--- ray/src/hd/rhd_sample.h 1998/08/19 17:45:24 3.1 +++ ray/src/hd/rhd_sample.h 2003/06/20 00:25:49 3.9 @@ -1,64 +1,100 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid: $Id: rhd_sample.h,v 3.9 2003/06/20 00:25:49 greg Exp $ */ /* * Sample data structures for holodeck display drivers. + * + * Include after "standard.h" */ #include "color.h" #include "tonemap.h" #include "rhdriver.h" +#include "object.h" -#ifndef int2 -#define int2 short +#ifndef INVALID +#define INVALID -1 #endif -#ifndef int4 -#define int4 int -#endif - /* child ordering */ -typedef struct rsamp { - float (*wp)[3]; /* world intersection point array */ - int4 *wd; /* world direction array */ + +#define SFLOAT float + +typedef OBJECT S_ID; + +#define S_ID_MAX ((1 << ((sizeof(S_ID)<<3)-1))-1) + +typedef struct samp { + SFLOAT (*wp)[3]; /* world intersection point array */ + int32 *wd; /* world direction array */ TMbright *brt; /* encoded brightness array */ BYTE (*chr)[3]; /* encoded chrominance array */ BYTE (*rgb)[3]; /* tone-mapped color array */ + int *info; /* Extra sample info */ + int *info1; /* Extra sample info */ int max_samp; /* maximum number of samples */ - int max_aux_pt; /* maximum number of aux points */ - int next_aux_pt; /* next auxilliary point to add */ - int replace_samp; /* next sample to free */ - int num_samp; /* reached end of list? */ - int tone_map; /* pointer to next value(s) to tonemap*/ - int free_samp; /* list of freed samples */ + int max_base_pt; /* maximum number of aux points */ + S_ID next_base_pt; /* next auxilliary point to add */ + S_ID replace_samp; /* next sample to free */ + int num_samp; /* current number of samples */ + S_ID tone_map; /* pointer to next value(s)t tonemap*/ + S_ID free_samp; /* next free sample */ char *base; /* base of allocated memory */ -} RSAMP; +} SAMP; -#define RS_W_PT(s) ((s)->wp) -#define RS_W_DIR(s) ((s)->wd) -#define RS_BRT(s) ((s)->brt) -#define RS_CHR(s) ((s)->chr) -#define RS_RGB(s) ((s)->rgb) -#define RS_MAX_SAMP(s) ((s)->max_samp) -#define RS_TONE_MAP(s) ((s)->tone_map) -#define RS_MAX_POINTS(s) ((s)->max_aux_pt) -#define RS_REPLACE_SAMP(s) ((s)->replace_samp) -#define RS_NEXT_AUX_PT(s) ((s)->next_aux_pt) -#define RS_MAX_AUX_PT(s) ((s)->max_aux_pt) -#define RS_BASE(s) ((s)->base) -#define RS_NUM_SAMP(s) ((s)->num_samp) -#define RS_FREE_SAMP(s) ((s)->free_samp) -#define RS_NTH_W_PT(s,n) (RS_W_PT(s)[(n)]) -#define RS_NTH_W_DIR(s,n) (RS_W_DIR(s)[(n)]) -#define RS_NTH_RGB(s,n) (RS_RGB(s)[(n)]) -#define RS_NTH_CHR(s,n) (RS_CHR(s)[(n)]) -#define RS_NTH_BRT(s,n) (RS_BRT(s)[(n)]) -#define RS_EOL(s) (RS_NUM_SAMP(s) >= RS_MAX_SAMP(s)) -extern RSAMP rsL; +/* Sample field access macros */ +#define S_W_PT(s) ((s)->wp) +#define S_W_DIR(s) ((s)->wd) +#define S_BRT(s) ((s)->brt) +#define S_CHR(s) ((s)->chr) +#define S_RGB(s) ((s)->rgb) +#define S_INFO(s) ((s)->info) +#define S_INFO1(s) ((s)->info1) +#define S_MAX_SAMP(s) ((s)->max_samp) +#define S_MAX_BASE_PT(s) ((s)->max_base_pt) +#define S_NEXT_BASE_PT(s) ((s)->next_base_pt) +#define S_REPLACE_SAMP(s) ((s)->replace_samp) +#define S_NUM_SAMP(s) ((s)->num_samp) +#define S_TONE_MAP(s) ((s)->tone_map) +#define S_FREE_SAMP(s) ((s)->free_samp) +#define S_BASE(s) ((s)->base) -extern double rsDepthEps; /* epsilon to compare depths (z fraction) */ +#define S_MAX_POINTS(s) ((s)->max_base_pt) +#define S_NTH_W_PT(s,n) (S_W_PT(s)[(n)]) +#define S_NTH_W_DIR(s,n) (S_W_DIR(s)[(n)]) +#define S_NTH_RGB(s,n) (S_RGB(s)[(n)]) +#define S_NTH_CHR(s,n) (S_CHR(s)[(n)]) +#define S_NTH_INFO(s,n) (S_INFO(s)[(n)]) +#define S_NTH_INFO1(s,n) (S_INFO1(s)[(n)]) +#define S_NTH_BRT(s,n) (S_BRT(s)[(n)]) -extern int4 encodedir(); -extern double fdir2diff(), dir2diff(); -extern void decodedir(); +/* Sample Flag macros */ +#define S_IS_FLAG(s) IS_FLAG(samp_flag,s) +#define S_SET_FLAG(s) SET_FLAG(samp_flag,s) +#define S_CLR_FLAG(s) CLR_FLAG(samp_flag,s) + +#define S_NTH_NEXT(s,n) S_NTH_W_DIR(s,n) +#define sUnalloc_samp(s,n) (S_NTH_NEXT(s,n)=S_FREE_SAMP(s),S_FREE_SAMP(s)=n) +#define sClear_base_points(s) (S_NEXT_BASE_PT(s) = S_MAX_SAMP(s)) +#define sClear(s) sInit(s) +/* MAXDIFF2 Max allowed cos angle squared of sample dir from current view */ +/* In terms of cos: if angle is 30: MAXDIFF2 = cos(30)^2, if difference + is greater than this point not accepted on rebuild + */ +#define MAXDIFF2 0.75 +/* Max difference in direction for points at infinity: if over 45degrees + not accepted on rebuild cos(45) + */ +#define MAXDIR 0.70710678 +#define MAXQUALITY 10000 /* Maximum quality for rendering rep */ + +extern SAMP rsL; +extern double sDepthEps; /* epsilon to compare depths (z fraction) */ +extern int32 encodedir(); /* Encodes FVECT direction */ +extern void decodedir(); /* Decodes dir-> FVECT */ +extern double fdir2diff(), dir2diff(); /* Compare dir and FVECT */ +extern int32 *samp_flag; /* Per/sample flags s */ + +/* These values are set by the driver, and used in the OGL call for glFrustum*/ +extern double dev_zmin,dev_zmax; +extern S_ID sAdd_base_point(); +extern SAMP *sAlloc(); +extern S_ID sAlloc_samp(); /* * int * smInit(n) : Initialize/clear data structures for n entries @@ -99,12 +135,9 @@ extern void decodedir(); * view has already been set up and the correct frame buffer has been * selected for drawing. The quality level is on a linear scale, where 100% * is full (final) quality. It is not necessary to redraw geometry that has - * been output since the last call to smClean(). + * been output since the last call to smClean(). (The last view drawn will + * be vp==&odev.v each time.) */ - -/* These values are set by the driver, and used in the OGL call for glFrustum*/ -extern double dev_zmin,dev_zmax; -
