--- ray/src/hd/rhdisp.c 1998/01/04 12:28:09 3.19 +++ ray/src/hd/rhdisp.c 2003/05/13 17:58:33 3.45 @@ -1,9 +1,6 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhdisp.c,v 3.45 2003/05/13 17:58:33 greg Exp $"; #endif - /* * Holodeck display process. */ @@ -18,16 +15,42 @@ static char SCCSid[] = "$SunId$ SGI"; #define VIEWHISTLEN 4 /* number of remembered views */ #endif +#ifndef FSIZDEF +#define FSIZDEF 0.125 /* default focus frame size */ +#endif + +#if defined(freebsd) +#define fbufcnt(f) ((f)->_r) +#elif defined(__GNUC__) +#define fbufcnt(f) ((f)->_IO_read_end - (f)->_IO_read_ptr) +#else +#define fbufcnt(f) ((f)->_cnt) +#endif + HOLO *hdlist[HDMAX+1]; /* global holodeck list */ +char *hdgfn[HDMAX]; /* holodeck section geometry list */ +char *hdpfn[HDMAX]; /* section portal list */ + char cmdlist[DC_NCMDS][8] = DC_INIT; int imm_mode = 0; /* bundles are being delivered immediately */ +int do_outside = 0; /* render from outside sections */ + +double eyesepdist = 1; /* eye separation distance */ + char *progname; /* global argv[0] */ FILE *sstdin, *sstdout; /* server's standard input and output */ +#ifdef DEBUG +extern time_t time(); +static time_t tmodesw; +static time_t timm, tadd; +static long nimmrays, naddrays; +#endif + #define RDY_SRV 01 #define RDY_DEV 02 #define RDY_SIN 04 @@ -37,7 +60,6 @@ main(argc, argv) int argc; char *argv[]; { - extern int eputs(); int rdy, inp, res = 0, pause = 0; progname = argv[0]; @@ -53,6 +75,9 @@ char *argv[]; sstdin = fdopen(inp, "r"); /* set command error vector */ erract[COMMAND].pf = eputs; +#ifdef DEBUG + tmodesw = time(NULL); +#endif /* enter main loop */ do { rdy = disp_wait(); @@ -69,18 +94,14 @@ char *argv[]; inp = dev_input(); if (inp & DFL(DC_SETVIEW)) new_view(&odev.v); - if (inp & DFL(DC_GETVIEW)) - printview(); - if (inp & DFL(DC_LASTVIEW)) + else if (inp & DFL(DC_LASTVIEW)) new_view(NULL); - if (inp & DFL(DC_RESUME)) { - serv_request(DR_NOOP, 0, NULL); - pause = 0; - } - if (inp & DFL(DC_PAUSE)) - pause = 1; if (inp & DFL(DC_REDRAW)) - imm_mode = beam_sync() > 0; + imm_mode = beam_sync(1) > 0; + if (inp & DFL(DC_GETVIEW)) + printview(); + if (inp & DFL(DC_FOCUS)) + set_focus(odev_args); if (inp & DFL(DC_KILL)) { serv_request(DR_KILL, 0, NULL); pause = 0; @@ -91,10 +112,16 @@ char *argv[]; serv_request(DR_RESTART, 0, NULL); pause = 0; } + if (inp & DFL(DC_RESUME)) { + serv_request(DR_NOOP, 0, NULL); + pause = 0; + } + if (inp & DFL(DC_PAUSE)) + pause = 1; if (inp & DFL(DC_QUIT)) serv_request(DR_SHUTDOWN, 0, NULL); } - if (rdy & RDY_SIN) /* user input from sstdin */ + if (rdy & RDY_SIN && !imm_mode) /* user input from sstdin */ switch (usr_input()) { case DC_PAUSE: pause = 1; @@ -108,6 +135,16 @@ char *argv[]; break; } } while (res != DS_SHUTDOWN); +#ifdef DEBUG + if (timm && nimmrays) + fprintf(stderr, + "%s: %.1f rays recalled/second (%ld rays total)\n", + progname, (double)nimmrays/timm, nimmrays); + if (tadd && naddrays) + fprintf(stderr, + "%s: %.1f rays calculated/second (%ld rays total)\n", + progname, (double)naddrays/tadd, naddrays); +#endif /* all done */ quit(0); } @@ -121,13 +158,20 @@ disp_wait() /* wait for more input */ int n; register int i; /* see if we can avoid select call */ - if (imm_mode || stdin->_cnt > 0) - return(RDY_SRV); - if (sstdin != NULL && sstdin->_cnt > 0) - return(RDY_SIN); - if (dev_flush()) + if (hdlist[0] == NULL) + return(RDY_SRV); /* initialize first */ + flgs = 0; /* flag what's ready already */ + if (imm_mode || fbufcnt(stdin) > 0) + flgs |= RDY_SRV; + if (sstdin != NULL && fbufcnt(sstdin) > 0) + flgs |= RDY_SIN; + if (odev.inpready) + flgs |= RDY_DEV; + if (flgs) /* got something? */ + return(flgs); + if (dev_flush()) /* else flush output & check keyboard+mouse */ return(RDY_DEV); - /* make the call */ + /* if nothing, we need to call select */ FD_ZERO(&readset); FD_ZERO(&errset); FD_SET(0, &readset); FD_SET(0, &errset); @@ -136,6 +180,7 @@ disp_wait() /* wait for more input */ n = odev.ifd+1; if (sstdin != NULL) { FD_SET(fileno(sstdin), &readset); + FD_SET(fileno(sstdin), &errset); if (fileno(sstdin) >= n) n = fileno(sstdin) + 1; } @@ -145,21 +190,23 @@ disp_wait() /* wait for more input */ return(0); error(SYSTEM, "select call failure in disp_wait"); } - flgs = 0; /* flag what's ready */ if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset)) flgs |= RDY_SRV; if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset)) flgs |= RDY_DEV; - if (sstdin != NULL && FD_ISSET(fileno(sstdin), &readset)) + if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) || + FD_ISSET(fileno(sstdin), &errset))) flgs |= RDY_SIN; return(flgs); } -add_holo(hdg) /* register a new holodeck section */ +add_holo(hdg, gfn, pfn) /* register a new holodeck section */ HDGRID *hdg; +char *gfn, *pfn; { VIEW nv; + double d; register int hd; for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++) @@ -169,8 +216,10 @@ HDGRID *hdg; hdlist[hd] = (HOLO *)malloc(sizeof(HOLO)); if (hdlist[hd] == NULL) error(SYSTEM, "out of memory in add_holo"); - bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID)); + bcopy((void *)hdg, (void *)hdlist[hd], sizeof(HDGRID)); hdcompgrid(hdlist[hd]); + hdgfn[hd] = savestr(gfn); + hdpfn[hd] = pfn && *pfn ? savestr(pfn) : (char *)NULL; if (hd) return; /* set initial viewpoint */ @@ -180,6 +229,12 @@ HDGRID *hdg; VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5); fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]); VCOPY(nv.vup, hdlist[0]->xv[2]); + if (do_outside) { + normalize(nv.vdir); + d = VLEN(hdlist[0]->xv[1]); + d += VLEN(hdlist[0]->xv[2]); + VSUM(nv.vp, nv.vp, nv.vdir, -d); + } new_view(&nv); } @@ -200,9 +255,16 @@ register PACKHEAD *p; for (i = p->nr; i--; ) { hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r); d = hddepth(hdlist[p->hd], packra(p)[i].d); - VSUM(wp, ro, rd, d); /* might be behind viewpoint */ - dev_value(packra(p)[i].v, wp, rd); + if (d < .99*FHUGE) { + VSUM(wp, ro, rd, d); /* might be behind viewpoint */ + dev_value(packra(p)[i].v, rd, wp); + } else + dev_value(packra(p)[i].v, rd, NULL); } +#ifdef DEBUG + if (imm_mode) nimmrays += p->nr; + else naddrays += p->nr; +#endif } @@ -211,6 +273,9 @@ register VIEW *v; { static VIEW viewhist[VIEWHISTLEN]; static unsigned nhist; + VIEW *dv; + int i, res[2]; + int2 *slist; char *err; /* restore previous view? */ if (v == NULL) { @@ -226,15 +291,30 @@ again: error(COMMAND, err); return; } + if (!dev_view(v)) /* notify display driver */ + goto again; if (v->type == VT_PAR) { error(COMMAND, "cannot handle parallel views"); return; } - if (!dev_view(v)) /* update display driver */ - goto again; - dev_flush(); /* update screen */ - if (!beam_view(v)) /* update beam list */ - goto again; + beam_init(odev.firstuse); /* compute new beam set */ + for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) { + if ((slist = beam_view(dv, res[0], res[1])) == NULL) { + if (!nhist) { + error(COMMAND, "invalid starting view"); + return; + } + copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN)); + goto again; /* poss. overloading dev_section()? */ + } + DCHECK(*slist < 0, WARNING, "no visible sections in new_view"); + for ( ; *slist >= 0; slist++) + dev_section(hdgfn[*slist], hdpfn[*slist]); + } + dev_section(NULL,NULL); /* end section list */ + dev_flush(); /* update display */ + /* update server */ + imm_mode = beam_sync(odev.firstuse) > 0; /* record new view */ if (v < viewhist || v >= viewhist+VIEWHISTLEN) { copystruct(viewhist + (nhist%VIEWHISTLEN), v); @@ -243,30 +323,92 @@ again: } +set_focus(args) /* set focus frame */ +char *args; +{ + double hcent, vcent, hsiz, vsiz; + VIEW *dv, vwfocus; + int i, res[2]; + + i = sscanf(args, "%lf %lf %lf %lf", &hcent, &vcent, &hsiz, &vsiz); + if (i < 2 || hcent < 0 || hcent > 1 || vcent < 0 || vcent > 1) { + beam_init(0); /* restore view */ + for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) + beam_view(dv, res[0], res[1]); + beam_sync(0); /* update server */ + return; + } + if (i < 4 || hsiz <= hcent || hsiz > 1 || vsiz <= vcent || vsiz > 1) + hsiz = vsiz = FSIZDEF; /* gave center only */ + else { + hsiz -= hcent; hcent += 0.5*hsiz; /* gave min and max */ + vsiz -= vcent; vcent += 0.5*vsiz; + } + beam_init(0); /* add basic views */ + for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) + beam_view(dv, res[0]>>4, res[1]>>4); + copystruct(&vwfocus, &odev.v); /* add focus view */ + switch (odev.v.type) { + case VT_PER: + vwfocus.horiz = 2.*180./PI*atan( + hsiz * tan(PI/180./2.*odev.v.horiz) ); + vwfocus.vert = 2.*180./PI*atan( + vsiz * tan(PI/180./2.*odev.v.vert) ); + break; + case VT_PAR: + case VT_ANG: + vwfocus.horiz = hsiz * odev.v.horiz; + vwfocus.vert = vsiz * odev.v.vert; + break; + case VT_HEM: + vwfocus.horiz = 2.*180./PI*asin( + hsiz * sin(PI/180./2.*odev.v.horiz) ); + vwfocus.vert = 2.*180./PI*asin( + vsiz * sin(PI/180./2.*odev.v.vert) ); + break; + case VT_CYL: + vwfocus.horiz = hsiz * odev.v.horiz; + vwfocus.vert = 2.*180./PI*atan( + vsiz * tan(PI/180./2.*odev.v.vert) ); + break; + default: + error(INTERNAL, "bad view type in set_focus"); + } + vwfocus.hoff = (odev.v.hoff + hcent - 0.5)/hsiz; + vwfocus.voff = (odev.v.voff + vcent - 0.5)/vsiz; + setview(&vwfocus); + beam_view(&vwfocus, (int)(3*odev.hres*hsiz)+100, + (int)(3*odev.vres*vsiz)+100); + beam_sync(0); /* update server */ +} + + int usr_input() /* get user input and process it */ { VIEW vparams; - char cmd[128]; + char cmd[256]; register char *args; register int i; - if (fgets(cmd, sizeof(cmd), sstdin) == NULL) - return(DC_QUIT); + if (fgets(cmd, sizeof(cmd), sstdin) == NULL) { + fclose(sstdin); + sstdin = NULL; + return(-1); + } + if (*cmd == '\n') + return(DC_RESUME); for (args = cmd; *args && !isspace(*args); args++) ; while (isspace(*args)) *args++ = '\0'; - if (!*cmd) - return(DC_RESUME); if (*args && args[i=strlen(args)-1] == '\n') args[i] = '\0'; for (i = 0; i < DC_NCMDS; i++) if (!strcmp(cmd, cmdlist[i])) break; if (i >= DC_NCMDS) { - sprintf(errmsg, "unknown command: %s", cmd); - error(COMMAND, errmsg); + dev_auxcom(cmd, args); return(-1); } switch (i) { @@ -283,12 +425,16 @@ usr_input() /* get user input and process it */ case DC_LASTVIEW: /* restore previous view */ new_view(NULL); break; + case DC_FOCUS: /* set focus frame */ + set_focus(args); + break; case DC_PAUSE: /* pause the current calculation */ case DC_RESUME: /* resume the calculation */ /* handled in main() */ break; case DC_REDRAW: /* redraw from server */ - imm_mode = beam_sync() > 0; + imm_mode = beam_sync(1) > 0; + dev_clear(); break; case DC_KILL: /* kill rtrace process(es) */ serv_request(DR_KILL, 0, NULL); @@ -333,7 +479,8 @@ serv_result() /* get next server result and process if (buf == NULL) buf = (char *)malloc(bufsiz=msg.nbytes); else - buf = (char *)realloc(buf, bufsiz=msg.nbytes); + buf = (char *)realloc((void *)buf, + bufsiz=msg.nbytes); if (buf == NULL) error(SYSTEM, "out of memory in serv_result"); } @@ -348,27 +495,45 @@ serv_result() /* get next server result and process disp_bundle((PACKHEAD *)buf); break; case DS_ADDHOLO: - if (msg.nbytes != sizeof(HDGRID)) + if (msg.nbytes < sizeof(HDGRID)+2) error(INTERNAL, "bad holodeck record from server"); - add_holo((HDGRID *)buf); + add_holo((HDGRID *)buf, buf+sizeof(HDGRID), + buf+sizeof(HDGRID)+strlen(buf+sizeof(HDGRID))+1); break; + case DS_OUTSECT: + do_outside = 1; + goto noargs; + case DS_EYESEP: + if (msg.nbytes <= 1 || (eyesepdist = atof(buf)) <= FTINY) + error(INTERNAL, "bad eye separation from server"); + break; case DS_STARTIMM: case DS_ENDIMM: - imm_mode = msg.type==DS_STARTIMM; - /* fall through */ + if (!(imm_mode = msg.type==DS_STARTIMM)) + dev_flush(); +#ifdef DEBUG + { + time_t tnow = time(NULL); + if (msg.type==DS_STARTIMM) tadd += tnow - tmodesw; + else timm += tnow - tmodesw; + tmodesw = tnow; + } +#endif + goto noargs; case DS_ACKNOW: case DS_SHUTDOWN: - if (msg.nbytes) { - sprintf(errmsg, - "unexpected body with server message %d", - msg.type); - error(INTERNAL, errmsg); - } - break; + goto noargs; default: error(INTERNAL, "unrecognized result from server process"); } return(msg.type); /* return message type */ +noargs: + if (msg.nbytes) { + sprintf(errmsg, "unexpected body with server message %d", + msg.type); + error(INTERNAL, errmsg); + } + return(msg.type); readerr: if (feof(stdin)) error(SYSTEM, "server process died"); @@ -382,6 +547,9 @@ char *p; { MSGHEAD msg; int m; + /* consistency checks */ + DCHECK(nbytes < 0 || nbytes > 0 & p == NULL, + CONSISTENCY, "bad buffer handed to serv_request"); /* get server's attention for big request */ if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) { serv_request(DR_ATTEN, 0, NULL); @@ -399,6 +567,7 @@ char *p; } +void eputs(s) /* put error message to stderr */ register char *s; { @@ -418,10 +587,13 @@ register char *s; } +void quit(code) /* clean up and exit */ int code; { + if (code) + exit(code); if (odev.v.type) dev_close(); - exit(code); + exit(0); }
