root/radiance/ray/src/hd/rhd_x11.c
Revision: 3.37
Committed: Thu Jan 1 11:21:55 2004 UTC (20 years, 3 months ago) by schorsch
Changes since 3.36: +121 -70 lines
Ansification and prototypes.
2 static const char RCSid[] = "$Id: rhd_x11.c,v 3.36 2003/09/19 18:33:05 greg Exp $";
5 * X11 driver for holodeck display.
6 * Based on rview driver.
7 */
8
9 #include <stdlib.h>
10 #include <stdio.h>
11 #include <X11/Xlib.h>
12 #include <X11/cursorfont.h>
13 #include <X11/Xutil.h>
14 #include <time.h>
15
16 #include "platform.h"
17 #include "rtmath.h"
18 #include "rterror.h"
19 #include "plocate.h"
20 #include "rhdisp.h"
21 #include "rhd_qtree.h"
22 #include "x11icon.h"
23
24 #ifndef RAYQLEN
25 #define RAYQLEN 50000 /* max. rays to queue before flush */
26 #endif
27
28 #ifndef FEQ
29 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
30 #endif
31
32 #define GAMMA 2.2 /* default gamma correction */
33
34 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
35
36 #define MOVPCT 7 /* percent distance to move /frame */
37 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
38 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
39 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
40
41 #define MINWIDTH 480 /* minimum graphics window width */
42 #define MINHEIGHT 400 /* minimum graphics window height */
43
44 #define VIEWDIST 356 /* assumed viewing distance (mm) */
45
46 #define BORWIDTH 5 /* border width */
47
48 #define ourscreen DefaultScreen(ourdisplay)
49 #define ourroot RootWindow(ourdisplay,ourscreen)
50 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
51 ButtonPressMask|ButtonReleaseMask)
52
53 #define levptr(etype) ((etype *)&currentevent)
54
55 struct driver odev; /* global device driver structure */
56
57 char odev_args[64]; /* command arguments */
58
59 static XEvent currentevent; /* current event */
60
61 static int ncolors = 0; /* color table size */
62 static int mapped = 0; /* window is mapped? */
63 static unsigned long *pixval = NULL; /* allocated pixels */
64 static unsigned long ourblack=0, ourwhite=1;
65
66 static Display *ourdisplay = NULL; /* our display */
67 static XVisualInfo ourvinfo; /* our visual information */
68 static Window gwind = 0; /* our graphics window */
69 static GC ourgc = 0; /* our graphics context for drawing */
70 static Colormap ourmap = 0; /* our color map */
71
72 static double pwidth, pheight; /* pixel dimensions (mm) */
73
74 static int inpresflags; /* input result flags */
75
76 static int headlocked = 0; /* lock vertical motion */
77
78
79 static int mytmflags(void);
80 static void xnewcolr(int ndx, int r, int g, int b);
81 static int getpixels(void);
82 static void freepixels(void);
83 static unsigned long true_pixel(register BYTE rgb[3]);
84 static void getevent(void);
85 static int ilclip(int dp[2][2], FVECT wp[2]);
86 static void draw3dline(FVECT wp[2]);
87 static void draw_grids(void);
88 static int moveview(int dx, int dy, int mov, int orb);
89 static void getframe(XButtonPressedEvent *ebut);
90 static void waitabit(void);
91 static void getmove(XButtonPressedEvent *ebut);
92 static void getkey(register XKeyPressedEvent *ekey);
93 static void fixwindow(register XExposeEvent *eexp);
94 static void resizewindow(register XConfigureEvent *ersz);
95
96
97 static int
98 mytmflags(void) /* figure out tone mapping flags */
99 {
100 extern char *progname;
101 register char *cp, *tail;
102 /* find basic name */
103 for (cp = tail = progname; *cp; cp++)
104 if (*cp == '/')
105 tail = cp+1;
106 for (cp = tail; *cp && *cp != '.'; cp++)
107 ;
108 if (cp-tail == 3 && !strncmp(tail, "x11", 3))
109 return(TM_F_CAMERA|TM_F_NOSTDERR);
110 if (cp-tail == 4 && !strncmp(tail, "x11h", 4))
111 return(TM_F_HUMAN|TM_F_NOSTDERR);
112 error(USER, "illegal driver name");
113 return 0; /* pro forma return */
114 }
115
116
117 extern void
118 dev_open( /* initialize X11 driver */
119 char *id
120 )
121 {
122 static RGBPRIMS myprims = STDPRIMS;
123 char *ev;
124 double gamval = GAMMA;
125 RGBPRIMP dpri = stdprims;
126 int nplanes;
127 XSetWindowAttributes ourwinattr;
128 XWMHints ourxwmhints;
129 XSizeHints oursizhints;
130 /* set quadtree globals */
131 qtMinNodesiz = 2;
132 /* open display server */
133 ourdisplay = XOpenDisplay(NULL);
134 if (ourdisplay == NULL)
135 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
136 /* find a usable visual */
137 nplanes = DisplayPlanes(ourdisplay, ourscreen);
138 if (XMatchVisualInfo(ourdisplay,ourscreen,
139 nplanes>12?nplanes:24,TrueColor,&ourvinfo) ||
140 XMatchVisualInfo(ourdisplay,ourscreen,
141 nplanes>12?nplanes:24,DirectColor,&ourvinfo)) {
142 ourblack = 0;
143 ourwhite = ourvinfo.red_mask |
144 ourvinfo.green_mask |
145 ourvinfo.blue_mask ;
146 } else {
147 if (nplanes < 4)
148 error(INTERNAL, "not enough colors\n");
149 if (!XMatchVisualInfo(ourdisplay,ourscreen,
150 nplanes,PseudoColor,&ourvinfo) &&
151 !XMatchVisualInfo(ourdisplay,ourscreen,
152 nplanes,GrayScale,&ourvinfo))
153 error(INTERNAL, "unsupported visual type\n");
154 ourblack = BlackPixel(ourdisplay,ourscreen);
155 ourwhite = WhitePixel(ourdisplay,ourscreen);
156 }
157 /* set gamma and tone mapping */
158 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
159 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
160 gamval = atof(ev);
161 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
162 sscanf(ev, "%f %f %f %f %f %f %f %f",
163 &myprims[RED][CIEX],&myprims[RED][CIEY],
164 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
165 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
166 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
167 dpri = myprims;
168 if (tmInit(mytmflags(), dpri, gamval) == NULL)
169 error(SYSTEM, "not enough memory in dev_open");
170 /* open window */
171 ourwinattr.background_pixel = ourblack;
172 ourwinattr.border_pixel = ourblack;
173 ourwinattr.event_mask = ourmask;
174 /* this is stupid */
175 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
176 ourvinfo.visual, AllocNone);
177 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
178 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
179 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
180 BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual,
181 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
182 if (gwind == 0)
183 error(SYSTEM, "cannot create window\n");
184 XStoreName(ourdisplay, gwind, id);
185 /* get graphics context */
186 ourgc = XCreateGC(ourdisplay, gwind, 0, NULL);
187 /* set window manager hints */
188 ourxwmhints.flags = InputHint|IconPixmapHint;
189 ourxwmhints.input = True;
190 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
191 gwind, x11icon_bits, x11icon_width, x11icon_height);
192 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
193 oursizhints.min_width = MINWIDTH;
194 oursizhints.min_height = MINHEIGHT;
195 oursizhints.flags = PMinSize;
196 XSetNormalHints(ourdisplay, gwind, &oursizhints);
197 /* figure out sensible view */
198 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
199 DisplayWidth(ourdisplay, ourscreen);
200 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
201 DisplayHeight(ourdisplay, ourscreen);
202 odev.v = stdview;
203 odev.v.type = VT_PER;
204 /* map the window and get its size */
205 XMapWindow(ourdisplay, gwind);
206 dev_input(); /* sets size and view angles */
207 /* allocate our leaf pile */
208 if (!qtAllocLeaves(DisplayWidth(ourdisplay,ourscreen) *
209 DisplayHeight(ourdisplay,ourscreen) * 3 /
210 (qtMinNodesiz*qtMinNodesiz*2)))
211 error(SYSTEM, "insufficient memory for leaf storage");
212 odev.name = id;
213 odev.ifd = ConnectionNumber(ourdisplay);
214 }
215
216
217 extern void
218 dev_close(void) /* close our display */
219 {
220 freepixels();
221 XFreeGC(ourdisplay, ourgc);
222 XDestroyWindow(ourdisplay, gwind);
223 gwind = 0;
224 ourgc = 0;
225 XCloseDisplay(ourdisplay);
226 ourdisplay = NULL;
227 qtFreeLeaves();
228 tmDone(NULL);
229 odev.v.type = 0;
230 odev.hres = odev.vres = 0;
231 odev.ifd = -1;
232 }
233
234
235 extern void
236 dev_clear(void) /* clear our quadtree */
237 {
238 qtCompost(100);
239 if (ncolors > 0)
240 new_ctab(ncolors);
241 rayqleft = 0; /* hold off update */
242 }
243
244
245 extern int
246 dev_view( /* assign new driver view */
247 VIEW *nv
248 )
249 {
250 if (nv->type == VT_PAR || /* check view legality */
251 nv->horiz > 160. || nv->vert > 160.) {
252 error(COMMAND, "illegal view type/angle");
253 nv->type = VT_PER;
254 nv->horiz = odev.v.horiz;
255 nv->vert = odev.v.vert;
256 return(0);
257 }
258 if (nv->vfore > FTINY) {
259 error(COMMAND, "cannot handle fore clipping");
260 nv->vfore = 0.;
261 return(0);
262 }
263 if (nv != &odev.v) {
264 if (!FEQ(nv->horiz,odev.v.horiz) || /* resize window? */
265 !FEQ(nv->vert,odev.v.vert)) {
266 int dw = DisplayWidth(ourdisplay,ourscreen);
267 int dh = DisplayHeight(ourdisplay,ourscreen);
268
269 dw -= 25; /* for window frame */
270 dh -= 50;
271 odev.hres = 2.*VIEWDIST/pwidth *
272 tan(PI/180./2.*nv->horiz);
273 odev.vres = 2.*VIEWDIST/pheight *
274 tan(PI/180./2.*nv->vert);
275 if (odev.hres > dw) {
276 odev.vres = dw * odev.vres / odev.hres;
277 odev.hres = dw;
278 }
279 if (odev.vres > dh) {
280 odev.hres = dh * odev.hres / odev.vres;
281 odev.vres = dh;
282 }
283 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
284 dev_input(); /* wait for resize event */
285 }
286 odev.v = *nv;
287 }
288 qtReplant();
289 return(1);
290 }
291
292
293 extern void
294 dev_section( /* add octree for geometry rendering */
295 char *ofn
296 )
297 {
298 /* unimplemented */
299 }
300
301
302 extern void
303 dev_auxcom( /* process an auxiliary command */
304 char *cmd,
305 char *args
306 )
307 {
308 sprintf(errmsg, "%s: unknown command", cmd);
309 error(COMMAND, errmsg);
310 }
311
312
313 extern VIEW *
314 dev_auxview( /* return nth auxiliary view */
315 int n,
316 int hvres[2]
317 )
318 {
319 if (n)
320 return(NULL);
321 hvres[0] = odev.hres; hvres[1] = odev.vres;
322 return(&odev.v);
323 }
324
325
326 extern int
327 dev_input(void) /* get X11 input */
328 {
329 inpresflags = 0;
330
331 do
332 getevent();
333
334 while (XPending(ourdisplay) > 0);
335
336 odev.inpready = 0;
337
338 return(inpresflags);
339 }
340
341
342 extern void
343 dev_paintr( /* fill a rectangle */
344 BYTE rgb[3],
345 int xmin,
346 int ymin,
347 int xmax,
348 int ymax
349 )
350 {
351 unsigned long pixel;
352
353 if (!mapped)
354 return;
355 if (ncolors > 0)
356 pixel = pixval[get_pixel(rgb, xnewcolr)];
357 else
358 pixel = true_pixel(rgb);
359 XSetForeground(ourdisplay, ourgc, pixel);
360 XFillRectangle(ourdisplay, gwind,
361 ourgc, xmin, odev.vres-ymax, xmax-xmin, ymax-ymin);
362 }
363
364
365 extern int
366 dev_flush(void) /* flush output */
367 {
368 qtUpdate();
369 rayqleft = RAYQLEN;
370 return(odev.inpready = XPending(ourdisplay));
371 }
372
373
374 static void
375 xnewcolr( /* enter a color into hardware table */
376 int ndx,
377 int r,
378 int g,
379 int b
380 )
381 {
382 XColor xcolor;
383
384 xcolor.pixel = pixval[ndx];
385 xcolor.red = r << 8;
386 xcolor.green = g << 8;
387 xcolor.blue = b << 8;
388 xcolor.flags = DoRed|DoGreen|DoBlue;
389
390 XStoreColor(ourdisplay, ourmap, &xcolor);
391 }
392
393
394 static int
395 getpixels(void) /* get the color map */
396 {
397 XColor thiscolor;
398 register int i, j;
399
400 if (ncolors > 0)
401 return(ncolors);
402 if (ourvinfo.visual == DefaultVisual(ourdisplay,ourscreen)) {
403 ourmap = DefaultColormap(ourdisplay,ourscreen);
404 goto loop;
405 }
406 newmap:
407 ourmap = XCreateColormap(ourdisplay,gwind,ourvinfo.visual,AllocNone);
408 loop:
409 for (ncolors = ourvinfo.colormap_size;
410 ncolors > ourvinfo.colormap_size/3;
411 ncolors = ncolors*.937) {
412 pixval = (unsigned long *)malloc(ncolors*sizeof(unsigned long));
413 if (pixval == NULL)
414 return(ncolors = 0);
415 if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors))
416 break;
417 free((void *)pixval);
418 pixval = NULL;
419 }
420 if (pixval == NULL) {
421 if (ourmap == DefaultColormap(ourdisplay,ourscreen))
422 goto newmap; /* try it with our map */
423 else
424 return(ncolors = 0); /* failed */
425 }
426 if (ourmap != DefaultColormap(ourdisplay,ourscreen))
427 for (i = 0; i < ncolors; i++) { /* reset black and white */
428 if (pixval[i] != ourblack && pixval[i] != ourwhite)
429 continue;
430 thiscolor.pixel = pixval[i];
431 thiscolor.flags = DoRed|DoGreen|DoBlue;
432 XQueryColor(ourdisplay,
433 DefaultColormap(ourdisplay,ourscreen),
434 &thiscolor);
435 XStoreColor(ourdisplay, ourmap, &thiscolor);
436 for (j = i; j+1 < ncolors; j++)
437 pixval[j] = pixval[j+1];
438 ncolors--;
439 i--;
440 }
441 XSetWindowColormap(ourdisplay, gwind, ourmap);
442 return(ncolors);
443 }
444
445
446 static void
447 freepixels(void) /* free our pixels */
448 {
449 if (ncolors == 0)
450 return;
451 XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L);
452 free((void *)pixval);
453 pixval = NULL;
454 ncolors = 0;
455 if (ourmap != DefaultColormap(ourdisplay,ourscreen))
456 XFreeColormap(ourdisplay, ourmap);
457 ourmap = 0;
458 }
459
460
461 static unsigned long
462 true_pixel( /* return true pixel value for color */
463 register BYTE rgb[3]
464 )
465 {
466 register unsigned long rval;
467
468 rval = ourvinfo.red_mask*rgb[RED]/255 & ourvinfo.red_mask;
469 rval |= ourvinfo.green_mask*rgb[GRN]/255 & ourvinfo.green_mask;
470 rval |= ourvinfo.blue_mask*rgb[BLU]/255 & ourvinfo.blue_mask;
471 return(rval);
472 }
473
474
475 static void
476 getevent(void) /* get next event */
477 {
478 XNextEvent(ourdisplay, levptr(XEvent));
479 switch (levptr(XEvent)->type) {
480 case ConfigureNotify:
481 resizewindow(levptr(XConfigureEvent));
482 break;
483 case UnmapNotify:
484 mapped = 0;
485 freepixels();
486 break;
487 case MapNotify:
488 if (ourvinfo.class == PseudoColor ||
489 ourvinfo.class == GrayScale) {
490 if (getpixels() == 0)
491 error(SYSTEM, "cannot allocate colors\n");
492 new_ctab(ncolors);
493 }
494 mapped = 1;
495 break;
496 case Expose:
497 fixwindow(levptr(XExposeEvent));
498 break;
499 case KeyPress:
500 getkey(levptr(XKeyPressedEvent));
501 break;
502 case ButtonPress:
503 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
504 getframe(levptr(XButtonPressedEvent));
505 else
506 getmove(levptr(XButtonPressedEvent));
507 break;
508 }
509 }
510
511
512 static int
513 ilclip( /* clip world coordinates to device */
514 int dp[2][2],
515 FVECT wp[2]
516 )
517 {
518 static FVECT vmin = {0.,0.,0.}, vmax = {1.-FTINY,1.-FTINY,FHUGE};
519 FVECT wpc[2], ip[2];
520 double d, d0, d1;
521 /* check for points behind view */
522 d = DOT(odev.v.vp, odev.v.vdir);
523 d0 = DOT(wp[0], odev.v.vdir) - d;
524 d1 = DOT(wp[1], odev.v.vdir) - d;
525 /* work on copy of world points */
526 if (d0 <= d1) {
527 VCOPY(wpc[0], wp[0]); VCOPY(wpc[1], wp[1]);
528 } else {
529 d = d0; d0 = d1; d1 = d;
530 VCOPY(wpc[1], wp[0]); VCOPY(wpc[0], wp[1]);
531 }
532 if (d0 <= FTINY) {
533 if (d1 <= FTINY) return(0);
534 VSUB(wpc[0], wpc[0], wpc[1]);
535 d = .99*d1/(d1-d0);
536 VSUM(wpc[0], wpc[1], wpc[0], d);
537 }
538 /* get view coordinates and clip to window */
539 viewloc(ip[0], &odev.v, wpc[0]);
540 viewloc(ip[1], &odev.v, wpc[1]);
541 if (!clip(ip[0], ip[1], vmin, vmax))
542 return(0);
543 dp[0][0] = ip[0][0]*odev.hres;
544 dp[0][1] = ip[0][1]*odev.vres;
545 dp[1][0] = ip[1][0]*odev.hres;
546 dp[1][1] = ip[1][1]*odev.vres;
547 return(1);
548 }
549
550
551 static void
552 draw3dline( /* draw 3d line in world coordinates */
553 FVECT wp[2]
554 )
555 {
556 int dp[2][2];
557
558 if (!ilclip(dp, wp))
559 return;
560 XDrawLine(ourdisplay, gwind, ourgc,
561 dp[0][0], odev.vres-1 - dp[0][1],
562 dp[1][0], odev.vres-1 - dp[1][1]);
563 }
564
565
566 static void
567 draw_grids(void) /* draw holodeck section grids */
568 {
569 static BYTE gridrgb[3] = {0x0, 0xff, 0xff};
570 unsigned long pixel;
571
572 if (ncolors > 0)
573 pixel = pixval[get_pixel(gridrgb, xnewcolr)];
574 else
575 pixel = true_pixel(gridrgb);
576 XSetForeground(ourdisplay, ourgc, pixel);
577 /* draw each grid line */
578 gridlines(draw3dline);
579 }
580
581
582 static int
583 moveview( /* move our view */
584 int dx,
585 int dy,
586 int mov,
587 int orb
588 )
589 {
590 VIEW nv;
591 FVECT odir, v1;
592 double d;
593 register int li;
594 /* start with old view */
595 nv = odev.v;
596 /* change view direction */
597 if (mov | orb) {
598 if ((li = qtFindLeaf(dx, dy)) < 0)
599 return(0); /* not on window */
600 VSUM(odir, qtL.wp[li], nv.vp, -1.);
601 } else {
602 if (viewray(nv.vp, nv.vdir, &odev.v,
603 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
604 return(0); /* outside view */
605 }
606 if (orb && mov) { /* orbit left/right */
607 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
608 VSUM(nv.vp, qtL.wp[li], odir, -1.);
609 spinvector(nv.vdir, nv.vdir, nv.vup, d);
610 } else if (orb) { /* orbit up/down */
611 fcross(v1, odir, nv.vup);
612 if (normalize(v1) == 0.)
613 return(0);
614 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
615 VSUM(nv.vp, qtL.wp[li], odir, -1.);
616 spinvector(nv.vdir, nv.vdir, v1, d);
617 } else if (mov) { /* move forward/backward */
618 d = MOVPCT/100. * mov;
619 VSUM(nv.vp, nv.vp, odir, d);
620 }
621 if (!mov ^ !orb && headlocked) { /* restore head height */
622 VSUM(v1, odev.v.vp, nv.vp, -1.);
623 d = DOT(v1, odev.v.vup);
624 VSUM(nv.vp, nv.vp, odev.v.vup, d);
625 }
626 if (setview(&nv) != NULL)
627 return(0); /* illegal view */
628 dev_view(&nv);
629 inpresflags |= DFL(DC_SETVIEW);
630 return(1);
631 }
632
633
634 static void
635 getframe( /* get focus frame */
636 XButtonPressedEvent *ebut
637 )
638 {
639 int startx = ebut->x, starty = ebut->y;
640 int endx, endy;
641
642 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
643 endx = levptr(XButtonReleasedEvent)->x;
644 endy = levptr(XButtonReleasedEvent)->y;
645 if ((endx == startx) | (endy == starty)) {
646 XBell(ourdisplay, 0);
647 return;
648 }
649 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
650 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
651 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
652 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
653 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
654 inpresflags |= DFL(DC_FOCUS);
655 }
656
657
658 static void
659 waitabit(void) /* pause a moment */
660 {
661 struct timespec ts;
662 ts.tv_sec = 0;
663 ts.tv_nsec = 100000000;
664 nanosleep(&ts, NULL);
665 }
666
667
668 static void
669 getmove( /* get view change */
670 XButtonPressedEvent *ebut
671 )
672 {
673 int movdir = MOVDIR(ebut->button);
674 int movorb = MOVORB(ebut->state);
675 int oldnodesiz = qtMinNodesiz;
676 Window rootw, childw;
677 int rootx, rooty, wx, wy;
678 unsigned int statemask;
679
680 qtMinNodesiz = 16; /* for quicker update */
681 XNoOp(ourdisplay);
682
683 while (!XCheckMaskEvent(ourdisplay,
684 ButtonReleaseMask, levptr(XEvent))) {
685 waitabit();
686 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
687 &rootx, &rooty, &wx, &wy, &statemask))
688 break; /* on another screen */
689
690 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
691 sleep(1);
692 continue;
693 }
694 XClearWindow(ourdisplay, gwind);
695 qtUpdate();
696 draw_grids();
697 }
698 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
699 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
700 wx = levptr(XButtonReleasedEvent)->x;
701 wy = levptr(XButtonReleasedEvent)->y;
702 moveview(wx, odev.vres-1-wy, movdir, movorb);
703 }
704 dev_flush();
705
706 qtMinNodesiz = oldnodesiz; /* restore quadtree resolution */
707 }
708
709
710 static void
711 getkey( /* get input key */
712 register XKeyPressedEvent *ekey
713 )
714 {
715 Window rootw, childw;
716 int rootx, rooty, wx, wy;
717 unsigned int statemask;
718 int n;
719 char buf[8];
720
721 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
722 if (n != 1)
723 return;
724 switch (buf[0]) {
725 case 'h': /* turn on height motion lock */
726 headlocked = 1;
727 return;
728 case 'H': /* turn off height motion lock */
729 headlocked = 0;
730 return;
731 case 'l': /* retrieve last view */
732 inpresflags |= DFL(DC_LASTVIEW);
733 return;
734 case 'f': /* frame view position */
735 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
736 &rootx, &rooty, &wx, &wy, &statemask))
737 return; /* on another screen */
738 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
739 1.-(wy+.5)/odev.vres);
740 inpresflags |= DFL(DC_FOCUS);
741 return;
742 case 'F': /* unfocus */
743 odev_args[0] = '\0';
744 inpresflags |= DFL(DC_FOCUS);
745 return;
746 case 'p': /* pause computation */
747 inpresflags |= DFL(DC_PAUSE);
748 return;
749 case 'v': /* spit out view */
750 inpresflags |= DFL(DC_GETVIEW);
751 return;
752 case '\n':
753 case '\r': /* resume computation */
754 inpresflags |= DFL(DC_RESUME);
755 return;
756 case CTRL('R'): /* redraw screen */
757 if (ncolors > 0)
758 new_ctab(ncolors);
759 qtRedraw(0, 0, odev.hres, odev.vres);
760 return;
761 case CTRL('L'): /* refresh from server */
762 if (inpresflags & DFL(DC_REDRAW))
763 return;
764 XClearWindow(ourdisplay, gwind);
765 draw_grids();
766 XFlush(ourdisplay);
767 qtCompost(100); /* unload the old tree */
768 if (ncolors > 0)
769 new_ctab(ncolors);
770 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
771 rayqleft = 0; /* hold off update */
772 return;
773 case 'K': /* kill rtrace process(es) */
774 inpresflags |= DFL(DC_KILL);
775 break;
776 case 'R': /* restart rtrace */
777 inpresflags |= DFL(DC_RESTART);
778 break;
779 case 'C': /* clobber holodeck */
780 inpresflags |= DFL(DC_CLOBBER);
781 break;
782 case 'q': /* quit the program */
783 inpresflags |= DFL(DC_QUIT);
784 return;
785 default:
786 XBell(ourdisplay, 0);
787 return;
788 }
789 }
790
791
792 static void
793 fixwindow( /* repair damage to window */
794 register XExposeEvent *eexp
795 )
796 {
797 if (odev.hres == 0 || odev.vres == 0) { /* first exposure */
798 odev.hres = eexp->width;
799 odev.vres = eexp->height;
800 }
801 qtRedraw(eexp->x, odev.vres - eexp->y - eexp->height,
802 eexp->x + eexp->width, odev.vres - eexp->y);
803 }
804
805
806 static void
807 resizewindow( /* resize window */
808 register XConfigureEvent *ersz
809 )
810 {
811 if (ersz->width == odev.hres && ersz->height == odev.vres)
812 return;
813
814 odev.hres = ersz->width;
815 odev.vres = ersz->height;
816
817 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
818 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
819
820 inpresflags |= DFL(DC_SETVIEW);
821 }
