| 1 |
/* RCSid $Id: rhd_qtree.h,v 3.19 2011/05/20 02:06:39 greg Exp $ */
| 2 |
| 3 |
* Quadtree data structures for holodeck display drivers.
| 4 |
| 5 |
#ifndef _RAD_RHD_QTREE_H_
| 6 |
#define _RAD_RHD_QTREE_H_
| 7 |
| 8 |
#include "color.h"
| 9 |
#include "tonemap.h"
| 10 |
#include "rhdriver.h"
| 11 |
| 12 |
#ifdef __cplusplus
| 13 |
extern "C" {
| 14 |
#endif
| 15 |
| 16 |
#define DL 0 /* down left */
| 17 |
#define DR 1 /* down right */
| 18 |
#define UL 2 /* up left */
| 19 |
#define UR 3 /* up right */
| 20 |
| 21 |
#define BRF(i) (0x1<<(i)) /* branch flag bit */
| 22 |
#define LFF(i) (0x10<<(i)) /* leaf flag bit */
| 23 |
#define CHF(i) (0x100<<(i)) /* change flag bit */
| 24 |
#define CHBRF(i) (0x101<<(i)) /* changed branch bit */
| 25 |
#define CHLFF(i) (0x110<<(i)) /* changed leaf bit */
| 26 |
#define BR_ANY 0xf /* flags for any branches */
| 27 |
#define LF_ANY 0xf0 /* flags for any leaves */
| 28 |
#define CH_ANY 0xf00 /* flags for any change */
| 29 |
| 30 |
typedef struct rtree {
| 31 |
short flgs; /* content flags (defined above) */
| 32 |
union {
| 33 |
struct rtree *b; /* if branch */
| 34 |
int li; /* if leaf */
| 35 |
} k[4]; /* children */
| 36 |
} RTREE;
| 37 |
| 38 |
extern struct rleaves {
| 39 |
float (*wp)[3]; /* world intersection point array */
| 40 |
int32 *wd; /* world direction array */
| 41 |
TMbright *brt; /* encoded brightness array */
| 42 |
uby8 (*chr)[3]; /* encoded chrominance array */
| 43 |
uby8 (*rgb)[3]; /* tone-mapped color array */
| 44 |
int nl; /* count of leaves in our pile */
| 45 |
int bl, tl; /* bottom and top (next) leaf index */
| 46 |
int tml; /* next leaf needing tone-mapping */
| 47 |
char *base; /* base of allocated memory */
| 48 |
} qtL; /* our pile of leaves */
| 49 |
| 50 |
#define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY)))
| 51 |
| 52 |
extern RTREE qtrunk; /* trunk of quadtree */
| 53 |
extern double qtDepthEps; /* epsilon to compare depths (z fraction) */
| 54 |
extern int qtMinNodesiz; /* minimum node dimension (pixels) */
| 55 |
| 56 |
extern int rayqleft; /* number of rays to queue before flush */
| 57 |
| 58 |
extern TMstruct *tmGlobal; /* global tone-mapping structure */
| 59 |
| 60 |
/* rhd_qtree.c */
| 61 |
extern int qtAllocLeaves(register int n);
| 62 |
extern void qtFreeLeaves(void);
| 63 |
extern int qtCompost(int pct);
| 64 |
extern void qtReplant(void);
| 65 |
extern int qtFindLeaf(int x, int y);
| 66 |
extern int qtMapLeaves(int redo);
| 67 |
/* rhd_qtree2c.c rhd_qtree2r.c */
| 68 |
extern void qtRedraw(int x0, int y0, int x1, int y1);
| 69 |
extern void qtUpdate(void);
| 70 |
| 71 |
#ifdef __cplusplus
| 72 |
| 73 |
#endif
| 74 |
#endif /* _RAD_RHD_QTREE_H_ */
| 75 |
