root/radiance/ray/src/hd/rhd_x11.c
Thu Jan 1 11:21:55 2004 UTC (20 years, 8 months ago) by schorsch
Changes since 3.36: +121 -70 lines
Diff to previous 3.36
Ansification and prototypes.
Fri Sep 19 18:33:05 2003 UTC (21 years ago) by greg
Changes since 3.35: +2 -2 lines
Diff to previous 3.35
Sun Jul 27 22:12:02 2003 UTC (21 years, 1 month ago) by schorsch
Diff to previous 3.34
Mon Jul 21 22:30:18 2003 UTC (21 years, 2 months ago) by schorsch
Changes since 3.33: +4 -4 lines
Diff to previous 3.33
Mon Apr 14 16:56:19 2003 UTC (21 years, 5 months ago) by greg
Changes since 3.32: +1 -1 lines
Diff to previous 3.32
Fixed interaction delay timing (supposed to be 50ms -- was 5ms)
Sat Feb 22 02:07:24 2003 UTC (21 years, 7 months ago) by greg
Changes since 3.31: +15 -7 lines
Diff to previous 3.31
Fri Dec 18 11:56:10 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.30: +7 -0 lines
Diff to previous 3.30
Thu Dec 10 10:45:54 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.29: +47 -2 lines
Diff to previous 3.29
created "frame" command to focus calculation
Fri Nov 13 14:25:52 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.28: +1 -3 lines
Diff to previous 3.28
fixed BYTE definition problem in header
Thu Aug 27 19:32:27 1998 UTC (26 years ago) by gwlarson
Changes since 3.27: +23 -7 lines
Diff to previous 3.27
finally fixed problem with grid drawing
Wed Aug 19 17:43:08 1998 UTC (26 years, 1 month ago) by gwlarson
Changes since 3.26: +4 -2 lines
Diff to previous 3.26
added odev.inpready member and periodic input checking to rhdisp
Wed Jun 17 15:44:07 1998 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.25: +9 -1 lines
Diff to previous 3.25
added dev_auxcom() for auxiliary command handling
Thu May 14 13:06:32 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.24: +12 -0 lines
Diff to previous 3.24
added multiple device view capability
Tue Jan 6 13:07:57 1998 UTC (26 years, 8 months ago) by gregl
Changes since 3.23: +14 -5 lines
Diff to previous 3.23
added check of DISPLAY_PRIMARIES environment variable
Tue Jan 6 05:26:19 1998 UTC (26 years, 8 months ago) by gregl
Changes since 3.22: +10 -0 lines
Diff to previous 3.22
created dev_clear() routine to clear device ray cache
Sun Jan 4 08:32:01 1998 UTC (26 years, 8 months ago) by gregl
Changes since 3.21: +1 -0 lines
Diff to previous 3.21
delay update after ^L
Thu Jan 1 14:48:46 1998 UTC (26 years, 8 months ago) by gregl
Diff to previous 3.20
increased leaf allocation by 50%
Thu Jan 1 13:00:15 1998 UTC (26 years, 8 months ago) by gregl
Changes since 3.19: +7 -2 lines
Diff to previous 3.19
Wed Dec 24 16:56:00 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.18: +1 -1 lines
Diff to previous 3.18
allow (slightly wrong) grid lines to be drawn even if !VT_PER
Wed Dec 24 14:04:22 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.17: +9 -11 lines
Diff to previous 3.17
reordered resize event and view setting
Fri Dec 19 14:44:58 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.16: +11 -9 lines
Diff to previous 3.16
vastly improved interactive view changes
Fri Dec 12 11:31:55 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.15: +1 -1 lines
Diff to previous 3.15
changed assumption about vertical window border size
Fri Dec 12 11:13:15 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.14: +9 -0 lines
Diff to previous 3.14
Thu Dec 11 16:45:58 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.13: +10 -17 lines
Diff to previous 3.13
normalized commands between driver and standard input
Thu Dec 11 09:37:43 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.12: +62 -24 lines
Diff to previous 3.12
added command for returning to previous view(s)
added check to dev_view() for illegal views
fixed bug in X11 driver on window resizing
Tue Dec 9 14:04:11 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.11: +8 -10 lines
Diff to previous 3.11
fixed problem with new view angle computation
Mon Dec 8 19:03:18 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.10: +17 -8 lines
Diff to previous 3.10
added ability to adjust window size on view change
Fri Dec 5 09:38:55 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.9: +0 -1 lines
Diff to previous 3.9
removed unnecessary assignment of qtDepthEps
Tue Nov 25 16:52:51 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.8: +65 -13 lines
Diff to previous 3.8
created gridlines() function to run through holodeck section grids
Tue Nov 25 11:21:50 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.7: +4 -0 lines
Diff to previous 3.7
improved display update
Mon Nov 24 15:17:06 1997 UTC (26 years, 10 months ago) by gregl
Changes since 3.6: +12 -2 lines
Diff to previous 3.6
added 'v' command to output views, and changed ^R and ^L commands
Fri Nov 21 16:10:17 1997 UTC (26 years, 10 months ago) by gregl
Changes since 3.5: +2 -1 lines
Diff to previous 3.5
added server-driven redraw function to replace display quadtree
Fri Nov 21 15:11:43 1997 UTC (26 years, 10 months ago) by gregl
Changes since 3.4: +5 -2 lines
Diff to previous 3.4
stopped pause function from resuming upon iconification and
interfering with full view updates
Fri Nov 21 13:35:58 1997 UTC (26 years, 10 months ago) by gregl
Changes since 3.3: +7 -5 lines
changed definition of global leaf pile to make tone mapping work better
Fri Nov 21 10:17:14 1997 UTC (26 years, 10 months ago) by gregl
Changes since 3.2: +5 -0 lines
added redraw (^R) command
Thu Nov 20 18:04:28 1997 UTC (26 years, 10 months ago) by gregl
Changes since 3.1: +105 -14 lines
added pause function
added view move function
changed leaf allocation
Wed Nov 19 18:01:03 1997 UTC (26 years, 10 months ago) by gregl
