root/radiance/ray/src/hd/rhd_qtree2r.c
Revision: 3.4
Committed: Sat Feb 22 02:07:24 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.3: +1 -4 lines
5 * Quadtree display support routines for rectangle output.
6 */
7
8 #include "standard.h"
9 #include "rhd_qtree.h"
10
11
12 static
13 redraw(tp, x0, y0, x1, y1, l) /* mark portion of a tree for redraw */
14 register RTREE *tp;
15 int x0, y0, x1, y1;
16 int l[2][2];
17 {
18 int quads = CH_ANY;
19 int mx, my;
20 register int i;
21 /* compute midpoint */
22 mx = (x0 + x1) >> 1;
23 my = (y0 + y1) >> 1;
24 /* see what to do */
25 if (l[0][0] > mx)
26 quads &= ~(CHF(UL)|CHF(DL));
27 else if (l[0][1] < mx)
28 quads &= ~(CHF(UR)|CHF(DR));
29 if (l[1][0] > my)
30 quads &= ~(CHF(DR)|CHF(DL));
31 else if (l[1][1] < my)
32 quads &= ~(CHF(UR)|CHF(UL));
33 tp->flgs |= quads; /* mark quadrants for update */
34 /* climb the branches */
35 for (i = 0; i < 4; i++)
36 if (tp->flgs & BRF(i) && quads & CHF(i))
37 redraw(tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
38 i&01 ? x1 : mx, i&02 ? y1 : my, l);
39 }
40
41
42 static
43 update(ca, tp, x0, y0, x1, y1) /* update tree display as needed */
44 BYTE ca[3]; /* returned average color */
45 register RTREE *tp;
46 int x0, y0, x1, y1;
47 {
48 int csm[3], nc;
49 register BYTE *cp;
50 BYTE rgb[3];
51 double dpth2[4], d2;
52 int gaps = 0;
53 int mx, my;
54 register int i;
55 /* compute leaf depths */
56 d2 = FHUGE*FHUGE;
57 for (i = 0; i < 4; i++)
58 if (tp->flgs & LFF(i)) {
59 FVECT dv;
60 register float *wp = qtL.wp[tp->k[i].li];
61
62 dv[0] = wp[0] - odev.v.vp[0];
63 dv[1] = wp[1] - odev.v.vp[1];
64 dv[2] = wp[2] - odev.v.vp[2];
65 dpth2[i] = DOT(dv,dv);
66 if (dpth2[i] < d2)
67 d2 = dpth2[i];
68 }
69 d2 *= (1.+qtDepthEps)*(1.+qtDepthEps);
70 /* compute midpoint */
71 mx = (x0 + x1) >> 1;
72 my = (y0 + y1) >> 1;
73 /* draw leaves */
74 csm[0] = csm[1] = csm[2] = nc = 0;
75 for (i = 0; i < 4; i++) {
76 if (tp->flgs & LFF(i) && dpth2[i] <= d2) {
77 cp = qtL.rgb[tp->k[i].li];
78 csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
79 nc++;
80 if (tp->flgs & CHF(i))
81 dev_paintr(cp, i&01 ? mx : x0, i&02 ? my : y0,
82 i&01 ? x1 : mx, i&02 ? y1 : my);
83 } else if ((tp->flgs & CHBRF(i)) == CHF(i))
84 gaps |= 1<<i; /* empty stem */
85 }
86 /* do branches */
87 for (i = 0; i < 4; i++)
88 if ((tp->flgs & CHBRF(i)) == CHBRF(i)) {
89 update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
90 i&01 ? x1 : mx, i&02 ? y1 : my);
91 csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
92 nc++;
93 }
94 if (nc > 1) {
95 ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
96 } else {
97 ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
98 }
99 /* fill in gaps with average */
100 for (i = 0; gaps && i < 4; gaps >>= 1, i++)
101 if (gaps & 01)
102 dev_paintr(ca, i&01 ? mx : x0, i&02 ? my : y0,
103 i&01 ? x1 : mx, i&02 ? y1 : my);
104 tp->flgs &= ~CH_ANY; /* all done */
105 }
106
107
108 qtRedraw(x0, y0, x1, y1) /* redraw part or all of our screen */
109 int x0, y0, x1, y1;
110 {
111 int lim[2][2];
112
113 if (is_stump(&qtrunk))
114 return;
115 if (!qtMapLeaves((lim[0][0]=x0) <= 0 & (lim[1][0]=y0) <= 0 &
116 (lim[0][1]=x1) >= odev.hres-1 & (lim[1][1]=y1) >= odev.vres-1))
117 return;
118 redraw(&qtrunk, 0, 0, odev.hres, odev.vres, lim);
119 }
120
121
122 qtUpdate() /* update our tree display */
123 {
124 BYTE ca[3];
125
126 if (is_stump(&qtrunk))
127 return;
128 if (!qtMapLeaves(0))
129 return;
130 update(ca, &qtrunk, 0, 0, odev.hres, odev.vres);
131 }
