root/radiance/ray/src/hd/rhd_qtree.h
Revision: 3.3
Committed: Fri Nov 21 13:35:58 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.2: +21 -14 lines
changed definition of global leaf pile to make tone mapping work better
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Quadtree data structures for holodeck display drivers.
7 */
8
9 #include "tonemap.h"
10 #include "rhdriver.h"
11 /* quantity of leaves to free at a time */
12 #ifndef LFREEPCT
13 #define LFREEPCT 15
14 #endif
15 /* child ordering */
16 #define DL 0 /* down left */
17 #define DR 1 /* down right */
18 #define UL 2 /* up left */
19 #define UR 3 /* up right */
20
21 #define BRF(i) (0x1<<(i)) /* branch flag bit */
22 #define LFF(i) (0x10<<(i)) /* leaf flag bit */
23 #define CHF(i) (0x100<<(i)) /* change flag bit */
24 #define CHBRF(i) (0x101<<(i)) /* changed branch bit */
25 #define CHLFF(i) (0x110<<(i)) /* changed leaf bit */
26 #define BR_ANY 0xf /* flags for any branches */
27 #define LF_ANY 0xf0 /* flags for any leaves */
28 #define CH_ANY 0xf00 /* flags for any change */
29
30 typedef struct rtree {
31 short flgs; /* content flags (defined above) */
32 union {
33 struct rtree *b; /* if branch */
34 int li; /* if leaf */
35 } k[4]; /* children */
36 } RTREE;
37
38 extern struct rleaves {
39 float (*wp)[3]; /* world intersection point array */
40 TMbright *brt; /* encoded brightness array */
41 BYTE (*chr)[3]; /* encoded chrominance array */
42 BYTE (*rgb)[3]; /* tone-mapped color array */
43 int nl; /* count of leaves in our pile */
44 int bl, tl; /* bottom and top (next) leaf index */
45 int tml; /* next leaf needing tone-mapping */
46 char *base; /* base of allocated memory */
47 } qtL; /* our pile of leaves */
48
49 extern RTREE qtrunk; /* trunk of quadtree */
50 extern double qtDepthEps; /* epsilon to compare depths (z fraction) */
51 extern int qtMinNodesiz; /* minimum node dimension (pixels) */
52
53
54 /************************************************************************
55 * These driver support routines implement the dev_value() call, but
56 * require the following callbacks:
57
58 dev_paintr(rgb, x0, y0, x1, y1) : paint a rectangle
59 BYTE rgb[3]; : rectangle color
60 int x0, y0, x1, y1; : rectangle boundaries
61
62 Draws an open rectangle between [x0,x1) and [y0,y1) with the color rgb.
63 This function is called many times by qtUpdate(), qtRedraw() and qtReplant().
64
65 ************************************************************************/
