root/radiance/ray/src/hd/rhd_qtree2c.c
Revision: 3.2
Committed: Sat Feb 22 02:07:24 2003 UTC (21 years, 4 months ago) by greg
Changes since 3.1: +1 -4 lines
5 * Quadtree display support routines for cone output.
6 */
7
8 #include "standard.h"
9 #include "rhd_qtree.h"
10
11
12 static
13 redraw(tp, x0, y0, x1, y1, l) /* mark portion of a tree for redraw */
14 register RTREE *tp;
15 int x0, y0, x1, y1;
16 int l[2][2];
17 {
18 int quads = CH_ANY;
19 int mx, my;
20 register int i;
21 /* compute midpoint */
22 mx = (x0 + x1) >> 1;
23 my = (y0 + y1) >> 1;
24 /* see what to do */
25 if (l[0][0] > mx)
26 quads &= ~(CHF(UL)|CHF(DL));
27 else if (l[0][1] < mx)
28 quads &= ~(CHF(UR)|CHF(DR));
29 if (l[1][0] > my)
30 quads &= ~(CHF(DR)|CHF(DL));
31 else if (l[1][1] < my)
32 quads &= ~(CHF(UR)|CHF(UL));
33 tp->flgs |= quads; /* mark quadrants for update */
34 /* climb the branches */
35 for (i = 0; i < 4; i++)
36 if (tp->flgs & BRF(i) && quads & CHF(i))
37 redraw(tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
38 i&01 ? x1 : mx, i&02 ? y1 : my, l);
39 }
40
41
42 static
43 cpaint(rgb, p, x0, y0, x1, y1) /* paint a cone within a rectangle */
44 BYTE rgb[3];
45 register float *p;
46 int x0, y0, x1, y1;
47 {
48 static FVECT ip, wp;
49 double rad;
50 /* compute base radius */
51 rad = (double)(y1 - y0 + x1 - x0)/(odev.hres + odev.vres);
52 /* approximate apex pos? */
53 if (p == NULL || y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) {
54 ip[0] = (double)(x0 + x1)/(odev.hres<<1);
55 ip[1] = (double)(y0 + y1)/(odev.vres<<1);
56 if (p != NULL) {
57 wp[0] = p[0] - odev.v.vp[0];
58 wp[1] = p[1] - odev.v.vp[1];
59 wp[2] = p[2] - odev.v.vp[2];
60 if (odev.v.type == VT_PER)
61 ip[2] = DOT(wp,odev.v.vdir);
62 else
63 ip[2] = VLEN(wp);
64 } else
65 ip[2] = FHUGE;
66 } else if (odev.v.type == VT_PER) { /* special case (faster) */
67 wp[0] = p[0] - odev.v.vp[0];
68 wp[1] = p[1] - odev.v.vp[1];
69 wp[2] = p[2] - odev.v.vp[2];
70 ip[2] = DOT(wp,odev.v.vdir);
71 ip[0] = DOT(wp,odev.v.hvec)/(ip[2]*odev.v.hn2) +
72 0.5 - odev.v.hoff;
73 ip[1] = DOT(wp,odev.v.vvec)/(ip[2]*odev.v.vn2) +
74 0.5 - odev.v.voff;
75 } else { /* general case */
76 VCOPY(wp, p);
77 viewloc(ip, &odev.v, wp);
78 }
79 dev_cone(rgb, ip, rad);
80 }
81
82
83 static
84 update(ca, tp, x0, y0, x1, y1) /* update tree display as needed */
85 BYTE ca[3]; /* returned average color */
86 register RTREE *tp;
87 int x0, y0, x1, y1;
88 {
89 int csm[3], nc;
90 register BYTE *cp;
91 BYTE rgb[3];
92 int gaps = 0;
93 int mx, my;
94 register int i;
95 /* compute midpoint */
96 mx = (x0 + x1) >> 1;
97 my = (y0 + y1) >> 1;
98 /* draw leaves */
99 csm[0] = csm[1] = csm[2] = nc = 0;
100 for (i = 0; i < 4; i++) {
101 if (tp->flgs & LFF(i)) {
102 cp = qtL.rgb[tp->k[i].li];
103 csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
104 nc++;
105 if (tp->flgs & CHF(i))
106 cpaint(cp, qtL.wp[tp->k[i].li],
107 i&01 ? mx : x0, i&02 ? my : y0,
108 i&01 ? x1 : mx, i&02 ? y1 : my);
109 } else if ((tp->flgs & CHBRF(i)) == CHF(i))
110 gaps |= 1<<i; /* empty stem */
111 }
112 /* do branches */
113 for (i = 0; i < 4; i++)
114 if ((tp->flgs & CHBRF(i)) == CHBRF(i)) {
115 update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
116 i&01 ? x1 : mx, i&02 ? y1 : my);
117 csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
118 nc++;
119 }
120 if (nc > 1) {
121 ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
122 } else {
123 ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
124 }
125 /* fill in gaps with average */
126 for (i = 0; gaps && i < 4; gaps >>= 1, i++)
127 if (gaps & 01)
128 cpaint(ca, (float *)NULL,
129 i&01 ? mx : x0, i&02 ? my : y0,
130 i&01 ? x1 : mx, i&02 ? y1 : my);
131 tp->flgs &= ~CH_ANY; /* all done */
132 }
133
134
135 qtRedraw(x0, y0, x1, y1) /* redraw part or all of our screen */
136 int x0, y0, x1, y1;
137 {
138 int lim[2][2];
139
140 if (is_stump(&qtrunk))
141 return;
142 if (!qtMapLeaves((lim[0][0]=x0) <= 0 & (lim[1][0]=y0) <= 0 &
143 (lim[0][1]=x1) >= odev.hres-1 & (lim[1][1]=y1) >= odev.vres-1))
144 return;
145 redraw(&qtrunk, 0, 0, odev.hres, odev.vres, lim);
146 }
147
148
149 qtUpdate() /* update our tree display */
150 {
151 BYTE ca[3];
152
153 if (is_stump(&qtrunk))
154 return;
155 if (!qtMapLeaves(0))
156 return;
157 update(ca, &qtrunk, 0, 0, odev.hres, odev.vres);
158 }
