root/radiance/ray/src/hd/rhd_qtree2r.c
Fri May 20 02:06:39 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.6: +6 -6 lines
Diff to previous 3.6 , to selected 3.2
Thu Jan 1 11:21:55 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.5: +32 -14 lines
Diff to previous 3.5 , to selected 3.2
Ansification and prototypes.
Sun Jul 27 22:12:02 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.4: +3 -3 lines
Diff to previous 3.4 , to selected 3.2
Sat Feb 22 02:07:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.3: +1 -4 lines
Diff to previous 3.3 , to selected 3.2
Wed Nov 26 20:13:10 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.2: +4 -4 lines
Diff to previous 3.2
changed to using macros in redraw()
Revision 3.2 - (view) (download) (annotate) - [selected]
Tue Nov 25 17:33:02 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.1: +21 -5 lines
Diff to previous 3.1
added depth comparison to mitigate occlusion errors
Tue Nov 25 16:51:41 1997 UTC (27 years, 5 months ago) by gregl
Diff to selected 3.2
