root/radiance/ray/src/hd/rhd_sample.h
Revision: 3.2
Committed: Fri Sep 11 11:52:25 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.1: +2 -1 lines
fixed triangle insertion using edge tracing
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Sample data structures for holodeck display drivers.
7 */
8 #include "color.h"
9 #include "tonemap.h"
10 #include "rhdriver.h"
11
12 #ifndef int2
13 #define int2 short
14 #endif
15 #ifndef int4
16 #define int4 int
17 #endif
18 /* child ordering */
19 typedef struct rsamp {
20 float (*wp)[3]; /* world intersection point array */
21 int4 *wd; /* world direction array */
22 TMbright *brt; /* encoded brightness array */
23 BYTE (*chr)[3]; /* encoded chrominance array */
24 BYTE (*rgb)[3]; /* tone-mapped color array */
25 int max_samp; /* maximum number of samples */
26 int max_aux_pt; /* maximum number of aux points */
27 int next_aux_pt; /* next auxilliary point to add */
28 int replace_samp; /* next sample to free */
29 int num_samp; /* reached end of list? */
30 int tone_map; /* pointer to next value(s) to tonemap*/
31 int free_samp; /* list of freed samples */
32 char *base; /* base of allocated memory */
33 } RSAMP;
34
35 #define RS_W_PT(s) ((s)->wp)
36 #define RS_W_DIR(s) ((s)->wd)
37 #define RS_BRT(s) ((s)->brt)
38 #define RS_CHR(s) ((s)->chr)
39 #define RS_RGB(s) ((s)->rgb)
40 #define RS_MAX_SAMP(s) ((s)->max_samp)
41 #define RS_TONE_MAP(s) ((s)->tone_map)
42 #define RS_MAX_POINTS(s) ((s)->max_aux_pt)
43 #define RS_REPLACE_SAMP(s) ((s)->replace_samp)
44 #define RS_NEXT_AUX_PT(s) ((s)->next_aux_pt)
45 #define RS_MAX_AUX_PT(s) ((s)->max_aux_pt)
46 #define RS_BASE(s) ((s)->base)
47 #define RS_NUM_SAMP(s) ((s)->num_samp)
48 #define RS_FREE_SAMP(s) ((s)->free_samp)
49 #define RS_NTH_W_PT(s,n) (RS_W_PT(s)[(n)])
50 #define RS_NTH_W_DIR(s,n) (RS_W_DIR(s)[(n)])
51 #define RS_NTH_RGB(s,n) (RS_RGB(s)[(n)])
52 #define RS_NTH_CHR(s,n) (RS_CHR(s)[(n)])
53 #define RS_NTH_BRT(s,n) (RS_BRT(s)[(n)])
54 #define RS_EOL(s) (RS_NUM_SAMP(s) >= RS_MAX_SAMP(s))
55 extern RSAMP rsL;
56
57 extern double rsDepthEps; /* epsilon to compare depths (z fraction) */
58
59 extern int4 encodedir();
60 extern double fdir2diff(), dir2diff();
61 extern void decodedir();
62 /*
63 * int
64 * smInit(n) : Initialize/clear data structures for n entries
65 * int n;
66 *
67 * Initialize sampL and other data structures for at least n samples.
68 * If n is 0, then free data structures. Return number actually allocated.
69 *
70 *
71 * int
72 * smNewSamp(c, p, v) : register new sample point and return index
73 * COLR c; : pixel color (RGBE)
74 * FVECT p; : world intersection point
75 * FVECT v; : ray direction vector
76 *
77 * Add new sample point to data structures, removing old values as necessary.
78 * New sample representation will be output in next call to smUpdate().
79 *
80 *
81 * int
82 * smFindSamp(orig, dir): intersect ray with 3D rep. and find closest sample
83 * FVECT orig, dir;
84 *
85 * Find the closest sample to the given ray. Return -1 on failure.
86 *
87 *
88 * smClean() : display has been wiped clean
89 *
90 * Called after display has been effectively cleared, meaning that all
91 * geometry must be resent down the pipeline in the next call to smUpdate().
92 *
93 *
94 * smUpdate(vp, qua) : update OpenGL output geometry for view vp
95 * VIEW *vp; : desired view
96 * int qua; : quality level (percentage on linear time scale)
97 *
98 * Draw new geometric representation using OpenGL calls. Assume that the
99 * view has already been set up and the correct frame buffer has been
100 * selected for drawing. The quality level is on a linear scale, where 100%
101 * is full (final) quality. It is not necessary to redraw geometry that has
102 * been output since the last call to smClean(). (The last view drawn will
103 * be vp==&odev.v each time.)
104 */
105
106 /* These values are set by the driver, and used in the OGL call for glFrustum*/
107 extern double dev_zmin,dev_zmax;
108
109
110
111
112
113
114
