root/radiance/ray/src/hd/rhdisp.c
Revision: 3.2
Committed: Thu Nov 20 18:05:57 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.1: +30 -4 lines
added eputs() function to prepend program name
added noop function to recover from vain DR_ATTEN
added pause function
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process.
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14 #include "selcall.h"
15
16 HOLO *hdlist[HDMAX+1]; /* global holodeck list */
17
18 int imm_mode = 0; /* bundles are being delivered immediately */
19
20 VIEW dvw; /* our current display view */
21
22 char *progname; /* global argv[0] */
23
24 #define SERV_READY 01
25 #define DEV_READY 02
26
27
28 main(argc, argv)
29 int argc;
30 char *argv[];
31 {
32 int rdy, inp, res = 0;
33
34 progname = argv[0];
35 if (argc != 2)
36 error(USER, "bad command line arguments");
37 /* open our device */
38 dev_open(argv[1]);
39 /* enter main loop */
40 do {
41 rdy = disp_wait();
42 while (rdy & DEV_READY) {
43 inp = dev_input(); /* take residual action here */
44 if (inp & DEV_NEWVIEW)
45 new_view(&odev.v);
46 if (inp & DEV_SHUTDOWN)
47 serv_request(DR_SHUTDOWN, 0, NULL);
48 if (inp & DEV_WAIT)
49 serv_request(DR_ATTEN, 0, NULL);
50 else
51 rdy &= ~DEV_READY;
52 }
53 if (rdy & SERV_READY) {
54 res = serv_result(); /* processes result, also */
55 if (res == DS_ACKNOW)
56 serv_request(DR_NOOP, 0, NULL);
57 }
58 } while (res != DS_SHUTDOWN);
59 /* all done */
60 quit(0);
61 }
62
63
64 int
65 disp_wait() /* wait for more input */
66 {
67 fd_set readset, errset;
68 int flgs;
69 int n;
70 register int i;
71 /* see if we can avoid select call */
72 if (imm_mode || stdin->_cnt > 0)
73 return(SERV_READY);
74 if (dev_flush())
75 return(DEV_READY);
76 /* make the call */
77 FD_ZERO(&readset); FD_ZERO(&errset);
78 FD_SET(0, &readset);
79 FD_SET(0, &errset);
80 FD_SET(odev.ifd, &readset);
81 FD_SET(odev.ifd, &errset);
82 n = odev.ifd + 1;
83 n = select(n, &readset, NULL, &errset, NULL);
84 if (n < 0) {
85 if (errno == EINTR)
86 return(0);
87 error(SYSTEM, "select call failure in disp_wait");
88 }
89 flgs = 0; /* flag what's ready */
90 if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset))
91 flgs |= SERV_READY;
92 if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset))
93 flgs |= DEV_READY;
94 return(flgs);
95 }
96
97
98 add_holo(hdg) /* register a new holodeck section */
99 HDGRID *hdg;
100 {
101 VIEW nv;
102 register int hd;
103
104 for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++)
105 ;
106 if (hd >= HDMAX)
107 error(INTERNAL, "too many holodeck sections in add_holo");
108 hdlist[hd] = (HOLO *)malloc(sizeof(HOLO));
109 if (hdlist[hd] == NULL)
110 error(SYSTEM, "out of memory in add_holo");
111 bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID));
112 hdcompgrid(hdlist[hd]);
113 if (hd)
114 return;
115 /* set initial viewpoint */
116 copystruct(&nv, &odev.v);
117 VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5);
118 VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5);
119 VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5);
120 fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]);
121 VCOPY(nv.vup, hdlist[0]->xv[2]);
122 new_view(&nv);
123 }
124
125
126 disp_bundle(p) /* display a ray bundle */
127 register PACKHEAD *p;
128 {
129 GCOORD gc[2];
130 FVECT ro, rd, wp;
131 double d;
132 register int i;
133 /* get beam coordinates */
134 if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL)
135 error(INTERNAL, "bad holodeck number in disp_bundle");
136 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
137 error(INTERNAL, "bad beam index in disp_bundle");
138 /* display each ray */
139 for (i = p->nr; i--; ) {
140 hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r);
141 d = hddepth(hdlist[p->hd], packra(p)[i].d);
142 VSUM(wp, ro, rd, d); /* might be behind viewpoint */
143 dev_value(packra(p)[i].v, wp);
144 }
145 }
146
147
148 new_view(v) /* change view parameters */
149 VIEW *v;
150 {
151 char *err;
152
153 if ((err = setview(v)) != NULL)
154 error(INTERNAL, err);
155 dev_view(v); /* update display driver */
156 beam_view(&dvw, v); /* update beam list */
157 copystruct(&dvw, v); /* record new view */
158 }
159
160
161 int
162 serv_result() /* get next server result and process it */
163 {
164 static char *buf = NULL;
165 static int bufsiz = 0;
166 MSGHEAD msg;
167 int n;
168 /* read message header */
169 if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1)
170 goto readerr;
171 if (msg.nbytes > 0) { /* get the message body */
172 if (msg.nbytes > bufsiz) {
173 if (buf == NULL)
174 buf = (char *)malloc(bufsiz=msg.nbytes);
175 else
176 buf = (char *)realloc(buf, bufsiz=msg.nbytes);
177 if (buf == NULL)
178 error(SYSTEM, "out of memory in serv_result");
179 }
180 if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes)
181 goto readerr;
182 }
183 switch (msg.type) { /* process results */
184 case DS_BUNDLE:
185 if (msg.nbytes < sizeof(PACKHEAD) ||
186 msg.nbytes != packsiz(((PACKHEAD *)buf)->nr))
187 error(INTERNAL, "bad display packet from server");
188 disp_bundle((PACKHEAD *)buf);
189 break;
190 case DS_ADDHOLO:
191 if (msg.nbytes != sizeof(HDGRID))
192 error(INTERNAL, "bad holodeck record from server");
193 add_holo((HDGRID *)buf);
194 break;
195 case DS_STARTIMM:
196 case DS_ENDIMM:
197 imm_mode = msg.type==DS_STARTIMM;
198 /* fall through */
199 case DS_ACKNOW:
200 case DS_SHUTDOWN:
201 if (msg.nbytes) {
202 sprintf(errmsg,
203 "unexpected body with server message %d",
204 msg.type);
205 error(INTERNAL, errmsg);
206 }
207 break;
208 default:
209 error(INTERNAL, "unrecognized result from server process");
210 }
211 return(msg.type); /* return message type */
212 readerr:
213 if (feof(stdin))
214 error(SYSTEM, "server process died");
215 error(SYSTEM, "error reading from server process");
216 }
217
218
219 serv_request(type, nbytes, p) /* send a request to the server process */
220 int type, nbytes;
221 char *p;
222 {
223 MSGHEAD msg;
224 int m;
225 /* get server's attention for big request */
226 if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) {
227 serv_request(DR_ATTEN, 0, NULL);
228 while ((m = serv_result()) != DS_ACKNOW)
229 if (m == DS_SHUTDOWN) /* the bugger quit on us */
230 quit(0);
231 }
232 msg.type = type; /* write and flush the message */
233 msg.nbytes = nbytes;
234 fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout);
235 if (nbytes > 0)
236 fwrite(p, 1, nbytes, stdout);
237 if (fflush(stdout) < 0)
238 error(SYSTEM, "write error in serv_request");
239 }
240
241
242 eputs(s) /* put error message to stderr */
243 register char *s;
244 {
245 static int midline = 0;
246
247 if (!*s)
248 return;
249 if (!midline++) { /* prepend line with program name */
250 fputs(progname, stderr);
251 fputs(": ", stderr);
252 }
253 fputs(s, stderr);
254 if (s[strlen(s)-1] == '\n') {
255 fflush(stderr);
256 midline = 0;
257 }
258 }
259
260
261 quit(code) /* clean up and exit */
262 int code;
263 {
264 if (odev.v.type)
265 dev_close();
266 exit(code);
267 }
