| 1 |
schorsch |
3.10 |
/* RCSid: $Id: rhd_sample.h,v 3.9 2003/06/20 00:25:49 greg Exp $ */
| 2 |
gwlarson |
3.1 |
| 3 |
* Sample data structures for holodeck display drivers.
| 4 |
greg |
3.9 |
| 5 |
* Include after "standard.h"
| 6 |
gwlarson |
3.1 |
| 7 |
schorsch |
3.10 |
#ifndef _RAD_RHD_SAMPLE_H_
| 8 |
#define _RAD_RHD_SAMPLE_H_
| 9 |
| 10 |
gwlarson |
3.1 |
#include "color.h"
| 11 |
#include "tonemap.h"
| 12 |
#include "rhdriver.h"
| 13 |
greg |
3.8 |
#include "object.h"
| 14 |
gwlarson |
3.1 |
| 15 |
schorsch |
3.10 |
#ifdef __cplusplus
| 16 |
extern "C" {
| 17 |
#endif
| 18 |
| 19 |
gwlarson |
3.3 |
#ifndef INVALID
| 20 |
#define INVALID -1
| 21 |
#endif
| 22 |
| 23 |
simmons |
3.7 |
#define SFLOAT float
| 24 |
greg |
3.8 |
| 25 |
typedef OBJECT S_ID;
| 26 |
| 27 |
#define S_ID_MAX ((1 << ((sizeof(S_ID)<<3)-1))-1)
| 28 |
gwlarson |
3.6 |
| 29 |
gwlarson |
3.3 |
typedef struct samp {
| 30 |
simmons |
3.7 |
SFLOAT (*wp)[3]; /* world intersection point array */
| 31 |
greg |
3.9 |
int32 *wd; /* world direction array */
| 32 |
gwlarson |
3.1 |
TMbright *brt; /* encoded brightness array */
| 33 |
BYTE (*chr)[3]; /* encoded chrominance array */
| 34 |
BYTE (*rgb)[3]; /* tone-mapped color array */
| 35 |
gwlarson |
3.6 |
int *info; /* Extra sample info */
| 36 |
greg |
3.8 |
int *info1; /* Extra sample info */
| 37 |
gwlarson |
3.1 |
int max_samp; /* maximum number of samples */
| 38 |
greg |
3.8 |
int max_base_pt; /* maximum number of aux points */
| 39 |
S_ID next_base_pt; /* next auxilliary point to add */
| 40 |
S_ID replace_samp; /* next sample to free */
| 41 |
gwlarson |
3.3 |
int num_samp; /* current number of samples */
| 42 |
greg |
3.8 |
S_ID tone_map; /* pointer to next value(s)t tonemap*/
| 43 |
S_ID free_samp; /* next free sample */
| 44 |
gwlarson |
3.1 |
char *base; /* base of allocated memory */
| 45 |
gwlarson |
3.3 |
} SAMP;
| 46 |
gwlarson |
3.1 |
| 47 |
gwlarson |
3.3 |
/* Sample field access macros */
| 48 |
#define S_W_PT(s) ((s)->wp)
| 49 |
#define S_W_DIR(s) ((s)->wd)
| 50 |
#define S_BRT(s) ((s)->brt)
| 51 |
#define S_CHR(s) ((s)->chr)
| 52 |
#define S_RGB(s) ((s)->rgb)
| 53 |
gwlarson |
3.6 |
#define S_INFO(s) ((s)->info)
| 54 |
greg |
3.8 |
#define S_INFO1(s) ((s)->info1)
| 55 |
gwlarson |
3.3 |
#define S_MAX_SAMP(s) ((s)->max_samp)
| 56 |
#define S_MAX_BASE_PT(s) ((s)->max_base_pt)
| 57 |
#define S_NEXT_BASE_PT(s) ((s)->next_base_pt)
| 58 |
#define S_REPLACE_SAMP(s) ((s)->replace_samp)
| 59 |
#define S_NUM_SAMP(s) ((s)->num_samp)
| 60 |
#define S_TONE_MAP(s) ((s)->tone_map)
| 61 |
gwlarson |
3.6 |
#define S_FREE_SAMP(s) ((s)->free_samp)
| 62 |
gwlarson |
3.3 |
#define S_BASE(s) ((s)->base)
| 63 |
gwlarson |
3.1 |
| 64 |
gwlarson |
3.3 |
#define S_MAX_POINTS(s) ((s)->max_base_pt)
| 65 |
#define S_NTH_W_PT(s,n) (S_W_PT(s)[(n)])
| 66 |
#define S_NTH_W_DIR(s,n) (S_W_DIR(s)[(n)])
| 67 |
#define S_NTH_RGB(s,n) (S_RGB(s)[(n)])
| 68 |
#define S_NTH_CHR(s,n) (S_CHR(s)[(n)])
| 69 |
gwlarson |
3.6 |
#define S_NTH_INFO(s,n) (S_INFO(s)[(n)])
| 70 |
greg |
3.8 |
#define S_NTH_INFO1(s,n) (S_INFO1(s)[(n)])
| 71 |
gwlarson |
3.3 |
#define S_NTH_BRT(s,n) (S_BRT(s)[(n)])
| 72 |
gwlarson |
3.6 |
| 73 |
gwlarson |
3.3 |
/* Sample Flag macros */
| 74 |
#define S_IS_FLAG(s) IS_FLAG(samp_flag,s)
| 75 |
#define S_SET_FLAG(s) SET_FLAG(samp_flag,s)
| 76 |
#define S_CLR_FLAG(s) CLR_FLAG(samp_flag,s)
| 77 |
gwlarson |
3.1 |
| 78 |
gwlarson |
3.4 |
#define S_NTH_NEXT(s,n) S_NTH_W_DIR(s,n)
| 79 |
gwlarson |
3.6 |
#define sUnalloc_samp(s,n) (S_NTH_NEXT(s,n)=S_FREE_SAMP(s),S_FREE_SAMP(s)=n)
| 80 |
gwlarson |
3.3 |
#define sClear_base_points(s) (S_NEXT_BASE_PT(s) = S_MAX_SAMP(s))
| 81 |
#define sClear(s) sInit(s)
| 82 |
gwlarson |
3.6 |
/* MAXDIFF2 Max allowed cos angle squared of sample dir from current view */
| 83 |
/* In terms of cos: if angle is 30: MAXDIFF2 = cos(30)^2, if difference
| 84 |
is greater than this point not accepted on rebuild
| 85 |
| 86 |
#define MAXDIFF2 0.75
| 87 |
/* Max difference in direction for points at infinity: if over 45degrees
| 88 |
not accepted on rebuild cos(45)
| 89 |
| 90 |
#define MAXDIR 0.70710678
| 91 |
gwlarson |
3.5 |
#define MAXQUALITY 10000 /* Maximum quality for rendering rep */
| 92 |
gwlarson |
3.1 |
| 93 |
gwlarson |
3.3 |
extern SAMP rsL;
| 94 |
extern double sDepthEps; /* epsilon to compare depths (z fraction) */
| 95 |
greg |
3.9 |
extern int32 encodedir(); /* Encodes FVECT direction */
| 96 |
gwlarson |
3.3 |
extern void decodedir(); /* Decodes dir-> FVECT */
| 97 |
extern double fdir2diff(), dir2diff(); /* Compare dir and FVECT */
| 98 |
greg |
3.9 |
extern int32 *samp_flag; /* Per/sample flags s */
| 99 |
gwlarson |
3.3 |
| 100 |
gwlarson |
3.1 |
/* These values are set by the driver, and used in the OGL call for glFrustum*/
| 101 |
extern double dev_zmin,dev_zmax;
| 102 |
greg |
3.8 |
extern S_ID sAdd_base_point();
| 103 |
gwlarson |
3.3 |
extern SAMP *sAlloc();
| 104 |
greg |
3.8 |
extern S_ID sAlloc_samp();
| 105 |
| 106 |
* int
| 107 |
* smInit(n) : Initialize/clear data structures for n entries
| 108 |
* int n;
| 109 |
| 110 |
* Initialize sampL and other data structures for at least n samples.
| 111 |
* If n is 0, then free data structures. Return number actually allocated.
| 112 |
| 113 |
| 114 |
* int
| 115 |
* smNewSamp(c, p, v) : register new sample point and return index
| 116 |
* COLR c; : pixel color (RGBE)
| 117 |
* FVECT p; : world intersection point
| 118 |
* FVECT v; : ray direction vector
| 119 |
| 120 |
* Add new sample point to data structures, removing old values as necessary.
| 121 |
* New sample representation will be output in next call to smUpdate().
| 122 |
| 123 |
| 124 |
* int
| 125 |
* smFindSamp(orig, dir): intersect ray with 3D rep. and find closest sample
| 126 |
* FVECT orig, dir;
| 127 |
| 128 |
* Find the closest sample to the given ray. Return -1 on failure.
| 129 |
| 130 |
| 131 |
* smClean() : display has been wiped clean
| 132 |
| 133 |
* Called after display has been effectively cleared, meaning that all
| 134 |
* geometry must be resent down the pipeline in the next call to smUpdate().
| 135 |
| 136 |
| 137 |
* smUpdate(vp, qua) : update OpenGL output geometry for view vp
| 138 |
* VIEW *vp; : desired view
| 139 |
* int qua; : quality level (percentage on linear time scale)
| 140 |
| 141 |
* Draw new geometric representation using OpenGL calls. Assume that the
| 142 |
* view has already been set up and the correct frame buffer has been
| 143 |
* selected for drawing. The quality level is on a linear scale, where 100%
| 144 |
* is full (final) quality. It is not necessary to redraw geometry that has
| 145 |
* been output since the last call to smClean(). (The last view drawn will
| 146 |
* be vp==&odev.v each time.)
| 147 |
| 148 |
gwlarson |
3.1 |
| 149 |
| 150 |
schorsch |
3.10 |
#ifdef __cplusplus
| 151 |
| 152 |
#endif
| 153 |
#endif /* _RAD_RHD_SAMPLE_H_ */
| 154 |
gwlarson |
3.1 |
| 155 |
| 156 |
