root/radiance/ray/src/hd/rhd_qtree2r.c
Revision: 3.8
Committed: Fri Oct 5 19:19:16 2018 UTC (5 years, 6 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Changes since 3.7: +9 -9 lines
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: rhd_qtree2r.c,v 3.7 2011/05/20 02:06:39 greg Exp $";
5 * Quadtree display support routines for rectangle output.
6 */
7
8 #include "standard.h"
9 #include "rhd_qtree.h"
10
11
12 static void redraw(RTREE *tp, int x0, int y0, int x1, int y1, int l[2][2]);
13 static void update( uby8 ca[3], RTREE *tp, int x0, int y0, int x1, int y1);
14
15
16 static void
17 redraw( /* mark portion of a tree for redraw */
18 RTREE *tp,
19 int x0,
20 int y0,
21 int x1,
22 int y1,
23 int l[2][2]
24 )
25 {
26 int quads = CH_ANY;
27 int mx, my;
28 int i;
29 /* compute midpoint */
30 mx = (x0 + x1) >> 1;
31 my = (y0 + y1) >> 1;
32 /* see what to do */
33 if (l[0][0] > mx)
34 quads &= ~(CHF(UL)|CHF(DL));
35 else if (l[0][1] < mx)
36 quads &= ~(CHF(UR)|CHF(DR));
37 if (l[1][0] > my)
38 quads &= ~(CHF(DR)|CHF(DL));
39 else if (l[1][1] < my)
40 quads &= ~(CHF(UR)|CHF(UL));
41 tp->flgs |= quads; /* mark quadrants for update */
42 /* climb the branches */
43 for (i = 0; i < 4; i++)
44 if (tp->flgs & BRF(i) && quads & CHF(i))
45 redraw(tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
46 i&01 ? x1 : mx, i&02 ? y1 : my, l);
47 }
48
49
50 static void
51 update( /* update tree display as needed */
52 uby8 ca[3], /* returned average color */
53 RTREE *tp,
54 int x0,
55 int y0,
56 int x1,
57 int y1
58 )
59 {
60 int csm[3], nc;
61 uby8 *cp;
62 uby8 rgb[3];
63 double dpth2[4], d2;
64 int gaps = 0;
65 int mx, my;
66 int i;
67 /* compute leaf depths */
68 d2 = FHUGE*FHUGE;
69 for (i = 0; i < 4; i++)
70 if (tp->flgs & LFF(i)) {
71 FVECT dv;
72 float *wp = qtL.wp[tp->k[i].li];
73
74 dv[0] = wp[0] - odev.v.vp[0];
75 dv[1] = wp[1] - odev.v.vp[1];
76 dv[2] = wp[2] - odev.v.vp[2];
77 dpth2[i] = DOT(dv,dv);
78 if (dpth2[i] < d2)
79 d2 = dpth2[i];
80 }
81 d2 *= (1.+qtDepthEps)*(1.+qtDepthEps);
82 /* compute midpoint */
83 mx = (x0 + x1) >> 1;
84 my = (y0 + y1) >> 1;
85 /* draw leaves */
86 csm[0] = csm[1] = csm[2] = nc = 0;
87 for (i = 0; i < 4; i++) {
88 if (tp->flgs & LFF(i) && dpth2[i] <= d2) {
89 cp = qtL.rgb[tp->k[i].li];
90 csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
91 nc++;
92 if (tp->flgs & CHF(i))
93 dev_paintr(cp, i&01 ? mx : x0, i&02 ? my : y0,
94 i&01 ? x1 : mx, i&02 ? y1 : my);
95 } else if ((tp->flgs & CHBRF(i)) == CHF(i))
96 gaps |= 1<<i; /* empty stem */
97 }
98 /* do branches */
99 for (i = 0; i < 4; i++)
100 if ((tp->flgs & CHBRF(i)) == CHBRF(i)) {
101 update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
102 i&01 ? x1 : mx, i&02 ? y1 : my);
103 csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
104 nc++;
105 }
106 if (nc > 1) {
107 ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
108 } else {
109 ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
110 }
111 /* fill in gaps with average */
112 for (i = 0; gaps && i < 4; gaps >>= 1, i++)
113 if (gaps & 01)
114 dev_paintr(ca, i&01 ? mx : x0, i&02 ? my : y0,
115 i&01 ? x1 : mx, i&02 ? y1 : my);
116 tp->flgs &= ~CH_ANY; /* all done */
117 }
118
119
120 void
121 qtRedraw( /* redraw part or all of our screen */
122 int x0,
123 int y0,
124 int x1,
125 int y1
126 )
127 {
128 int lim[2][2];
129
130 if (is_stump(&qtrunk))
131 return;
132 if (!qtMapLeaves(((lim[0][0]=x0) <= 0) & ((lim[1][0]=y0) <= 0) &
133 ((lim[0][1]=x1) >= odev.hres-1) & ((lim[1][1]=y1) >= odev.vres-1)))
134 return;
135 redraw(&qtrunk, 0, 0, odev.hres, odev.vres, lim);
136 }
137
138
139 void
140 qtUpdate(void) /* update our tree display */
141 {
142 uby8 ca[3];
143
144 if (is_stump(&qtrunk))
145 return;
146 if (!qtMapLeaves(0))
147 return;
148 update(ca, &qtrunk, 0, 0, odev.hres, odev.vres);
149 }
