root/Development/ray/src/hd/rhd_qtree2c.c
Revision: 3.5
Committed: Fri Oct 5 19:19:16 2018 UTC (7 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Changes since 3.4: +9 -9 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.5 static const char RCSid[] = "$Id: rhd_qtree2c.c,v 3.4 2011/05/20 02:06:39 greg Exp $";
3 gregl 3.1 #endif
4     /*
5     * Quadtree display support routines for cone output.
6     */
7
8     #include "standard.h"
9     #include "rhd_qtree.h"
10
11 schorsch 3.3 static void redraw(RTREE *tp, int x0, int y0, int x1, int y1, int l[2][2]);
12 greg 3.4 static void cpaint(uby8 rgb[3], float *p, int x0, int y0, int x1, int y1);
13     static void update(uby8 ca[3], RTREE *tp, int x0, int y0, int x1, int y1);
14 gregl 3.1
15 schorsch 3.3
16
17     static void
18     redraw( /* mark portion of a tree for redraw */
19 greg 3.5 RTREE *tp,
20 schorsch 3.3 int x0,
21     int y0,
22     int x1,
23     int y1,
24     int l[2][2]
25     )
26 gregl 3.1 {
27     int quads = CH_ANY;
28     int mx, my;
29 greg 3.5 int i;
30 gregl 3.1 /* compute midpoint */
31     mx = (x0 + x1) >> 1;
32     my = (y0 + y1) >> 1;
33     /* see what to do */
34     if (l[0][0] > mx)
35     quads &= ~(CHF(UL)|CHF(DL));
36     else if (l[0][1] < mx)
37     quads &= ~(CHF(UR)|CHF(DR));
38     if (l[1][0] > my)
39     quads &= ~(CHF(DR)|CHF(DL));
40     else if (l[1][1] < my)
41     quads &= ~(CHF(UR)|CHF(UL));
42     tp->flgs |= quads; /* mark quadrants for update */
43     /* climb the branches */
44     for (i = 0; i < 4; i++)
45     if (tp->flgs & BRF(i) && quads & CHF(i))
46     redraw(tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
47     i&01 ? x1 : mx, i&02 ? y1 : my, l);
48     }
49
50
51 schorsch 3.3 static void
52     cpaint( /* paint a cone within a rectangle */
53 greg 3.4 uby8 rgb[3],
54 greg 3.5 float *p,
55 schorsch 3.3 int x0,
56     int y0,
57     int x1,
58     int y1
59     )
60 gregl 3.1 {
61     static FVECT ip, wp;
62     double rad;
63     /* compute base radius */
64     rad = (double)(y1 - y0 + x1 - x0)/(odev.hres + odev.vres);
65     /* approximate apex pos? */
66     if (p == NULL || y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) {
67     ip[0] = (double)(x0 + x1)/(odev.hres<<1);
68     ip[1] = (double)(y0 + y1)/(odev.vres<<1);
69     if (p != NULL) {
70     wp[0] = p[0] - odev.v.vp[0];
71     wp[1] = p[1] - odev.v.vp[1];
72     wp[2] = p[2] - odev.v.vp[2];
73     if (odev.v.type == VT_PER)
74     ip[2] = DOT(wp,odev.v.vdir);
75     else
76     ip[2] = VLEN(wp);
77     } else
78     ip[2] = FHUGE;
79     } else if (odev.v.type == VT_PER) { /* special case (faster) */
80     wp[0] = p[0] - odev.v.vp[0];
81     wp[1] = p[1] - odev.v.vp[1];
82     wp[2] = p[2] - odev.v.vp[2];
83     ip[2] = DOT(wp,odev.v.vdir);
84     ip[0] = DOT(wp,odev.v.hvec)/(ip[2]*odev.v.hn2) +
85     0.5 - odev.v.hoff;
86     ip[1] = DOT(wp,odev.v.vvec)/(ip[2]*odev.v.vn2) +
87     0.5 - odev.v.voff;
88     } else { /* general case */
89     VCOPY(wp, p);
90     viewloc(ip, &odev.v, wp);
91     }
92     dev_cone(rgb, ip, rad);
93     }
94
95
96 schorsch 3.3 static void
97     update( /* update tree display as needed */
98 greg 3.4 uby8 ca[3], /* returned average color */
99 greg 3.5 RTREE *tp,
100 schorsch 3.3 int x0,
101     int y0,
102     int x1,
103     int y1
104     )
105 gregl 3.1 {
106     int csm[3], nc;
107 greg 3.5 uby8 *cp;
108 greg 3.4 uby8 rgb[3];
109 gregl 3.1 int gaps = 0;
110     int mx, my;
111 greg 3.5 int i;
112 gregl 3.1 /* compute midpoint */
113     mx = (x0 + x1) >> 1;
114     my = (y0 + y1) >> 1;
115     /* draw leaves */
116     csm[0] = csm[1] = csm[2] = nc = 0;
117     for (i = 0; i < 4; i++) {
118     if (tp->flgs & LFF(i)) {
119     cp = qtL.rgb[tp->k[i].li];
120     csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
121     nc++;
122     if (tp->flgs & CHF(i))
123     cpaint(cp, qtL.wp[tp->k[i].li],
124     i&01 ? mx : x0, i&02 ? my : y0,
125     i&01 ? x1 : mx, i&02 ? y1 : my);
126     } else if ((tp->flgs & CHBRF(i)) == CHF(i))
127     gaps |= 1<<i; /* empty stem */
128     }
129     /* do branches */
130     for (i = 0; i < 4; i++)
131     if ((tp->flgs & CHBRF(i)) == CHBRF(i)) {
132     update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
133     i&01 ? x1 : mx, i&02 ? y1 : my);
134     csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
135     nc++;
136     }
137     if (nc > 1) {
138     ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
139     } else {
140     ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
141     }
142     /* fill in gaps with average */
143     for (i = 0; gaps && i < 4; gaps >>= 1, i++)
144     if (gaps & 01)
145     cpaint(ca, (float *)NULL,
146     i&01 ? mx : x0, i&02 ? my : y0,
147     i&01 ? x1 : mx, i&02 ? y1 : my);
148     tp->flgs &= ~CH_ANY; /* all done */
149     }
150
151
152 greg 3.5 void
153 schorsch 3.3 qtRedraw( /* redraw part or all of our screen */
154     int x0,
155     int y0,
156     int x1,
157     int y1
158     )
159 gregl 3.1 {
160     int lim[2][2];
161
162     if (is_stump(&qtrunk))
163     return;
164 schorsch 3.3 if (!(qtMapLeaves((lim[0][0]=x0) <= 0) & ((lim[1][0]=y0) <= 0) &
165     ((lim[0][1]=x1) >= odev.hres-1) & ((lim[1][1]=y1) >= odev.vres-1)))
166 gregl 3.1 return;
167     redraw(&qtrunk, 0, 0, odev.hres, odev.vres, lim);
168     }
169
170
171 greg 3.5 void
172 schorsch 3.3 qtUpdate(void) /* update our tree display */
173 gregl 3.1 {
174 greg 3.4 uby8 ca[3];
175 gregl 3.1
176     if (is_stump(&qtrunk))
177     return;
178     if (!qtMapLeaves(0))
179     return;
180     update(ca, &qtrunk, 0, 0, odev.hres, odev.vres);
181     }
