1 |
/* RCSid: $Id$ */ |
2 |
3 |
* Sample data structures for holodeck display drivers. |
4 |
5 |
#include "color.h" |
6 |
#include "tonemap.h" |
7 |
#include "rhdriver.h" |
8 |
#include "object.h" |
9 |
10 |
#ifndef int2 |
11 |
#define int2 short |
12 |
#endif |
13 |
#ifndef int4 |
14 |
#define int4 int |
15 |
#endif |
16 |
17 |
#ifndef INVALID |
18 |
#define INVALID -1 |
19 |
#endif |
20 |
21 |
#define SFLOAT float |
22 |
23 |
typedef OBJECT S_ID; |
24 |
25 |
#define S_ID_MAX ((1 << ((sizeof(S_ID)<<3)-1))-1) |
26 |
27 |
typedef struct samp { |
28 |
SFLOAT (*wp)[3]; /* world intersection point array */ |
29 |
int4 *wd; /* world direction array */ |
30 |
TMbright *brt; /* encoded brightness array */ |
31 |
BYTE (*chr)[3]; /* encoded chrominance array */ |
32 |
BYTE (*rgb)[3]; /* tone-mapped color array */ |
33 |
int *info; /* Extra sample info */ |
34 |
int *info1; /* Extra sample info */ |
35 |
int max_samp; /* maximum number of samples */ |
36 |
int max_base_pt; /* maximum number of aux points */ |
37 |
S_ID next_base_pt; /* next auxilliary point to add */ |
38 |
S_ID replace_samp; /* next sample to free */ |
39 |
int num_samp; /* current number of samples */ |
40 |
S_ID tone_map; /* pointer to next value(s)t tonemap*/ |
41 |
S_ID free_samp; /* next free sample */ |
42 |
char *base; /* base of allocated memory */ |
43 |
} SAMP; |
44 |
45 |
/* Sample field access macros */ |
46 |
#define S_W_PT(s) ((s)->wp) |
47 |
#define S_W_DIR(s) ((s)->wd) |
48 |
#define S_BRT(s) ((s)->brt) |
49 |
#define S_CHR(s) ((s)->chr) |
50 |
#define S_RGB(s) ((s)->rgb) |
51 |
#define S_INFO(s) ((s)->info) |
52 |
#define S_INFO1(s) ((s)->info1) |
53 |
#define S_MAX_SAMP(s) ((s)->max_samp) |
54 |
#define S_MAX_BASE_PT(s) ((s)->max_base_pt) |
55 |
#define S_NEXT_BASE_PT(s) ((s)->next_base_pt) |
56 |
#define S_REPLACE_SAMP(s) ((s)->replace_samp) |
57 |
#define S_NUM_SAMP(s) ((s)->num_samp) |
58 |
#define S_TONE_MAP(s) ((s)->tone_map) |
59 |
#define S_FREE_SAMP(s) ((s)->free_samp) |
60 |
#define S_BASE(s) ((s)->base) |
61 |
62 |
#define S_MAX_POINTS(s) ((s)->max_base_pt) |
63 |
#define S_NTH_W_PT(s,n) (S_W_PT(s)[(n)]) |
64 |
#define S_NTH_W_DIR(s,n) (S_W_DIR(s)[(n)]) |
65 |
#define S_NTH_RGB(s,n) (S_RGB(s)[(n)]) |
66 |
#define S_NTH_CHR(s,n) (S_CHR(s)[(n)]) |
67 |
#define S_NTH_INFO(s,n) (S_INFO(s)[(n)]) |
68 |
#define S_NTH_INFO1(s,n) (S_INFO1(s)[(n)]) |
69 |
#define S_NTH_BRT(s,n) (S_BRT(s)[(n)]) |
70 |
71 |
/* Sample Flag macros */ |
72 |
#define S_IS_FLAG(s) IS_FLAG(samp_flag,s) |
73 |
#define S_SET_FLAG(s) SET_FLAG(samp_flag,s) |
74 |
#define S_CLR_FLAG(s) CLR_FLAG(samp_flag,s) |
75 |
76 |
#define S_NTH_NEXT(s,n) S_NTH_W_DIR(s,n) |
77 |
#define sUnalloc_samp(s,n) (S_NTH_NEXT(s,n)=S_FREE_SAMP(s),S_FREE_SAMP(s)=n) |
78 |
#define sClear_base_points(s) (S_NEXT_BASE_PT(s) = S_MAX_SAMP(s)) |
79 |
#define sClear(s) sInit(s) |
80 |
/* MAXDIFF2 Max allowed cos angle squared of sample dir from current view */ |
81 |
/* In terms of cos: if angle is 30: MAXDIFF2 = cos(30)^2, if difference |
82 |
is greater than this point not accepted on rebuild |
83 |
84 |
#define MAXDIFF2 0.75 |
85 |
/* Max difference in direction for points at infinity: if over 45degrees |
86 |
not accepted on rebuild cos(45) |
87 |
88 |
#define MAXDIR 0.70710678 |
89 |
#define MAXQUALITY 10000 /* Maximum quality for rendering rep */ |
90 |
91 |
extern SAMP rsL; |
92 |
extern double sDepthEps; /* epsilon to compare depths (z fraction) */ |
93 |
extern int4 encodedir(); /* Encodes FVECT direction */ |
94 |
extern void decodedir(); /* Decodes dir-> FVECT */ |
95 |
extern double fdir2diff(), dir2diff(); /* Compare dir and FVECT */ |
96 |
extern int4 *samp_flag; /* Per/sample flags s */ |
97 |
98 |
/* These values are set by the driver, and used in the OGL call for glFrustum*/ |
99 |
extern double dev_zmin,dev_zmax; |
100 |
extern S_ID sAdd_base_point(); |
101 |
extern SAMP *sAlloc(); |
102 |
extern S_ID sAlloc_samp(); |
103 |
104 |
* int |
105 |
* smInit(n) : Initialize/clear data structures for n entries |
106 |
* int n; |
107 |
108 |
* Initialize sampL and other data structures for at least n samples. |
109 |
* If n is 0, then free data structures. Return number actually allocated. |
110 |
111 |
112 |
* int |
113 |
* smNewSamp(c, p, v) : register new sample point and return index |
114 |
* COLR c; : pixel color (RGBE) |
115 |
* FVECT p; : world intersection point |
116 |
* FVECT v; : ray direction vector |
117 |
118 |
* Add new sample point to data structures, removing old values as necessary. |
119 |
* New sample representation will be output in next call to smUpdate(). |
120 |
121 |
122 |
* int |
123 |
* smFindSamp(orig, dir): intersect ray with 3D rep. and find closest sample |
124 |
* FVECT orig, dir; |
125 |
126 |
* Find the closest sample to the given ray. Return -1 on failure. |
127 |
128 |
129 |
* smClean() : display has been wiped clean |
130 |
131 |
* Called after display has been effectively cleared, meaning that all |
132 |
* geometry must be resent down the pipeline in the next call to smUpdate(). |
133 |
134 |
135 |
* smUpdate(vp, qua) : update OpenGL output geometry for view vp |
136 |
* VIEW *vp; : desired view |
137 |
* int qua; : quality level (percentage on linear time scale) |
138 |
139 |
* Draw new geometric representation using OpenGL calls. Assume that the |
140 |
* view has already been set up and the correct frame buffer has been |
141 |
* selected for drawing. The quality level is on a linear scale, where 100% |
142 |
* is full (final) quality. It is not necessary to redraw geometry that has |
143 |
* been output since the last call to smClean(). (The last view drawn will |
144 |
* be vp==&odev.v each time.) |
145 |
146 |
147 |
148 |
149 |
150 |
151 |
