1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* Sample data structures for holodeck display drivers. |
7 |
8 |
#include "color.h" |
9 |
#include "tonemap.h" |
10 |
#include "rhdriver.h" |
11 |
12 |
#ifndef int2 |
13 |
#define int2 short |
14 |
#endif |
15 |
#ifndef int4 |
16 |
#define int4 int |
17 |
#endif |
18 |
/* child ordering */ |
19 |
typedef struct rsamp { |
20 |
float (*wp)[3]; /* world intersection point array */ |
21 |
int4 *wd; /* world direction array */ |
22 |
TMbright *brt; /* encoded brightness array */ |
23 |
BYTE (*chr)[3]; /* encoded chrominance array */ |
24 |
BYTE (*rgb)[3]; /* tone-mapped color array */ |
25 |
int max_samp; /* maximum number of samples */ |
26 |
int max_aux_pt; /* maximum number of aux points */ |
27 |
int next_aux_pt; /* next auxilliary point to add */ |
28 |
int replace_samp; /* next sample to free */ |
29 |
int num_samp; /* reached end of list? */ |
30 |
int tone_map; /* pointer to next value(s) to tonemap*/ |
31 |
int free_samp; /* list of freed samples */ |
32 |
char *base; /* base of allocated memory */ |
33 |
} RSAMP; |
34 |
35 |
#define RS_W_PT(s) ((s)->wp) |
36 |
#define RS_W_DIR(s) ((s)->wd) |
37 |
#define RS_BRT(s) ((s)->brt) |
38 |
#define RS_CHR(s) ((s)->chr) |
39 |
#define RS_RGB(s) ((s)->rgb) |
40 |
#define RS_MAX_SAMP(s) ((s)->max_samp) |
41 |
#define RS_TONE_MAP(s) ((s)->tone_map) |
42 |
#define RS_MAX_POINTS(s) ((s)->max_aux_pt) |
43 |
#define RS_REPLACE_SAMP(s) ((s)->replace_samp) |
44 |
#define RS_NEXT_AUX_PT(s) ((s)->next_aux_pt) |
45 |
#define RS_MAX_AUX_PT(s) ((s)->max_aux_pt) |
46 |
#define RS_BASE(s) ((s)->base) |
47 |
#define RS_NUM_SAMP(s) ((s)->num_samp) |
48 |
#define RS_FREE_SAMP(s) ((s)->free_samp) |
49 |
#define RS_NTH_W_PT(s,n) (RS_W_PT(s)[(n)]) |
50 |
#define RS_NTH_W_DIR(s,n) (RS_W_DIR(s)[(n)]) |
51 |
#define RS_NTH_RGB(s,n) (RS_RGB(s)[(n)]) |
52 |
#define RS_NTH_CHR(s,n) (RS_CHR(s)[(n)]) |
53 |
#define RS_NTH_BRT(s,n) (RS_BRT(s)[(n)]) |
54 |
#define RS_EOL(s) (RS_NUM_SAMP(s) >= RS_MAX_SAMP(s)) |
55 |
extern RSAMP rsL; |
56 |
57 |
extern double rsDepthEps; /* epsilon to compare depths (z fraction) */ |
58 |
59 |
extern int4 encodedir(); |
60 |
extern double fdir2diff(), dir2diff(); |
61 |
extern void decodedir(); |
62 |
63 |
* int |
64 |
* smInit(n) : Initialize/clear data structures for n entries |
65 |
* int n; |
66 |
67 |
* Initialize sampL and other data structures for at least n samples. |
68 |
* If n is 0, then free data structures. Return number actually allocated. |
69 |
70 |
71 |
* int |
72 |
* smNewSamp(c, p, v) : register new sample point and return index |
73 |
* COLR c; : pixel color (RGBE) |
74 |
* FVECT p; : world intersection point |
75 |
* FVECT v; : ray direction vector |
76 |
77 |
* Add new sample point to data structures, removing old values as necessary. |
78 |
* New sample representation will be output in next call to smUpdate(). |
79 |
80 |
81 |
* int |
82 |
* smFindSamp(orig, dir): intersect ray with 3D rep. and find closest sample |
83 |
* FVECT orig, dir; |
84 |
85 |
* Find the closest sample to the given ray. Return -1 on failure. |
86 |
87 |
88 |
* smClean() : display has been wiped clean |
89 |
90 |
* Called after display has been effectively cleared, meaning that all |
91 |
* geometry must be resent down the pipeline in the next call to smUpdate(). |
92 |
93 |
94 |
* smUpdate(vp, qua) : update OpenGL output geometry for view vp |
95 |
* VIEW *vp; : desired view |
96 |
* int qua; : quality level (percentage on linear time scale) |
97 |
98 |
* Draw new geometric representation using OpenGL calls. Assume that the |
99 |
* view has already been set up and the correct frame buffer has been |
100 |
* selected for drawing. The quality level is on a linear scale, where 100% |
101 |
* is full (final) quality. It is not necessary to redraw geometry that has |
102 |
* been output since the last call to smClean(). |
103 |
104 |
105 |
/* These values are set by the driver, and used in the OGL call for glFrustum*/ |
106 |
extern double dev_zmin,dev_zmax; |
107 |
108 |
109 |
110 |
111 |
112 |
113 |
