1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Quadtree display support routines for cone output. |
6 |
7 |
8 |
#include "standard.h" |
9 |
#include "rhd_qtree.h" |
10 |
11 |
12 |
static |
13 |
redraw(tp, x0, y0, x1, y1, l) /* mark portion of a tree for redraw */ |
14 |
register RTREE *tp; |
15 |
int x0, y0, x1, y1; |
16 |
int l[2][2]; |
17 |
18 |
int quads = CH_ANY; |
19 |
int mx, my; |
20 |
register int i; |
21 |
/* compute midpoint */ |
22 |
mx = (x0 + x1) >> 1; |
23 |
my = (y0 + y1) >> 1; |
24 |
/* see what to do */ |
25 |
if (l[0][0] > mx) |
26 |
quads &= ~(CHF(UL)|CHF(DL)); |
27 |
else if (l[0][1] < mx) |
28 |
quads &= ~(CHF(UR)|CHF(DR)); |
29 |
if (l[1][0] > my) |
30 |
quads &= ~(CHF(DR)|CHF(DL)); |
31 |
else if (l[1][1] < my) |
32 |
quads &= ~(CHF(UR)|CHF(UL)); |
33 |
tp->flgs |= quads; /* mark quadrants for update */ |
34 |
/* climb the branches */ |
35 |
for (i = 0; i < 4; i++) |
36 |
if (tp->flgs & BRF(i) && quads & CHF(i)) |
37 |
redraw(tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0, |
38 |
i&01 ? x1 : mx, i&02 ? y1 : my, l); |
39 |
40 |
41 |
42 |
static |
43 |
cpaint(rgb, p, x0, y0, x1, y1) /* paint a cone within a rectangle */ |
44 |
BYTE rgb[3]; |
45 |
register float *p; |
46 |
47 |
48 |
static FVECT ip, wp; |
49 |
double rad; |
50 |
/* compute base radius */ |
51 |
rad = (double)(y1 - y0 + x1 - x0)/(odev.hres + odev.vres); |
52 |
/* approximate apex pos? */ |
53 |
if (p == NULL || y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) { |
54 |
ip[0] = (double)(x0 + x1)/(odev.hres<<1); |
55 |
ip[1] = (double)(y0 + y1)/(odev.vres<<1); |
56 |
if (p != NULL) { |
57 |
wp[0] = p[0] - odev.v.vp[0]; |
58 |
wp[1] = p[1] - odev.v.vp[1]; |
59 |
wp[2] = p[2] - odev.v.vp[2]; |
60 |
if (odev.v.type == VT_PER) |
61 |
ip[2] = DOT(wp,odev.v.vdir); |
62 |
else |
63 |
ip[2] = VLEN(wp); |
64 |
} else |
65 |
ip[2] = FHUGE; |
66 |
} else if (odev.v.type == VT_PER) { /* special case (faster) */ |
67 |
68 |
69 |
70 |
71 |
ip[0] = DOT(wp,odev.v.hvec)/(ip[2]*odev.v.hn2) + |
72 |
0.5 - odev.v.hoff; |
73 |
ip[1] = DOT(wp,odev.v.vvec)/(ip[2]*odev.v.vn2) + |
74 |
0.5 - odev.v.voff; |
75 |
} else { /* general case */ |
76 |
VCOPY(wp, p); |
77 |
viewloc(ip, &odev.v, wp); |
78 |
79 |
dev_cone(rgb, ip, rad); |
80 |
81 |
82 |
83 |
static |
84 |
update(ca, tp, x0, y0, x1, y1) /* update tree display as needed */ |
85 |
BYTE ca[3]; /* returned average color */ |
86 |
87 |
88 |
89 |
int csm[3], nc; |
90 |
register BYTE *cp; |
91 |
BYTE rgb[3]; |
92 |
int gaps = 0; |
93 |
int mx, my; |
94 |
register int i; |
95 |
96 |
97 |
98 |
/* draw leaves */ |
99 |
csm[0] = csm[1] = csm[2] = nc = 0; |
100 |
for (i = 0; i < 4; i++) { |
101 |
if (tp->flgs & LFF(i)) { |
102 |
cp = qtL.rgb[tp->k[i].li]; |
103 |
csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2]; |
104 |
nc++; |
105 |
if (tp->flgs & CHF(i)) |
106 |
cpaint(cp, qtL.wp[tp->k[i].li], |
107 |
108 |
i&01 ? x1 : mx, i&02 ? y1 : my); |
109 |
} else if ((tp->flgs & CHBRF(i)) == CHF(i)) |
110 |
gaps |= 1<<i; /* empty stem */ |
111 |
112 |
/* do branches */ |
113 |
114 |
if ((tp->flgs & CHBRF(i)) == CHBRF(i)) { |
115 |
update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0, |
116 |
117 |
csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2]; |
118 |
nc++; |
119 |
120 |
if (nc > 1) { |
121 |
ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc; |
122 |
} else { |
123 |
ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2]; |
124 |
125 |
/* fill in gaps with average */ |
126 |
for (i = 0; gaps && i < 4; gaps >>= 1, i++) |
127 |
if (gaps & 01) |
128 |
cpaint(ca, (float *)NULL, |
129 |
130 |
131 |
tp->flgs &= ~CH_ANY; /* all done */ |
132 |
133 |
134 |
135 |
qtRedraw(x0, y0, x1, y1) /* redraw part or all of our screen */ |
136 |
137 |
138 |
int lim[2][2]; |
139 |
140 |
if (is_stump(&qtrunk)) |
141 |
return; |
142 |
if (!qtMapLeaves((lim[0][0]=x0) <= 0 & (lim[1][0]=y0) <= 0 & |
143 |
(lim[0][1]=x1) >= odev.hres-1 & (lim[1][1]=y1) >= odev.vres-1)) |
144 |
return; |
145 |
redraw(&qtrunk, 0, 0, odev.hres, odev.vres, lim); |
146 |
147 |
148 |
149 |
qtUpdate() /* update our tree display */ |
150 |
151 |
BYTE ca[3]; |
152 |
153 |
154 |
return; |
155 |
if (!qtMapLeaves(0)) |
156 |
return; |
157 |
update(ca, &qtrunk, 0, 0, odev.hres, odev.vres); |
158 |
