root/radiance/ray/src/hd/rhd_qtree2c.c
Revision: 3.5
Committed: Fri Oct 5 19:19:16 2018 UTC (6 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Changes since 3.4: +9 -9 lines
2 static const char RCSid[] = "$Id: rhd_qtree2c.c,v 3.4 2011/05/20 02:06:39 greg Exp $";
5 * Quadtree display support routines for cone output.
6 */
7
8 #include "standard.h"
9 #include "rhd_qtree.h"
10
11 static void redraw(RTREE *tp, int x0, int y0, int x1, int y1, int l[2][2]);
12 static void cpaint(uby8 rgb[3], float *p, int x0, int y0, int x1, int y1);
13 static void update(uby8 ca[3], RTREE *tp, int x0, int y0, int x1, int y1);
14
15
16
17 static void
18 redraw( /* mark portion of a tree for redraw */
19 RTREE *tp,
20 int x0,
21 int y0,
22 int x1,
23 int y1,
24 int l[2][2]
25 )
26 {
27 int quads = CH_ANY;
28 int mx, my;
29 int i;
30 /* compute midpoint */
31 mx = (x0 + x1) >> 1;
32 my = (y0 + y1) >> 1;
33 /* see what to do */
34 if (l[0][0] > mx)
35 quads &= ~(CHF(UL)|CHF(DL));
36 else if (l[0][1] < mx)
37 quads &= ~(CHF(UR)|CHF(DR));
38 if (l[1][0] > my)
39 quads &= ~(CHF(DR)|CHF(DL));
40 else if (l[1][1] < my)
41 quads &= ~(CHF(UR)|CHF(UL));
42 tp->flgs |= quads; /* mark quadrants for update */
43 /* climb the branches */
44 for (i = 0; i < 4; i++)
45 if (tp->flgs & BRF(i) && quads & CHF(i))
46 redraw(tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
47 i&01 ? x1 : mx, i&02 ? y1 : my, l);
48 }
49
50
51 static void
52 cpaint( /* paint a cone within a rectangle */
53 uby8 rgb[3],
54 float *p,
55 int x0,
56 int y0,
57 int x1,
58 int y1
59 )
60 {
61 static FVECT ip, wp;
62 double rad;
63 /* compute base radius */
64 rad = (double)(y1 - y0 + x1 - x0)/(odev.hres + odev.vres);
65 /* approximate apex pos? */
66 if (p == NULL || y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) {
67 ip[0] = (double)(x0 + x1)/(odev.hres<<1);
68 ip[1] = (double)(y0 + y1)/(odev.vres<<1);
69 if (p != NULL) {
70 wp[0] = p[0] - odev.v.vp[0];
71 wp[1] = p[1] - odev.v.vp[1];
72 wp[2] = p[2] - odev.v.vp[2];
73 if (odev.v.type == VT_PER)
74 ip[2] = DOT(wp,odev.v.vdir);
75 else
76 ip[2] = VLEN(wp);
77 } else
78 ip[2] = FHUGE;
79 } else if (odev.v.type == VT_PER) { /* special case (faster) */
80 wp[0] = p[0] - odev.v.vp[0];
81 wp[1] = p[1] - odev.v.vp[1];
82 wp[2] = p[2] - odev.v.vp[2];
83 ip[2] = DOT(wp,odev.v.vdir);
84 ip[0] = DOT(wp,odev.v.hvec)/(ip[2]*odev.v.hn2) +
85 0.5 - odev.v.hoff;
86 ip[1] = DOT(wp,odev.v.vvec)/(ip[2]*odev.v.vn2) +
87 0.5 - odev.v.voff;
88 } else { /* general case */
89 VCOPY(wp, p);
90 viewloc(ip, &odev.v, wp);
91 }
92 dev_cone(rgb, ip, rad);
93 }
94
95
96 static void
97 update( /* update tree display as needed */
98 uby8 ca[3], /* returned average color */
99 RTREE *tp,
100 int x0,
101 int y0,
102 int x1,
103 int y1
104 )
105 {
106 int csm[3], nc;
107 uby8 *cp;
108 uby8 rgb[3];
109 int gaps = 0;
110 int mx, my;
111 int i;
112 /* compute midpoint */
113 mx = (x0 + x1) >> 1;
114 my = (y0 + y1) >> 1;
115 /* draw leaves */
116 csm[0] = csm[1] = csm[2] = nc = 0;
117 for (i = 0; i < 4; i++) {
118 if (tp->flgs & LFF(i)) {
119 cp = qtL.rgb[tp->k[i].li];
120 csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
121 nc++;
122 if (tp->flgs & CHF(i))
123 cpaint(cp, qtL.wp[tp->k[i].li],
124 i&01 ? mx : x0, i&02 ? my : y0,
125 i&01 ? x1 : mx, i&02 ? y1 : my);
126 } else if ((tp->flgs & CHBRF(i)) == CHF(i))
127 gaps |= 1<<i; /* empty stem */
128 }
129 /* do branches */
130 for (i = 0; i < 4; i++)
131 if ((tp->flgs & CHBRF(i)) == CHBRF(i)) {
132 update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
133 i&01 ? x1 : mx, i&02 ? y1 : my);
134 csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
135 nc++;
136 }
137 if (nc > 1) {
138 ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
139 } else {
140 ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
141 }
142 /* fill in gaps with average */
143 for (i = 0; gaps && i < 4; gaps >>= 1, i++)
144 if (gaps & 01)
145 cpaint(ca, (float *)NULL,
146 i&01 ? mx : x0, i&02 ? my : y0,
147 i&01 ? x1 : mx, i&02 ? y1 : my);
148 tp->flgs &= ~CH_ANY; /* all done */
149 }
150
151
152 void
153 qtRedraw( /* redraw part or all of our screen */
154 int x0,
155 int y0,
156 int x1,
157 int y1
158 )
159 {
160 int lim[2][2];
161
162 if (is_stump(&qtrunk))
163 return;
164 if (!(qtMapLeaves((lim[0][0]=x0) <= 0) & ((lim[1][0]=y0) <= 0) &
165 ((lim[0][1]=x1) >= odev.hres-1) & ((lim[1][1]=y1) >= odev.vres-1)))
166 return;
167 redraw(&qtrunk, 0, 0, odev.hres, odev.vres, lim);
168 }
169
170
171 void
172 qtUpdate(void) /* update our tree display */
173 {
174 uby8 ca[3];
175
176 if (is_stump(&qtrunk))
177 return;
178 if (!qtMapLeaves(0))
179 return;
180 update(ca, &qtrunk, 0, 0, odev.hres, odev.vres);
181 }
