--- ray/src/hd/rhdisp.c 1997/12/18 18:14:15 3.16 +++ ray/src/hd/rhdisp.c 2018/10/05 19:19:16 3.55 @@ -1,43 +1,78 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhdisp.c,v 3.55 2018/10/05 19:19:16 greg Exp $"; #endif - /* * Holodeck display process. */ +#include +#include + +#include "rterror.h" #include "rholo.h" #include "rhdisp.h" #include "rhdriver.h" #include "selcall.h" -#include #ifndef VIEWHISTLEN #define VIEWHISTLEN 4 /* number of remembered views */ #endif +#ifndef FSIZDEF +#define FSIZDEF 0.125 /* default focus frame size */ +#endif + +#if defined(freebsd) +#define fbufcnt(f) ((f)->_r) +#elif defined(__GNUC__) +#define fbufcnt(f) ((f)->_IO_read_end - (f)->_IO_read_ptr) +#else +#define fbufcnt(f) ((f)->_cnt) +#endif + HOLO *hdlist[HDMAX+1]; /* global holodeck list */ +char *hdgfn[HDMAX]; /* holodeck section geometry list */ +char *hdpfn[HDMAX]; /* section portal list */ + char cmdlist[DC_NCMDS][8] = DC_INIT; int imm_mode = 0; /* bundles are being delivered immediately */ +int do_outside = 0; /* render from outside sections */ + +double eyesepdist = 1; /* eye separation distance */ + char *progname; /* global argv[0] */ FILE *sstdin, *sstdout; /* server's standard input and output */ +#ifdef DEBUG +extern time_t time(); +static time_t tmodesw; +static time_t timm, tadd; +static long nimmrays, naddrays; +#endif + #define RDY_SRV 01 #define RDY_DEV 02 #define RDY_SIN 04 +static int disp_wait(void); +static void add_holo(HDGRID *hdg, char *gfn, char *pfn); +static void disp_bundle(PACKHEAD *p); +static void new_view(VIEW *v); +static void set_focus(char *args); +static int usr_input(void); +static void printview(void); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { - extern int eputs(); int rdy, inp, res = 0, pause = 0; progname = argv[0]; @@ -53,25 +88,33 @@ char *argv[]; sstdin = fdopen(inp, "r"); /* set command error vector */ erract[COMMAND].pf = eputs; +#ifdef DEBUG + tmodesw = time(NULL); +#endif /* enter main loop */ do { rdy = disp_wait(); + if (rdy & RDY_SRV) { /* process server result */ + res = serv_result(); + if (pause && res != DS_SHUTDOWN) { + serv_request(DR_ATTEN, 0, NULL); + while ((res = serv_result()) != DS_ACKNOW && + res != DS_SHUTDOWN) + ; + } + } if (rdy & RDY_DEV) { /* user input from driver */ inp = dev_input(); if (inp & DFL(DC_SETVIEW)) new_view(&odev.v); - if (inp & DFL(DC_GETVIEW)) - printview(); - if (inp & DFL(DC_LASTVIEW)) + else if (inp & DFL(DC_LASTVIEW)) new_view(NULL); - if (inp & DFL(DC_RESUME)) { - serv_request(DR_NOOP, 0, NULL); - pause = 0; - } - if (inp & DFL(DC_PAUSE)) - pause = 1; if (inp & DFL(DC_REDRAW)) - imm_mode = beam_sync() > 0; + imm_mode = beam_sync(1) > 0; + if (inp & DFL(DC_GETVIEW)) + printview(); + if (inp & DFL(DC_FOCUS)) + set_focus(odev_args); if (inp & DFL(DC_KILL)) { serv_request(DR_KILL, 0, NULL); pause = 0; @@ -82,10 +125,16 @@ char *argv[]; serv_request(DR_RESTART, 0, NULL); pause = 0; } + if (inp & DFL(DC_RESUME)) { + serv_request(DR_NOOP, 0, NULL); + pause = 0; + } + if (inp & DFL(DC_PAUSE)) + pause = 1; if (inp & DFL(DC_QUIT)) serv_request(DR_SHUTDOWN, 0, NULL); } - if (rdy & RDY_SIN) /* user input from sstdin */ + if (rdy & RDY_SIN && !imm_mode) /* user input from sstdin */ switch (usr_input()) { case DC_PAUSE: pause = 1; @@ -98,36 +147,44 @@ char *argv[]; pause = 0; break; } - if (rdy & RDY_SRV) { /* process server result */ - res = serv_result(); - if (pause && res != DS_SHUTDOWN) { - serv_request(DR_ATTEN, 0, NULL); - while ((res = serv_result()) != DS_ACKNOW && - res != DS_SHUTDOWN) - ; - } - } } while (res != DS_SHUTDOWN); +#ifdef DEBUG + if (timm && nimmrays) + fprintf(stderr, + "%s: %.1f rays recalled/second (%ld rays total)\n", + progname, (double)nimmrays/timm, nimmrays); + if (tadd && naddrays) + fprintf(stderr, + "%s: %.1f rays calculated/second (%ld rays total)\n", + progname, (double)naddrays/tadd, naddrays); +#endif /* all done */ quit(0); + return 0; /* pro forma return */ } -int -disp_wait() /* wait for more input */ +static int +disp_wait(void) /* wait for more input */ { fd_set readset, errset; int flgs; int n; - register int i; /* see if we can avoid select call */ - if (imm_mode || stdin->_cnt > 0) - return(RDY_SRV); - if (sstdin != NULL && sstdin->_cnt > 0) - return(RDY_SIN); - if (dev_flush()) + if (hdlist[0] == NULL) + return(RDY_SRV); /* initialize first */ + flgs = 0; /* flag what's ready already */ + if (imm_mode || fbufcnt(stdin) > 0) + flgs |= RDY_SRV; + if (sstdin != NULL && fbufcnt(sstdin) > 0) + flgs |= RDY_SIN; + if (odev.inpready) + flgs |= RDY_DEV; + if (flgs) /* got something? */ + return(flgs); + if (dev_flush()) /* else flush output & check keyboard+mouse */ return(RDY_DEV); - /* make the call */ + /* if nothing, we need to call select */ FD_ZERO(&readset); FD_ZERO(&errset); FD_SET(0, &readset); FD_SET(0, &errset); @@ -136,6 +193,7 @@ disp_wait() /* wait for more input */ n = odev.ifd+1; if (sstdin != NULL) { FD_SET(fileno(sstdin), &readset); + FD_SET(fileno(sstdin), &errset); if (fileno(sstdin) >= n) n = fileno(sstdin) + 1; } @@ -145,22 +203,27 @@ disp_wait() /* wait for more input */ return(0); error(SYSTEM, "select call failure in disp_wait"); } - flgs = 0; /* flag what's ready */ if (FD_ISSET(0, &readset) || FD_ISSET(0, &errset)) flgs |= RDY_SRV; if (FD_ISSET(odev.ifd, &readset) || FD_ISSET(odev.ifd, &errset)) flgs |= RDY_DEV; - if (sstdin != NULL && FD_ISSET(fileno(sstdin), &readset)) + if (sstdin != NULL && (FD_ISSET(fileno(sstdin), &readset) || + FD_ISSET(fileno(sstdin), &errset))) flgs |= RDY_SIN; return(flgs); } -add_holo(hdg) /* register a new holodeck section */ -HDGRID *hdg; +static void +add_holo( /* a new holodeck section */ + HDGRID *hdg, + char *gfn, + char *pfn +) { VIEW nv; - register int hd; + double d; + int hd; for (hd = 0; hd < HDMAX && hdlist[hd] != NULL; hd++) ; @@ -169,30 +232,40 @@ HDGRID *hdg; hdlist[hd] = (HOLO *)malloc(sizeof(HOLO)); if (hdlist[hd] == NULL) error(SYSTEM, "out of memory in add_holo"); - bcopy((char *)hdg, (char *)hdlist[hd], sizeof(HDGRID)); + memcpy((void *)hdlist[hd], (void *)hdg, sizeof(HDGRID)); hdcompgrid(hdlist[hd]); + hdgfn[hd] = savestr(gfn); + hdpfn[hd] = pfn && *pfn ? savestr(pfn) : (char *)NULL; if (hd) return; /* set initial viewpoint */ - copystruct(&nv, &odev.v); + nv = odev.v; VSUM(nv.vp, hdlist[0]->orig, hdlist[0]->xv[0], 0.5); VSUM(nv.vp, nv.vp, hdlist[0]->xv[1], 0.5); VSUM(nv.vp, nv.vp, hdlist[0]->xv[2], 0.5); fcross(nv.vdir, hdlist[0]->xv[1], hdlist[0]->xv[2]); VCOPY(nv.vup, hdlist[0]->xv[2]); + if (do_outside) { + normalize(nv.vdir); + d = VLEN(hdlist[0]->xv[1]); + d += VLEN(hdlist[0]->xv[2]); + VSUM(nv.vp, nv.vp, nv.vdir, -d); + } new_view(&nv); } -disp_bundle(p) /* display a ray bundle */ -register PACKHEAD *p; +static void +disp_bundle( /* display a ray bundle */ + PACKHEAD *p +) { GCOORD gc[2]; FVECT ro, rd, wp; double d; - register int i; + int i; /* get beam coordinates */ - if (p->hd < 0 | p->hd >= HDMAX || hdlist[p->hd] == NULL) + if ((p->hd < 0) | (p->hd >= HDMAX) || hdlist[p->hd] == NULL) error(INTERNAL, "bad holodeck number in disp_bundle"); if (!hdbcoord(gc, hdlist[p->hd], p->bi)) error(INTERNAL, "bad beam index in disp_bundle"); @@ -200,17 +273,29 @@ register PACKHEAD *p; for (i = p->nr; i--; ) { hdray(ro, rd, hdlist[p->hd], gc, packra(p)[i].r); d = hddepth(hdlist[p->hd], packra(p)[i].d); - VSUM(wp, ro, rd, d); /* might be behind viewpoint */ - dev_value(packra(p)[i].v, wp, rd); + if (d < .99*FHUGE) { + VSUM(wp, ro, rd, d); /* might be behind viewpoint */ + dev_value(packra(p)[i].v, rd, wp); + } else + dev_value(packra(p)[i].v, rd, NULL); } +#ifdef DEBUG + if (imm_mode) nimmrays += p->nr; + else naddrays += p->nr; +#endif } -new_view(v) /* change view parameters */ -register VIEW *v; +static void +new_view( /* change view parameters */ + VIEW *v +) { static VIEW viewhist[VIEWHISTLEN]; static unsigned nhist; + VIEW *dv; + int i, res[2]; + int16 *slist; char *err; /* restore previous view? */ if (v == NULL) { @@ -220,57 +305,149 @@ register VIEW *v; while (nhist < VIEWHISTLEN && viewhist[nhist].type) nhist++; v = viewhist + ((nhist-1)%VIEWHISTLEN); - } else if ((err = setview(v)) != NULL) { + } else +again: + if ((err = setview(v)) != NULL) { error(COMMAND, err); return; } -again: + if (!dev_view(v)) /* notify display driver */ + goto again; if (v->type == VT_PAR) { error(COMMAND, "cannot handle parallel views"); return; } - if (!dev_view(v)) /* update display driver */ - goto again; - dev_flush(); /* update screen */ - if (!beam_view(v)) /* update beam list */ - goto again; + beam_init(odev.firstuse); /* compute new beam set */ + for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) { + if ((slist = beam_view(dv, res[0], res[1])) == NULL) { + if (!nhist) { + error(COMMAND, "invalid starting view"); + return; + } + *v = *(viewhist + ((nhist-1)%VIEWHISTLEN)); + goto again; /* XXX overloading dev_section()? */ + } + DCHECK(*slist < 0, WARNING, "no visible sections in new_view"); + for ( ; *slist >= 0; slist++) + dev_section(hdgfn[*slist], hdpfn[*slist]); + } + dev_section(NULL,NULL); /* end section list */ + dev_flush(); /* update display */ + /* update server */ + imm_mode = beam_sync(odev.firstuse) > 0; /* record new view */ if (v < viewhist || v >= viewhist+VIEWHISTLEN) { - copystruct(viewhist + (nhist%VIEWHISTLEN), v); + *(viewhist + (nhist%VIEWHISTLEN)) = *v; nhist++; } } -int -usr_input() /* get user input and process it */ +static void +set_focus( /* set focus frame */ + char *args +) { + double hcent, vcent, hsiz, vsiz; + VIEW *dv, vwfocus; + int i, res[2]; + + i = sscanf(args, "%lf %lf %lf %lf", &hcent, &vcent, &hsiz, &vsiz); + if (i < 2 || hcent < 0 || hcent > 1 || vcent < 0 || vcent > 1) { + beam_init(0); /* restore view */ + for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) + beam_view(dv, res[0], res[1]); + beam_sync(0); /* update server */ + return; + } + if (i < 4 || hsiz <= hcent || hsiz > 1 || vsiz <= vcent || vsiz > 1) + hsiz = vsiz = FSIZDEF; /* gave center only */ + else { + hsiz -= hcent; hcent += 0.5*hsiz; /* gave min and max */ + vsiz -= vcent; vcent += 0.5*vsiz; + } + beam_init(0); /* add basic views */ + for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) + beam_view(dv, res[0]>>4, res[1]>>4); + vwfocus = odev.v; /* add focus view */ + switch (odev.v.type) { + case VT_PER: + vwfocus.horiz = 2.*180./PI*atan( + hsiz * tan(PI/180./2.*odev.v.horiz) ); + vwfocus.vert = 2.*180./PI*atan( + vsiz * tan(PI/180./2.*odev.v.vert) ); + break; + case VT_PAR: + case VT_ANG: + vwfocus.horiz = hsiz * odev.v.horiz; + vwfocus.vert = vsiz * odev.v.vert; + break; + case VT_PLS: + vwfocus.horiz = hsiz * sin((PI/180./2.)*odev.v.horiz) / + (1.0 + cos((PI/180./2.)*odev.v.horiz)); + vwfocus.horiz *= vwfocus.horiz; + vwfocus.horiz = (2.*180./PI)*acos((1. - vwfocus.horiz) / + (1. + vwfocus.horiz)); + vwfocus.vert = vsiz * sin((PI/180./2.)*odev.v.vert) / + (1.0 + cos((PI/180./2.)*odev.v.vert)); + vwfocus.vert *= vwfocus.vert; + vwfocus.vert = (2.*180./PI)*acos((1. - vwfocus.vert) / + (1. + vwfocus.vert)); + break; + case VT_HEM: + vwfocus.horiz = 2.*180./PI*asin( + hsiz * sin(PI/180./2.*odev.v.horiz) ); + vwfocus.vert = 2.*180./PI*asin( + vsiz * sin(PI/180./2.*odev.v.vert) ); + break; + case VT_CYL: + vwfocus.horiz = hsiz * odev.v.horiz; + vwfocus.vert = 2.*180./PI*atan( + vsiz * tan(PI/180./2.*odev.v.vert) ); + break; + default: + error(INTERNAL, "bad view type in set_focus"); + } + vwfocus.hoff = (odev.v.hoff + hcent - 0.5)/hsiz; + vwfocus.voff = (odev.v.voff + vcent - 0.5)/vsiz; + setview(&vwfocus); + beam_view(&vwfocus, (int)(3*odev.hres*hsiz)+100, + (int)(3*odev.vres*vsiz)+100); + beam_sync(0); /* update server */ +} + + +static int +usr_input(void) /* get user input and process it */ +{ VIEW vparams; - char cmd[128]; - register char *args; - register int i; + char cmd[256]; + char *args; + int i; - if (fgets(cmd, sizeof(cmd), sstdin) == NULL) - return(DC_QUIT); + if (fgets(cmd, sizeof(cmd), sstdin) == NULL) { + fclose(sstdin); + sstdin = NULL; + return(-1); + } + if (*cmd == '\n') + return(DC_RESUME); for (args = cmd; *args && !isspace(*args); args++) ; while (isspace(*args)) *args++ = '\0'; - if (!*cmd) - return(DC_RESUME); if (*args && args[i=strlen(args)-1] == '\n') args[i] = '\0'; for (i = 0; i < DC_NCMDS; i++) if (!strcmp(cmd, cmdlist[i])) break; if (i >= DC_NCMDS) { - sprintf(errmsg, "unknown command: %s", cmd); - error(COMMAND, errmsg); + dev_auxcom(cmd, args); return(-1); } switch (i) { case DC_SETVIEW: /* set the view */ - copystruct(&vparams, &odev.v); + vparams = odev.v; if (!sscanview(&vparams, args)) error(COMMAND, "missing view options"); else @@ -282,12 +459,16 @@ usr_input() /* get user input and process it */ case DC_LASTVIEW: /* restore previous view */ new_view(NULL); break; + case DC_FOCUS: /* set focus frame */ + set_focus(args); + break; case DC_PAUSE: /* pause the current calculation */ case DC_RESUME: /* resume the calculation */ /* handled in main() */ break; case DC_REDRAW: /* redraw from server */ - imm_mode = beam_sync() > 0; + imm_mode = beam_sync(1) > 0; + dev_clear(); break; case DC_KILL: /* kill rtrace process(es) */ serv_request(DR_KILL, 0, NULL); @@ -308,7 +489,8 @@ usr_input() /* get user input and process it */ } -printview() /* print our current view to server stdout */ +static void +printview(void) /* print our current view to server stdout */ { fputs(VIEWSTR, sstdout); fprintview(&odev.v, sstdout); @@ -318,25 +500,25 @@ printview() /* print our current view to server stdo int -serv_result() /* get next server result and process it */ +serv_result(void) /* get next server result and process it */ { static char *buf = NULL; static int bufsiz = 0; MSGHEAD msg; - int n; /* read message header */ - if (fread((char *)&msg, sizeof(MSGHEAD), 1, stdin) != 1) + if (getbinary(&msg, sizeof(MSGHEAD), 1, stdin) != 1) goto readerr; if (msg.nbytes > 0) { /* get the message body */ if (msg.nbytes > bufsiz) { if (buf == NULL) buf = (char *)malloc(bufsiz=msg.nbytes); else - buf = (char *)realloc(buf, bufsiz=msg.nbytes); + buf = (char *)realloc((void *)buf, + bufsiz=msg.nbytes); if (buf == NULL) error(SYSTEM, "out of memory in serv_result"); } - if (fread(buf, 1, msg.nbytes, stdin) != msg.nbytes) + if (getbinary(buf, 1, msg.nbytes, stdin) != msg.nbytes) goto readerr; } switch (msg.type) { /* process results */ @@ -347,42 +529,65 @@ serv_result() /* get next server result and process disp_bundle((PACKHEAD *)buf); break; case DS_ADDHOLO: - if (msg.nbytes != sizeof(HDGRID)) + if (msg.nbytes < sizeof(HDGRID)+2) error(INTERNAL, "bad holodeck record from server"); - add_holo((HDGRID *)buf); + add_holo((HDGRID *)buf, buf+sizeof(HDGRID), + buf+sizeof(HDGRID)+strlen(buf+sizeof(HDGRID))+1); break; + case DS_OUTSECT: + do_outside = 1; + goto noargs; + case DS_EYESEP: + if (msg.nbytes <= 1 || (eyesepdist = atof(buf)) <= FTINY) + error(INTERNAL, "bad eye separation from server"); + break; case DS_STARTIMM: case DS_ENDIMM: - imm_mode = msg.type==DS_STARTIMM; - if (msg.type == DS_ENDIMM) - dev_flush(); /* update display NOW */ - /* fall through */ + if (!(imm_mode = (msg.type==DS_STARTIMM))) + dev_flush(); +#ifdef DEBUG + { + time_t tnow = time(NULL); + if (msg.type==DS_STARTIMM) tadd += tnow - tmodesw; + else timm += tnow - tmodesw; + tmodesw = tnow; + } +#endif + goto noargs; case DS_ACKNOW: case DS_SHUTDOWN: - if (msg.nbytes) { - sprintf(errmsg, - "unexpected body with server message %d", - msg.type); - error(INTERNAL, errmsg); - } - break; + goto noargs; default: error(INTERNAL, "unrecognized result from server process"); } return(msg.type); /* return message type */ +noargs: + if (msg.nbytes) { + sprintf(errmsg, "unexpected body with server message %d", + msg.type); + error(INTERNAL, errmsg); + } + return(msg.type); readerr: if (feof(stdin)) error(SYSTEM, "server process died"); error(SYSTEM, "error reading from server process"); + return -1; } -serv_request(type, nbytes, p) /* send a request to the server process */ -int type, nbytes; -char *p; +void +serv_request( /* send a request to the server process */ + int type, + int nbytes, + char *p +) { MSGHEAD msg; int m; + /* consistency checks */ + DCHECK(nbytes < 0 || nbytes > 0 & p == NULL, + CONSISTENCY, "bad buffer handed to serv_request"); /* get server's attention for big request */ if (nbytes >= BIGREQSIZ-sizeof(MSGHEAD)) { serv_request(DR_ATTEN, 0, NULL); @@ -392,16 +597,18 @@ char *p; } msg.type = type; /* write and flush the message */ msg.nbytes = nbytes; - fwrite((char *)&msg, sizeof(MSGHEAD), 1, stdout); + putbinary(&msg, sizeof(MSGHEAD), 1, stdout); if (nbytes > 0) - fwrite(p, 1, nbytes, stdout); + putbinary(p, 1, nbytes, stdout); if (fflush(stdout) < 0) error(SYSTEM, "write error in serv_request"); } -eputs(s) /* put error message to stderr */ -register char *s; +void +eputs( /* put error message to stderr */ + char *s +) { static int midline = 0; @@ -419,10 +626,14 @@ register char *s; } -quit(code) /* clean up and exit */ -int code; +void +quit( /* clean up and exit */ + int code +) { + if (code) + exit(code); if (odev.v.type) dev_close(); - exit(code); + exit(0); }
