--- ray/src/hd/rhdisp.c 1998/01/06 05:26:20 3.22 +++ ray/src/hd/rhdisp.c 1998/07/13 17:55:51 3.27 @@ -1,4 +1,4 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint static char SCCSid[] = "$SunId$ SGI"; @@ -26,6 +26,8 @@ int imm_mode = 0; /* bundles are being delivered imme int do_outside = 0; /* render from outside sections */ +double eyesepdist = 1; /* eye separation distance */ + char *progname; /* global argv[0] */ FILE *sstdin, *sstdout; /* server's standard input and output */ @@ -93,7 +95,7 @@ char *argv[]; if (inp & DFL(DC_PAUSE)) pause = 1; if (inp & DFL(DC_REDRAW)) - imm_mode = beam_sync() > 0; + imm_mode = beam_sync(1) > 0; if (inp & DFL(DC_KILL)) { serv_request(DR_KILL, 0, NULL); pause = 0; @@ -159,6 +161,7 @@ disp_wait() /* wait for more input */ n = odev.ifd+1; if (sstdin != NULL) { FD_SET(fileno(sstdin), &readset); + FD_SET(fileno(sstdin), &errset); if (fileno(sstdin) >= n) n = fileno(sstdin) + 1; } @@ -173,7 +176,8 @@ disp_wait() /* wait for more input */ flgs |= RDY_SRV; if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset)) flgs |= RDY_DEV; - if (sstdin != NULL && FD_ISSET(fileno(sstdin), &readset)) + if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) || + FD_ISSET(fileno(sstdin), &errset))) flgs |= RDY_SIN; return(flgs); } @@ -245,6 +249,8 @@ register VIEW *v; { static VIEW viewhist[VIEWHISTLEN]; static unsigned nhist; + VIEW *dv; + int i, res[2]; char *err; /* restore previous view? */ if (v == NULL) { @@ -264,11 +270,20 @@ again: error(COMMAND, "cannot handle parallel views"); return; } - if (!dev_view(v)) /* update display driver */ + if (!dev_view(v)) /* notify display driver */ goto again; dev_flush(); /* update screen */ - if (!beam_view(v)) /* update beam list */ - goto again; + beam_init(0); /* compute new beam set */ + for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) + if (!beam_view(dv, res[0], res[1])) { + if (!nhist) { + error(COMMAND, "invalid starting view"); + return; + } + copystruct(v, viewhist + ((nhist-1)%VIEWHISTLEN)); + goto again; + } + beam_sync(0); /* update server */ /* record new view */ if (v < viewhist || v >= viewhist+VIEWHISTLEN) { copystruct(viewhist + (nhist%VIEWHISTLEN), v); @@ -281,26 +296,28 @@ int usr_input() /* get user input and process it */ { VIEW vparams; - char cmd[128]; + char cmd[256]; register char *args; register int i; - if (fgets(cmd, sizeof(cmd), sstdin) == NULL) - return(DC_QUIT); + if (fgets(cmd, sizeof(cmd), sstdin) == NULL) { + fclose(sstdin); + sstdin = NULL; + return(-1); + } + if (!*cmd) + return(DC_RESUME); for (args = cmd; *args && !isspace(*args); args++) ; while (isspace(*args)) *args++ = '\0'; - if (!*cmd) - return(DC_RESUME); if (*args && args[i=strlen(args)-1] == '\n') args[i] = '\0'; for (i = 0; i < DC_NCMDS; i++) if (!strcmp(cmd, cmdlist[i])) break; if (i >= DC_NCMDS) { - sprintf(errmsg, "unknown command: %s", cmd); - error(COMMAND, errmsg); + dev_auxcom(cmd, args); return(-1); } switch (i) { @@ -322,7 +339,7 @@ usr_input() /* get user input and process it */ /* handled in main() */ break; case DC_REDRAW: /* redraw from server */ - imm_mode = beam_sync() > 0; + imm_mode = beam_sync(1) > 0; dev_clear(); break; case DC_KILL: /* kill rtrace process(es) */ @@ -389,6 +406,10 @@ serv_result() /* get next server result and process break; case DS_OUTSECT: do_outside = 1; + break; + case DS_EYESEP: + if (msg.nbytes <= 1 || (eyesepdist = atof(buf)) <= FTINY) + error(INTERNAL, "bad eye separation from server"); break; case DS_STARTIMM: case DS_ENDIMM:
