0)
244 error(SYSTEM, "write error in serv_request");
245 }
246
247
248 eputs(s) /* put error message to stderr */
249 register char *s;
250 {
251 static int midline = 0;
252
253 if (!*s)
254 return;
255 if (!midline++) { /* prepend line with program name */
256 fputs(progname, stderr);
257 fputs(": ", stderr);
258 }
259 fputs(s, stderr);
260 if (s[strlen(s)-1] == '\n') {
261 fflush(stderr);
262 midline = 0;
263 }
264 }
265
266
267 quit(code) /* clean up and exit */
268 int code;
269 {
270 if (odev.v.type)
271 dev_close();
272 exit(code);
273 }
